Wyze Cam v3 Person Detection: Advanced Security with Wyze Cam v4 Series
When it comes to reliable person detection and home security, the Wyze Cam v4 series offers cutting-edge technology designed to keep your property safe and monitored with precision. Whether you want indoor or outdoor coverage, Wyze provides versatile options with enhanced features like 2.5K QHD resolution, color night vision, and smart motion detection that includes person detection capabilities.
Wyze Cam v4: The Ultimate Smart Security Camera
Superior Video Quality and Person Detection
The Wyze Cam v4 is engineered with a CMOS Starlight Sensor and delivers crystal-clear 2.5K QHD (2560x1440) video resolution. This high-definition clarity ensures that person detection is accurate and detailed, helping you distinguish between people, pets, and other motion triggers.
- Field of View: Wide 115.8° diagonal, 98.5° horizontal, and 53.1° vertical coverage for broad surveillance.
- Night Vision: Enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) to detect people even in low light.
- Motion Detection Zones: Customize detection areas to reduce false alerts.
- Two-Way Audio & Siren: Communicate directly or deter intruders with a built-in 99dB siren.
- Weather Resistance: Rated IP65, suitable for outdoor use withstanding temperatures from -4°F to 122°F.
Smart Home Integration and Connectivity
Wyze Cam v4 supports both 2.4 GHz and Wi-Fi 6 networks, ensuring fast and stable connections. It integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing voice control and automation.
Flexible Mounting Options
Mount your Wyze Cam v4 on walls, ceilings, or use the magnetic adhesive mount for easy installation indoors or outdoors.
Wyze Cam v4 Outdoor Bundle: Enhanced Outdoor Security
All-in-One Outdoor Protection
The Wyze Cam v4 Outdoor Bundle includes everything you need for robust outdoor security:
- 2.5K QHD Resolution: Crystal-clear video with Wide Dynamic Range (WDR) for balanced lighting.
- Enhanced Color Night Vision: See vivid colors even at night.
- Motion-Activated Spotlight: Automatically lights up when motion is detected, improving person detection accuracy.
- 24/7 Local Recording: Continuous recording with included 128GB microSD card.
- Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
- Compatibility: Works with Alexa and Google Assistant for smart home control.
- Power Source: Wired for uninterrupted power supply.
- Outdoor Durability: Designed specifically for outdoor environments.
This bundle is perfect for those who want a comprehensive outdoor security solution with person detection that alerts you instantly and clearly.
Alt text: Family enjoying outdoor security with Wyze Cam v4 Outdoor Bundle
Cam v4 + Lamp Socket v2 Bundle: Power and Smart Lighting Combined
Convenient Power Solution for Wyze Cams
The Cam v4 + Lamp Socket v2 Bundle is an innovative way to power your Wyze Cam v4 without needing a traditional outlet. This bundle is ideal for outdoor lighting fixtures and offers:
- Motion-Activated Lights: Automatically turn on lights when motion is detected, enhancing person detection.
- Dusk to Dawn Scheduling: Lights operate automatically based on ambient light.
- Linkability: Connect multiple lamp sockets for extended coverage.
- Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.
This solution is perfect for users looking to integrate smart lighting with their Wyze Cam v4 for improved security and convenience.
Why Choose Wyze Cam v4 for Person Detection?
Wyze Cam v4 stands out with its advanced person detection technology, high-resolution video, and smart home compatibility, making it a top choice for anyone seeking reliable and affordable home security.
- Accurate Person Detection: Reduces false alarms by distinguishing people from other movements.
- High-Quality Video: 2.5K QHD resolution ensures clear identification.
- Night Vision: Enhanced color night vision helps you see details even in darkness.
- Smart Alerts: Receive instant notifications on your phone.
- Versatile Installation: Indoor or outdoor use with weatherproof design.
Summary of Wyze Cam v4 Person Detection Products
| Product Name | Key Features | Price (USD) |
| Wyze Cam v4 | 2.5K QHD, Color Night Vision, IP65, Alexa/Google | $100.00 |
| Wyze Cam v4 Outdoor Bundle | Wired, Spotlight, 24/7 Local Recording, Wi-Fi 6 | $69.99 |
| Cam v4 + Lamp Socket v2 Bundle | Power via lamp socket, motion-activated lights | $49.96 |
Enhance your home security today with Wyze Cam v4 and its powerful person detection features, ensuring peace of mind day and night.
What is person detection on Wyze Cam v4 and how does it work?
Person detection on Wyze Cam v4 uses advanced smart motion detection technology to accurately identify people in its field of view. The camera distinguishes between people, pets, and other motion triggers, reducing false alarms and ensuring you receive relevant security alerts.Does Wyze Cam v4 offer high-definition video quality?
Yes, Wyze Cam v4 features a CMOS Starlight Sensor and delivers crystal-clear 2.5K QHD (2560x1440) video resolution. This high-definition clarity ensures detailed footage for accurate person detection and easy identification.Can Wyze Cam v4 be used outdoors?
Absolutely. Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. It can withstand temperatures from -4°F to 122°F, ensuring reliable performance in various weather conditions.Does Wyze Cam v4 have color night vision?
Yes, Wyze Cam v4 is equipped with enhanced color night vision, featuring 4 IR LEDs and 2 white spotlight LEDs. This allows the camera to capture vivid, full-color footage even in low-light or nighttime conditions.What smart home systems are compatible with Wyze Cam v4?
Wyze Cam v4 integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, a 128GB microSD card for 24/7 local recording, a motion-activated spotlight, and all necessary accessories for outdoor installation. It is designed for robust outdoor security with enhanced person detection.How does the Cam v4 + Lamp Socket v2 Bundle work?
The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 through a standard outdoor lighting fixture. It features motion-activated lights, dusk to dawn scheduling, and the ability to link multiple lamp sockets for extended coverage, enhancing both lighting and security.Does Wyze Cam v4 support continuous recording?
Yes, with the Wyze Cam v4 Outdoor Bundle, you can enjoy 24/7 continuous local recording using the included 128GB microSD card, ensuring you never miss important events.What connectivity options does Wyze Cam v4 offer?
Wyze Cam v4 supports both 2.4 GHz Wi-Fi and Wi-Fi 6 networks, providing fast and stable wireless connections for reliable video streaming and smart home integration.How can I install Wyze Cam v4?
Wyze Cam v4 offers flexible mounting options, including wall, ceiling, and magnetic adhesive mounts. This makes it easy to install the camera indoors or outdoors according to your security needs.What are the main benefits of Wyze Cam v4 person detection?
Wyze Cam v4 person detection provides accurate alerts by distinguishing people from other motion, reduces false alarms, offers high-quality 2.5K QHD video, enhanced color night vision, and instant smart notifications to your phone.Is Wyze Cam v4 affordable compared to other security cameras?
Yes, Wyze Cam v4 offers advanced person detection, high-resolution video, and smart home compatibility at a competitive price, making it a cost-effective choice for reliable home security.
