20ft Discreet USB Extension Cable for Wyze Cam – Reduce Clutter
Discreet Long USB Cable for Wyze Cam: Reduce Cord Clutter with a 20ft Extension
If you're looking to extend the reach of your Wyze Cam while keeping your space tidy and free from messy cords, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. Designed specifically for Wyze cameras, this long USB cable allows you to position your camera exactly where you need it without compromising on aesthetics or functionality.
Wyze Cam USB Extension Cable - 20ft: Freedom to Place Your Camera Anywhere
Key Features
  • Length: 20 feet of durable USB cable to extend your camera’s reach.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Ease of Use: Simply plug in to extend your existing USB cable without any complicated setup.
  • Clutter Reduction: Enables discreet cable routing to reduce visible cord clutter around your home or office.
This extension cable is ideal for users who want to mount their Wyze Cam in hard-to-reach or aesthetically sensitive areas, such as high corners, behind furniture, or outdoors with proper weatherproofing.
Wyze Cam OG: The Perfect Camera to Pair with Your Extension Cable
Why Choose Wyze Cam OG?
  • 120° Wide Field of View: Capture more of your space with a broad viewing angle.
  • Built-in Spotlight & Mini-Siren: Deter intruders with a 40-lumen spotlight and a 90-decibel siren.
  • Indoor/Outdoor Use: IP65 weather resistance means it can withstand rain and harsh weather.
  • 3X Faster Notifications: Stay informed instantly with rapid motion alerts.
  • Upgraded Two-Way Audio: Clear communication with enhanced microphone and speaker.
  • Quick Live HD Streaming: Connect and view live video 50% faster than previous models.
  • Custom Detection Zones: Focus on specific areas to reduce false alerts.
  • Supports MicroSD Cards: Local storage up to 256GB for continuous recording.
Pairing the Wyze Cam OG with the 20ft USB extension cable gives you the flexibility to install your camera exactly where you want it, without worrying about power outlet proximity or unsightly cables.
“Protect every space, inside and outside, with a camera that’s as versatile as your needs.”
Wyze Cam in Home Setting Alt text: Wyze Cam OG discreetly mounted in a modern living room
Benefits of Using a Long USB Extension Cable with Wyze Cam
Enhanced Placement Options
The 20ft USB extension cable allows you to place your Wyze Cam in optimal locations for better coverage and security, such as:
  • High ceilings or corners
  • Behind plants or décor for discreet monitoring
  • Outdoor areas with weatherproof cameras
Reduced Cord Clutter
Long cables can often create a tangled mess, but with careful routing and the right length, you can keep your space neat and organized. The Wyze USB extension cable’s length is perfect for hiding cables along walls, baseboards, or through cable channels.
Compatibility and Convenience
This cable is designed specifically for Wyze cameras, ensuring reliable power delivery and data transmission without signal loss or interference.
Summary
For anyone seeking a discreet, long USB cable solution for Wyze Cam, the Wyze Cam USB Extension Cable - 20ft is an affordable, reliable, and easy-to-use accessory. When combined with the Wyze Cam OG, it offers a powerful, flexible home security setup that minimizes cord clutter and maximizes camera placement options.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam OG
TypeAccessoryCamera
Price$7.99$29.98 (1 Pack)
CompatibilityWyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, Wyze Cam OG TelephotoStandalone camera
Cable Length20 ft USB extension cable6 ft power cable included
FunctionExtends USB cable length for Wyze camerasSecurity camera with built-in spotlight and 2-way audio
Field of ViewN/A120° field of view
SpotlightN/ABuilt-in 40-lumen spotlight
AudioN/AImproved 2-way audio
Weather ResistanceN/AIP65 (Indoor/Outdoor)
Video ResolutionN/A1920 x 1080 (1080p)
NotificationsN/A3X faster motion notifications
Local Storage SupportN/ASupports up to 256GB microSD
WarrantyNot specified1-Year
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to position your camera in optimal locations while reducing visible cord clutter. It is ideal for mounting cameras in hard-to-reach or discreet areas without compromising on aesthetics or functionality.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
How does the Wyze Cam USB Extension Cable help reduce cord clutter?The 20ft length of the Wyze Cam USB Extension Cable allows you to route the cable discreetly along walls, baseboards, or through cable channels, keeping your space neat and organized by minimizing visible cords.
Is the Wyze Cam USB Extension Cable easy to install?Yes, the Wyze Cam USB Extension Cable is very easy to use. Simply plug it into your existing USB cable to extend the reach—no complicated setup is required.
Can I use the Wyze Cam USB Extension Cable outdoors?Yes, you can use the Wyze Cam USB Extension Cable outdoors when paired with weather-resistant Wyze cameras like the Wyze Cam OG, which has an IP65 weather resistance rating. Ensure proper weatherproofing for the cable connections.
What are the benefits of pairing the Wyze Cam OG with the 20ft USB extension cable?Pairing the Wyze Cam OG with the 20ft USB extension cable gives you the flexibility to install your camera exactly where you want it, regardless of power outlet proximity. This setup maximizes coverage, reduces cord clutter, and takes advantage of the Wyze Cam OG’s advanced features like a wide field of view, built-in spotlight, mini-siren, and rapid notifications.
Does the Wyze Cam USB Extension Cable affect power delivery or video quality?No, the Wyze Cam USB Extension Cable is designed specifically for Wyze cameras to ensure reliable power delivery and data transmission without signal loss or interference.
What are the key features of the Wyze Cam OG?The Wyze Cam OG features a 120° wide field of view, built-in 40-lumen spotlight, 90-decibel mini-siren, IP65 weather resistance for indoor/outdoor use, 3X faster notifications, upgraded two-way audio, quick live HD streaming, custom detection zones, and support for microSD cards up to 256GB for continuous recording.
Where are the best places to install a Wyze Cam using the 20ft USB extension cable?The 20ft USB extension cable allows you to install your Wyze Cam in high ceilings or corners, behind plants or décor for discreet monitoring, and in outdoor areas when using weatherproof cameras.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?What are the benefits of using the Wyze Cam OG with the USB extension cable?Do you have any ongoing sales or promotions for the Wyze Cam or accessories?
