Deter Trespassers: Wyze Cam with 20ft USB Extension Cable
Deterring Trespassers with a Well-Placed Wyze Cam Using a 20ft USB Extension Cable
When it comes to home security, positioning your Wyze Cam exactly where it can capture the best view is crucial. However, limited cable length can restrict your camera placement, reducing its effectiveness in deterring trespassers. The Wyze Cam USB Extension Cable - 20ft offers a simple and affordable solution to extend your camera’s reach, allowing you to place your Wyze Cam in the optimal spot for maximum coverage and security.
Wyze Cam USB Extension Cable - 20ft: Extend Your Security Reach
Freedom to Place Your Camera Anywhere
Say goodbye to the frustration of short cables limiting your Wyze Cam placement. The Wyze Cam USB Extension Cable extends your camera’s reach by 20 feet, giving you the flexibility to install your camera in hard-to-reach or strategic locations such as high corners, eaves, or farther from power outlets.
  • Compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Durable USB extension cable designed specifically for Wyze Cam power needs.
  • Easy plug-and-play setup with no additional tools required.
With this extension cable, you can position your Wyze Cam exactly where it’s needed to monitor entry points, driveways, or backyard perimeters, enhancing your home’s security footprint.
Wyze Cam v4: Advanced Security Camera for Outdoor Use
Powerful Features for Effective Trespasser Deterrence
The Wyze Cam v4 is a top-tier security camera designed to provide crystal-clear video and smart features that help you keep an eye on your property day and night.
  • 2.5K QHD video resolution for sharp, detailed footage.
  • Color night vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) to illuminate dark areas.
  • Built-in 99dB siren and two-way audio for real-time deterrence and communication.
  • Weather-resistant IP65 rating, perfect for outdoor installations.
  • Multiple mounting options including wall, ceiling, and magnetic mounts.
  • Supports local microSD storage up to 512GB and cloud storage options.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
Perfect Pairing with the 20ft USB Extension Cable
The Wyze Cam v4 comes with a 6-foot USB cable, but when combined with the 20ft USB extension cable, you gain the freedom to install the camera far from power outlets, such as on a distant porch or garage exterior, maximizing your coverage area. Wyze Cam v4 installed outdoors illuminating a porch at night Alt text: Wyze Cam v4 mounted on porch illuminating outdoor area at night
Cam v4 + Lamp Socket v2 Bundle: Smart Lighting Meets Security
Power Your Wyze Cam v4 Without an Outlet
For locations where power outlets are scarce or inconvenient, the Cam v4 + Lamp Socket v2 Bundle offers an innovative solution. This bundle allows you to power your Wyze Cam v4 directly from an existing outdoor light fixture, eliminating the need for extension cords or additional wiring.
  • The Lamp Socket v2 screws into your outdoor light fixture (E26 socket) and powers the Wyze Cam v4.
  • Compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.
  • Enables motion-activated lighting that works in tandem with your camera’s motion detection.
  • Control your outdoor lights remotely via the Wyze app.
  • Easy installation—just screw in the socket like a lightbulb.
  • Supports LED or CFL bulbs under 20W (incandescent bulbs not recommended).
This bundle not only powers your camera but also upgrades your outdoor lighting to smart, motion-activated illumination, enhancing security by startling potential trespassers with sudden light.
Why Use a Long USB Extension Cable with Wyze Cam?
Maximize Camera Placement Flexibility
  • Extend your camera’s power source up to 20 feet away.
  • Avoid unsightly or unsafe wiring runs.
  • Position cameras in optimal locations for better field of view and coverage.
  • Combine with smart power solutions like the Lamp Socket v2 for even more flexible installations.
Enhance Your Home Security Setup
By combining the Wyze Cam v4 with the 20ft USB extension cable and optionally the Lamp Socket v2, you create a versatile, powerful security system that can be tailored to your home’s unique layout and lighting conditions. This setup ensures your cameras are always powered and positioned to deter trespassers effectively.
“A well-placed Wyze Cam powered by a long USB extension cable is a game-changer for home security, allowing you to monitor and protect your property without compromise.”
Summary
  • Wyze Cam USB Extension Cable - 20ft: Extend your camera’s reach for flexible placement.
  • Wyze Cam v4: High-resolution, weatherproof camera with night vision and siren.
  • Cam v4 + Lamp Socket v2 Bundle: Power your camera from outdoor light fixtures and add smart lighting.
Together, these products provide a comprehensive solution to deter trespassers by enabling strategic camera placement and smart lighting control. Outdoor porch light with Wyze Cam and smart lamp socket installed Alt text: Outdoor porch light with Wyze Cam and smart lamp socket installed
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Cam v4 + Lamp Socket v2 Bundle
Product TypeAccessory (USB Extension Cable)CameraBundle (Camera + Lamp Socket)
Price$7.99$100.00 (regular), $35.98 (some bundles)$49.96
Cable Length20 ft USB extension6-Foot Flat micro USB to USB-AIncludes 20ft extension cable (implied) + lamp socket
Compatible DevicesWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Camera ResolutionN/A2.5K QHD (2560x1440)Includes Wyze Cam v4 (2.5K QHD)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Weather ResistanceN/AIP65Lamp Socket: Not weatherproof, suitable for damp locations
Power SourceUSBWired (5V/1A adapter)Lamp Socket powers camera without outlet
FeaturesExtends USB cable lengthColor Night Vision, Motion-Activated Spotlight, Wi-Fi 6, Two-Way Talk, Siren, Local Storage up to 512GBPowers Wyze Cam v4, Motion-Activated Lights, Dusk to Dawn Scheduling
DimensionsN/A2in x 2in x 2 3/8inLamp Socket: 56.5mm x 56.5mm x 65mm
WeightN/A0.49 lb (222 g)Lamp Socket: 80 g
ConnectivityUSBWi-Fi 6, Bluetooth 5.2Wi-Fi 2.4GHz, Bluetooth
Warranty30-day hassle-free returns1 Year1 Year
Additional NotesCompatible with multiple Wyze Cam modelsSupports Alexa, Google Assistant, IFTTTIncandescent bulbs not supported; use CFL or LED under 20W
What is the Wyze Cam USB Extension Cable - 20ft and how does it improve home security?The Wyze Cam USB Extension Cable - 20ft is a durable cable designed to extend the reach of your Wyze Cam by 20 feet. This allows you to place your camera in optimal locations, such as high corners or far from power outlets, ensuring better coverage and improved ability to deter trespassers.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
How do I install the Wyze Cam USB Extension Cable?Installation is simple and requires no additional tools. Just plug the extension cable into your Wyze Cam’s USB power cable and connect the other end to your power source. This plug-and-play setup makes it easy to extend your camera’s reach.
What are the key features of the Wyze Cam v4 for outdoor security?The Wyze Cam v4 offers 2.5K QHD video resolution, color night vision with 4 IR LEDs and 2 white spotlight LEDs, a built-in 99dB siren, two-way audio, weather-resistant IP65 rating, multiple mounting options, support for local microSD storage up to 512GB, and compatibility with Alexa, Google Assistant, and IFTTT.
How does the 20ft USB extension cable enhance the Wyze Cam v4’s installation options?The 20ft USB extension cable allows you to install the Wyze Cam v4 far from power outlets, such as on a distant porch or garage exterior, maximizing your camera’s coverage area and improving your home’s security.
What is the Cam v4 + Lamp Socket v2 Bundle and how does it work?The Cam v4 + Lamp Socket v2 Bundle lets you power your Wyze Cam v4 directly from an existing outdoor light fixture (E26 socket), eliminating the need for extension cords. The Lamp Socket v2 also enables motion-activated lighting and remote control of your outdoor lights via the Wyze app.
Can the Lamp Socket v2 be used with other Wyze Cam models?Yes, the Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.
What types of bulbs are supported by the Lamp Socket v2?The Lamp Socket v2 supports LED or CFL bulbs under 20W. Incandescent bulbs are not recommended.
Why should I use a long USB extension cable with my Wyze Cam?A long USB extension cable allows you to position your Wyze Cam in the most effective locations for monitoring entry points, driveways, or backyard perimeters. It helps avoid unsightly or unsafe wiring runs and maximizes your camera’s field of view and coverage.
How can I maximize my home security setup with Wyze products?Combine the Wyze Cam v4 with the 20ft USB extension cable and, if needed, the Lamp Socket v2. This setup provides flexible camera placement, reliable power, and smart lighting control, creating a comprehensive security system to deter trespassers.
How does the Wyze Cam USB Extension Cable improve camera placement?What are the benefits of using the Wyze Cam v4 for outdoor security?Do you have any deals, ongoing sales, discounts, or promotions?
