Rugged Solar Panel Kits for Long-Term Wyze Camera Surveillance
Rugged Solar Panel Kits for Long-Term Wyze Surveillance
When it comes to setting up a reliable, long-term outdoor surveillance system with Wyze cameras, having a rugged solar panel kit is essential. These kits ensure your Wyze Battery Cam Pro and Wyze Cam Outdoor stay powered continuously without the hassle of frequent recharging. Whether you’re monitoring your home, RV, or remote property, Wyze’s solar-powered solutions provide weather-resistant, flexible, and efficient power options to keep your security system running smoothly.
Wyze Battery Cam Solar Panel: Extend Your Camera’s Battery Life
The Wyze Battery Cam Solar Panel is designed specifically to support Wyze’s outdoor cameras by converting sunlight into continuous power. This accessory is perfect for users who want to maximize their camera uptime without worrying about battery drain.
Key Features:
  • Continuous Power Supply: Keeps your Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2 recording longer by providing a steady solar charge.
  • Weather Resistant: Rated IP65 for dust and water resistance, making it ideal for all weather conditions.
  • Flexible Mounting: Comes with a 360° freestyle mount and a 13-foot weatherproof power cable, allowing you to position the panel for optimal sun exposure anywhere.
  • Easy Installation: Mount it on walls, poles, or other outdoor surfaces without complicated wiring.
This solar panel is a cost-effective way to maintain your camera’s battery life, especially in remote or off-grid locations where power outlets are unavailable.
Wyze Battery Cam Pro: Advanced Wireless Security Camera
The Wyze Battery Cam Pro is a powerful, wire-free security camera that pairs perfectly with the solar panel for a truly autonomous surveillance setup.
Highlights:
  • 2.5K HDR Video Resolution: Crystal-clear video with enhanced color and detail, day or night.
  • Integrated Spotlight & Siren: 150 lumens LED spotlight and a 100 dB siren to deter intruders.
  • Radar + PIR Motion Detection: Dual sensors for precise and early motion alerts.
  • Removable Rechargeable Batteries: Hot-swap batteries to avoid downtime.
  • IP65 Weatherproof: Built to withstand rain, dust, and extreme temperatures (-20°C to 50°C).
  • Dual-Band WiFi Support: Connects easily to both 2.4 GHz and 5 GHz networks.
  • Local and Cloud Storage: Supports up to 256GB microSD cards and optional Cam Plus cloud recording.
With the Wyze Battery Cam Pro, you get a versatile, high-performance camera that can be powered indefinitely when paired with the Wyze Battery Cam Solar Panel.
Wyze Battery Cam Pro + Solar Panel Bundle: Ready for Rugged Outdoor Use
For those looking for an all-in-one solution, the Wyze Battery Cam Pro + Solar Panel bundle offers convenience and value. This package combines the advanced features of the Battery Cam Pro with the continuous power benefits of the solar panel.
Bundle Benefits:
  • Plug-and-Play Solar Power: Easily convert your camera into a solar-powered security system.
  • Up to 6 Months Battery Life: Thanks to the 6200mAh rechargeable battery and solar charging.
  • Weatherproof and Durable: Both camera and solar panel are IP65 rated for outdoor resilience.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless automation.
  • Flexible Mounting Options: Includes standard mounts and a long-range power cable for versatile installation.
This bundle is ideal for users who want a rugged, maintenance-free surveillance setup that can operate in harsh environments for extended periods.
Additional Power Options: Wyze Removable Battery Pack
To complement your solar-powered setup, the Wyze Removable Battery Pack offers a convenient way to keep your cameras running without interruption.
Features:
  • 6200mAh Capacity: Matches the Battery Cam Pro’s battery for up to 6 months of use.
  • Quick Recharge: Approximately 9 hours to full charge via USB-C.
  • Lightweight and Compact: Easy to swap batteries on the go.
  • Durable Design: Operates in temperatures from -20°C to 50°C, suitable for outdoor use.
Having extra battery packs on hand ensures your surveillance system remains active even during extended periods of low sunlight.
Why Choose Wyze Solar-Powered Surveillance?
“Harnessing solar power for your Wyze cameras means less downtime, fewer battery swaps, and a greener, more sustainable security solution.”
Wyze’s solar panel kits and battery cameras are designed with rugged outdoor use in mind. Their weatherproof ratings, flexible mounting options, and long battery life make them perfect for:
  • Remote properties without easy access to power.
  • RVs, campers, and travel trailers needing reliable security.
  • Outdoor areas exposed to harsh weather conditions.
  • Users seeking a wire-free, low-maintenance surveillance system.
Summary of Rugged Solar Surveillance Solutions
ProductKey BenefitsWeather ResistanceBattery LifeVideo Quality
Wyze Battery Cam Solar PanelContinuous solar power, flexible mountingIP65N/A (Accessory)N/A
Wyze Battery Cam Pro2.5K HDR, spotlight, radar + PIR detectionIP65Up to 6 months2560 x 1440 (2.5K)
Wyze Battery Cam Pro + Solar Panel BundleAll-in-one solar-powered camera solutionIP65Up to 6 months2560 x 1440 (2.5K)
Wyze Removable Battery PackSpare battery, quick rechargeSuitable for outdoorsUp to 6 monthsN/A
Outdoor Solar-Powered Security Camera Setup Solar-powered Wyze Battery Cam Pro mounted outdoors for continuous surveillance Wyze Battery Cam Pro in Action Wyze Battery Cam Pro providing crystal-clear 2.5K HDR video with integrated spotlight
Harness the power of the sun and keep your Wyze surveillance system running longer with rugged, weatherproof solar panel kits and battery cameras designed for the outdoors. Whether you choose individual components or the convenient bundle, Wyze offers reliable, wire-free security solutions that stand up to the elements and keep you protected.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam ProWyze Battery Cam Pro + Solar Panel
TypeAccessoryCameraCamera Bundle
Video ResolutionN/A2560 x 1440 (2.5K)2560 x 1440 (2.5K)
WirelessN/AYesYes
Power SourceSolar Panel (extends battery life)Removable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs + Solar Panel
Battery CapacityN/A6200mAh6200mAh
Battery LifeExtends battery lifeUp to 6 MonthsUp to 6 Months (extended with solar panel)
Charging TimeN/AApproximately 9 hoursApproximately 9 hours
Weather ResistanceIP65IP65IP65
Operating TemperatureN/A-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)
Motion DetectionN/ARadar + PIRRadar + PIR
Integrated Spotlight & SirenN/AYesYes
Local Storage SupportN/AUp to 256 GB microSD cardsUp to 256 GB microSD cards
Cloud StorageN/ACam Plus subscriptionCam Plus subscription
Mounting360° Freestyle Mount, weatherproof1/4” - 20 standard mount1/4” - 20 standard mount
Power Cable Length13-foot weatherproof cableN/AIncluded with solar panel
Dimensions173 mm x 120 mm x 17 mm2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches
WeightN/A0.94 lbs0.94 lbs
Color OptionsN/ABlack, WhiteBlack, White
Price$24.99 (sold out/unavailable)$89.98 (1 pack)$109.98
Included ItemsSolar PanelCameraCamera + Solar Panel
Additional FeaturesWeather resistant, mountable anywhereIntegrated Spotlight, Radar + PIR, 2.4 & 5 GHz WiFi, Two-way audioIntegrated Spotlight, Radar + PIR, 2.4 & 5 GHz WiFi, Two-way audio, Solar powered extension
What is the Wyze Battery Cam Solar Panel and how does it work?The Wyze Battery Cam Solar Panel is an accessory designed to provide continuous solar power to Wyze outdoor cameras, such as the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2. It converts sunlight into energy, keeping your camera charged and reducing the need for frequent battery replacements or recharging.
Are Wyze solar panel kits weatherproof for outdoor use?Yes, Wyze solar panel kits and cameras are rated IP65 for dust and water resistance, making them ideal for all weather conditions, including rain, dust, and extreme temperatures.
How long does the Wyze Battery Cam Pro last on a single charge?The Wyze Battery Cam Pro can last up to 6 months on a single charge, thanks to its 6200mAh rechargeable battery. When paired with the Wyze Battery Cam Solar Panel, the camera can operate indefinitely with sufficient sunlight.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers 2.5K HDR video resolution, an integrated 150 lumens LED spotlight, a 100 dB siren, radar and PIR motion detection, removable rechargeable batteries, IP65 weatherproofing, dual-band WiFi support, and both local (microSD) and cloud storage options.
Can I use the Wyze Battery Cam Pro and Solar Panel bundle for remote or off-grid locations?Yes, the Wyze Battery Cam Pro + Solar Panel bundle is ideal for remote properties, RVs, campers, and other off-grid locations where access to power outlets is limited. The solar panel ensures continuous power, and the camera’s weatherproof design makes it suitable for harsh outdoor environments.
How easy is it to install the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is designed for easy installation. It comes with a 360° freestyle mount and a 13-foot weatherproof power cable, allowing flexible placement on walls, poles, or other outdoor surfaces without complicated wiring.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The bundle includes the Wyze Battery Cam Pro, the Wyze Battery Cam Solar Panel, standard mounting hardware, and a long-range power cable. This all-in-one package provides a plug-and-play solar-powered security solution for outdoor surveillance.
Is the Wyze Removable Battery Pack compatible with the Wyze Battery Cam Pro?Yes, the Wyze Removable Battery Pack is designed to match the Wyze Battery Cam Pro’s battery, offering up to 6 months of use per charge. It is lightweight, compact, and can be quickly swapped to keep your camera running without interruption.
Can Wyze solar-powered cameras be integrated with smart home systems?Yes, Wyze solar-powered cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration and automation within your smart home ecosystem.
What are the benefits of using a solar-powered surveillance system with Wyze cameras?Using a solar-powered surveillance system with Wyze cameras reduces downtime, minimizes battery swaps, and provides a sustainable, wire-free security solution. It is especially beneficial for outdoor, remote, or hard-to-reach locations.
Can you tell me more about the features of the Wyze Battery Cam Solar Panel?How does the Wyze Battery Cam Pro work with the solar panel?Do you have any ongoing sales or discounts for the Wyze Battery Cam or solar panel?
