Indoor Adhesive LED Light Strips with Alexa & Google Control
Indoor Adhesive LED Light Strips with Alexa & Google Voice Control
Transform your indoor spaces with vibrant, customizable LED light strips that respond effortlessly to your voice commands. Whether you want to set the perfect ambiance for movie nights, brighten up your workspace, or add a splash of color to your home décor, these smart LED light strips with Alexa and Google Assistant compatibility are your ideal solution. Explore the best indoor adhesive LED light strips designed for seamless integration with your smart home ecosystem.
Wyze Light Strip: Brilliant Accent Lighting Made Simple
Key Features
  • 16 Million Colors: Choose from a vast palette to color your world exactly how you want it.
  • Easy Installation: Just peel, stick, and plug in anywhere indoors for instant accent lighting.
  • Music Mode: Lights sync to your favorite tunes using the built-in microphone, perfect for parties or relaxing evenings.
  • Sun Match: Automatically adjusts color temperature to match the natural light cycle, helping you wake, work, or wind down naturally.
  • Voice Control: Compatible with Alexa and Google Assistant for hands-free lighting adjustments.
  • Vacation Mode & Sleep Routines: Simulate presence when away or create gentle wake-up and sleep lighting schedules.
  • Timers & Automations: Set schedules or automate lighting with the Wyze app.
Available Sizes & Pricing
  • 16.4 Feet – $19.99
  • 32.8 Feet – $35.99
The Wyze Light Strip is perfect for adding subtle, colorful accents behind TVs, under cabinets, or along shelves.
Wyze Light Strip in cozy living room Alt: Cozy indoor living room with Wyze Light Strip accent lighting
Wyze Light Strip Pro: Advanced Multi-Color Segment Control
Why Choose Wyze Light Strip Pro?
  • Multi-Color Segment Control: Unlike standard strips, it can display up to 16 different colors simultaneously for dynamic, eye-catching effects.
  • Protective Epoxy Coating: Durable and flexible with a refined finish, ideal for long-term indoor use.
  • Trimmable Design: Customize the length precisely to fit your space.
  • Music Mode & Sun Match: Same smart features as the standard strip, syncing lights to music and natural light cycles.
  • Voice Control: Fully compatible with Alexa and Google Assistant.
  • Vacation Mode & Sleep Routines: Enhance your smart home automation with personalized lighting schedules.
  • Timers & Automations: Easily set up through the Wyze app.
  • 16.4 Feet – $29.99
  • 32.8 Feet – $44.99
Perfect for creating vibrant, multi-hued lighting effects in living rooms, gaming setups, or behind sofas.
Wyze Light Strip Pro behind sofa Alt: Modern living room with Wyze Light Strip Pro behind sofa
Wyze Light Party & Smart Lighting Kits: Complete Smart Lighting Solutions
Wyze Light Party
  • 16 Million Colors & Tunable White: Adjust color and brightness effortlessly for any occasion.
  • Includes: Wyze Light Strip (32.8 ft) plus various Wyze Bulb Color packs.
  • Voice & App Control: Compatible with Alexa, Google Assistant, and IFTTT.
  • Ideal For: Those who want a full smart lighting setup combining bulbs and strips for layered lighting effects.
Smart Lighting Kits with Bulb Color BR30 + Light Strip Pro Bundle
  • All-in-One Bundle: Combines the Wyze Bulb Color BR30 with the advanced Light Strip Pro.
  • Bulb Specs: 30-950 lumens, 1800K-6500K color temperature, 25,000 hours lifespan.
  • Light Strip Pro Specs: 16 million colors, 16 customizable zones, indoor use.
  • Connectivity: Wi-Fi (2.4 GHz) and Bluetooth for seamless control.
  • Voice Assistant Integration: Works with Alexa and Google Assistant.
  • Perfect For: Users seeking a versatile, customizable lighting experience with both bulbs and strips.
Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle
  • Similar to the BR30 bundle but with Wyze Bulb Color (A19 style) and 16.4 ft Light Strip Pro.
  • Offers brilliant LED accent lighting with full smart control.
These kits provide a comprehensive smart lighting upgrade for your home, combining the flexibility of LED strips with the convenience of smart bulbs.
Why Choose Wyze Indoor LED Light Strips with Voice Control?
"Your voice is now your light switch."
Control brightness, color, and power with simple commands to Alexa or Google Assistant.
  • Easy Adhesive Installation: Stick the strips anywhere indoors without hassle.
  • Customizable Ambiance: From subtle warm whites to vibrant RGB colors.
  • Smart Automations: Set timers, routines, and vacation modes for convenience and security.
  • Music Sync: Turn any room into a party zone with lights that dance to your music.
  • Energy Efficient: Low power consumption with long-lasting LEDs.
  • App Control: Full control and customization through the Wyze app on Android and iOS.
Conclusion
For anyone looking to enhance their indoor environment with smart, adhesive LED light strips that integrate seamlessly with Alexa and Google voice control, Wyze offers a range of products tailored to your needs. From the affordable and versatile Wyze Light Strip to the feature-rich Wyze Light Strip Pro and comprehensive smart lighting kits, you can create the perfect lighting atmosphere for every room and occasion.
Product Highlights Summary
  • Wyze Light Strip: Easy, colorful accent lighting with voice control.
  • Wyze Light Strip Pro: Multi-color segment control with advanced effects.
  • Wyze Light Party: Complete lighting bundles with bulbs and strips.
  • Smart Lighting Kits: Bundles combining bulbs and Light Strip Pro for ultimate customization.
Enhance your home lighting experience today with Wyze smart LED light strips — the perfect blend of style, technology, and convenience.
Wyze Bulb Cam lifestyle Alt: Modern home interior with smart lighting and security integration
SEO Keywords Included
Indoor LED light strip, adhesive LED light strip, smart LED strip Alexa, Google voice control LED strip, Wyze Light Strip, Wyze Light Strip Pro, smart lighting kit, multi-color LED strip, voice-controlled lighting, smart home lighting.
FeatureWyze Light StripWyze Light Strip ProWyze Light PartySmart Lighting Kit - Bulb Color BR30 + Light Strip Pro BundleSmart Lighting Kit - Bulb Color + Light Strip Pro Bundle
TypeConnected HomeSmart LightingConnected HomeSmart LightingSmart Lighting
Size / Length16.4 ft, 32.8 ft16.4 ft, 32.8 ftLight Strip: 32.8 ftLight Strip Pro: 16.4 ftLight Strip Pro: 16.4 ft
Price Range$19.99 - $35.99$29.99 - $44.99$59.98 - $83.97 (bundle styles)$53.98 - $77.97 (bundle with BR30 bulbs)$52.98 - $74.97 (bundle with Bulb Color)
Color Capability16 million colors, one color per strip16 million colors, up to 16 colors per strip (multi-color segment control)16 million colors (RGB + tunable white)16 million colors (Light Strip Pro multicolor)16 million colors (Light Strip Pro multicolor)
Lighting EffectsBasic lighting effectsAdvanced lighting effectsCustomizable color and brightnessAdvanced lighting effectsAdvanced lighting effects
Protective CoatingNo epoxy coatingClear epoxy coatingNot specifiedClear epoxy coating (Light Strip Pro)Clear epoxy coating (Light Strip Pro)
Music ModeYes, built-in microphoneYes, built-in microphoneIncludedIncludedIncluded
Sun MatchYesYesNot specifiedYesYes
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, BluetoothAlexa, Google Assistant, IFTTT
Vacation ModeYesYesNot specifiedYesYes
Sleep RoutinesYesYesNot specifiedYesYes
Timers & AutomationsYesYesNot specifiedYesYes
Customizable Zones1 (one color per strip)16 (multi-color segments)116 (Light Strip Pro)16 (Light Strip Pro)
Included ItemsWyze Light Strip onlyWyze Light Strip Pro onlyBundles include Light Strip 32ft + bulbs (varies by style)1x Wyze Bulb Color BR30, 1x Light Strip ProWyze Bulb Color 2 or 4 Pack, 1x Light Strip Pro
Bulb IncludedNoNoYes (varies by bundle style)Yes (BR30 bulbs)Yes (Bulb Color)
Bulb TypeN/AN/ABR30, Bulb Color (depending on bundle)BR30Bulb Color
Bulb LumensN/AN/A30 - 950 lumens (BR30), 30 - 1100 lumens (A19 Bulb Color)30 - 950 lumens (BR30)30 - 1100 lumens
Bulb Color TemperatureN/AN/A1800K - 6500K1800K - 6500K1800K - 6500K
WarrantyNot specified1 Year1 Year1 Year1 Year
UsageIndoorIndoorIndoorIndoorIndoor
ConnectivityWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, Bluetooth
Trimmable DesignNot specifiedYesNot specifiedYesYes
Cuttable SectionsNot specifiedYesNot specifiedYesYes
What are Wyze indoor adhesive LED light strips?Wyze indoor adhesive LED light strips are smart lighting solutions designed for easy installation and seamless integration with your smart home. They offer customizable colors, voice control with Alexa and Google Assistant, and can be used to enhance the ambiance of any indoor space.
How do I control Wyze LED light strips with Alexa or Google Assistant?Wyze LED light strips are fully compatible with Alexa and Google Assistant. Simply connect the strips to your Wi-Fi network, link your Wyze account to your preferred voice assistant, and use voice commands to turn lights on or off, adjust brightness, or change colors.
What is the difference between Wyze Light Strip and Wyze Light Strip Pro?The Wyze Light Strip offers easy accent lighting with 16 million colors and basic smart features. The Wyze Light Strip Pro adds advanced multi-color segment control, allowing up to 16 different colors to display simultaneously, and features a protective epoxy coating for added durability.
Can Wyze LED light strips sync with music?Yes, both Wyze Light Strip and Wyze Light Strip Pro feature a Music Mode. The built-in microphone allows the lights to sync with your favorite tunes, creating dynamic lighting effects perfect for parties or relaxing evenings.
Are Wyze LED light strips easy to install?Absolutely. Wyze LED light strips feature an adhesive backing for simple peel-and-stick installation. Just stick the strip to any clean indoor surface, plug it in, and set it up using the Wyze app.
What sizes are available for Wyze Light Strip and Light Strip Pro?Both Wyze Light Strip and Wyze Light Strip Pro are available in 16.4 feet and 32.8 feet lengths, making them suitable for a variety of indoor applications.
Can I customize the length of Wyze Light Strip Pro?Yes, the Wyze Light Strip Pro features a trimmable design, allowing you to cut the strip to the exact length needed for your space.
What is Sun Match on Wyze LED light strips?Sun Match is a feature that automatically adjusts the color temperature of your Wyze LED light strips to match the natural light cycle, helping you wake up, work, or wind down more naturally.
Do Wyze LED light strips support timers and automations?Yes, you can set schedules, timers, and automations for your Wyze LED light strips using the Wyze app. This allows for convenient routines, vacation mode, and sleep lighting schedules.
What is included in the Wyze Light Party and Smart Lighting Kits?The Wyze Light Party kit includes a 32.8 ft Wyze Light Strip and Wyze Bulb Color packs for a complete smart lighting setup. Smart Lighting Kits bundle Wyze Bulb Color (BR30 or A19) with the Light Strip Pro, offering versatile and customizable lighting for your home.
Are Wyze LED light strips energy efficient?Yes, Wyze LED light strips use energy-efficient LEDs with low power consumption and a long lifespan, making them an eco-friendly choice for smart home lighting.
Can I control Wyze LED light strips with my smartphone?Yes, you can control all Wyze LED light strips using the Wyze app on Android and iOS devices. The app allows you to adjust colors, brightness, set schedules, and create automations.
Where can I use Wyze indoor adhesive LED light strips?Wyze indoor adhesive LED light strips are perfect for accent lighting behind TVs, under cabinets, along shelves, in living rooms, gaming setups, or anywhere you want to add customizable smart lighting indoors.
Can you tell me more about the installation process for the Wyze Light Strip?What are the differences between the Wyze Light Strip and the Wyze Light Strip Pro?Do you have any ongoing sales or promotions for the Wyze Light Strip?
