Wyze Cordless Vacuum S: Best for High Ceilings & Fans Cleaning
Wyze Cordless Vacuum S: The Ultimate Solution for High Ceilings and Fans
When it comes to cleaning hard-to-reach places like high ceilings and ceiling fans, having a lightweight, powerful, and versatile cordless vacuum is essential. The Wyze Cordless Vacuum S is designed to meet these needs with impressive suction power, extended battery life, and smart features that make cleaning effortless and efficient. Wyze Cordless Vacuum S lifestyle Experience the freedom of cordless cleaning with Wyze Cordless Vacuum S.
Powerful Suction for Deep Cleaning High Surfaces
The Wyze Cordless Vacuum S boasts an outstanding suction power of up to 20,000 Pa in Turbo Mode, ensuring that dust, cobwebs, and allergens are thoroughly removed from high ceilings and fan blades. It offers three suction modes to balance power and battery life:
  • Turbo Mode: 20,000 Pa (10 minutes runtime)
  • Medium Mode: 9,000 Pa (23 minutes runtime)
  • ECO Mode: 6,000 Pa (40 minutes runtime)
This range allows you to customize your cleaning intensity depending on the task, making it perfect for delicate fan blades or stubborn ceiling corners.
Lightweight and Ergonomic Design for Easy Reach
Weighing only 2.8 lbs for the main unit and 4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is incredibly light, reducing arm fatigue when cleaning overhead. Its total length of 41.1 inches when assembled helps you reach high ceilings and fans without the need for ladders or stools. The vacuum’s steel grey body with Wyze green accents combines style with functionality, while the 6 daylight-bright LED lights on the brush head illuminate dark corners and ceiling fan blades for thorough cleaning.
Long-Lasting Battery and Quick Charging
Equipped with a 6-cell lithium-ion battery (2,000mAh*6), the Wyze Cordless Vacuum S offers up to 40 minutes of runtime in ECO mode, enough to clean multiple rooms or several fans and ceiling areas on a single charge. The battery charges fully in 4-6 hours via AC charging, so it’s ready when you need it. For extended cleaning sessions, consider the Wyze Cordless Vacuum S - Battery Pack, an official accessory designed to provide extra juice and keep you cleaning longer without interruption.
Advanced Filtration and Smart Features
The vacuum features a 3-stage filtration system including a HEPA filter, which traps fine dust and allergens, making it ideal for maintaining air quality while cleaning high and dusty areas. The LED screen displays battery status and suction mode, giving you full control at your fingertips. Included attachments such as the Crevice Tool and Floor Brush enhance versatility, allowing you to clean narrow fan blades, corners, and other tricky spots with ease.
Essential Accessories for Enhanced Cleaning
  • Designed specifically for the Wyze Cordless Vacuum S
  • Extends cleaning time for large or multiple high-ceiling areas
  • Priced affordably to keep your vacuum powered up
  • Bends to reach awkward angles without strain
  • Perfect for cleaning ceiling fans and corners without moving furniture
  • Compatible only with Wyze Cordless Vacuum
Wyze Cordless Vacuum - HEPA Filter
  • Replace regularly to maintain optimal filtration
  • Comes in convenient 2-pack for continuous use
  • Ensures clean air while vacuuming dust from high places
Wyze vacuum cleaning sofa with pet Versatile cleaning for every surface, from floors to high ceilings.
Why Choose Wyze Cordless Vacuum S for High Ceilings and Fans?
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support."
— Wyze product description
The Wyze Cordless Vacuum S combines powerful suction, lightweight design, and smart features to make cleaning high ceilings and fans easier than ever. Its long battery life and flexible accessories ensure you can tackle dust and allergens wherever they hide, without the hassle of cords or heavy equipment.
Product Summary
FeatureSpecification
Suction PowerUp to 20,000 Pa (Turbo Mode)
Weight2.8 lbs (main unit), 4.9 lbs (assembled)
Battery6-cell lithium-ion, 40 min runtime (ECO)
Charging Time4-6 hours
Dust Cup Volume0.7 L
Noise Level65 dBA (Turbo Mode)
Dimensions (assembled)41.1 inches
Filtration3-stage with HEPA filter
Included AttachmentsCrevice Tool, Floor Brush, HEPA Filter, Dust Cap
FeatureWyze Cordless Vacuum SWyze Cordless Vacuum S - Battery PackWyze Cordless Vacuum - Foldable Vacuum Tube
TypeConnected Home VacuumAccessory - Battery PackAccessory - Foldable Vacuum Tube
Price$139.99 (compare at $193.99)$59.99$15.99 (compare at $29.99)
CompatibilityWyze Cordless Vacuum SWyze Cordless Vacuum SWyze Cordless Vacuum
Suction PowerUp to 20,000 PaN/AN/A
Battery Life40 minutes (interchangeable lithium-ion battery)Provides extra battery powerN/A
Motors2 motors (one in vacuum, one in brush head)N/AN/A
Weight2.8 poundsN/AN/A
Cleaning Speeds3 speeds: Eco (6,000 Pa), Med (9,000 Pa), Turbo (20,000 Pa)N/AN/A
LED Lights6 daylight-bright LEDs in brush headN/AN/A
Filtration System3-stage filtration with HEPA filterN/AN/A
Dust CupEasy one-finger release, washableN/AN/A
Additional FeaturesBrushless digital motor, interchangeable batteryDesigned specifically to extend vacuum runtimeBends for easier cleaning in hard-to-reach areas
Stock StatusIn stockLow stock (36 left)Available
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What makes the Wyze Cordless Vacuum S ideal for cleaning high ceilings and ceiling fans?The Wyze Cordless Vacuum S is specifically designed for hard-to-reach areas like high ceilings and ceiling fans. Its lightweight build (only 4.9 lbs fully assembled), extended reach (41.1 inches), and powerful suction (up to 20,000 Pa in Turbo Mode) make it easy to clean overhead surfaces without the need for ladders or stools.
How powerful is the suction on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers up to 20,000 Pa of suction power in Turbo Mode, ensuring deep cleaning of dust, cobwebs, and allergens from high surfaces. It also features Medium Mode (9,000 Pa) and ECO Mode (6,000 Pa) to balance cleaning power and battery life.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO Mode, 23 minutes in Medium Mode, and 10 minutes in Turbo Mode. The 6-cell lithium-ion battery fully charges in 4-6 hours, allowing you to clean multiple rooms or high areas on a single charge.
What attachments are included with the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S comes with a Crevice Tool, Floor Brush, HEPA Filter, and Dust Cap. These attachments enhance versatility, making it easy to clean narrow fan blades, corners, and other tricky spots.
Does the Wyze Cordless Vacuum S have a HEPA filter?Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system that includes a HEPA filter. This system traps fine dust and allergens, helping to maintain clean air while vacuuming high and dusty areas.
Are there accessories available to extend the cleaning capabilities of the Wyze Cordless Vacuum S?Yes, there are several accessories available, including the Wyze Cordless Vacuum S - Battery Pack for extended runtime, the Foldable Vacuum Tube for reaching awkward angles, and replacement HEPA filters to maintain optimal filtration.
How much does the Wyze Cordless Vacuum S weigh?The main unit of the Wyze Cordless Vacuum S weighs just 2.8 lbs, and it weighs 4.9 lbs when fully assembled, making it easy to maneuver and ideal for cleaning overhead surfaces.
How bright are the LED lights on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features 6 daylight-bright LED lights on the brush head, which illuminate dark corners and ceiling fan blades for thorough and effective cleaning.
How large is the dust cup on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing you to clean multiple areas before needing to empty it.
Is the Wyze Cordless Vacuum S noisy during operation?The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo Mode, which is relatively quiet for a vacuum with such powerful suction.
How do I charge the Wyze Cordless Vacuum S and how long does it take?The Wyze Cordless Vacuum S charges via AC power and takes approximately 4-6 hours to reach a full charge.
Is the Foldable Vacuum Tube compatible with the Wyze Cordless Vacuum S?The Foldable Vacuum Tube is compatible with the Wyze Cordless Vacuum, making it easier to clean ceiling fans and corners without moving furniture. Please check compatibility with your specific model before purchasing.
What are the different suction modes available on the Wyze Cordless Vacuum S?How long does it take to fully charge the Wyze Cordless Vacuum S?Is there a warranty for the Wyze Cordless Vacuum S?
