Discover the Wyze Cordless Vacuum S: Powerful Cleaning with Convenient Charging Options
If you're searching for a
cordless vacuum with convenient charging station placement options, the
Wyze Cordless Vacuum S stands out as a top choice. Designed for modern homes, this vacuum combines powerful suction, lightweight design, and smart features to make cleaning effortless. Whether you have hardwood floors, carpets, or pet hair to tackle, the Wyze Cordless Vacuum S delivers exceptional performance with flexible charging solutions to fit your lifestyle.
Wyze Cordless Vacuum S: Specs That Impress
Powerful Suction and Lightweight Design
- Suction Power: Up to 20,000 Pa in Turbo Mode, with 100 AW power
- Weight: Only 2.8 lbs for the main unit, 4.9 lbs when fully assembled — as light as 2.8 pounds of feathers!
- Battery: Interchangeable 6-cell lithium-ion battery (2,000mAh*6) providing up to 40 minutes of runtime in ECO mode
- Noise Level: Quiet operation at 65 dBA in Turbo Mode
- Dimensions: Compact 12.4 x 4.5 x 8.7 inches (main unit), 41.1 inches when assembled
- Color: Sleek steel grey with signature Wyze green accents
Smart Features for Efficient Cleaning
- Dual motors for enhanced suction and cleaning power
- 3-stage filtration system including a HEPA filter to trap fine dust and allergens
- LED screen for easy monitoring of battery and suction mode
- Six daylight-bright LED lights on the brush head to illuminate dark corners and under furniture
Versatile Attachments Included
- Crevice Tool for tight spaces
- Floor Brush for all floor types
- Dust Cap and HEPA Filter for easy maintenance
- Standard Tube and Quick Start Guide for hassle-free setup
Experience the freedom of cordless cleaning with a vacuum that’s powerful, lightweight, and smartly designed to fit your home.
Convenient Charging Station Placement Options
The Wyze Cordless Vacuum S supports
AC charging with a wide input range (100-240V~50/60Hz), making it easy to place the charging station wherever it suits your home layout. The vacuum fully charges in 4-6 hours, ensuring it’s ready when you need it.
Accessories to Enhance Charging and Usage
- Wyze Cordless Vacuum S - Battery Pack ($59.99): Extend your cleaning sessions with an extra battery designed specifically for the Wyze Cordless Vacuum S. Swap batteries on the go for uninterrupted cleaning.
- Wyze Cordless Vacuum S - Charger ($4.99): Keep a replacement charger handy to ensure your vacuum is always powered up, perfect for multiple charging station setups or as a backup.
Additional Accessories for Customized Cleaning
Foldable Vacuum Tube
- Price: $15.99
- Description: Bends so you don’t have to, making it easier to clean hard-to-reach areas without straining. Compatible only with Wyze Cordless Vacuum.
HEPA Filter Replacement (2 Pack)
- Price: $15.99
- Keep your vacuum performing at its best by regularly replacing the HEPA filters designed exclusively for Wyze Cordless Vacuum.
Mini Motorized Brush Head
- Price: $29.99
- Perfect for cleaning car seats, sofas, and upholstery. Compact and powerful, this accessory is tailored for the Wyze Cordless Vacuum to tackle pet hair and dirt in tight spaces.
Why Choose Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S is more than just a vacuum — it’s a smart cleaning companion designed for convenience, power, and flexibility. Its lightweight design and powerful suction make it ideal for everyday messes, while the interchangeable battery and versatile charging options ensure you’re never left without power. With a range of accessories to customize your cleaning experience, this vacuum adapts to your home’s unique needs.
Summary of Wyze Cordless Vacuum S and Accessories
Product | Key Feature | Price |
Wyze Cordless Vacuum S | 20,000 Pa suction, 40 min runtime, lightweight | $139.99 |
Battery Pack | Extra battery for extended cleaning | $59.99 |
Charger | Replacement charger for convenience | $4.99 |
Foldable Vacuum Tube | Flexible tube for hard-to-reach spots | $15.99 |
HEPA Filter (2 Pack) | Regular filter replacement | $15.99 |
Mini Motorized Brush Head | For upholstery and car seats | $29.99 |
Upgrade your cleaning routine with the Wyze Cordless Vacuum S and its convenient charging station placement options — the perfect blend of power, portability, and smart design.
What are the key features of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S features powerful suction up to 20,000 Pa in Turbo Mode, a lightweight design (only 2.8 lbs for the main unit), a 3-stage filtration system with a HEPA filter, an LED screen for battery and mode monitoring, and six LED lights on the brush head for cleaning dark areas. It also offers up to 40 minutes of runtime in ECO mode and supports convenient charging station placement.How long does the Wyze Cordless Vacuum S battery last and how is it charged?
The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO mode with its interchangeable 6-cell lithium-ion battery. The vacuum supports AC charging with a wide input range (100-240V~50/60Hz) and fully charges in 4-6 hours. You can place the charging station wherever it best fits your home layout.Can I extend the cleaning time of the Wyze Cordless Vacuum S?
Yes, you can extend your cleaning sessions by purchasing an extra Wyze Cordless Vacuum S Battery Pack. The battery is interchangeable, allowing you to swap batteries on the go for uninterrupted cleaning.What accessories are available for the Wyze Cordless Vacuum S?
Available accessories include a Battery Pack for extended cleaning, a replacement Charger, a Foldable Vacuum Tube for hard-to-reach areas, HEPA Filter Replacements (2 Pack) for optimal performance, and a Mini Motorized Brush Head for cleaning upholstery, car seats, and pet hair.Is the Wyze Cordless Vacuum S suitable for pet hair and different floor types?
Yes, the Wyze Cordless Vacuum S is designed to handle pet hair, hardwood floors, carpets, and more. Its powerful suction, dual motors, and included attachments like the Mini Motorized Brush Head make it effective for various surfaces and pet-friendly cleaning.How quiet is the Wyze Cordless Vacuum S during operation?
The Wyze Cordless Vacuum S operates quietly at just 65 dBA in Turbo Mode, making it suitable for use in homes without causing significant noise disturbance.What is included in the box with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, Standard Tube, and a Quick Start Guide for easy setup and versatile cleaning.How do I maintain the Wyze Cordless Vacuum S for optimal performance?
To maintain optimal performance, regularly replace the HEPA filters with the dedicated Wyze Cordless Vacuum S HEPA Filter Replacements. Clean the dust cap and brush heads as needed, and ensure the battery is charged and in good condition.What are the dimensions and weight of the Wyze Cordless Vacuum S?
The main unit of the Wyze Cordless Vacuum S measures 12.4 x 4.5 x 8.7 inches and weighs only 2.8 lbs. When fully assembled, it is 41.1 inches long and weighs 4.9 lbs, making it lightweight and easy to maneuver.Where can I buy replacement parts and accessories for the Wyze Cordless Vacuum S?
You can purchase replacement parts and accessories such as the Battery Pack, Charger, Foldable Vacuum Tube, HEPA Filter Replacements, and Mini Motorized Brush Head directly from the Wyze website.
