Extend Wyze Cam Battery Life with Solar Panel Power
Extend Your Wyze Cam Battery Life with the Wyze Battery Cam Solar Panel
If you're looking to maximize the battery life of your Wyze Battery Cam or Wyze Cam Outdoor, the Wyze Battery Cam Solar Panel is the perfect accessory to keep your cameras powered longer without the hassle of frequent recharging. Designed specifically for Wyze's wireless battery cameras, this solar panel harnesses the power of the sun to provide continuous energy, making it ideal for outdoor security setups, vacation homes, RVs, and more.
Why Choose the Wyze Battery Cam Solar Panel?
  • Continuous Power Supply: Keep your Wyze Cam Outdoor v1/v2 or Wyze Battery Cam Pro recording for extended periods without needing to bring the camera inside for charging.
  • Weather Resistant: Built with an IP65 rating, the solar panel is dustproof and weatherproof, ensuring reliable performance rain or shine.
  • Flexible Mounting: Comes with a 360° freestyle mount and a 13-foot weatherproof power cable, allowing you to position the panel for optimal sun exposure anywhere around your property.
  • Easy Installation: Mount it on walls, poles, or any outdoor surface to seamlessly integrate with your existing Wyze camera setup.
"Record for longer. Attach a solar panel to your Wyze Battery Cam Pro to extend the battery life."
Wyze Battery Cam Pro: Powerful Security with Wireless Freedom
The Wyze Battery Cam Pro is a cutting-edge wireless security camera that offers high-resolution video and smart detection features without the need for a power outlet or hub. When paired with the Wyze Battery Cam Solar Panel, it becomes a truly solar-powered security solution.
Key Features of Wyze Battery Cam Pro
  • 2.5K HDR Video Resolution: Capture crystal-clear footage with vibrant colors and balanced lighting, day or night.
  • Integrated Spotlight & Siren: Deter intruders with a motion-activated 150-lumen spotlight and a loud siren.
  • Radar + PIR Motion Detection: Dual sensors provide early and precise motion alerts with customizable detection zones.
  • Removable, Rechargeable Battery Packs: Hot-swap batteries to avoid downtime and keep your security uninterrupted.
  • IP65 Weatherproof: Designed to withstand harsh outdoor conditions.
  • Dual-Band WiFi Support: Connects easily to both 2.4 GHz and 5 GHz networks for stable streaming.
  • Local and Cloud Storage: Supports up to 256GB microSD cards for local recording and offers cloud storage options with Cam Plus.
Battery Life and Power Options
  • The camera’s rechargeable 6200mAh battery can last up to 6 months on a single charge.
  • Combine with the Wyze Battery Cam Solar Panel to convert your camera into a solar-powered device, reducing the need for manual recharging.
Wyze Battery Cam Pro + Solar Panel Bundle: Ultimate Solar-Powered Security
For those who want a ready-to-go solar security camera, the Wyze Battery Cam Pro + Solar Panel bundle offers the best of both worlds. This package includes the high-performance Wyze Battery Cam Pro paired with the solar panel accessory, providing a seamless solar-powered security solution right out of the box.
Bundle Highlights
  • All-in-One Solution: Get the camera and solar panel together for extended battery life and enhanced security.
  • Weatherproof and Durable: Both components are designed to endure outdoor environments with IP65 rating.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Flexible Mounting: Includes standard mounts and a long-range power cable for versatile installation.
  • Extended Battery Life: Solar panel continuously charges the camera’s 6200mAh battery, supporting up to 6 months of operation without manual charging.
Enhance Your Setup with Wyze Removable Battery Packs
To further ensure your Wyze Battery Cam Pro stays powered, consider adding Wyze Removable Battery Packs. These 6200mAh rechargeable batteries are designed for quick swapping, so you never have to take your camera offline for charging.
Benefits of Wyze Removable Battery Packs
  • Long-Lasting Power: Each battery lasts up to 6 months on a single charge.
  • Convenient USB-C Charging: Fast and easy to recharge with a built-in USB-C port.
  • Compact and Lightweight: Easy to carry and swap without hassle.
Compatible with Wyze Battery Cam Pro and Duo Cam Doorbell.
Why Solar Power Your Wyze Battery Cam?
Using the Wyze Battery Cam Solar Panel with your Wyze Battery Cam Pro or Wyze Cam Outdoor offers several advantages:
  • Reduced Maintenance: Less frequent battery swaps or recharging means more time focused on security.
  • Eco-Friendly: Harness renewable solar energy to power your security system sustainably.
  • Ideal for Remote Locations: Perfect for cabins, RVs, or outdoor areas without easy access to power outlets.
  • Reliable Security: Keep your cameras running continuously to never miss a moment.
Summary: The Perfect Solar-Powered Security Setup
ProductKey BenefitPrice (Approx.)
Wyze Battery Cam Solar PanelExtends battery life with solar$24.99
Wyze Battery Cam ProHigh-res wireless security camera$89.98
Wyze Battery Cam Pro + Solar Panel BundleComplete solar-powered camera kit$109.98
Wyze Removable Battery PackExtra rechargeable battery$22.99
Outdoor Solar-Powered Security Camera Keep your Wyze Cam powered all day with solar energy. Wyze Battery Cam Pro Mounted Outdoors Wireless, weatherproof security with 2.5K HDR video. Solar Panel Mounted for Maximum Sunlight Flexible mounting options for perfect solar positioning.
Power your Wyze Battery Cam with the Wyze Battery Cam Solar Panel and enjoy extended, hassle-free security coverage. Whether you choose the camera alone, the solar panel accessory, or the bundled package, you’re investing in reliable, weatherproof, and smart home security that lasts.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery Pack
TypeAccessoryCameraCamera BundleAccessory
Price$24.99 (Solar Panel), $5.99 (USB-C Cable)$89.98 - $219.98 (depending on pack)$109.98$22.99
CompatibilityWyze Cam Outdoor v1/v2, Wyze Battery Cam ProWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Battery Cam Pro, Wyze Duo Cam Doorbell
Video ResolutionN/A2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)N/A
Power SourceSolar Panel (extends battery life)Removable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs + SolarRechargeable Battery Pack (6200mAh)
Battery CapacityN/A6200mAh6200mAh6200mAh
Battery LifeExtends battery lifeUp to 6 monthsUp to 6 months (with solar panel extension)Up to 6 months
Weather ResistanceIP65IP65IP65Operates -4°F to 122°F, <90% humidity
Mounting360° Freestyle Mount, mountable anywhereMultiple mounting options including wall/ceilingMultiple mounting options including wall/ceilingN/A
Cable Length13-foot weatherproof power cableN/AN/AN/A
WirelessN/AYes, 2.4 & 5 GHz WiFiYes, 2.4 & 5 GHz WiFiN/A
Motion DetectionN/ARadar + PIR Motion DetectionRadar + PIR Motion DetectionN/A
Spotlight & SirenN/AIntegrated Spotlight & SirenIntegrated Spotlight & SirenN/A
Local StorageN/ASupports microSD up to 256GBSupports microSD up to 256GBN/A
Dimensions173 mm x 120 mm x 17 mm2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches2.9 in x 1.6 in x 0.9 in
WeightN/A0.94 lbs0.94 lbs3.9 oz (110g)
Additional FeaturesWeather resistant, mountable anywhereIntegrated spotlight, two-way audio, local recordingIntegrated spotlight, two-way audio, local recordingUSB-C charging port, rechargeable lithium-ion
Charging TimeN/AApprox. 9 hoursApprox. 9 hoursApprox. 9 hours at 25°C
What is the Wyze Battery Cam Solar Panel and how does it work?The Wyze Battery Cam Solar Panel is an accessory designed to extend the battery life of Wyze Battery Cam Pro and Wyze Cam Outdoor cameras. It harnesses solar energy to provide continuous power, reducing the need for frequent manual recharging and ensuring your cameras stay operational for longer periods.
Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models. It is specifically designed to work with Wyze's wireless battery-powered cameras.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro features a rechargeable 6200mAh battery that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Can the Wyze Battery Cam Pro be used as a solar-powered security camera?Yes, when paired with the Wyze Battery Cam Solar Panel, the Wyze Battery Cam Pro becomes a solar-powered security camera, allowing for continuous operation without the need for manual recharging.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel is built with an IP65 weather-resistant rating, making it dustproof and weatherproof for reliable outdoor performance in various weather conditions.
What are the benefits of using a solar panel with my Wyze Battery Cam?Using a solar panel with your Wyze Battery Cam reduces maintenance by minimizing battery swaps and recharging, provides eco-friendly power, is ideal for remote locations without power outlets, and ensures reliable, continuous security coverage.
What is included in the Wyze Battery Cam Pro + Solar Panel Bundle?The Wyze Battery Cam Pro + Solar Panel Bundle includes the high-resolution Wyze Battery Cam Pro and the Wyze Battery Cam Solar Panel, offering a complete solar-powered security solution with flexible mounting options and weatherproof durability.
How do I install the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel comes with a 360° freestyle mount and a 13-foot weatherproof power cable, allowing you to easily mount it on walls, poles, or any outdoor surface for optimal sun exposure.
Are there removable battery packs available for the Wyze Battery Cam Pro?Yes, Wyze offers removable 6200mAh rechargeable battery packs for the Wyze Battery Cam Pro. These allow for quick swapping, so you never have to take your camera offline for charging.
What smart home integrations are supported by the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation.
What storage options are available for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro supports local storage with microSD cards up to 256GB and offers cloud storage options through Wyze Cam Plus.
How much does the Wyze Battery Cam Solar Panel cost?The Wyze Battery Cam Solar Panel is priced at approximately $24.99.
Can I use the Wyze Battery Cam Solar Panel for vacation homes or RVs?Yes, the Wyze Battery Cam Solar Panel is ideal for vacation homes, RVs, cabins, and other remote locations where access to power outlets may be limited.
How does the Wyze Battery Cam Solar Panel work to extend battery life?What are the installation requirements for the Wyze Battery Cam Solar Panel?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
