20ft Wyze Cam USB Extension Cable for Garden Trellis Setup
Prolonged Reach for Wyze Cam Setup on a Garden Trellis
Setting up your Wyze Cam on a garden trellis can be a fantastic way to monitor your outdoor space, but often the challenge lies in the limited cable length. To overcome this, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s reach without compromising power or connectivity.
Wyze Cam USB Extension Cable - 20ft: Extend Your Camera’s Reach Effortlessly
Key Features
  • Length: 20 feet of USB extension cable, providing ample length to position your Wyze Cam exactly where you need it.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Ease of Use: Simply plug the extension cable between your camera and power source to gain extra length without any complicated setup.
  • Durability: Designed to maintain stable power and data transmission over the extended length.
Why Choose the 20ft Extension Cable for Garden Trellis Setup?
Garden trellises often require cameras to be placed at a distance from power outlets. This cable allows you to mount your Wyze Cam high on the trellis or in a hard-to-reach spot while still ensuring continuous power supply. It’s an affordable and practical solution to enhance your outdoor security coverage.
Say goodbye to short cables and enjoy the freedom of flexible camera placement with this 20ft USB extension cable.
Enhance Outdoor Monitoring with Wyze Cam + Lamp Socket Bundles
If you want to power your Wyze Cam without relying on nearby outlets, consider the Cam v4 + Lamp Socket v2 Bundle or the Pan v3 + Lamp Socket v2 Bundle. These bundles allow you to use existing outdoor light fixtures to power your cameras, eliminating the need for extra wiring.
  • Smart Power Solution: Powers Wyze Cam v4 using your outdoor lamp socket.
  • Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Smart Lighting: Control your outdoor lights via the Wyze app, enabling motion-activated illumination.
  • Easy Installation: Screw in the lamp socket like a lightbulb—no electrician needed.
  • Energy Efficient: Use with CFL or LED bulbs under 20W for safe operation.
  • Flexible Power: Powers Wyze Cam Pan v3 without an outlet.
  • Device Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for seamless integration.
  • Weather-Ready: Suitable for damp locations, perfect for outdoor use.
  • Compact Design: Lightweight and easy to install with standard E26 lamp sockets.
These bundles transform your outdoor lighting into smart, motion-activated security hubs, perfect for garden trellis setups where power outlets are scarce.
Why Use Wyze Cam with Prolonged Reach Accessories on a Garden Trellis?
  • Optimal Coverage: Position your camera at the ideal height and angle on your trellis to monitor your garden or yard effectively.
  • Continuous Power: Avoid interruptions by using the 20ft USB extension cable or lamp socket bundles to maintain a steady power supply.
  • Smart Automation: Combine with Wyze app features like motion detection and light control to enhance security and convenience.
  • Weather Resistance: Many Wyze Cam models and accessories are designed to withstand outdoor conditions, ensuring reliable performance.
Summary
For anyone looking to set up a Wyze Cam on a garden trellis with extended reach, the Wyze Cam USB Extension Cable - 20ft is an essential accessory. It provides the freedom to place your camera exactly where you need it without worrying about power limitations. For even smarter outdoor setups, the Cam v4 + Lamp Socket v2 Bundle and Pan v3 + Lamp Socket v2 Bundle offer innovative solutions to power your cameras through existing light fixtures, adding convenience and smart lighting control.
Outdoor Wyze Cam Setup on Garden Trellis Alt text: Wyze Cam mounted on a garden trellis monitoring a backyard
FeatureWyze Cam USB Extension Cable - 20ftCam v4 + Lamp Socket v2 BundlePan v3 + Lamp Socket v2 Bundle
Product TypeUSB Extension CableBundle (Wyze Cam v4 + Lamp Socket v2)Bundle (Wyze Cam Pan v3 + Lamp Socket v2)
Price$7.99$49.96$53.96
Cable Length20 ftN/AN/A
Compatible CamerasWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4, Lamp Socket v2 compatible with Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Pan v3Wyze Cam Pan v3, Lamp Socket v2 compatible with Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Pan v3
Lamp Socket IncludedNoYesYes
Lamp Socket ColorN/AWhiteWhite
Lamp Socket DimensionsN/A56.5mm x 56.5mm x 65mm56.5mm x 56.5mm x 65mm
Lamp Socket WeightN/A80 g80 g
Lamp Socket Socket TypeN/AE26E26
Lamp Socket Power InputN/A120V~, 60Hz120V~, 60Hz
Max Lamp PowerN/A20W20W
Lamp Socket ConnectivityN/A802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth
Lamp Socket Weather ResistanceN/ANot weatherproof, suitable for damp locationsNot weatherproof, suitable for damp locations
Lamp Socket Phone CompatibilityN/AAndroid 7.0+, iOS 12.0+Android 7.0+, iOS 12.0+
InstallationN/AScrew-in lamp socketScrew-in lamp socket
NotesExtends USB cable length for Wyze CamsPowers Cam v4 without outlet, smart lighting featuresPowers Pan v3 without outlet, smart lighting features
What is the Wyze Cam USB Extension Cable - 20ft and how does it help with garden trellis setups?The Wyze Cam USB Extension Cable - 20ft is a long USB cable designed to extend the reach of your Wyze Cam, making it easy to mount your camera on a garden trellis or other hard-to-reach outdoor locations. It ensures continuous power and stable connectivity, allowing you to position your camera exactly where you need it for optimal garden or yard monitoring.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2, Pan v3, OG Standard, and OG Telephoto models, ensuring broad support for most Wyze outdoor cameras.
How do I install the Wyze Cam USB Extension Cable for my outdoor camera?Installation is simple: just plug the extension cable between your Wyze Cam and its power source. No complicated setup is required, making it easy to extend your camera’s reach for garden trellis or other outdoor installations.
Can I use the Wyze Cam USB Extension Cable outdoors?Yes, the Wyze Cam USB Extension Cable is designed for durability and stable power transmission, making it suitable for outdoor use when setting up your camera on a garden trellis or similar locations.
What are the benefits of using a lamp socket bundle with my Wyze Cam for outdoor setups?Lamp socket bundles, such as the Cam v4 + Lamp Socket v2 Bundle and Pan v3 + Lamp Socket v2 Bundle, allow you to power your Wyze Cam using existing outdoor light fixtures. This eliminates the need for nearby power outlets or extra wiring, and also enables smart lighting control and motion-activated illumination through the Wyze app.
Which Wyze Cam models are supported by the Lamp Socket v2 Bundles?The Lamp Socket v2 Bundles support Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models, providing flexible power solutions for a variety of Wyze cameras.
Are the lamp socket bundles weather-resistant and suitable for outdoor use?Yes, the lamp socket bundles are designed for outdoor use and are suitable for damp locations, making them ideal for garden trellis setups and other exterior installations.
How do I install the Wyze Cam Lamp Socket v2 Bundle?Installation is easy—simply screw the lamp socket into your existing outdoor light fixture like a regular lightbulb. No electrician is needed, and you can use CFL or LED bulbs under 20W for safe operation.
What are the advantages of using prolonged reach accessories for Wyze Cam on a garden trellis?Using prolonged reach accessories like the 20ft USB extension cable or lamp socket bundles allows you to position your Wyze Cam at the ideal height and angle for comprehensive garden monitoring, ensures continuous power supply, and enables smart automation features such as motion detection and light control for enhanced security and convenience.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?What are the benefits of using the Wyze Cam with the lamp socket bundles for outdoor setups?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam or its accessories?
