Affordable Refurbished Wyze Cams with Full Color Night Vision
Affordable Refurbished Wyze Cams with Full Color Night Vision for Indoor and Outdoor Security
Looking for an affordable, reliable security camera that offers full color night vision for both indoor and outdoor use? Wyze offers a range of refurbished cameras that combine advanced features, weather resistance, and smart home compatibility — all at budget-friendly prices. Whether you want crystal-clear video, motion-activated lighting, or 360° coverage, Wyze has you covered.
Wyze Cam v4: The Ultimate Affordable Security Camera with Enhanced Color Night Vision
Wyze Cam v4 is the clearest and most advanced Wyze camera yet, delivering 2.5K QHD resolution and enhanced color night vision that reveals stunning details even in low light. This camera is perfect for both indoor and outdoor security thanks to its IP65 weather resistance rating.
Key Features:
  • 2.5K Quad HD Resolution: Capture crystal-clear video with vibrant colors and sharp details.
  • Enhanced Color Night Vision: See full-color footage at night, unlike traditional black-and-white night vision.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • 24/7 Local Recording: Supports continuous recording to microSD cards up to 256GB without subscription fees.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Easy Setup & Mounting: Bluetooth setup and magnetic mount make installation hassle-free.
  • IP65 Weather Resistant: Durable for outdoor use in rain, snow, or shine.
Wyze Cam v4 is available in multiple colors and pack sizes, making it easy to customize your security setup affordably. Wyze Cam v4 lifestyle outdoor
Wyze Cam Pan v3: 360° Pan and Tilt with Weatherproof Design
For those who want full coverage with a single camera, the Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, allowing you to monitor an entire room or outdoor area. This camera is fully IP65 weather resistant, making it suitable for outdoor use when paired with the Wyze Outdoor Power Adapter.
Highlights:
  • 360° Pan & 180° Tilt: Complete coverage with smooth, quiet motion tracking.
  • Automatic Motion Tracking: The camera follows moving objects automatically for detailed monitoring.
  • Color Night Vision: Starlight sensor technology provides vivid color footage even in darkness.
  • Two-Way Audio: Communicate through the camera with clear sound.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward.
  • IP65 Weather Resistance: Built to withstand rain and snow for outdoor security.
  • Custom Detection Zones: Focus alerts on specific areas to reduce false alarms.
Wyze Cam Pan v3 is an excellent choice for those needing versatile, dynamic surveillance indoors or outdoors. Wyze Cam Pan v3 lifestyle snow
Wyze Cam OG: Budget-Friendly Indoor/Outdoor Camera with Spotlight
If you want a dependable camera with essential features at a lower price point, the Wyze Cam OG is a great option. It offers 1080p HD video, color night vision, and a built-in spotlight for added security.
Features:
  • 1080p Full HD Video: Clear and smooth video quality.
  • Color Night Vision: Four IR LEDs provide color footage in low light.
  • Built-in 40 Lumen Spotlight: Illuminate dark areas to deter unwanted visitors.
  • 90 dB Siren: User-activated alarm for extra security.
  • Two-Way Audio: Talk and listen through the camera.
  • IP65 Weather Resistant: Suitable for indoor and outdoor use.
  • Fast Live Streaming: 50% faster than previous Wyze models.
Wyze Cam OG is perfect for those who want a simple, effective security camera with full color night vision without breaking the bank.
Why Choose Wyze for Refurbished Security Cameras?
Wyze refurbished cameras offer the perfect balance of affordability and advanced features. With full color night vision, weather resistance, and smart home integration, these cameras provide peace of mind for your home or business security needs. Plus, their compact designs and easy installation make them ideal for any setting.
Summary of Affordable Wyze Cameras with Full Color Night Vision
ModelResolutionNight Vision TypeWeather ResistanceSpecial FeaturesPrice Range (Refurbished)
Wyze Cam v42.5K QHDEnhanced Color Night VisionIP65Motion spotlight, 24/7 recording, Wi-Fi 6$35.98+
Wyze Cam Pan v31080pColor Night Vision (Starlight Sensor)IP65360° pan/tilt, motion tracking, privacy mode$39.98+
Wyze Cam OG1080pColor Night Vision (IR LEDs)IP65Built-in spotlight, siren, fast streaming$29.98+
Protect your home day and night with affordable Wyze refurbished cameras featuring full color night vision and weatherproof designs. Experience smart, reliable security without compromise.
Tags and Highlights
This selection of Wyze refurbished cameras ensures you get the best value for your money with advanced security features tailored for both indoor and outdoor environments. Choose the model that fits your needs and enjoy peace of mind with full color night vision and smart home compatibility.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam OG
TypeWired CameraWired Camera (Pan & Tilt)Wired Camera
Resolution2.5K QHD (2560x1440)Not specified (likely 1080p)1080p (1920x1080)
Field of View (DFOV)115.8°360° Pan, 180° Tilt120°
Night VisionEnhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs, 72 lumens)Color Night Vision with Starlight Sensor4 IR LEDs (850nm), B&W Night Vision
Audio99dB waterproof speaker, simultaneous two-way talk, noise & echo cancellationTwo-way audioBuilt-in speaker & microphone; noise & echo cancellation
SirenYes (built-in)Not specified90 dB user-activated siren
SpotlightMotion-activated spotlightNot specifiedBuilt-in spotlight (40 lumens)
Motion DetectionYes, with motion detection zonesYes, with motion tracking and custom zonesYes, with custom detection zones
Sound DetectionYesYesNot specified
Smoke & CO AlertsYesYesYes
Local StoragemicroSD card up to 512GB (required)microSD card support (up to 256GB)microSD up to 256GB (exFAT format)
Cloud StorageAvailable with subscriptionAvailable with subscriptionNot specified
Wi-Fi2.4 GHz Wi-Fi + Wi-Fi 6 support2.4 GHz Wi-Fi2.4 GHz Wi-Fi (802.11 b/g/n)
BluetoothBluetooth 5.2Not specifiedNot specified
Weather ResistanceIP65IP65IP65
Operating Temperature-4ºF to 122ºF (-20ºC to 50ºC)Not specified-4ºF to 131ºF (-20ºC to 55ºC)
Dimensions2in x 2in x 2 3/8inNot specified1.89in x 1.89in x 1.89in
Weight0.49 lb (222 g)Not specified4.1 oz (116 g)
Mounting OptionsStand, Wall, Ceiling, Magnetic mountNot specifiedStand, Wall, Ceiling mounts
Power Adapter Output5V/1A (Indoor), Outdoor adapter sold separatelyNot specified5V/1A
Special FeaturesAuto-zoom with AI Smart Focus, Wide Dynamic Range (WDR), Alexa/Google/IFTTT integration360° pan, 180° tilt, motion tracking, Privacy Mode, Alexa/Google/IFTTT integrationFaster live streaming, 3X faster notifications, upgraded 2-way audio
Price (1 Pack)$35.98$39.98$29.98
What are the benefits of buying a refurbished Wyze security camera?Refurbished Wyze security cameras offer advanced features like full color night vision, weather resistance, and smart home compatibility at a more affordable price. Each camera is tested to ensure reliability, making them a budget-friendly choice for home or business security.
Which Wyze refurbished camera is best for outdoor use?All featured Wyze refurbished cameras—Wyze Cam v4, Wyze Cam Pan v3, and Wyze Cam OG—are IP65 weather resistant, making them suitable for outdoor use. The Wyze Cam v4 offers enhanced color night vision and a motion-activated spotlight, while the Wyze Cam Pan v3 provides 360° pan and 180° tilt for complete coverage.
Do Wyze refurbished cameras have full color night vision?Yes, all the highlighted Wyze refurbished cameras feature full color night vision. The Wyze Cam v4 and Cam Pan v3 use advanced sensors for vivid color footage in low light, while the Wyze Cam OG uses IR LEDs to provide color night vision.
Can I use Wyze refurbished cameras indoors and outdoors?Yes, Wyze refurbished cameras are designed for both indoor and outdoor use. Their IP65 weather resistance ensures durability in rain, snow, or shine, making them versatile for any environment.
What is the video resolution of Wyze refurbished cameras?Wyze Cam v4 offers 2.5K QHD resolution for crystal-clear video, while Wyze Cam Pan v3 and Wyze Cam OG provide 1080p Full HD video for clear and smooth footage.
Do Wyze refurbished cameras support continuous recording?Yes, the Wyze Cam v4 supports 24/7 local recording to microSD cards up to 256GB without subscription fees. Other models also support local recording, but check specific model details for maximum storage capacity.
Are Wyze refurbished cameras compatible with smart home assistants?Yes, Wyze refurbished cameras work seamlessly with Alexa, Google Assistant, and IFTTT, allowing for easy integration into your smart home setup.
What special security features do Wyze refurbished cameras offer?Wyze refurbished cameras offer features such as motion-activated spotlights, loud sirens, two-way audio, automatic motion tracking, privacy mode, and custom detection zones to enhance your security.
How easy is it to install a Wyze refurbished camera?Wyze refurbished cameras are designed for easy installation, featuring Bluetooth setup and magnetic mounts for hassle-free mounting and setup.
What is the price range for Wyze refurbished cameras with full color night vision?Refurbished Wyze cameras with full color night vision start at $29.98 for the Wyze Cam OG, $35.98 for the Wyze Cam v4, and $39.98 for the Wyze Cam Pan v3, making them affordable options for high-quality security.
What are the key features of the Wyze Cam v4?Can you tell me more about the weather resistance of the Wyze cameras?Are there any ongoing sales or discounts for Wyze cameras?
