Color Smart Bulb & Light Strip Kits for Recessed Lighting
Color Smart Bulbs and Light Strip Kits for Recessed Lighting
Transform your recessed lighting setup with vibrant, customizable smart lighting solutions that bring color, ambiance, and convenience to your home. Whether you want to create a cozy atmosphere, energize your living space, or highlight architectural features, these color smart bulbs and light strip kits offer seamless control and brilliant illumination tailored to your style.
Wyze Light Strip: Brilliant LED Accent Lighting
Enhance your recessed lighting with the Wyze Light Strip, designed to add vivid color accents to any indoor space. Available in two lengths—16.4 feet and 32.8 feet—this light strip delivers up to 16 million colors, allowing you to customize your lighting environment with ease.
Key Features:
  • Length Options: 16.4 ft (18 watts) and 32.8 ft (36 watts) to fit various room sizes.
  • Color Range: 16 million colors with single customizable zone.
  • Brightness: Blue (0.8 lm/LED), Red (1.0 lm/LED), Green (2.5 lm/LED) at 20mA.
  • Connectivity: Dual communication via 802.11 b/g/n Wi-Fi (2.4 GHz) and Bluetooth.
  • Installation: Easy adhesive backing with cuttable strips for perfect fit.
  • Indoor Use Only: Ideal for recessed lighting in living rooms, kitchens, or bedrooms.
  • Music Sync: Built-in microphone enables lighting to pulse with your favorite tunes.
  • Durability: Long life expectancy of 25,000 hours.
This light strip is perfect for adding subtle or dramatic color effects around your recessed fixtures, under cabinets, or behind furniture. Wyze Light Strip in Living Room Create vibrant ambiance with Wyze Light Strip behind your sofa
Wyze Light Party: Complete Color Lighting Kit with Bulbs and Strip
For a comprehensive recessed lighting upgrade, the Wyze Light Party bundle combines smart color bulbs with a 32.8-foot light strip, delivering a full spectrum of lighting options for your home.
What’s Included:
  • Wyze Color Bulbs (BR30 or A19 styles) in packs of 2 or 4.
  • 32.8 ft Wyze Light Strip with 16 million colors.
  • Controller, adhesive clips, power adapter, and quick start guide.
Highlights:
  • Color Temperature Range: 1800K to 6500K tunable white plus 16 million RGB colors.
  • Brightness: Up to 950 lumens for BR30 bulbs, perfect for recessed fixtures.
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice and automation control.
  • Damp Location Rated: Suitable for bathrooms or kitchens with recessed lighting.
  • Wireless Control: 2.4 GHz Wi-Fi and Bluetooth connectivity.
  • Customizable Zones: Single zone for light strip, adjustable brightness and color for bulbs.
  • Long Life: 25,000 hours of reliable use.
This kit is ideal for those who want to effortlessly switch between bright white light and colorful moods, all controlled from the Wyze app.
Smart Lighting Kits with Bulb Color BR30 + Light Strip Pro Bundle
If you want advanced customization and professional-grade lighting for your recessed fixtures, consider the Smart Lighting Kit - Bulb Color BR30 + Light Strip Pro Bundle.
Features:
  • Wyze Bulb Color BR30: 30 to 950 lumens, 1800K-6500K color temperature, CRI 90+ for true color rendering.
  • Wyze Light Strip Pro: 16.4 ft multicolor strip with 16 customizable zones for dynamic lighting effects.
  • Connectivity: Wi-Fi (802.11 b/g/n 2.4 GHz) and Bluetooth.
  • Suitable for Damp Locations: Safe for bathrooms and kitchens.
  • Indoor Use: Perfect for recessed lighting in living rooms, hallways, or accent areas.
  • Durability: 25,000 hours life expectancy with 1-year warranty.
  • Cuttable and Flexible: Easily fit the strip to your recessed lighting layout.
This bundle offers the ultimate control over your recessed lighting with multizone color effects and high-quality smart bulbs designed to fit standard recessed fixtures.
Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle
Another excellent option is the Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle, which pairs Wyze’s versatile color bulbs with the Light Strip Pro for a balanced lighting solution.
Benefits:
  • Bulb Options: Available in 2 or 4 packs, delivering 30-1100 lumens with adjustable color temperature.
  • Light Strip Pro: 16.4 ft with 16 customizable zones and 16 million colors.
  • Voice Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT.
  • Indoor and Damp Location Use: Perfect for recessed lighting in various rooms.
  • Easy Setup: Adhesive backing and app control for seamless installation and management.
  • Long-lasting: 25,000 hours lifespan with 1-year warranty.
This kit is perfect for users who want a flexible, smart lighting system that can be tailored to different moods and occasions. Wyze Light Strip Lifestyle Brighten your kitchen or living space with Wyze Light Strip
Why Choose These Smart Lighting Kits for Recessed Lighting?
Smart recessed lighting solutions like these Wyze kits offer unparalleled flexibility, vibrant color options, and easy app-based control. Whether you want to highlight architectural details, create a relaxing ambiance, or energize your space with dynamic colors, these kits provide everything you need for a modern, connected home lighting experience.
  • Customizable Colors & Zones: Choose from millions of colors and multiple zones for personalized lighting.
  • Smart Controls: Use your smartphone or voice assistants to adjust brightness, color, and schedules.
  • Energy Efficient: LED technology ensures low power consumption and long life.
  • Easy Installation: Adhesive strips and standard bulb sizes make upgrading your recessed lighting hassle-free.
  • Music Sync & Automation: Enhance parties or daily routines with lighting that reacts to sound or automates based on your preferences.
Conclusion
Upgrade your recessed lighting with Wyze’s color smart bulbs and light strip kits to enjoy vibrant, customizable illumination that fits your lifestyle. From the versatile Wyze Light Strip to comprehensive bundles like the Wyze Light Party and Smart Lighting Kits with BR30 bulbs, these products deliver brilliant color, smart connectivity, and easy installation for any indoor recessed lighting project. Start creating your perfect lighting atmosphere today with these innovative smart lighting solutions.
Feature / ProductWyze Light StripWyze Light PartySmart Lighting Kit - Bulb Color BR30 + Light Strip Pro BundleSmart Lighting Kit - Bulb Color + Light Strip Pro Bundle
TypeConnected HomeConnected HomeSmart LightingSmart Lighting
Variants / Styles16.4 ft ($19.99), 32.8 ft ($35.99)Bundles: BR30 2pk + 32ft LS ($59.98), BR30 4pk + 32ft LS ($83.97), Bulb Color 4pk + 32ft LS ($80.97)Bulb Color BR30 2-Pack + 16.4ft Light Strip Pro ($53.98), 4-Pack + 16.4ft LS Pro ($77.97)Bulb Color 2-Pack + 16.4ft Light Strip Pro ($52.98), 4-Pack + 16.4ft LS Pro ($74.97)
Light Strip Length16.4 ft, 32.8 ft32 ft16.4 ft (Light Strip Pro)16.4 ft (Light Strip Pro)
Light Strip TypeBasic Light Strip (single color per segment)Wyze Light Strip 32ft (part of bundle)Light Strip Pro (16 customizable multicolor segments)Light Strip Pro (16 customizable multicolor segments)
Bulb IncludedNoYes (BR30 or Bulb Color depending on bundle)Yes (Bulb Color BR30)Yes (Bulb Color)
Bulb Color OptionsN/A16 million colors + tunable white16 million colors, 1800K-6500K, 30-950 lumens16 million colors, 1800K-6500K, 30-1100 lumens
Bulb PowerN/AN/A11.5W (BR30)12W (Bulb Color)
Light Strip Colors16 million colors16 million colors + tunable white16 million colors, multicolor16 million colors, multicolor
Light Strip FeaturesPeel, stick, plug, Music Mode, Sun Match, Voice Control, Vacation Mode, Sleep Routines, Timers & AutomationsSync with bulbs, Music Mode, Voice Control, Vacation Mode, NotificationsMulti-color 16 customizable segments, Music Mode, Voice Control, Vacation Mode, Sleep Routines, Timers & AutomationsMulti-color 16 customizable segments, Music Mode, Voice Control, Vacation Mode, Sleep Routines, Timers & Automations
Communication Mode802.11 b/g/n, 2.4 GHz, Bluetooth802.11 b/g/n, 2.4 GHz, Bluetooth802.11 b/g/n, 2.4 GHz, Bluetooth802.11 b/g/n, 2.4 GHz, Bluetooth
Power SourceCorded ElectricCorded Electric (Light Strip), Bulbs powered by socketCorded Electric (Light Strip Pro), Bulb power via socketCorded Electric (Light Strip Pro), Bulb power via socket
TrimmableYesYes (Light Strip)Yes (Light Strip Pro)Yes (Light Strip Pro)
Indoor/Outdoor UseIndoor OnlyIndoor OnlyIndoor OnlyIndoor Only
WarrantyNot specifiedNot specified1 Year1 Year
Price Range$19.99 - $35.99 (sold out)$59.98 - $83.97$53.98 - $77.97$52.98 - $74.97
Included in BoxLight Strip, power adapter, controller, adhesive clips, quick start guide, alcohol wipesBundled bulbs + 32ft Light Strip1x Bulb Color BR30, 1x Light Strip ProBulb Color pack, Light Strip Pro
What are the benefits of using color smart bulbs and light strip kits for recessed lighting?Color smart bulbs and light strip kits for recessed lighting offer customizable colors, adjustable brightness, and smart controls via app or voice assistants. They help create vibrant ambiance, highlight architectural features, and provide energy-efficient, long-lasting illumination tailored to your style.
What is the Wyze Light Strip and how can it enhance my recessed lighting?The Wyze Light Strip is an LED accent lighting solution available in 16.4 ft and 32.8 ft lengths, offering up to 16 million colors. It features easy adhesive installation, Wi-Fi and Bluetooth connectivity, music sync, and a long lifespan, making it ideal for adding vivid color accents to recessed lighting in living rooms, kitchens, or bedrooms.
What is included in the Wyze Light Party bundle for recessed lighting?The Wyze Light Party bundle includes Wyze Color Bulbs (BR30 or A19 styles) in packs of 2 or 4, a 32.8 ft Wyze Light Strip, a controller, adhesive clips, power adapter, and a quick start guide. This kit provides a full spectrum of lighting options for your home’s recessed fixtures.
Are Wyze smart lighting kits compatible with voice assistants?Yes, Wyze smart lighting kits are compatible with Alexa, Google Assistant, and IFTTT, allowing you to control your recessed lighting with voice commands or through automation routines.
Can Wyze smart bulbs and light strips be used in damp locations like bathrooms or kitchens?Yes, many Wyze smart bulbs and light strips are rated for damp locations, making them suitable for use in bathrooms and kitchens with recessed lighting.
What is the difference between the Wyze Light Strip and the Wyze Light Strip Pro?The Wyze Light Strip offers a single customizable color zone, while the Wyze Light Strip Pro features 16 customizable zones for dynamic, multicolor lighting effects. Both provide millions of color options and easy installation.
How long do Wyze smart bulbs and light strips last?Wyze smart bulbs and light strips have a long life expectancy of up to 25,000 hours, ensuring reliable and energy-efficient lighting for years.
How easy is it to install Wyze smart lighting kits for recessed lighting?Wyze smart lighting kits are designed for easy installation. The light strips feature adhesive backing and are cuttable for a perfect fit, while the bulbs fit standard recessed fixtures. The Wyze app provides step-by-step setup instructions.
Can I control the color and brightness of Wyze smart bulbs and light strips?Yes, you can fully control the color and brightness of Wyze smart bulbs and light strips using the Wyze app or compatible voice assistants. The bulbs offer adjustable color temperature and brightness, while the strips provide millions of color options and customizable zones.
Do Wyze smart lighting kits support music sync features?Yes, the Wyze Light Strip includes a built-in microphone that enables the lighting to pulse and change colors in sync with your favorite music, perfect for parties and entertainment.
Are Wyze smart lighting kits energy efficient?Yes, Wyze smart bulbs and light strips use LED technology, which ensures low power consumption and long-lasting performance, making them an energy-efficient choice for recessed lighting.
What is the warranty on Wyze smart bulbs and light strips?Wyze smart bulbs and light strips come with a 1-year warranty, providing peace of mind and reliable support for your smart lighting investment.
What are the different lengths available for the Wyze Light Strip?Can the Wyze Light Strip be used in damp locations like bathrooms?Do you have any deals, ongoing sales, discounts, or promotions?
