Discover the Wyze Cordless Vacuum S: Powerful Cleaning Meets Easy Maintenance
If you're searching for a
cordless vacuum with washable filters for easy maintenance, the
Wyze Cordless Vacuum S stands out as a top choice. Designed for modern homes, this vacuum combines powerful suction, lightweight design, and a user-friendly filtration system that makes upkeep simple and hassle-free.
Why Choose Wyze Cordless Vacuum S?
Exceptional Suction Power for Deep Cleaning
The Wyze Cordless Vacuum S delivers an impressive
20,000 Pa suction power in Turbo Mode, ensuring even the most stubborn dirt and pet hair are effortlessly removed. It offers multiple suction settings to suit your cleaning needs:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
This versatility means you can clean everything from delicate surfaces to heavy debris with ease.
Ultra-Lightweight and Ergonomic
Weighing just
2.8 pounds for the main unit and
4.9 pounds when fully assembled, the Wyze Cordless Vacuum S is as light as feathers, making it easy to maneuver around furniture, stairs, and tight spaces without fatigue.
Long-Lasting, Interchangeable Battery
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), this vacuum offers up to
40 minutes of runtime in ECO mode. The battery is interchangeable, allowing you to swap in a fresh pack for extended cleaning sessions without waiting for a recharge.
Washable and Replaceable HEPA Filters for Easy Maintenance
The vacuum features a
3-stage filtration system including a
washable HEPA filter that traps fine dust and allergens, promoting a healthier home environment. Regular filter replacement is simple with dedicated Wyze HEPA filter packs designed specifically for this model.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Enjoy effortless cleaning around your home and pets with the Wyze Cordless Vacuum S.
Key Features at a Glance
- Dual Motors: Two powerful motors maximize suction efficiency.
- LED Screen: Displays battery life and suction mode for easy monitoring.
- 6 Daylight-Bright LED Lights: Illuminate dark corners and under furniture for thorough cleaning.
- Dust Cup Volume: 0.7 liters capacity reduces frequent emptying.
- Noise Level: Quiet operation at 65 dBA in Turbo Mode.
- Dimensions: Compact main unit (12.4 x 4.5 x 8.7 inches) and assembled length of 41.1 inches.
- Color: Sleek steel grey with signature Wyze green accents.
Enhance Your Cleaning Experience with Wyze Accessories
To get the most out of your Wyze Cordless Vacuum S, consider these compatible accessories designed for convenience and extended functionality:
Wyze Cordless Vacuum S - Battery Pack
Need extra runtime? The
Wyze Cordless Vacuum S Battery Pack is a perfect companion for longer cleaning sessions. Easily swap batteries and keep cleaning without interruption.
Wyze Cordless Vacuum - HEPA Filter (2 Pack)
Maintain peak performance by replacing your HEPA filters regularly. These filters are washable and designed exclusively for Wyze vacuums, ensuring optimal air quality and suction.
This accessory bends to reach awkward spaces, reducing strain and making it easier to clean under furniture or in tight corners.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Ideal for cleaning car seats, sofas, and upholstery, this brush head attachment tackles pet hair and dirt in hard-to-reach areas.
Lightweight and powerful, the Wyze Cordless Vacuum S is perfect for everyday home cleaning.
Easy Charging and Storage
The Wyze Cordless Vacuum S charges via AC charging with a standard input of 100-240V~50/60Hz, reaching full charge in
4-6 hours. A replacement charger is also available to keep your vacuum ready at all times.
Summary: The Ideal Cordless Vacuum for Effortless Cleaning and Maintenance
The
Wyze Cordless Vacuum S is a standout cordless vacuum that combines:
- Powerful suction modes for versatile cleaning
- Lightweight design for easy handling
- Washable and replaceable HEPA filters for simple maintenance
- Long battery life with interchangeable packs
- Useful accessories to customize your cleaning experience
Whether you have pets, hardwood floors, or need a vacuum that’s easy to maintain, the Wyze Cordless Vacuum S is engineered to meet your needs with efficiency and convenience.
Keep your floors spotless with the Wyze Cordless Vacuum S, designed for modern living.
What makes the Wyze Cordless Vacuum S a top choice for home cleaning?
The Wyze Cordless Vacuum S stands out due to its powerful 20,000 Pa suction in Turbo Mode, lightweight design, washable HEPA filters, long-lasting interchangeable battery, and user-friendly features like an LED screen and bright LED lights for thorough cleaning.How powerful is the suction on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers up to 20,000 Pa suction power in Turbo Mode, 9,000 Pa in Medium Mode, and 6,000 Pa in ECO Mode, making it effective for deep cleaning carpets, pet hair, and hard floors.How long does the battery last on the Wyze Cordless Vacuum S?
The vacuum provides up to 40 minutes of runtime in ECO Mode, 23 minutes in Medium Mode, and 10 minutes in Turbo Mode. The battery is interchangeable, so you can swap in a fresh pack for extended cleaning sessions.Are the filters on the Wyze Cordless Vacuum S washable and replaceable?
Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system with a washable HEPA filter. The filters are easy to clean and can be replaced with dedicated Wyze HEPA filter packs for optimal performance.How much does the Wyze Cordless Vacuum S weigh?
The main unit weighs just 2.8 pounds, and the fully assembled vacuum weighs 4.9 pounds, making it ultra-lightweight and easy to maneuver around your home.What accessories are available for the Wyze Cordless Vacuum S?
Available accessories include the Wyze Cordless Vacuum S Battery Pack for extra runtime, washable HEPA filter packs, a foldable vacuum tube for cleaning under furniture, and a mini motorized brush head for upholstery and car interiors.How do I charge the Wyze Cordless Vacuum S and how long does it take?
The vacuum charges via AC charging with a standard input of 100-240V~50/60Hz. It takes approximately 4-6 hours to reach a full charge. Replacement chargers are also available.What is the dust cup capacity of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, reducing the need for frequent emptying during cleaning sessions.Is the Wyze Cordless Vacuum S suitable for homes with pets?
Yes, the powerful suction, washable HEPA filter, and specialized accessories like the mini motorized brush head make the Wyze Cordless Vacuum S ideal for homes with pets, effectively removing pet hair and dander.What are the noise levels of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S operates quietly at just 65 dBA in Turbo Mode, making it suitable for use in homes without causing significant noise disturbance.
