Buy Wyze Cam OG Telephoto & Telephoto Security Cameras with Customized Detection Zones
When it comes to securing your home or business with precision and clarity, Wyze offers cutting-edge telephoto security cameras designed to meet your needs. The
Wyze Cam OG Telephoto stands out as a top choice for those seeking enhanced zoom capabilities combined with smart detection features. Additionally, the
Wyze Cam v4 Outdoor Bundle provides advanced motion detection zones and vibrant night vision, perfect for customized security setups.
Explore the detailed specs and benefits of these cameras below to find the perfect fit for your security needs.
Wyze Cam OG Telephoto: Precision Zoom Meets Smart Security
Key Features & Specifications
- 3x Telephoto Lens: Capture distant details clearly with a narrow field of view (27° diagonal), perfect for focused surveillance.
- 1080p Full HD Video: Crisp video quality with 20 FPS during the day and 10 FPS at night ensures you never miss a moment.
- Improved 2-Way Audio: Enhanced microphone and speaker with noise and echo cancellation for clear communication.
- Night Vision: Equipped with 4 IR LEDs (850nm) for reliable night monitoring.
- Customizable Mounting: Flexible installation options including stand, wall mount, and ceiling mount.
- Local Storage Support: Up to 256GB microSD card compatibility for extensive local video storage.
- Weather Resistant: Rated IP65 for indoor/outdoor use, capable of operating in temperatures from -4°F to 131°F.
- Fast Notifications: 3x faster alerts keep you informed instantly.
- Connectivity & Integration: Supports 2.4 GHz Wi-Fi and integrates seamlessly with Alexa, Google Assistant, and IFTTT.
Why Choose Wyze Cam OG Telephoto?
This camera is ideal for users who want to zoom in on specific areas such as driveways, gates, or distant entry points without sacrificing video quality. Its telephoto lens combined with quick live streaming and smart audio makes it a versatile security solution for both indoor and outdoor environments.
Experience clear, focused security with Wyze Cam OG Telephoto.
Wyze Cam v4 Outdoor Bundle: Customized Detection Zones & Enhanced Night Vision
Advanced Security Features
- 2.5K QHD Resolution: Ultra-clear video with 2560x1440 pixels for detailed monitoring.
- Enhanced Color Night Vision: See vibrant colors even in low light, thanks to advanced sensor technology.
- Motion Detection Zones: Customize detection areas to reduce false alerts and focus on critical zones.
- Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring intruders.
- 24/7 Local Recording: Continuous recording with included 128GB microSD card.
- Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
- Multiple Mounting Options: Includes stand, wall mount, ceiling mount, and magnetic wall mount for versatile placement.
- Smart Home Integration: Compatible with Alexa and Google Assistant for voice control and automation.
- Weatherproof Design: IP65 rating ensures durability in harsh outdoor conditions.
Ideal Use Cases
Perfect for homeowners who want a comprehensive outdoor security solution with the ability to tailor motion detection zones. The enhanced night vision and spotlight provide peace of mind around the clock, while the high-resolution video captures every detail.
Why Customized Detection Zones Matter
Customized detection zones allow you to define specific areas within the camera’s field of view where motion triggers alerts. This feature is crucial for:
- Minimizing false alarms caused by irrelevant movements like passing cars or animals.
- Focusing on vulnerable entry points such as doors, windows, or driveways.
- Enhancing battery life and storage efficiency by recording only relevant events.
Both the Wyze Cam OG Telephoto and Wyze Cam v4 Outdoor Bundle support this feature, making them smart choices for tailored security.
Summary: Which Wyze Telephoto Security Camera is Right for You?
Feature | Wyze Cam OG Telephoto | Wyze Cam v4 Outdoor Bundle |
Video Resolution | 1080p Full HD | 2.5K QHD (2560x1440) |
Telephoto Zoom | 3x Telephoto Lens | Wide-angle with motion zones |
Night Vision | IR LEDs (850nm) | Enhanced Color Night Vision + Spotlight |
Motion Detection Zones | No (focus on telephoto zoom) | Yes |
Audio | Improved 2-way with noise cancellation | Improved 2-way audio |
Storage | Up to 256GB microSD | 128GB microSD included |
Weather Resistance | IP65 | IP65 |
Smart Home Integration | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant |
Price Range | $25.98 - $58.98 (1 or 2 pack) | $69.99 (bundle with accessories) |
Choose the
Wyze Cam OG Telephoto if you need focused zoom capabilities with fast notifications and versatile mounting. Opt for the
Wyze Cam v4 Outdoor Bundle if you want higher resolution, customizable detection zones, and enhanced night vision for comprehensive outdoor security.
"Secure your home with precision and clarity — Wyze telephoto cameras deliver smart, customizable surveillance tailored to your needs."
Product Highlights
Enhance Your Security Setup Today
Investing in Wyze telephoto security cameras means gaining peace of mind with smart, reliable, and customizable surveillance. Whether you prioritize zoom clarity or advanced detection zones, Wyze has the perfect camera to protect your property day and night.
Images used in this page showcase lifestyle settings of Wyze cameras installed outdoors, emphasizing real-world security applications.
What is the Wyze Cam OG Telephoto and what makes it unique?
The Wyze Cam OG Telephoto is a security camera featuring a 3x telephoto lens, allowing you to capture distant details with a narrow 27° diagonal field of view. It offers 1080p Full HD video, improved 2-way audio with noise and echo cancellation, night vision, and flexible mounting options. Its standout feature is the ability to focus on specific areas like driveways or gates without sacrificing video quality.What are the key features of the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle offers 2.5K QHD resolution for ultra-clear video, enhanced color night vision, customizable motion detection zones, a motion-activated spotlight, 24/7 local recording with a 128GB microSD card, Wi-Fi 6 support, multiple mounting options, smart home integration with Alexa and Google Assistant, and an IP65 weatherproof design.How do customized detection zones work on Wyze security cameras?
Customized detection zones allow you to define specific areas within the camera’s field of view where motion will trigger alerts. This helps minimize false alarms from irrelevant movements, focus on vulnerable entry points, and improve battery life and storage efficiency by recording only relevant events. The Wyze Cam v4 Outdoor Bundle supports this feature.Which Wyze camera is best for focused zoom and distant surveillance?
The Wyze Cam OG Telephoto is best for focused zoom and distant surveillance. Its 3x telephoto lens and narrow field of view make it ideal for monitoring specific areas such as driveways, gates, or distant entry points with clear, detailed video.Does the Wyze Cam OG Telephoto support local video storage?
Yes, the Wyze Cam OG Telephoto supports local video storage with compatibility for microSD cards up to 256GB, allowing for extensive local recording.Is the Wyze Cam v4 Outdoor Bundle suitable for outdoor use?
Yes, the Wyze Cam v4 Outdoor Bundle is designed for outdoor use with an IP65 weatherproof rating, ensuring durability in harsh weather conditions. It also features enhanced night vision and a motion-activated spotlight for comprehensive outdoor security.What smart home integrations are available with Wyze security cameras?
Both the Wyze Cam OG Telephoto and Wyze Cam v4 Outdoor Bundle integrate with Alexa and Google Assistant for voice control and automation. The OG Telephoto also supports IFTTT for additional smart home connectivity.What is the video resolution difference between Wyze Cam OG Telephoto and Wyze Cam v4 Outdoor Bundle?
The Wyze Cam OG Telephoto records in 1080p Full HD, while the Wyze Cam v4 Outdoor Bundle offers higher 2.5K QHD resolution (2560x1440 pixels) for more detailed video monitoring.Can I use Wyze security cameras for both indoor and outdoor surveillance?
Yes, both the Wyze Cam OG Telephoto and Wyze Cam v4 Outdoor Bundle are rated IP65 for weather resistance, making them suitable for both indoor and outdoor surveillance applications.How do I choose between the Wyze Cam OG Telephoto and the Wyze Cam v4 Outdoor Bundle?
Choose the Wyze Cam OG Telephoto if you need focused zoom capabilities, fast notifications, and versatile mounting for specific surveillance areas. Opt for the Wyze Cam v4 Outdoor Bundle if you want higher resolution, customizable detection zones, enhanced night vision, and a comprehensive outdoor security solution.
