Discover the Wyze Cordless Vacuum S: Comfortable, Powerful Cleaning
If you're searching for a
cordless vacuum with an easy grip handle that delivers powerful suction and comfortable cleaning, the
Wyze Cordless Vacuum S is your perfect match. Designed for effortless handling and maximum cleaning efficiency, this vacuum combines lightweight design with advanced technology to keep your home spotless without the hassle of cords.
Why Choose Wyze Cordless Vacuum S?
Lightweight & Ergonomic Design for Comfortable Cleaning
Weighing just
2.8 pounds for the main unit and
4.9 pounds when fully assembled, the Wyze Cordless Vacuum S feels as light as feathers in your hand. Its ergonomic handle ensures a comfortable grip, reducing fatigue during extended cleaning sessions. Whether you're vacuuming floors, stairs, or upholstery, this vacuum is designed to move with ease and precision.
Powerful Suction with Multiple Modes
Experience the freedom of cordless cleaning with
20,000 Pa suction power in Turbo Mode, ensuring deep cleaning on carpets and hard floors alike. The vacuum offers three suction modes to suit your cleaning needs:
- Turbo Mode: 20,000 Pa for tough dirt (10 minutes runtime)
- Medium Mode: 9,000 Pa for everyday cleaning (23 minutes runtime)
- ECO Mode: 6,000 Pa for extended cleaning sessions (40 minutes runtime)
This versatility means you can switch modes depending on the mess, saving battery life without compromising performance.
Long-Lasting Battery & Quick Recharge
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the Wyze Cordless Vacuum S provides up to
40 minutes of runtime in ECO mode. When it’s time to recharge, the vacuum reaches full charge in just
4-6 hours via AC charging, so it’s ready when you are.
Enjoy effortless cleaning with the lightweight Wyze Cordless Vacuum S, perfect for pet owners and sofa cleaning.
Advanced Features for a Superior Cleaning Experience
Dual Motors & LED Screen
The Wyze Cordless Vacuum S is powered by
two motors, delivering consistent suction power across all surfaces. The built-in
LED screen provides real-time information on battery life and suction mode, keeping you informed and in control.
3-Stage Filtration & Bright LED Brush Head
Keep your home allergen-free with the
3-stage filtration system, including a HEPA filter that traps fine dust and particles. The vacuum’s brush head is equipped with
6 daylight-bright LED lights, illuminating dark corners and under furniture for thorough cleaning.
Versatile Attachments Included
The vacuum comes with a range of attachments to tackle every cleaning challenge:
- Crevice Tool for tight spaces
- Floor Brush for hard floors and carpets
- Dust Cap
- HEPA Filter and Filter Housing
- Standard Tube for extended reach
- Quick Start Guide for easy setup
Enhance Your Wyze Cordless Vacuum S with Accessories
Maximize your vacuum’s performance and convenience with these compatible accessories designed specifically for the Wyze Cordless Vacuum S:
Wyze Cordless Vacuum S - Battery Pack
Need extra cleaning time? The
replacement battery pack ensures you never run out of power during your cleaning routine. Perfect for extended sessions or multiple rooms.
Wyze Cordless Vacuum S - Charger
Keep a spare
charger handy to ensure your vacuum is always ready to go, whether at home or on the move.
This
foldable tube bends for easier access to hard-to-reach areas, reducing strain and making cleaning more comfortable.
Wyze Cordless Vacuum - HEPA Filter
Maintain optimal air quality by regularly replacing your
HEPA filter with this convenient 2-pack.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Ideal for
car seats and sofas, this mini brush head attachment tackles pet hair and dirt in tight spaces with ease.
Lightweight and powerful, the Wyze Cordless Vacuum S makes cleaning effortless around your home and pets.
Specifications at a Glance
Feature | Specification |
Suction Power | 100 AW; 20,000 Pa (Turbo Mode) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | 40 min (ECO), 23 min (Medium), 10 min (Turbo) |
Charging Time | 4-6 hours |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo Mode) |
Dimensions | 12.4 x 4.5 x 8.7 in (main unit) |
Color | Steel grey with Wyze green accents |
Operating Temperature | -4ºF to 169ºF |
Filtration | 3-stage with HEPA filter |
LED Lights | 6 daylight-bright LEDs on brush head |
The Wyze Cordless Vacuum S is the ultimate solution for those who want a lightweight, powerful, and easy-to-handle vacuum that adapts to all cleaning needs. Its ergonomic design and advanced features make it a standout choice for comfortable, efficient home cleaning.
Summary
The
Wyze Cordless Vacuum S stands out as a top-tier cordless vacuum with an easy grip handle, powerful suction, and versatile attachments. Whether you’re tackling pet hair, dust, or everyday dirt, this vacuum offers the perfect balance of comfort and performance. Enhance your cleaning experience with dedicated accessories designed to keep your vacuum running at its best.
What are the key features of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S features a lightweight and ergonomic design, powerful 20,000 Pa suction in Turbo Mode, three cleaning modes, a 3-stage HEPA filtration system, dual motors, an LED display, and a brush head with 6 daylight-bright LED lights. It also comes with versatile attachments for various cleaning needs.How much does the Wyze Cordless Vacuum S weigh?
The main unit of the Wyze Cordless Vacuum S weighs just 2.8 pounds, and the fully assembled vacuum weighs 4.9 pounds, making it easy to handle and maneuver.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode, thanks to its 6-cell lithium-ion battery.How long does it take to fully charge the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S takes approximately 4-6 hours to reach a full charge using the included AC charger.What types of surfaces can the Wyze Cordless Vacuum S clean?
The Wyze Cordless Vacuum S is designed for versatile cleaning on carpets, hard floors, stairs, upholstery, and even car interiors, thanks to its powerful suction and included attachments.Does the Wyze Cordless Vacuum S have a HEPA filter?
Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system that includes a HEPA filter, effectively trapping fine dust and allergens to keep your home air clean.What attachments are included with the Wyze Cordless Vacuum S?
The vacuum comes with a crevice tool, floor brush, dust cap, HEPA filter and filter housing, standard tube for extended reach, and a quick start guide.Are there additional accessories available for the Wyze Cordless Vacuum S?
Yes, you can enhance your vacuum with accessories such as a replacement battery pack, spare charger, foldable vacuum tube, HEPA filter 2-pack, and a mini motorized brush head for car seats and sofas.How powerful is the suction on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo Mode, ensuring deep cleaning performance on both carpets and hard floors.Does the Wyze Cordless Vacuum S have an LED display?
Yes, the vacuum features a built-in LED screen that provides real-time information on battery life and suction mode.What is the dust cup capacity of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing for extended cleaning before needing to empty the bin.Is the Wyze Cordless Vacuum S suitable for pet owners?
Absolutely. The Wyze Cordless Vacuum S is lightweight, powerful, and comes with attachments like the mini motorized brush head, making it ideal for cleaning pet hair from floors, furniture, and car interiors.What is the noise level of the Wyze Cordless Vacuum S?
The vacuum operates at a noise level of 65 dBA in Turbo Mode, providing powerful cleaning without excessive noise.What are the dimensions and color of the Wyze Cordless Vacuum S?
The main unit measures 12.4 x 4.5 x 8.7 inches and comes in a stylish steel grey color with Wyze green accents.What is the operating temperature range for the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S is designed to operate in temperatures ranging from -4ºF to 169ºF.
