Bluetooth Earbuds with Passive Noise Reduction for Clear Sound
Bluetooth Earbuds with Passive Noise Reduction for Clear Music Playback
When it comes to enjoying music with crystal-clear sound and minimal distractions, Bluetooth earbuds with passive noise reduction are a must-have. These earbuds block out ambient noise naturally through their design, allowing you to immerse yourself in your favorite tunes without interruption. Below, we highlight the top product that fits your need for Bluetooth earbuds featuring passive noise reduction and exceptional audio clarity.
Wyze Noise-Cancelling Headphones: Your Ultimate Audio Companion
Exceptional Noise Reduction Technology
Experience music like never before with the Wyze Noise-Cancelling Headphones. These headphones combine both active and passive noise reduction to deliver an immersive listening experience. While active noise cancellation (ANC) reduces up to 40dB of outside noise using four noise-cancelling microphones and an ultra-fast processor, the over-ear design provides excellent passive noise isolation by physically blocking ambient sounds.
"You’ll think the rest of the world is standing still."
Superior Sound Quality
Equipped with dual 40mm TPU composite diaphragm drivers, these headphones deliver deep bass, stable mids, and crisp highs across a wide frequency range up to 38kHz. Whether you’re listening to your favorite playlist, podcasts, or movies, the sound is rich and detailed, transporting you to the front row of a live concert.
Comfortable and Intuitive Design
  • Memory Foam Earpads: Soft, responsive memory foam cushions your ears for fatigue-free wear during long listening sessions.
  • Wear Detection: Audio automatically pauses when you remove the headphones and resumes when you put them back on.
  • Touch Controls: Easily manage calls, volume, playback, and voice assistants with intuitive touch gestures on the earcups.
  • Transparency Mode: Quickly amplify outside sounds without removing your headphones, perfect for catching announcements or conversations.
Connectivity and Smart Features
  • Bluetooth 5.0: Enjoy a stable wireless connection with the ability to connect to two devices simultaneously.
  • Voice Assistant Integration: Built-in Amazon Alexa and compatibility with Siri, Google Assistant, and Bixby let you control music, check weather, and more using just your voice.
  • Dual Voice-Isolating Microphones: Ensure crystal-clear calls even in noisy environments.
Available Variants and Pricing
  • Colors: Black, White
  • Styles: With or without travel case
  • Price Range: $89.99 - $99.99
Wyze Noise-Cancelling Headphones Lifestyle Enjoy music anywhere with Wyze Noise-Cancelling Headphones
Why Choose Wyze Noise-Cancelling Headphones for Passive Noise Reduction?
  • Combines active and passive noise reduction for superior sound isolation.
  • High-fidelity audio with dual drivers for a balanced and immersive experience.
  • Comfortable design for extended wear.
  • Smart features including voice assistant support and wear detection.
  • Reliable Bluetooth 5.0 connectivity with multi-device pairing.
If you are searching specifically for Bluetooth earbuds or headphones that offer passive noise reduction alongside clear music playback, the Wyze Noise-Cancelling Headphones stand out as the best choice in this category.
Summary
For clear, uninterrupted music playback with effective passive noise reduction, the Wyze Noise-Cancelling Headphones deliver premium sound quality, comfort, and smart features. Whether commuting, working, or relaxing, these headphones help you focus on your music by minimizing outside distractions naturally and electronically.
FeatureWyze Noise-Cancelling Headphones (New)Wyze Noise-Cancelling Headphones (Refurbished)
Color VariantsBlack, WhiteBlack
Style VariantsNo Travel Case, With Travel CaseNo Travel Case
Price$80.99 - $99.99$34.99
Noise Cancellation Type40dB Quick On/Off Hybrid Active Noise Cancellation (ANC)Hybrid Active Noise Cancellation
Noise Cancellation Depth40 dB40 dB
Microphones6 total (4 for noise cancellation, 2 for voice pickup)6 total (4 for noise cancellation, 2 for voice pickup)
Battery LifeUp to 20 hoursUp to 20 hours
Charging MethodUSB Type-CUSB Type-C
Charging TimeAround 2 hoursAround 2 hours
Quick Charge10 minutes for up to 4 hours playback10 minutes for up to 4 hours playback
Bluetooth VersionBluetooth 5.0Bluetooth 5.0
Bluetooth Range33 ft (10 m)33 ft (10 m)
Speaker Driver DimensionsDual 40 mm dome type drivers40 mm dome type driver
Frequency Response (Bluetooth)20 - 20,000 Hz20 - 20,000 Hz
Frequency Response (Line-in)20 - 38,000 Hz20 - 38,000 Hz
Sensitivity113 dB/mW @1 kHz113 dB/mW @1 kHz
Total Harmonic Distortion<0.5%<0.5%
Impedance32 Ω32 Ω
Ear Cushion MaterialMemory foam covered in protein leatherMemory foam covered in protein leather
Headband MaterialMultilayer composite of stainless steel, EVA foam, and plastic, covered in protein leatherSame
Earcup Cover MaterialABS plastic and PC with special coating for touch gesturesSame
Weight9.9 oz9.9 oz
Included AccessoriesHeadphones, Soft Carrying Pouch, USB Type-C Cable, Audio Cable, Quick Start GuideSame
Special FeaturesTransparency Mode, Wear Detection, Quick Conversations, Customizable EQ via Wyze app, Voice Assistant Integration (Alexa, Google Assistant, Siri, Bixby), Dual voice-isolating microphones, Touch controlsSame
Return Policy30-day hassle-free returnsFinal sale, no returns
What are the key features of Wyze Noise-Cancelling Headphones?Wyze Noise-Cancelling Headphones offer both active and passive noise reduction, dual 40mm TPU composite diaphragm drivers for high-fidelity sound, memory foam earpads for comfort, wear detection, intuitive touch controls, transparency mode, Bluetooth 5.0 connectivity, voice assistant integration, and dual voice-isolating microphones for clear calls.
How does passive noise reduction work in Wyze Noise-Cancelling Headphones?Passive noise reduction in Wyze Noise-Cancelling Headphones is achieved through their over-ear design and memory foam earpads, which physically block out ambient sounds, allowing you to enjoy music with fewer distractions.
Do Wyze Noise-Cancelling Headphones support Bluetooth connectivity?Yes, Wyze Noise-Cancelling Headphones feature Bluetooth 5.0, providing a stable wireless connection and the ability to pair with two devices simultaneously.
Can I use voice assistants with Wyze Noise-Cancelling Headphones?Yes, Wyze Noise-Cancelling Headphones have built-in Amazon Alexa and are compatible with Siri, Google Assistant, and Bixby, allowing you to control music, check the weather, and more using your voice.
What is the price range for Wyze Noise-Cancelling Headphones?Wyze Noise-Cancelling Headphones are available in the price range of $89.99 to $99.99, depending on the selected style and whether you choose a travel case.
Are Wyze Noise-Cancelling Headphones comfortable for long listening sessions?Yes, the headphones feature soft memory foam earpads designed for fatigue-free wear, making them comfortable for extended use.
What colors and styles are available for Wyze Noise-Cancelling Headphones?Wyze Noise-Cancelling Headphones are available in Black and White, with options to purchase with or without a travel case.
How does the wear detection feature work on Wyze Noise-Cancelling Headphones?The wear detection feature automatically pauses audio when you remove the headphones and resumes playback when you put them back on, providing a seamless listening experience.
What makes Wyze Noise-Cancelling Headphones ideal for clear music playback?With dual 40mm drivers, advanced noise reduction technology, and a wide frequency range up to 38kHz, Wyze Noise-Cancelling Headphones deliver rich, detailed, and immersive sound for clear music playback.
Do Wyze Noise-Cancelling Headphones have a transparency mode?Yes, the headphones include a transparency mode that allows you to amplify outside sounds without removing the headphones, making it easy to hear announcements or conversations.
What are the key features of the Wyze Noise-Cancelling Headphones?Can you tell me more about the comfort features of the Wyze Noise-Cancelling Headphones?Are there any ongoing promotions or discounts for the Wyze Noise-Cancelling Headphones?
