Discover the Wyze Battery Cam Pro: The Ultimate Multifunctional Camera with Local Recording for Property Monitoring
For those interested in a multifunctional camera with local recording capability for property monitoring, the Wyze Battery Cam Pro is a top recommendation. Here’s why it excels:
  • 2.5K HDR Video Resolution : Provides clear and detailed footage, ensuring you capture every important moment.
  • Wire-Free and No Hub Required : Enjoy a hassle-free, wireless installation without additional equipment.
  • Integrated Spotlight & Siren : Enhances security with built-in deterrent features.
  • Radar + PIR Motion Detection : Utilizes advanced motion detection technology for accurate alerts.
  • Removable, Rechargeable Battery Packs : Offers up to 6 months of operation per charge, with the option for local recording using a MicroSD card.
  • IP65 Weatherproof : Designed to withstand various weather conditions for outdoor use.
  • 2.4 & 5GHz WiFi Support : Provides flexible connectivity options.
For customers looking for a solution with uninterrupted, high-capacity, wired recording, consider comparing with Wyze Cam v4.
Feature Wyze Cam v4 Wyze Battery Cam Pro
Image Wyze Cam v4 Wyze Battery Cam Pro
Video Resolution 2.5K QHD (2560 x 1440) 2.5K HDR (2560 x 1440)
Local Storage microSD card up to 512 GB microSD card up to 256 GB
24/7 Local Recording Yes (with microSD card) Yes (with microSD card)
Power Source Wired (requires power adapter) Removable, rechargeable battery
Battery Life N/A (wired) Up to 6 months per charge
Weather Resistance IP65 IP65
Night Vision Enhanced Color Night Vision + IR IR Night Vision + White LEDs
Motion Detection Yes (zones, person detection) Radar + PIR Motion Detection
Smart Integrations Alexa, Google Assistant, IFTTT Alexa, Google Assistant, IFTTT
WiFi Support 2.4 GHz & Wi‑Fi 6 2.4 GHz & 5 GHz
Time Lapse Yes (with microSD card) N/A
Can you tell me more about the features of the Wyze Battery Cam Pro? How does the motion detection work on the Wyze Battery Cam Pro? Do you have any ongoing sales or promotions for the Wyze Battery Cam Pro?
