Wyze Cam Pan v3: Motion Tracking Camera for Alexa Routines
Wyze Cam Pan v3: The Ultimate Motion Tracking Camera for Alexa Routines
If you're searching for a motion tracking camera that seamlessly integrates with Alexa routines for home automation, the Wyze Cam Pan v3 stands out as a top choice. Designed for both indoor and outdoor use, this smart camera offers 360° horizontal pan and 180° vertical tilt, ensuring you never miss a moment. Its compatibility with Alexa routines allows you to automate your home security effortlessly.
Experience smart home automation with Wyze Cam Pan v3 — your eyes and ears that work with Alexa to keep your home safe and connected.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 weather-resistant outdoor camera
Key Features of Wyze Cam Pan v3
  • 360° Pan & 180° Tilt: Complete coverage with smooth rotation up to 110° per second.
  • 1080p Full HD Video: Crisp, clear video with H.264 encoding at 20 fps during the day and 15 fps at night.
  • Night Vision: Equipped with 4 IR LEDs (850 nm) for clear black-and-white night vision.
  • Color Night Vision (with Cam Plus Bundle): See more details even in low light.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for real-time communication.
  • Alexa Integration: Easily set up Alexa routines to trigger camera actions or alerts.
  • Weather Resistant: IP65 rating makes it suitable for outdoor use (with Wyze Outdoor Power Adapter).
  • Storage: Supports up to 256 GB microSD card for local recording.
  • Connectivity: Works on 2.4 GHz Wi-Fi networks (802.11 b/g/n).
  • Compact & Durable: Matte polycarbonate body with glass + plastic lens, weighing just 320g.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Automation & Features
For those who want to unlock the full potential of the Wyze Cam Pan v3, the Cam Plus Bundle offers advanced features such as:
  • Color Night Vision: See vivid colors even in the dark.
  • Extended Cloud Storage: 30 days of event video storage.
  • Person Detection & Motion Zones: Customize alerts and reduce false alarms.
  • Alexa Routine Compatibility: Automate actions like turning on lights or sending notifications when motion is detected.
This bundle includes everything you need to get started: the camera, power adapter, mounting kit, and quick start guide.
Make Your Setup Smarter with Wyze Cam Pan v3 Accessories
  • Wyze Cam Pan v3 Skins by dBrand: Personalize and protect your camera with stylish vinyl skins available in Green Camo or Triple Black. These skins prevent scratches and give your camera a unique look.
  • Wyze Cam Pan v3 USB Cable: Keep your camera powered with a reliable replacement USB cable.
  • Pan v3 + Lamp Socket v2 Bundle: Power your Wyze Cam Pan v3 through a lamp socket without needing an outlet, perfect for flexible installation options.
Why Choose Wyze Cam Pan v3 for Alexa Automation?
The Wyze Cam Pan v3 is not just a camera; it’s a smart home companion that integrates smoothly with Alexa routines. Whether you want your camera to start recording when you leave home, trigger smart lights upon motion detection, or receive instant push notifications, this camera makes automation simple and effective.
"With Alexa integration, Wyze Cam Pan v3 transforms your home security into a hands-free, intelligent system."
Two-way audio feature with pet Communicate easily with two-way audio
Technical Specifications at a Glance
FeatureSpecification
Video Resolution1920 x 1080 (1080p)
Frame RateDay: 20 fps / Night: 15 fps
Field of View120° FOV
Rotation SpeedUp to 110° per second
Night Vision4 IR LEDs (850 nm)
AudioBuilt-in speaker & mic, 2-way audio
Connectivity802.11 b/g/n (2.4 GHz only)
StorageUp to 256 GB microSD (ExFAT format)
Operating Temperature-20°C to 50°C (-4°F to 122°F)
Weather ResistanceIP65 (with outdoor power adapter)
Dimensions124mm x 60mm x 63mm
Weight320 g (11.29 oz)
Conclusion
For anyone looking to enhance their home automation with a motion tracking camera that works flawlessly with Alexa routines, the Wyze Cam Pan v3 is an unbeatable option. Its versatile pan-tilt capabilities, weather resistance, and smart features make it perfect for both indoor and outdoor security. Bundles and accessories further expand its functionality, ensuring you get the most out of your smart home setup. Upgrade your home security and automation today with Wyze Cam Pan v3 — smart, reliable, and Alexa-ready.
Feature / ProductWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus BundleWyze Cam Pan v3 Skins by dBrand (Skin Only)Pan v3 + Lamp Socket v2 Bundle
TypeCameraCamera + 30-Day Cam Plus SubscriptionAccessory (Skin)Bundle (Camera + Lamp Socket)
Price$39.98 (1 Pack)$39.98$11.98$53.96
Color VariantsBlack, WhiteBlack, WhiteN/A (Skin Styles: Green Camo, Triple Black)Black, White
Pack Options1, 2, 3 PacksSingle camera onlyN/ASingle camera + lamp socket
Weather ResistanceIP65 rated (outdoor ready with adapter)IP65 rated (outdoor ready with adapter)N/ALamp socket suitable for damp locations only
Pan & Tilt Coverage360° pan, 180° tilt360° pan, 180° tiltN/ASame as Wyze Cam Pan v3
Motion TrackingYes, automatic motion trackingYes, automatic motion trackingN/AYes, automatic motion tracking
Night VisionColor Night Vision with Starlight SensorColor Night Vision with Starlight SensorN/ASame as Wyze Cam Pan v3
Two-Way AudioYesYesN/AYes
Privacy ModeYesYesN/AYes
Cam Plus Subscription IncludedNoYes, free 30-day trial, then $2.99/month/cam auto-renewN/ANo
Custom Detection ZonesYesYesN/AYes
Smoke & CO AlertsYesYesN/AYes
Local Storage SupportYes (microSD cards sold separately)Yes (microSD cards sold separately)N/AYes
Outdoor Power Adapter RequiredYes (sold separately)Yes (sold separately)N/AYes (sold separately)
Skin MaterialN/AN/AStylish vinyl, precision-cut, scratch protectionN/A
Skin StylesN/AN/AGreen Camo, Triple BlackN/A
Skin IncludesN/AN/A1x Skin, 1x Installation InstructionsN/A
Lamp Socket FeaturesN/AN/AN/APowers Pan v3 without outlet, E26 socket, 120V~, 60Hz, max 20W lamp power
Lamp Socket CompatibilityN/AN/AN/ACompatible with Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Lamp Socket Weather ResistanceN/AN/AN/ANot weatherproof, suitable for damp locations only
Lamp Socket Dimensions & WeightN/AN/AN/A56.5mm x 56.5mm x 65mm, 80g
Warranty1 Year1 YearN/A1 Year
What is the Wyze Cam Pan v3 and how does it work with Alexa routines?The Wyze Cam Pan v3 is a smart motion tracking camera designed for both indoor and outdoor use. It features 360° horizontal pan and 180° vertical tilt, providing complete coverage of your space. The camera seamlessly integrates with Alexa routines, allowing you to automate actions such as recording video, turning on lights, or sending notifications when motion is detected, making home automation easy and effective.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is weather-resistant with an IP65 rating when used with the Wyze Outdoor Power Adapter. This makes it suitable for both indoor and outdoor security applications, even in challenging weather conditions.
What are the key features of the Wyze Cam Pan v3?Key features of the Wyze Cam Pan v3 include 360° pan and 180° tilt, 1080p Full HD video, night vision with 4 IR LEDs, two-way audio with noise and echo cancellation, Alexa integration for smart routines, weather resistance (IP65), support for up to 256 GB microSD card for local storage, and compatibility with 2.4 GHz Wi-Fi networks.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera, power adapter, mounting kit, and a quick start guide. The Cam Plus subscription unlocks advanced features such as color night vision, 30 days of cloud event video storage, person detection, motion zones, and enhanced Alexa routine compatibility.
Does the Wyze Cam Pan v3 support local video storage?Yes, the Wyze Cam Pan v3 supports local video storage with a microSD card of up to 256 GB (ExFAT format), allowing you to record and store footage directly on the device.
Can I use the Wyze Cam Pan v3 with 5 GHz Wi-Fi networks?No, the Wyze Cam Pan v3 is compatible only with 2.4 GHz Wi-Fi networks (802.11 b/g/n) and does not support 5 GHz Wi-Fi.
What accessories are available for the Wyze Cam Pan v3?Available accessories for the Wyze Cam Pan v3 include dBrand vinyl skins for personalization and protection, a replacement USB cable, and the Pan v3 + Lamp Socket v2 Bundle, which allows you to power the camera through a lamp socket for flexible installation.
How does the two-way audio feature work on the Wyze Cam Pan v3?The Wyze Cam Pan v3 is equipped with a built-in speaker and microphone, enabling real-time two-way audio communication. This feature includes noise and echo cancellation, allowing you to listen and speak to people or pets through the camera using the Wyze app.
What are the technical specifications of the Wyze Cam Pan v3?The Wyze Cam Pan v3 offers 1080p video resolution (1920 x 1080), 20 fps during the day and 15 fps at night, a 120° field of view, up to 110° per second rotation speed, 4 IR LEDs for night vision, two-way audio, 2.4 GHz Wi-Fi connectivity, up to 256 GB microSD card support, IP65 weather resistance (with outdoor power adapter), and operates in temperatures from -20°C to 50°C (-4°F to 122°F).
Why should I choose the Wyze Cam Pan v3 for Alexa home automation?The Wyze Cam Pan v3 is an ideal choice for Alexa home automation due to its seamless integration with Alexa routines, advanced motion tracking, weather resistance, and versatile pan-tilt capabilities. It allows you to automate security actions, receive instant alerts, and control other smart devices, making your home security smarter and more convenient.
What are the key features of the Wyze Cam Pan v3?Can the Wyze Cam Pan v3 be used for both indoor and outdoor purposes?Is there a warranty for the Wyze Cam Pan v3?
