Discover the Wyze Cordless Vacuum S: Hassle-Free Cleaning with Wall Mount Storage
If you're searching for a
cordless vacuum with wall mount for hassle-free storage, the
Wyze Cordless Vacuum S is your perfect cleaning companion. Designed to combine powerful suction, lightweight design, and smart features, this vacuum makes home cleaning effortless and convenient. Whether you have hardwood floors, carpets, or pet hair to tackle, the Wyze Cordless Vacuum S delivers outstanding performance with easy storage solutions.
Powerful Suction and Lightweight Design
Exceptional Cleaning Power
The Wyze Cordless Vacuum S boasts an impressive
20,000 Pa suction power in Turbo Mode, ensuring deep cleaning on all surfaces. It offers multiple suction modes to suit your cleaning needs:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
With
two motors working in tandem, this vacuum efficiently picks up dust, dirt, and pet hair with ease.
Featherlight Weight for Easy Handling
Weighing only
2.8 lbs for the main unit and
4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is incredibly lightweight. This makes it easy to maneuver around furniture, stairs, and tight spaces without fatigue.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Alt text: Person vacuuming sofa with Wyze Cordless Vacuum S, pet-friendly cleaning
Long-Lasting Battery and Convenient Charging
Interchangeable Lithium-Ion Battery
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the Wyze Cordless Vacuum S offers up to
40 minutes of runtime in ECO mode, allowing you to clean your entire home on a single charge. The battery is interchangeable, so you can easily swap it out for extended cleaning sessions.
Efficient Charging
The vacuum charges via
AC charging with an input of
100-240V~50/60Hz, reaching full charge in
4-6 hours. This ensures your vacuum is ready whenever you need it.
Smart Features and Accessories for Enhanced Cleaning
LED Screen and Lighting
The vacuum features an
LED screen that displays suction mode and battery status clearly. Additionally, the brush head is equipped with
6 daylight-bright LED lights, illuminating dark corners and under furniture for thorough cleaning.
3-Stage Filtration System
The Wyze Cordless Vacuum S includes a
3-stage filtration system with a HEPA filter to trap fine dust and allergens, making it ideal for allergy sufferers and pet owners.
Included Attachments
- Crevice Tool for tight spaces
- Floor Brush for general cleaning
- Dust Cap
- HEPA Filter and Filter Housing
- Standard Tube
- Quick Start Guide
Hassle-Free Storage with Wall Mount
The Wyze Cordless Vacuum S supports
wall mount storage, allowing you to keep your vacuum neatly stored and always charged. This space-saving solution keeps your vacuum off the floor and ready for quick access, perfect for busy households.
Enhance Your Vacuum Experience with Wyze Accessories
Wyze Cordless Vacuum S - Battery Pack
Need extra cleaning time? The
Wyze Cordless Vacuum S Battery Pack is designed specifically for this model, providing additional power when you need it most.
Foldable Vacuum Tube
The
Wyze Cordless Vacuum Foldable Vacuum Tube bends to reach difficult areas without straining your wrist, making cleaning under furniture and tight spots easier.
HEPA Filter Replacement
Maintain peak performance by regularly replacing the
Wyze Cordless Vacuum HEPA Filter. Available in convenient 2-packs, these filters ensure your vacuum continues to trap allergens effectively.
Mini Motorized Brush Head
Perfect for cleaning car seats, sofas, and upholstery, the
Wyze Cordless Vacuum Mini Motorized Brush Head is a versatile accessory designed exclusively for the Wyze Cordless Vacuum.
Alt text: Modern home interior with Wyze Cordless Vacuum S mounted on wall for storage
Specifications at a Glance
Feature | Specification |
Suction Power | 100 AW / 20,000 Pa (Turbo Mode) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery Type | 6-cell lithium-ion |
Battery Capacity | 2,000mAh*6 |
Runtime | 40 min (ECO), 23 min (Medium), 10 min (Turbo) |
Charging Time | 4-6 hours |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo Mode) |
Dimensions | 12.4 x 4.5 x 8.7 in (main unit) |
Color | Steel grey with Wyze green accents |
Operating Temperature | -4ºF to 169ºF (-20ºC to 75ºC) |
Why Choose Wyze Cordless Vacuum S?
- Cordless freedom with powerful suction
- Lightweight and ergonomic for easy use
- Long battery life with quick recharge
- Smart LED display and lighting for efficient cleaning
- Wall mount storage for clutter-free homes
- Wide range of accessories to customize your cleaning
Summary
The
Wyze Cordless Vacuum S is a top-tier cordless vacuum cleaner that combines power, portability, and smart features. Its wall mount storage option makes it ideal for those seeking a clutter-free, hassle-free cleaning solution. With multiple accessories available, you can tailor your vacuuming experience to fit your lifestyle perfectly.
What is the suction power of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers up to 20,000 Pa of suction power in Turbo Mode, ensuring deep cleaning on all surfaces including carpets, hardwood floors, and pet hair.How long does the Wyze Cordless Vacuum S battery last?
The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode on a single charge.Is the Wyze Cordless Vacuum S lightweight and easy to use?
Yes, the Wyze Cordless Vacuum S is designed for easy handling, weighing only 2.8 lbs for the main unit and 4.9 lbs when fully assembled, making it simple to maneuver around furniture and tight spaces.Does the Wyze Cordless Vacuum S come with wall mount storage?
Yes, the Wyze Cordless Vacuum S supports wall mount storage, allowing you to keep your vacuum neatly stored, off the floor, and always charged for quick access.What type of filtration system does the Wyze Cordless Vacuum S use?
The Wyze Cordless Vacuum S features a 3-stage filtration system with a HEPA filter, effectively trapping fine dust and allergens, making it ideal for allergy sufferers and pet owners.What accessories are included with the Wyze Cordless Vacuum S?
Included accessories are a crevice tool, floor brush, dust cap, HEPA filter and filter housing, standard tube, and a quick start guide.How long does it take to fully charge the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S takes approximately 4-6 hours to fully charge using AC charging (100-240V~50/60Hz input).Can I replace the battery in the Wyze Cordless Vacuum S?
Yes, the Wyze Cordless Vacuum S features an interchangeable 6-cell lithium-ion battery, allowing you to swap batteries for extended cleaning sessions.Does the Wyze Cordless Vacuum S have LED lighting?
Yes, the vacuum has an LED screen that displays suction mode and battery status, and the brush head is equipped with 6 daylight-bright LED lights to illuminate dark corners and under furniture.Are there additional accessories available for the Wyze Cordless Vacuum S?
Yes, you can enhance your cleaning experience with accessories such as the Wyze Cordless Vacuum S Battery Pack, Foldable Vacuum Tube, HEPA Filter Replacement (2-pack), and Mini Motorized Brush Head.What is the dust cup capacity of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing for efficient cleaning with fewer interruptions.Is the Wyze Cordless Vacuum S suitable for pet hair?
Yes, with its powerful suction and specialized accessories, the Wyze Cordless Vacuum S is highly effective at picking up pet hair from floors, furniture, and upholstery.What are the dimensions and color of the Wyze Cordless Vacuum S?
The main unit measures 12.4 x 4.5 x 8.7 inches and comes in steel grey with Wyze green accents.What is the noise level of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo Mode, providing powerful cleaning with minimal disturbance.
