Extend Wyze Cam Battery Life with Compact Solar Panel
Extend Your Wyze Cam Battery Life with the Compact Solar Panel
If you're looking to maximize the battery performance of your Wyze Cam, especially the Wyze Battery Cam Pro, the
Wyze Battery Cam Solar Panel is the perfect accessory to keep your camera powered longer without frequent recharging. Designed for outdoor use and easy installation, this compact solar panel harnesses the sun’s energy to extend your camera’s battery life seamlessly.
Wyze Battery Cam Solar Panel: Power Your Camera with Sunlight
Key Features and Benefits
- Weather Resistant Design: Rated IP65, the solar panel withstands rain, dust, and harsh outdoor conditions, making it ideal for any environment.
- Compact and Mountable Anywhere: Measuring just 173 mm x 120 mm x 17 mm, it can be mounted with a 360° adjustable wall mount to capture optimal sunlight.
- Efficient Solar Power: With a 2.5W, 5VDC solar power rating, it provides steady charging to your Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2.
- Long 13-foot Power Cable: The included micro USB-C cable allows flexible placement of the panel away from the camera for better sun exposure.
- Complete Installation Kit: Comes with screws, wall anchors, and a quick start guide for hassle-free setup.
Attach this solar panel to your Wyze Battery Cam Pro and enjoy extended recording time powered by clean, renewable energy.
Wyze Battery Cam Pro: High-Performance Wireless Security Camera
Advanced Camera Specifications
- 2.5K HDR Video Resolution: Crystal-clear 2560 x 1440 video quality with H.264 encoding for sharp, detailed footage.
- Battery Life Up to 6 Months: Powered by a removable 6200mAh rechargeable battery pack, it offers long-lasting wireless operation.
- Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security by deterring intruders.
- Radar + PIR Motion Detection: Dual sensors provide accurate motion alerts with fewer false alarms.
- Weatherproof IP65 Rating: Durable against rain and dust, suitable for outdoor use in temperatures from -20°C to 50°C.
- Connectivity: Supports both 2.4 GHz and 5 GHz WiFi bands for reliable wireless performance.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Two-Way Audio: Communicate through the camera with a built-in speaker and MEMS digital microphone.
Dimensions and Design
- Compact size (2.5 x 1.8 x 3.5 inches) and lightweight (0.94 lbs) with a matte finish and standard 1/4” - 20 mounting thread.
- Available in Black or White to blend with your home exterior.
Wyze Battery Cam Pro + Solar Panel Bundle: Ready for Extended Outdoor Security
For those who want an all-in-one solution, the
Wyze Battery Cam Pro + Solar Panel bundle offers the camera and solar panel together at a great value. This combo ensures your camera stays powered longer with minimal maintenance, perfect for vacation homes, RVs, or any outdoor setting where power outlets are limited.
Bundle Highlights
- All the advanced features of the Wyze Battery Cam Pro.
- Solar panel included to keep your camera charged using sunlight.
- Weatherproof and durable for year-round outdoor use.
- Supports local storage up to 256 GB microSD and cloud recording with Cam Plus.
Why Choose Wyze Battery Cam with Solar Panel?
Combining the Wyze Battery Cam Pro with the compact solar panel accessory means you get continuous, wire-free security monitoring without worrying about battery drain. The solar panel’s weather-resistant design and flexible mounting options make it easy to install in any sunny spot, while the camera’s advanced features ensure you never miss a moment.
Ideal Use Cases
- Front porch or backyard security where power outlets are unavailable.
- Vacation homes or cabins needing long-term monitoring.
- RVs, campers, and travel trailers for on-the-go security.
- Anywhere you want to reduce battery charging frequency and enjoy eco-friendly power.
Summary of Product Specs
Product | Battery Life | Weather Resistance | Video Resolution | Key Features |
Wyze Battery Cam Pro | Up to 6 months | IP65 | 2.5K HDR | Spotlight, Siren, Radar + PIR, 2.4/5 GHz WiFi |
Wyze Battery Cam Solar Panel | Solar-powered charging | IP65 | N/A | 2.5W solar panel, 13 ft cable, 360° mount |
Wyze Battery Cam Pro + Solar Panel | Up to 6 months + solar | IP65 | 2.5K HDR | All camera features + solar charging |
Alt text: Wyze Battery Cam Pro mounted outdoors with solar panel in sunlight
Enhance your Wyze Cam experience with the compact solar panel accessory and enjoy extended battery life powered by the sun. Whether you choose the camera alone or the bundled option, you get reliable, wire-free security with smart features and eco-friendly power.
Feature | Wyze Battery Cam Solar Panel | Wyze Battery Cam Pro | Wyze Battery Cam Pro + Solar Panel |
Type | Accessory | Camera | Camera Bundle |
Video Resolution | N/A | 2.5K HDR (2560 x 1440) | 2.5K HDR (2560 x 1440) |
Power Source | Solar Panel (extends battery life) | Removable, Rechargeable Battery Packs (6200mAh) | Removable, Rechargeable Battery Packs + Solar Panel |
Battery Life | Extends battery life | Up to 6 months | Up to 6 months (extended with solar panel) |
Charging Time | N/A | Approximately 9 hours | Approximately 9 hours |
Weather Resistance | IP65 (Weatherproof and dustproof) | IP65 Weatherproof | IP65 Weatherproof |
Compatibility | Wyze Cam Outdoor v1/v2, Wyze Battery Cam Pro | N/A | N/A |
Mounting | 360° Freestyle Mount, mountable anywhere | Wall mount included, 1/4” - 20 standard mount | Wall mount included, 1/4” - 20 standard mount |
Cable Length | 13-foot weatherproof power cable | N/A | N/A |
Connectivity | N/A | 2.4 & 5 GHz WiFi, Bluetooth 5.1 | 2.4 & 5 GHz WiFi, Bluetooth 5.1 |
Motion Detection | N/A | Radar + PIR Motion Detection | Radar + PIR Motion Detection |
Spotlight & Siren | N/A | Integrated Spotlight (150 lumens), 100 dB siren | Integrated Spotlight (150 lumens), 100 dB siren |
Local Storage | N/A | Supports up to 256 GB microSD cards | Supports up to 256 GB microSD cards |
Dimensions | 173 mm x 120 mm x 17 mm | 2.5 x 1.8 x 3.5 inches | 2.5 x 1.8 x 3.5 inches |
Weight | Not specified | 0.94 lbs (camera only) | 0.94 lbs (camera only) |
Price | $24.99 (Solar Panel), $5.99 (USB-C Adapter Cable) | $89.98 (1 Pack) | $109.98 (Bundle) |
How does the Wyze Battery Cam Solar Panel extend my camera's battery life?
The Wyze Battery Cam Solar Panel harnesses solar energy to continuously charge your Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2, reducing the need for frequent manual recharging and ensuring your camera stays powered for longer periods.Is the Wyze Battery Cam Solar Panel weatherproof for outdoor use?
Yes, the Wyze Battery Cam Solar Panel is rated IP65, making it weather resistant and suitable for outdoor use in rain, dust, and harsh environmental conditions.What cameras are compatible with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models.How easy is it to install the Wyze Battery Cam Solar Panel?
Installation is simple and hassle-free. The solar panel comes with a 360° adjustable wall mount, a 13-foot power cable for flexible placement, screws, wall anchors, and a quick start guide.What are the key features of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro features 2.5K HDR video resolution, up to 6 months of battery life, a built-in spotlight and 100 dB siren, radar and PIR motion detection, IP65 weatherproof rating, dual-band WiFi (2.4 GHz and 5 GHz), smart home integration, and two-way audio.Can I use the Wyze Battery Cam Pro and Solar Panel bundle for remote locations?
Yes, the Wyze Battery Cam Pro + Solar Panel bundle is ideal for remote locations such as vacation homes, cabins, RVs, and areas without easy access to power outlets, providing reliable, wire-free security monitoring.How long is the power cable included with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel includes a 13-foot micro USB-C power cable, allowing you to position the panel for optimal sunlight exposure.Does the Wyze Battery Cam Pro support local and cloud storage?
Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB and offers cloud recording with a Cam Plus subscription.What is the video quality of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro records in crystal-clear 2.5K HDR (2560 x 1440) resolution, providing sharp and detailed video footage.Is the Wyze Battery Cam Pro compatible with smart home systems?
Yes, the Wyze Battery Cam Pro works with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
What are the installation requirements for the Wyze Battery Cam Solar Panel?Can the Wyze Battery Cam Solar Panel be used in all weather conditions?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam or solar panel?
