Wyze Cordless Vacuum S: The Ultimate Cordless Vacuum for Quick Transitions from Carpet to Tile
When it comes to efficient and versatile cleaning, the
Wyze Cordless Vacuum S stands out as a top choice for homeowners seeking a lightweight, powerful vacuum that easily transitions between carpet and tile floors. Designed with convenience and performance in mind, this cordless vacuum offers unmatched suction power, smart features, and a user-friendly design that makes cleaning effortless.
Powerful Suction for Every Surface
The Wyze Cordless Vacuum S boasts an impressive suction system with multiple power modes to tackle different floor types:
- Turbo Mode: 20,000 Pa suction power for deep cleaning carpets and stubborn dirt.
- Medium Mode: 9,000 Pa for everyday cleaning on mixed surfaces.
- ECO Mode: 6,000 Pa for gentle cleaning on delicate tile or hardwood floors.
With
100 AW of airflow and two motors working in tandem, this vacuum ensures thorough dirt and debris removal whether you're on plush carpet or smooth tile.
Lightweight and Ergonomic Design
Weighing only
2.8 lbs for the main unit and
4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is as light as 2.8 pounds of feathers. This makes it incredibly easy to maneuver around furniture, stairs, and tight spaces without fatigue.
Its compact dimensions (12.4 x 4.5 x 8.7 inches for the main unit) and steel grey finish with Wyze green accents add a modern touch to your cleaning tools.
Long-Lasting Battery Life for Extended Cleaning
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the vacuum offers flexible runtime options:
- ECO Mode: Up to 40 minutes of continuous cleaning.
- Medium Mode: 23 minutes.
- Turbo Mode: 10 minutes for intensive cleaning bursts.
The battery is interchangeable, allowing you to swap in a fresh pack for uninterrupted cleaning sessions. The included
Wyze Cordless Vacuum S - Battery Pack accessory ensures you never run out of juice during your chores.
Advanced Features for Smart Cleaning
- LED Screen: Displays real-time battery status and suction mode.
- 3-Stage Filtration System: Captures fine dust and allergens, ideal for pet owners and allergy sufferers.
- 6 Daylight-Bright LED Lights: Illuminate dark corners and under furniture for thorough cleaning.
- Attachments Included: Crevice tool, floor brush, HEPA filter, dust cap, and more for versatile cleaning needs.
Effortless cleaning on hardwood and tile floors with Wyze Cordless Vacuum S
Essential Accessories to Enhance Your Wyze Cordless Vacuum S Experience
Need extra power for larger cleaning jobs? The
Wyze Cordless Vacuum S - Battery Pack is designed specifically for the vacuum, providing additional runtime so you can clean without interruption.
- Price: $59.99
- Hassle-free 30-day return policy
- Perfect for homes with multiple floor types or larger areas
Wyze Cordless Vacuum S - Charger
Keep your vacuum ready to go with the official
replacement charger. Compact and efficient, it ensures your vacuum charges safely and quickly.
- Price: $4.99
- Compatible exclusively with Wyze Cordless Vacuum S
- 30-day hassle-free returns
This innovative accessory bends to reach tricky spots without you having to contort yourself. Ideal for cleaning under furniture or tight corners.
- Price: $15.99 (compare at $29.99)
- Compatible with Wyze Cordless Vacuum only
Wyze Cordless Vacuum - HEPA Filter
Maintain peak filtration performance by regularly replacing your HEPA filter. This pack of two ensures your vacuum continues to trap allergens and fine dust effectively.
- Price: $15.99 for 2-pack
- Designed exclusively for Wyze Cordless Vacuum
Pet-friendly cleaning made easy with Wyze Cordless Vacuum S
Why Choose Wyze Cordless Vacuum S for Carpet to Tile Transitions?
The Wyze Cordless Vacuum S is engineered for seamless transitions between different floor types, making it the perfect choice for homes with mixed surfaces like carpet and tile. Its powerful suction modes, lightweight design, and smart features combine to deliver a cleaning experience that is both efficient and enjoyable.
Whether you need to quickly switch from vacuuming your carpeted living room to sweeping tile floors in the kitchen, the Wyze Cordless Vacuum S adapts instantly without losing performance or requiring complicated adjustments.
Summary of Wyze Cordless Vacuum S Key Specifications
Feature | Specification |
Suction Power | 20,000 Pa (Turbo), 9,000 Pa (Medium), 6,000 Pa (ECO) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | 40 min (ECO), 23 min (Medium), 10 min (Turbo) |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo Mode) |
Dimensions (Main Unit) | 12.4 x 4.5 x 8.7 inches |
Color | Steel grey with Wyze green accents |
Filtration | 3-stage with HEPA filter |
Included Attachments | Crevice tool, floor brush, HEPA filter, dust cap, standard tube |
Experience the freedom of cordless cleaning with the Wyze Cordless Vacuum S — powerful, lightweight, and smartly designed for quick transitions from carpet to tile floors.
What makes the Wyze Cordless Vacuum S ideal for both carpet and tile floors?
The Wyze Cordless Vacuum S is engineered with multiple suction modes, allowing seamless transitions between carpet and tile. Turbo Mode delivers 20,000 Pa for deep carpet cleaning, while ECO Mode provides gentle suction for delicate tile or hardwood floors. Its lightweight design and versatile attachments make it easy to clean all floor types efficiently.How powerful is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S features a robust suction system with up to 20,000 Pa in Turbo Mode, 9,000 Pa in Medium Mode, and 6,000 Pa in ECO Mode. With 100 AW of airflow and dual motors, it effectively removes dirt and debris from both carpets and hard floors.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers up to 40 minutes of runtime in ECO Mode, 23 minutes in Medium Mode, and 10 minutes in Turbo Mode. The battery is interchangeable, so you can swap in a fresh pack for extended cleaning sessions.Is the Wyze Cordless Vacuum S lightweight and easy to use?
Yes, the Wyze Cordless Vacuum S weighs only 2.8 lbs for the main unit and 4.9 lbs when fully assembled. Its ergonomic and compact design makes it easy to maneuver around furniture, stairs, and tight spaces without causing fatigue.What smart features does the Wyze Cordless Vacuum S offer?
The vacuum includes an LED screen that displays real-time battery status and suction mode, a 3-stage filtration system with a HEPA filter for capturing fine dust and allergens, and 6 daylight-bright LED lights to illuminate dark corners and under furniture.What attachments come with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a crevice tool, floor brush, HEPA filter, dust cap, and a standard tube, providing versatile cleaning options for different surfaces and hard-to-reach areas.Are there additional accessories available for the Wyze Cordless Vacuum S?
Yes, you can purchase the Wyze Cordless Vacuum S - Battery Pack for extra runtime, the official replacement charger, and HEPA filter packs. There is also a foldable vacuum tube available for the Wyze Cordless Vacuum (not the S model) to help reach tricky spots.How effective is the Wyze Cordless Vacuum S for pet owners and allergy sufferers?
The Wyze Cordless Vacuum S features a 3-stage filtration system with a HEPA filter that captures fine dust and allergens, making it an excellent choice for pet owners and those with allergies.What is the dust cup capacity of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing for extended cleaning sessions before needing to empty the bin.What is the noise level of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo Mode, making it relatively quiet for a powerful cordless vacuum.What is the return policy for Wyze Cordless Vacuum S accessories?
All official Wyze Cordless Vacuum S accessories, including the battery pack and charger, come with a hassle-free 30-day return policy.What are the dimensions and color of the Wyze Cordless Vacuum S?
The main unit of the Wyze Cordless Vacuum S measures 12.4 x 4.5 x 8.7 inches and features a modern steel grey finish with Wyze green accents.
