Wyze Backyard Security Camera with Solar Panel Kit
Backyard Security Camera Powered by Solar Panel Kit for Wyze Battery Cam
Enhance your backyard security with a reliable, wire-free camera system powered sustainably by solar energy. Wyze offers an ideal combination of advanced battery-powered cameras and a dedicated solar panel accessory designed to keep your devices running longer without frequent recharging. Whether you already own a Wyze Battery Cam Pro or are looking for an all-in-one solar-powered security solution, Wyze has you covered.
Wyze Battery Cam Solar Panel: Extend Your Camera’s Battery Life Naturally
The
Wyze Battery Cam Solar Panel is the perfect accessory to keep your Wyze outdoor cameras powered continuously by harnessing the sun’s energy.
Key Features:
- Continuous Power Supply: Extends the battery life of your Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2 by charging it directly from sunlight.
- Weather Resistant: Built to withstand rain, dust, and outdoor elements with an IP65 rating, ensuring durability in all seasons.
- Flexible Mounting: Comes with a 360° freestyle mount and a 13-foot weatherproof power cable, allowing you to position the solar panel for optimal sun exposure anywhere in your backyard.
- Easy Installation: Simply attach the solar panel to your camera and mount it in a sunny spot—no wiring or electrician needed.
Record for longer and never worry about your camera running out of battery during critical moments.
Wyze Battery Cam Pro: High-Definition Wireless Security Camera
The
Wyze Battery Cam Pro is a powerful, wire-free security camera designed for outdoor use, delivering crystal-clear 2.5K HDR video and smart detection features.
Why Choose Wyze Battery Cam Pro?
- 2.5K HDR Video Resolution: Capture sharp, vibrant footage day or night with enhanced color night vision.
- Integrated Spotlight & Siren: Deter intruders with a bright 150-lumen spotlight and a loud siren.
- Radar + PIR Motion Detection: Dual sensors provide early and precise motion alerts with customizable detection zones.
- Weatherproof & Wireless: IP65-rated for all-weather protection and supports both 2.4 GHz and 5 GHz WiFi for flexible connectivity.
- Removable Rechargeable Batteries: Hot-swap batteries easily to keep your camera running without downtime.
- Local & Cloud Storage: Supports up to 256GB microSD cards for local recording and offers cloud storage options with Cam Plus subscription.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless voice control and automation.
No power outlet? No problem. The Battery Cam Pro combined with the solar panel kit makes it a truly wireless, sustainable security solution.
Wyze Battery Cam Pro + Solar Panel Bundle: Ready-to-Go Solar Security
For those seeking convenience and value, the
Wyze Battery Cam Pro + Solar Panel bundle offers a complete package that combines the camera and solar panel in one purchase.
Bundle Highlights:
- Up to 6 Months Battery Life: Thanks to the 6200mAh removable battery and solar charging, enjoy extended monitoring without frequent recharging.
- Weatherproof Design: IP65 rating ensures reliable operation in temperatures from -20°C to 50°C (-4°F to 122°F).
- Advanced Imaging: CMOS-Starlight sensor with F1.6 aperture and 8x digital zoom for detailed surveillance.
- Integrated Spotlight & Siren: Bright LEDs and a 100 dB siren enhance security and deterrence.
- Wireless & Easy Setup: Bluetooth 5.1 for quick setup and dual-band WiFi for stable connectivity.
- Smart Features: Radar + PIR motion detection, color night vision, two-way audio, and local microSD recording.
This bundle is the ultimate backyard security solution powered sustainably by solar energy, perfect for those who want hassle-free, long-lasting protection.
Experience seamless backyard security with Wyze’s solar-powered camera system.
Why Choose Solar-Powered Backyard Security Cameras?
Solar-powered security cameras like the Wyze Battery Cam Pro combined with the Wyze Battery Cam Solar Panel offer several advantages:
- Eco-Friendly & Cost-Effective: Reduce electricity consumption by using renewable solar energy.
- Wire-Free Convenience: No need for power outlets or complicated wiring, ideal for remote or hard-to-reach backyard locations.
- Continuous Monitoring: Solar panels keep your camera charged throughout the day, minimizing downtime.
- Weatherproof Durability: Designed to withstand outdoor conditions, ensuring reliable performance year-round.
- Smart Features: Advanced motion detection, night vision, and two-way audio keep your property safe and connected.
Summary: The Perfect Solar-Powered Security Setup for Your Backyard
Product | Highlights |
Wyze Battery Cam Solar Panel | Weatherproof, 360° mount, 13 ft cable, extends battery life |
Wyze Battery Cam Pro | 2.5K HDR, spotlight & siren, radar + PIR detection, removable battery |
Wyze Battery Cam Pro + Solar Panel Bundle | All-in-one solar-powered camera, up to 6 months battery life, IP65 rated |
With Wyze’s solar panel kit and battery cameras, you can secure your backyard effortlessly with a sustainable, wireless, and smart security system.
Feature | Wyze Battery Cam Solar Panel | Wyze Battery Cam Pro | Wyze Battery Cam Pro + Solar Panel |
Type | Accessory | Camera | Camera Bundle |
Video Resolution | N/A | 2.5K HDR (2560 x 1440) | 2.5K HDR (2560 x 1440) |
Power Source | Solar Panel (weather resistant) | Removable, Rechargeable Battery Packs | Removable, Rechargeable Battery Packs + Solar Panel |
Battery Life | Extends battery life | Up to 6 Months | Up to 6 Months (extended with solar panel) |
Weather Resistance | IP65 (weatherproof and dustproof) | IP65 | IP65 |
Compatibility | Wyze Cam Outdoor v1/v2, Wyze Battery Cam Pro | Wyze Battery Cam Pro | Wyze Battery Cam Pro + Solar Panel |
Mounting | 360° Freestyle Mount, mountable anywhere | 1/4” - 20 standard mount, wall mount included | 1/4” - 20 standard mount, wall mount included |
Cable Length | 13-foot weatherproof power cable | N/A | Included with solar panel |
Wireless | N/A | Yes (2.4 & 5 GHz WiFi, BLE 5.1) | Yes (2.4 & 5 GHz WiFi, BLE 5.1) |
Integrated Spotlight & Siren | N/A | Yes | Yes |
Motion Detection | N/A | Radar + PIR Motion Detection | Radar + PIR Motion Detection |
Local Storage | N/A | Supports up to 256 GB microSD cards | Supports up to 256 GB microSD cards |
Cloud Storage | N/A | Available with Cam Plus subscription | Available with Cam Plus subscription |
Dimensions | 173 mm x 120 mm x 17 mm | 2.5 x 1.8 x 3.5 inches | 2.5 x 1.8 x 3.5 inches |
Weight | N/A | 0.94 lbs | 0.94 lbs |
Price | $24.99 (solar panel), $5.99 (USB-C cable) | From $89.98 (single camera) | $109.98 (bundle) |
What is the Wyze Battery Cam Solar Panel and how does it work?
The Wyze Battery Cam Solar Panel is an accessory designed to keep your Wyze outdoor cameras powered by harnessing solar energy. It connects directly to your Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2, providing a continuous power supply from sunlight, which extends your camera’s battery life and reduces the need for frequent recharging.Is the Wyze Battery Cam Solar Panel weatherproof?
Yes, the Wyze Battery Cam Solar Panel is IP65-rated, making it weather resistant and capable of withstanding rain, dust, and outdoor elements. This ensures reliable performance in all seasons.How easy is it to install the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is designed for easy installation. It comes with a 360° freestyle mount and a 13-foot weatherproof power cable, allowing you to position it for optimal sun exposure. No wiring or electrician is needed—simply attach the panel to your camera and mount it in a sunny spot.What are the key features of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro offers 2.5K HDR video resolution, enhanced color night vision, an integrated 150-lumen spotlight, a loud siren, radar and PIR motion detection, weatherproof IP65 rating, removable rechargeable batteries, support for local and cloud storage, and compatibility with Alexa, Google Assistant, and IFTTT.Can I use the Wyze Battery Cam Pro without a power outlet?
Yes, the Wyze Battery Cam Pro is a wire-free, battery-powered security camera. When paired with the Wyze Battery Cam Solar Panel, it becomes a truly wireless and sustainable security solution, eliminating the need for a power outlet.What is included in the Wyze Battery Cam Pro + Solar Panel Bundle?
The Wyze Battery Cam Pro + Solar Panel Bundle includes the Wyze Battery Cam Pro and the Wyze Battery Cam Solar Panel, providing a complete, ready-to-go solar-powered security solution for your backyard.How long does the battery last with the Wyze Battery Cam Pro + Solar Panel Bundle?
With the 6200mAh removable battery and solar charging, the Wyze Battery Cam Pro + Solar Panel Bundle can provide up to 6 months of battery life, depending on usage and sunlight exposure.What are the benefits of using a solar-powered security camera for my backyard?
Solar-powered security cameras like the Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel offer eco-friendly and cost-effective operation, wire-free convenience, continuous monitoring, weatherproof durability, and advanced smart features such as motion detection, night vision, and two-way audio.Does the Wyze Battery Cam Pro support local and cloud storage?
Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256GB and offers cloud storage options through the Cam Plus subscription.Is the Wyze Battery Cam Pro compatible with smart home systems?
Yes, the Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless voice control and smart home automation.What is the operating temperature range for the Wyze Battery Cam Pro + Solar Panel Bundle?
The Wyze Battery Cam Pro + Solar Panel Bundle is IP65-rated and operates reliably in temperatures ranging from -20°C to 50°C (-4°F to 122°F).What smart security features does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro features radar and PIR motion detection, customizable detection zones, color night vision, two-way audio, an integrated spotlight, and a 100 dB siren for enhanced security and deterrence.
What are the key features of the Wyze Battery Cam Solar Panel?How does the solar panel extend the battery life of the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
