Automate Wyze Cam v4 Security with Alexa Routines
Automated Routines with Alexa to Arm or Disarm Wyze Cam v4
Enhance your home security effortlessly by integrating Wyze Cam v4 with Alexa-enabled automated routines. Whether you want to arm your camera when leaving home or disarm it upon arrival, Wyze Cam v4 offers seamless compatibility with Alexa voice commands and smart home automation. This guide highlights the best Wyze Cam v4 products designed for smart, automated security control.
Wyze Cam v4: The Smart Indoor/Outdoor Security Camera
Key Features and Specifications
  • Crystal-clear 2.5K QHD Video Resolution: Capture every detail with 2560x1440 pixels for sharp, vibrant footage.
  • Enhanced Color Night Vision: See in full color even in low-light conditions thanks to 4 IR LEDs and 2 white spotlight LEDs.
  • Wide Field of View: 115.8° diagonal, 98.5° horizontal, and 53.1° vertical coverage to monitor large areas.
  • Robust Sensor: CMOS Starlight Sensor ensures excellent image quality day and night.
  • Two-Way Audio & Built-in Siren: Communicate through the camera or deter intruders with a loud 99dB siren.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic adhesive mounts for flexible installation.
  • Weather Resistant: Rated IP65 for reliable outdoor use in temperatures from -4°F to 122°F.
  • Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6 for fast, stable connections.
  • Alexa Integration: Easily arm or disarm your camera using Alexa routines or voice commands.
  • Local and Cloud Storage: Supports microSD cards up to 512GB and optional cloud subscription plans.
Automate with Alexa
Set up Alexa routines to arm your Wyze Cam v4 automatically when you leave home or disarm it when you return. For example:
  • Leaving Home: Alexa can trigger the camera to arm and start motion detection.
  • Arriving Home: Alexa can disarm the camera to avoid false alarms.
  • Voice Commands: Simply say, "Alexa, arm my Wyze Cam," or "Alexa, disarm my Wyze Cam."
This integration provides peace of mind and hands-free control over your home security. Wyze Cam v4 in outdoor lifestyle setting Experience smart home security with Wyze Cam v4 outdoors
Wyze Cam v4 Outdoor Bundle: Complete Security Solution
What’s Included?
  • Wyze Cam v4 camera with all the features above.
  • Wyze Outdoor Power Adapter for continuous wired power.
  • 128GB Wyze MicroSD Card for 24/7 local recording.
Enhanced Features for Outdoor Use
  • Wired Power Source: Ensures uninterrupted operation without battery concerns.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected, enhancing color night vision.
  • Smoke and CO Alerts: Receive notifications for smoke or carbon monoxide detection.
  • Motion Detection Zones: Customize detection areas to reduce false alarms.
  • Wi-Fi 6 Support: Faster and more reliable connectivity outdoors.
  • Alexa & Google Assistant Compatible: Control your outdoor security with voice commands and routines.
This bundle is perfect for users wanting a robust, always-on outdoor security system integrated with Alexa for automated routines. Wyze Cam v4 Outdoor Bundle lifestyle Secure your outdoor spaces with Wyze Cam v4 Outdoor Bundle
Wyze Cam v4 Home Security Bundle: All-in-One Protection
Bundle Highlights
  • Includes multiple Wyze Cam v4 cameras for indoor and outdoor coverage.
  • Enhanced 2-way audio for clearer communication.
  • Motion-activated spotlight and person detection for precise alerts.
  • Supports microSD cards up to 128GB with Class 10 and UHS-3 (U3) for high-speed recording.
  • IP65 weather resistance for reliable outdoor use.
  • Alexa integration for voice control and automated routines.
Why Choose the Home Security Bundle?
This bundle is ideal for comprehensive home security, offering multiple cameras with advanced features and Alexa compatibility. Automate your entire home’s security system with Alexa routines that arm or disarm cameras based on your schedule or location.
Wyze Cam v4 + FREE 32GB MicroSD Card: Value and Convenience
Features
  • Same powerful 2.5K QHD resolution and enhanced color night vision.
  • Motion-activated spotlight and person detection.
  • Supports Wi-Fi 6 and Alexa integration.
  • Includes a free 32GB microSD card for local storage.
  • Wired power with outdoor compatibility (requires outdoor power adapter sold separately).
This option is perfect for users looking to start with a single camera and enjoy local storage right out of the box, with full Alexa routine support.
Why Choose Wyze Cam v4 for Alexa Automated Routines?
Wyze Cam v4 stands out as a versatile, high-quality security camera that integrates effortlessly with Alexa. Its advanced features like color night vision, motion-activated spotlight, and person detection combined with Alexa’s smart routines make it easy to automate your home security. Whether you want to arm your cameras when you leave or disarm them when you arrive, Wyze Cam v4 offers reliable performance and smart home convenience.
Summary of Wyze Cam v4 Alexa Integration Benefits
  • Hands-free arming/disarming with Alexa voice commands.
  • Customizable routines based on your daily schedule or location.
  • Real-time alerts and two-way communication.
  • High-resolution video with color night vision for clear monitoring.
  • Flexible mounting and weather resistance for indoor/outdoor use.
  • Local and cloud storage options for video backup.
Secure your home smarter with Wyze Cam v4 and Alexa automated routines today.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price$100.00$69.99$169.99$35.98
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD
Color Night VisionYesYesYesYes
Night Vision Type4 IR LEDs + 2 white spotlight LEDs4 IR LEDs + 2 white spotlight LEDs4 IR LEDs + 2 white spotlight LEDsYes
Weather ResistanceIP65IP65IP65IP65
Motion-Activated SpotlightYesYesYesYes
AudioEnhanced Two-Way Talk, 99dB SirenEnhanced Two-Way Talk, 99dB SirenImproved 2-way audio, 99dB SirenEnhanced Two-Way Talk
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Local Storage SupportmicroSD card up to 512 GB128GB microSD Card included128GB microSD Card includedRequires microSD card (included 32GB)
Continuous RecordingYesYesYesYes
Motion & Sound DetectionYesYesYesYes
Smart Detection (Subscription)AvailableAvailableAvailableAvailable
Person DetectionYesYesYesYes
Smoke & CO AlertsYesYesYesYes
Field of View (DFOV x HFOV x VFOV)115.8° x 98.5° x 53.1°115.9° x 98.5° x 53.1°115.8° x 98.5° x 53.1°Not specified
Mounting OptionsStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticNot specified
Power Adapter IncludedIndoor 5V/1AWyze Outdoor Power Adapter includedIncluded (5V/1A adapter)Requires Outdoor Power Adapter
Bluetooth Version5.2Not specifiedNot specifiedNot specified
Video FPS (Day/Night)20 FPS / 15 FPSNot specified20 FPS / 15 FPSNot specified
Digital Zoom8xNot specified8xNot specified
Warranty1 Year1 Year1 YearNot specified
Included ItemsCamera onlyCamera, Outdoor Power Adapter, 128GB microSD CardCamera, 128GB microSD Card, Power AdapterCamera, Free 32GB microSD Card
How do I automate Wyze Cam v4 arming and disarming with Alexa?You can automate Wyze Cam v4 arming and disarming by setting up Alexa routines. For example, you can create a routine to arm your camera and enable motion detection when you leave home, and disarm it when you return. Simply use Alexa voice commands like 'Alexa, arm my Wyze Cam' or 'Alexa, disarm my Wyze Cam' for hands-free control.
Is Wyze Cam v4 compatible with Alexa voice commands?Yes, Wyze Cam v4 is fully compatible with Alexa. You can use Alexa voice commands to arm or disarm your camera, as well as integrate it into automated routines for smart home security control.
What are the key features of Wyze Cam v4?Wyze Cam v4 offers 2.5K QHD video resolution, enhanced color night vision, a wide field of view, two-way audio, a built-in 99dB siren, multiple mounting options, IP65 weather resistance, support for 2.4 GHz Wi-Fi and Wi-Fi 6, Alexa integration, and both local and cloud storage options.
Can Wyze Cam v4 be used outdoors?Yes, Wyze Cam v4 is IP65 weather resistant and can be used both indoors and outdoors. It operates reliably in temperatures from -4°F to 122°F and offers flexible mounting options for various locations.
What storage options are available for Wyze Cam v4?Wyze Cam v4 supports local storage with microSD cards up to 512GB (or up to 128GB in some bundles) and offers optional cloud subscription plans for video backup and remote access.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera, Wyze Outdoor Power Adapter for continuous wired power, and a 128GB Wyze MicroSD Card for 24/7 local recording. It also features a motion-activated spotlight, smoke and CO alerts, customizable motion detection zones, and Wi-Fi 6 support.
Does Wyze Cam v4 support motion detection and person detection?Yes, Wyze Cam v4 features advanced motion detection and person detection. You can customize motion detection zones to reduce false alarms and receive precise alerts for important events.
Can I use Wyze Cam v4 with Google Assistant?Yes, Wyze Cam v4 is compatible with both Alexa and Google Assistant, allowing you to control your security camera with voice commands and smart home routines.
What is the benefit of the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple cameras for comprehensive indoor and outdoor coverage, enhanced two-way audio, motion-activated spotlight, person detection, and Alexa integration for automated routines. It is ideal for users seeking all-in-one home protection.
Does Wyze Cam v4 support Wi-Fi 6?Yes, Wyze Cam v4 supports both 2.4 GHz Wi-Fi and Wi-Fi 6, ensuring fast and stable connectivity for reliable video streaming and smart home integration.
What is included with the Wyze Cam v4 + FREE 32GB MicroSD Card offer?This offer includes a Wyze Cam v4 camera with 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, person detection, Wi-Fi 6 support, Alexa integration, and a free 32GB microSD card for local storage. An outdoor power adapter is required for outdoor use and is sold separately.
Why should I choose Wyze Cam v4 for Alexa automated routines?Wyze Cam v4 is a versatile, high-quality security camera that integrates seamlessly with Alexa. Its advanced features, such as color night vision, motion-activated spotlight, and person detection, combined with Alexa’s smart routines, make it easy to automate your home security for hands-free convenience and peace of mind.
How do I set up Alexa routines for my Wyze Cam v4?Can I customize the motion detection zones on the Wyze Cam v4?Do you have any deals, ongoing sales, discounts, or promotions?
