Extend Wyze Cam Outdoor Runtime with a Solar Panel Upgrade
Extend Your Wyze Cam Outdoor Runtime with Solar Power
If you're looking to attach a solar panel to extend your Wyze Cam Outdoor's runtime and recording time, the Wyze Battery Cam Solar Panel is the perfect accessory. Designed specifically for Wyze's battery-powered cameras, this solar panel harnesses the power of the sun to keep your camera running longer without frequent recharging.
Wyze Battery Cam Solar Panel: Power Your Camera with the Sun
Key Features
  • Compatibility: Works seamlessly with Wyze Cam Outdoor v1, v2, and Wyze Battery Cam Pro.
  • Weather Resistant: Rated IP65, it withstands rain, dust, and harsh outdoor conditions.
  • Easy Installation: Comes with a 360° adjustable mount and a 13-foot micro USB cable for flexible placement.
  • Power Output: 2.5W, 5V DC solar panel efficiently charges your camera’s battery.
  • Complete Kit: Includes solar panel, wall mount, micro USB and USB-C adapter cables, screws, anchors, and a quick start guide.
Attach this solar panel to your Wyze Battery Cam Pro or Outdoor Cam to enjoy extended battery life and uninterrupted recording, even in remote locations.
Outdoor solar-powered security camera
Wyze Battery Cam Pro: High-Quality Wireless Security Camera
Why Choose Wyze Battery Cam Pro?
  • 2.5K HDR Video Resolution: Crystal-clear video with 2560 x 1440 resolution and H.264 encoding.
  • Wireless & Wire-Free: No hub required, powered by removable and rechargeable 6200mAh battery packs.
  • Long Battery Life: Up to 6 months on a single charge, extendable with the solar panel.
  • Advanced Motion Detection: Radar + PIR sensors for accurate alerts.
  • Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security.
  • Weatherproof Design: IP65 rating ensures reliable outdoor performance.
  • Connectivity: Supports both 2.4 GHz and 5 GHz WiFi networks.
  • Local & Cloud Storage: Supports up to 256GB microSD cards and cloud recording with Cam Plus.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Dimensions & Build
  • Compact size: 2.5 x 1.8 x 3.5 inches, weighing just 0.94 lbs.
  • Durable PC plastic construction with a matte finish.
  • Includes a wall mount for easy installation.
Pair your Wyze Battery Cam Pro with the solar panel to maximize uptime and reduce the hassle of manual recharging.
Wyze Battery Cam Pro + Solar Panel Bundle
For those who want an all-in-one solution, the Wyze Battery Cam Pro + Solar Panel bundle offers convenience and extended performance. This combo provides the latest in wireless security technology with the added benefit of solar-powered battery extension.
Bundle Highlights
2.5K HDR Video with Color Night Vision Integrated Spotlight & Siren for enhanced security Radar + PIR Motion Detection for precise alerts IP65 Weatherproof for all-season use Removable, rechargeable battery packs with solar charging Supports 2.4 & 5 GHz WiFi for stable connectivity Home security camera with solar panel
Why Use a Solar Panel with Your Wyze Cam Outdoor?
Using a solar panel with your Wyze Cam Outdoor or Battery Cam Pro offers several benefits:
  • Extended Battery Life: Solar power continuously charges your camera, reducing downtime.
  • Eco-Friendly: Harness renewable energy to keep your security system running sustainably.
  • Convenience: Less frequent manual recharging means more peace of mind.
  • Versatile Mounting: Place your camera and solar panel in optimal sunlight locations for best performance.
With the Wyze Battery Cam Solar Panel, you can enjoy longer recording times and reliable security coverage without worrying about battery depletion.
Summary
To extend your Wyze Cam Outdoor runtime and recording time, the Wyze Battery Cam Solar Panel is the ideal accessory. Compatible with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro, it offers weather-resistant, efficient solar charging. Pair it with the Wyze Battery Cam Pro or get the Wyze Battery Cam Pro + Solar Panel bundle for a complete, wire-free security solution that lasts longer and performs better.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam Pro + Solar PanelWyze Battery Cam Pro
Product TypeAccessoryCamera BundleCamera
Included ItemsSolar Panel, USB-C Adapter Cable (sold separately)Wyze Battery Cam Pro, Wyze Solar PanelWyze Battery Cam Pro
Video ResolutionN/A2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)
Power SourceSolar Panel (extends battery life)Battery + Solar Panel (continuous power)Removable, Rechargeable Battery Packs
Battery LifeExtends battery life of compatible camerasExtended with solar panelUp to 6 months
Compatible CamerasWyze Cam Outdoor v1/v2, Wyze Battery Cam ProWyze Battery Cam ProWyze Battery Cam Pro
Weather ResistanceIP65 (weatherproof and dustproof)IP65IP65
Mounting360° Freestyle Mount, mountable anywhereFlexible mounting optionsStandard 1/4” - 20 mount included
Power Cable Length13-foot weatherproof cableIncluded with solar panelN/A
WirelessN/AYesYes
Wi-Fi SupportN/A2.4 & 5 GHz2.4 & 5 GHz
Motion DetectionN/ARadar + PIRRadar + PIR
Spotlight & SirenN/AIntegrated spotlight & sirenIntegrated spotlight & siren
Video StorageN/ALocal recording via microSD cardLocal recording via microSD card
Price$24.99 (Solar Panel), $5.99 (USB-C Cable)$109.98$89.98 (1 Pack), $159.98 (2 Pack), $219.98 (3 Pack)
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What is the Wyze Battery Cam Solar Panel and how does it work?The Wyze Battery Cam Solar Panel is an accessory designed to extend the runtime and recording time of Wyze Cam Outdoor v1, v2, and Wyze Battery Cam Pro. It harnesses solar energy to continuously charge your camera’s battery, reducing the need for frequent manual recharging.
Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with Wyze Cam Outdoor v1, Wyze Cam Outdoor v2, and Wyze Battery Cam Pro.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel is rated IP65, making it weather resistant and able to withstand rain, dust, and harsh outdoor conditions.
What is included in the Wyze Battery Cam Solar Panel kit?The kit includes the solar panel, a 360° adjustable wall mount, a 13-foot micro USB cable, USB-C adapter cables, screws, anchors, and a quick start guide for easy installation.
How easy is it to install the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is designed for easy installation, featuring a 360° adjustable mount and a long 13-foot cable for flexible placement in optimal sunlight.
What are the benefits of using a solar panel with my Wyze Cam Outdoor or Battery Cam Pro?Using a solar panel extends your camera’s battery life, provides eco-friendly and sustainable power, reduces the need for manual recharging, and allows for versatile mounting in locations with optimal sunlight.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers 2.5K HDR video resolution, wireless and wire-free operation, up to 6 months of battery life (extendable with the solar panel), advanced radar and PIR motion detection, integrated spotlight and siren, IP65 weatherproof design, support for 2.4 GHz and 5 GHz WiFi, local and cloud storage, and smart home integration with Alexa, Google Assistant, and IFTTT.
Does the Wyze Battery Cam Pro require a hub to operate?No, the Wyze Battery Cam Pro is completely wireless and does not require a hub. It is powered by removable and rechargeable battery packs.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The bundle includes the Wyze Battery Cam Pro and the Wyze Battery Cam Solar Panel, providing a complete wireless security solution with extended battery life, 2.5K HDR video, color night vision, integrated spotlight and siren, radar and PIR motion detection, and IP65 weatherproofing.
How does the solar panel help with camera placement?The included 13-foot cable and adjustable mount allow you to place the solar panel in the best sunlight while positioning your camera for optimal security coverage, even in remote or hard-to-reach locations.
How do I install the solar panel on my Wyze Cam Outdoor?What are the benefits of using a solar panel with my Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions?
