Wyze Cam Pan v3: Voice Assistant Compatible Security Camera
Voice Assistant Compatible Camera: Wyze Cam Pan v3
Looking for a versatile security camera that responds to simple voice commands? The Wyze Cam Pan v3 is your ideal choice. This smart camera offers seamless integration with popular voice assistants like Alexa and Google Assistant, allowing you to control your camera hands-free with ease.
Key Features of Wyze Cam Pan v3
  • 360° Pan & 180° Tilt: Complete coverage with smooth, fast rotation up to 110° per second.
  • 1080p Full HD Video: Crisp, clear video quality with H.264 encoding.
  • Night Vision: Equipped with 4 IR LEDs (850 nm) for reliable night monitoring.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation lets you listen and talk remotely.
  • Voice Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT for effortless voice control.
  • Weather Resistant: IP65 rating makes it suitable for both indoor and outdoor use (outdoor use requires a separate power adapter).
  • Storage Options: Supports up to 256 GB microSD cards in ExFAT format for local storage.
  • Connectivity: Works on 2.4 GHz Wi-Fi networks (802.11 b/g/n).
  • Mobile Compatibility: Supports Android 9.0+ and iOS 15.0+ devices.
This camera is perfect for home security, pet monitoring, and even RV or camper surveillance, thanks to its durable polycarbonate body and weatherproof design. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3: Weather-resistant and ready for outdoor use
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
For those who want an enhanced experience, the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same powerful camera with added benefits:
  • Color Night Vision: See more details in low light with color night vision technology.
  • Included Accessories: Comes with a power adapter, micro USB cable, mounting kit, and quick start guide.
  • Push Notifications: Instant alerts on your phone for motion or sound detection.
  • Same Voice Assistant Compatibility: Works flawlessly with Alexa, Google Assistant, and IFTTT.
  • One-Year Warranty: Peace of mind with manufacturer support.
This bundle is ideal for users who want a ready-to-go package with premium features and extended cloud storage options.
Pan v3 Outdoor Bundle: Ultimate Outdoor Security
If your priority is outdoor surveillance with extended power and storage capabilities, the Pan v3 Outdoor Bundle is designed for you:
  • IP67 Weather Resistance: Enhanced protection against dust and water, perfect for harsh outdoor environments.
  • Extended Cable Length: Total 12.5 ft cable for flexible installation.
  • Supports 128GB microSD Card: Store up to 192 hours of HD video locally.
  • Compatible with Multiple Wyze Cameras: Works with Wyze Cam v3, v4, OG series, and Battery Cam Pro.
  • Certified Safety: FCC and UL certifications ensure quality and reliability.
This bundle is perfect for homeowners and outdoor enthusiasts who need robust, weatherproof security with voice control convenience. Two-way audio feature with pet Stay connected with two-way audio for indoor monitoring
Why Choose Wyze Cam Pan v3 for Voice Control?
The Wyze Cam Pan v3 stands out as a smart security camera that combines advanced features with voice assistant compatibility, making home monitoring effortless and interactive.
  • Simple Voice Commands: Ask Alexa or Google Assistant to pan, tilt, or zoom your camera.
  • Smart Alerts: Receive push notifications instantly on your smartphone.
  • Flexible Installation: Use indoors or outdoors with weather resistance and optional outdoor power adapter.
  • Affordable Pricing: Competitive price points with options for single units, bundles, and accessories.
Whether you want to keep an eye on your pets, monitor your home, or secure your outdoor spaces, the Wyze Cam Pan v3 series offers a reliable, voice-controlled solution.
Summary of Wyze Cam Pan v3 Variants
Product VariantPrice (USD)Key FeaturesUse Case
Wyze Cam Pan v3 (Single)$39.98360° pan, 1080p, IP65, voice controlIndoor/outdoor
Wyze Cam Pan v3 + 30-Day Cam Plus$39.98Includes power adapter, color night visionEnhanced monitoring
Pan v3 Outdoor Bundle$76.96IP67 rating, extended cables, 128GB storageOutdoor security
Enhance Your Wyze Cam Pan v3 Experience
Consider adding accessories like the Wyze Cam Pan v3 Skins by dBrand for stylish protection or replacement parts such as the Wyze Cam Pan v3 USB Cable to keep your camera running smoothly.
By choosing the Wyze Cam Pan v3, you get a feature-rich, voice assistant compatible camera that adapts to your lifestyle and security needs with ease.
FeatureWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus BundlePan v3 Outdoor Bundle
Price$39.98 (1 Pack)$39.98$76.96
Color VariantsBlack, WhiteBlack, WhiteBlack, White
Indoor/Outdoor UseIndoor/Outdoor (requires Outdoor Power Adapter for outdoor use)Indoor/Outdoor (requires Outdoor Power Adapter for outdoor use)Indoor/Outdoor (includes Outdoor Power Adapter)
Weather ResistanceIP65IP65IP65 (Outdoor Power Adapter rated IP67)
Pan & Tilt Range360° horizontal, 180° vertical360° horizontal, 180° vertical360° horizontal, 180° vertical
Video Resolution1080p (1920 x 1080)1080p (1920 x 1080)1080p (1920 x 1080)
Night VisionColor Night Vision with Starlight SensorColor Night Vision with Starlight SensorColor Night Vision with Starlight Sensor
Motion TrackingYes, automatic motion trackingYes, automatic motion trackingYes, automatic motion tracking
Two-Way AudioYesYesYes
Cloud Storage14-Day free cloud storageIncludes 30-Day free Cam Plus trial (unlimited event video cloud storage)14-Day free cloud storage
Local StorageSupports microSD cards (up to 32GB)Supports microSD cards (up to 32GB)Supports microSD cards (up to 128GB)
CPU1.5 GHz1.5 GHz1.5 GHz
Image Sensor1/2.9'' CMOS1/2.9'' CMOS1/2.9'' CMOS
Video EncodingH.264H.264H.264
Video FPSDay: 20 fps / Night: 15 fpsDay: 20 fps / Night: 15 fpsDay: 20 fps / Night: 15 fps
Field of View120°120°120°
Dimensions (Camera)124mm (H) x 60mm (W) x 63mm (D)124mm (H) x 60mm (W) x 63mm (D)124mm (H) x 60mm (W) x 63mm (D)
Weight (Camera)11.29 oz (320 g)11.29 oz (320 g)11.29 oz (320 g)
Outdoor Power AdapterSold separatelySold separatelyIncluded (White, IP67 rated)
Outdoor Power Adapter Cable LengthN/AN/ATotal 12.5 ft (3.8 m) cable
Warranty1 Year1 Year1 Year
Additional FeaturesPrivacy Mode, Pan Scan™, Custom Detection Zones, Smoke & CO AlertsSame as Wyze Cam Pan v3 plus 30-day Cam Plus trialSame as Wyze Cam Pan v3 plus Outdoor Power Adapter included
Is the Wyze Cam Pan v3 compatible with voice assistants like Alexa and Google Assistant?Yes, the Wyze Cam Pan v3 is fully compatible with popular voice assistants such as Alexa and Google Assistant. You can control your camera hands-free using simple voice commands for functions like panning, tilting, and zooming.
What are the key features of the Wyze Cam Pan v3 security camera?The Wyze Cam Pan v3 offers 360° pan and 180° tilt, 1080p Full HD video, night vision with 4 IR LEDs, two-way audio with noise and echo cancellation, voice assistant integration, IP65 weather resistance, support for up to 256GB microSD cards, and compatibility with Android 9.0+ and iOS 15.0+ devices.
Can the Wyze Cam Pan v3 be used outdoors?Yes, the Wyze Cam Pan v3 is weather resistant with an IP65 rating, making it suitable for both indoor and outdoor use. For outdoor installation, a separate outdoor power adapter is required. The Pan v3 Outdoor Bundle offers even higher IP67 weather resistance for harsh environments.
Does the Wyze Cam Pan v3 support local storage?Yes, the Wyze Cam Pan v3 supports local storage with microSD cards up to 256GB in ExFAT format, allowing you to store hours of HD video footage directly on the device.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera, a power adapter, micro USB cable, mounting kit, quick start guide, and a 30-day Cam Plus subscription. This bundle also features color night vision, push notifications, and a one-year warranty.
What makes the Pan v3 Outdoor Bundle ideal for outdoor security?The Pan v3 Outdoor Bundle is designed for outdoor security with an IP67 weather resistance rating, a 12.5 ft extended cable for flexible installation, support for up to 128GB microSD cards, and compatibility with multiple Wyze camera models. It is also FCC and UL certified for safety and reliability.
How does two-way audio work on the Wyze Cam Pan v3?The Wyze Cam Pan v3 features built-in two-way audio with a speaker and microphone, allowing you to listen and talk remotely through the Wyze app. Noise and echo cancellation ensure clear communication, making it ideal for monitoring pets or communicating with family members.
What devices are compatible with the Wyze Cam Pan v3 app?The Wyze Cam Pan v3 app is compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher, ensuring broad support for most smartphones and tablets.
What are the storage options for Wyze Cam Pan v3 video recordings?Wyze Cam Pan v3 supports local storage via microSD cards up to 256GB and offers cloud storage options through the Cam Plus subscription, which provides extended video history and smart notifications.
Are there accessories available for the Wyze Cam Pan v3?Yes, you can enhance your Wyze Cam Pan v3 experience with accessories such as Wyze Cam Pan v3 Skins by dBrand for added protection and style, as well as replacement parts like the Wyze Cam Pan v3 USB Cable.
What is the warranty period for the Wyze Cam Pan v3?The Wyze Cam Pan v3 comes with a one-year manufacturer warranty, providing peace of mind and support for your purchase.
What Wi-Fi networks does the Wyze Cam Pan v3 support?The Wyze Cam Pan v3 operates on 2.4 GHz Wi-Fi networks (802.11 b/g/n), ensuring reliable connectivity for your home or office.
What are the main differences between the Wyze Cam Pan v3 variants?The Wyze Cam Pan v3 (Single) offers 360° pan, 1080p video, IP65 weather resistance, and voice control. The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle adds color night vision, included accessories, and a Cam Plus subscription. The Pan v3 Outdoor Bundle features IP67 weather resistance, extended cables, and support for 128GB microSD cards, making it ideal for outdoor security.
What are the key features of the Wyze Cam Pan v3?Can the Wyze Cam Pan v3 be used for outdoor surveillance?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Pan v3?
