BR30 Smart Bulbs with Voice Control for Alexa and Google Assistant
Looking for the perfect BR30 smart bulb that offers seamless voice control with Alexa and Google Assistant? Discover the Wyze Bulb Color BR30, a premium smart lighting solution designed to fit your recessed lighting fixtures while delivering vibrant colors, customizable brightness, and smart home integration. This page highlights the best BR30 smart bulbs with voice control, focusing on features, specs, and smart capabilities to enhance your home lighting experience.
Wyze Bulb Color BR30: The Ultimate Smart BR30 Bulb
Alt: Living room illuminated with colorful smart BR30 bulbs
Brilliant Color and Brightness Control
The Wyze Bulb Color BR30 stands out with its ability to produce
16 million ultra-accurate colors, allowing you to set the perfect mood for any occasion—from game day excitement to relaxing wine nights. Unlike most BR30 bulbs that max out at 650 lumens, this bulb offers a
wide lumen range from 30lm to 950lm, giving you the flexibility to brighten or dim your space exactly as you want.
Perfect Fit and Easy Installation
Designed with a standard
E26 base and BR30 shape, this bulb fits effortlessly into your existing recessed or can lighting fixtures. It’s ideal for living rooms, kitchens, and hallways where directional, soft-edged lighting is preferred.
Smart Features and Voice Control
- Voice Control: Compatible with Alexa and Google Assistant, you can easily turn the lights on/off, adjust brightness, or change colors using simple voice commands.
- Custom Scenes: Create and save multicolor lighting scenes in the Wyze app for quick access.
- Sun Match: Automatically adjusts color temperature throughout the day to support your natural circadian rhythm.
- Notifications & Automations: Use the bulb for visual alerts triggered by other Wyze devices, such as motion or entry sensors.
- Sleep Routines: Wake up or fall asleep to gradual light changes mimicking sunrise and sunset.
- Music Mode: Sync your lights to the beat of your favorite music when grouped with Wyze Light Strips.
Additional Details
- CRI Rating: 90+ for vibrant, true-to-life colors.
Not for use with dimmer switches.
- Available in 2-pack and 4-pack options for convenience and value.
Wyze Bulb Color: Versatile Smart Bulb for Every Room
While not a BR30 shape, the Wyze Bulb Color is a top-tier smart bulb offering
16 million colors and a bright output of up to
1100 lumens. It supports voice control with Alexa and Google Assistant, making it a versatile choice for various lighting needs.
Key Features
- Wide brightness range from 30lm to 1100lm.
- Custom presets and white light temperature control.
- 90+ CRI for accurate color rendering.
- Brilliant notifications and sleep routines.
- Music Mode for dynamic lighting effects.
- Grouping capabilities with other Wyze smart lighting products.
This bulb is perfect for standard fixtures and complements the BR30 bulbs in your home for a cohesive smart lighting setup.
Wyze Bulb White: Simple, Bright, and Smart
For those who prefer classic white lighting with smart controls, the Wyze Bulb White offers:
- Brightness from 30 to 800 lumens.
- Adjustable color temperature from 2700K (warm) to 6500K (cool).
- 90+ CRI for clear, natural light.
- Voice control with Alexa and Google Assistant.
- Compatibility with the Wyze app for scheduling, grouping, and vacation mode.
- Suitable for damp locations and long-lasting with a 25,000-hour life expectancy.
This bulb is ideal for bedrooms, bathrooms, and any space where warm or cool white light is preferred.
Alt: Bedroom illuminated with warm white smart bulb for sleep routines
Why Choose Wyze Smart Bulbs for Your Voice-Controlled Home?
"Transform your home lighting with Wyze smart bulbs that combine vibrant colors, customizable brightness, and seamless voice control for Alexa and Google Assistant."
Wyze smart bulbs are designed to integrate effortlessly into your smart home ecosystem. Whether you want to create immersive lighting scenes, automate your lights based on your daily routines, or control your bulbs hands-free with voice commands, Wyze offers reliable, affordable, and feature-rich options.
Summary of Features for BR30 Smart Bulbs with Voice Control
Feature | Wyze Bulb Color BR30 | Wyze Bulb Color | Wyze Bulb White |
Bulb Shape | BR30 | A19 | A19 |
Base Type | E26 | E26 | E26 |
Max Brightness (Lumens) | 950 | 1100 | 800 |
Color Options | 16 million colors + white temp | 16 million colors + white temp | White light (2700K-6500K) |
CRI Rating | 90+ | 90+ | 90+ |
Voice Control | Alexa, Google Assistant | Alexa, Google Assistant | Alexa, Google Assistant |
App Control | Wyze app | Wyze app | Wyze app |
Special Features | Sun Match, Music Mode, Scenes | Music Mode, Scenes | Sleep Routines, Vacation Mode |
Dimmer Compatibility | Not for dimmer switches | Yes | Yes |
Enhance Your Smart Home Lighting Today
Upgrade your home lighting with the Wyze Bulb Color BR30 for recessed fixtures, or complement it with Wyze Bulb Color and Wyze Bulb White for a complete smart lighting experience. Enjoy the convenience of voice control with Alexa and Google Assistant, and create the perfect ambiance for every moment.
Alt: Modern kitchen illuminated with smart BR30 recessed bulbs
What is the Wyze Bulb Color BR30 and what makes it unique?
The Wyze Bulb Color BR30 is a smart BR30-shaped bulb designed for recessed lighting fixtures. It stands out with its ability to produce 16 million ultra-accurate colors, a wide brightness range from 30 to 950 lumens, and seamless voice control compatibility with Alexa and Google Assistant. It also features customizable scenes, Sun Match for circadian rhythm support, and Music Mode for dynamic lighting effects.Are Wyze smart bulbs compatible with Alexa and Google Assistant?
Yes, all Wyze smart bulbs, including the Wyze Bulb Color BR30, Wyze Bulb Color, and Wyze Bulb White, are compatible with Alexa and Google Assistant. This allows you to control your lights using simple voice commands for turning on/off, adjusting brightness, or changing colors.Can I use Wyze Bulb Color BR30 in my existing recessed lighting fixtures?
Yes, the Wyze Bulb Color BR30 is specifically designed with a standard E26 base and BR30 shape, making it a perfect fit for most recessed or can lighting fixtures in living rooms, kitchens, and hallways.What smart features does the Wyze Bulb Color BR30 offer?
The Wyze Bulb Color BR30 offers a range of smart features, including voice control, customizable lighting scenes, Sun Match for automatic color temperature adjustment, visual notifications triggered by other Wyze devices, sleep routines for gradual light changes, and Music Mode for syncing lights to music.Is the Wyze Bulb Color BR30 compatible with dimmer switches?
No, the Wyze Bulb Color BR30 is not compatible with dimmer switches. It is designed to be dimmed and controlled via the Wyze app or through voice assistants like Alexa and Google Assistant.What is the CRI rating of Wyze smart bulbs and why is it important?
Wyze smart bulbs, including the BR30, Color, and White models, have a CRI (Color Rendering Index) rating of 90+. This high CRI ensures vibrant, true-to-life colors and natural-looking light in your home.What are the differences between Wyze Bulb Color BR30, Wyze Bulb Color, and Wyze Bulb White?
The Wyze Bulb Color BR30 is a BR30-shaped bulb for recessed fixtures with up to 950 lumens and 16 million colors. The Wyze Bulb Color is an A19-shaped bulb with up to 1100 lumens and also offers 16 million colors. The Wyze Bulb White is an A19-shaped bulb with up to 800 lumens, adjustable white temperature (2700K-6500K), and classic white lighting. All support voice control and app integration.Can I create custom lighting scenes with Wyze smart bulbs?
Yes, you can create and save custom multicolor lighting scenes using the Wyze app. This allows you to quickly set the perfect ambiance for any occasion and access your favorite lighting presets with ease.What is Sun Match and how does it work with Wyze Bulb Color BR30?
Sun Match is a feature that automatically adjusts the color temperature of your Wyze Bulb Color BR30 throughout the day to support your natural circadian rhythm. This helps promote better sleep and overall well-being by mimicking natural sunlight patterns.Are Wyze smart bulbs suitable for all rooms in the house?
Yes, Wyze smart bulbs are versatile and suitable for various rooms. The BR30 is ideal for recessed fixtures in living rooms, kitchens, and hallways. The Wyze Bulb Color and Wyze Bulb White are perfect for standard fixtures in bedrooms, bathrooms, and other spaces where you want customizable or classic white lighting.How long do Wyze smart bulbs last?
Wyze smart bulbs, including the Wyze Bulb White, are designed for longevity with a life expectancy of up to 25,000 hours, making them a reliable choice for everyday use.Can I group Wyze smart bulbs together for synchronized control?
Yes, you can group Wyze smart bulbs together in the Wyze app for synchronized control. This allows you to manage multiple bulbs at once, set scenes, and create cohesive lighting effects throughout your home.What is Music Mode on Wyze smart bulbs?
Music Mode is a feature that allows your Wyze smart bulbs to sync with the beat of your favorite music, creating dynamic and immersive lighting effects. This feature is available when grouping Wyze Bulb Color BR30 or Wyze Bulb Color with Wyze Light Strips.Are Wyze smart bulbs energy efficient?
Yes, Wyze smart bulbs are energy efficient, offering adjustable brightness and long-lasting LED technology to help reduce energy consumption while providing high-quality lighting.
