Affordable Smart Home Front Porch Security System with Video
Affordable Smart Home Front Porch Security System with Video Monitor
Securing your front porch has never been easier or more affordable. With the latest smart home technology, you can monitor your doorstep in real-time, communicate with visitors, and control your door locks remotely—all from your smartphone. This guide highlights the best smart home front porch security systems featuring video monitoring, designed to keep your home safe without breaking the bank.
The Front Porch Security Bundle: Complete Video Monitoring & Access Control
The Front Porch Security Bundle is the ultimate all-in-one solution for smart home front porch security. It combines high-definition video monitoring with smart lock technology, giving you full control and peace of mind.
Key Features:
  • 1080p HD Video Doorbell & Chime: See your front porch clearly with crisp 1080p resolution. The two-way audio lets you greet visitors or delivery personnel remotely.
  • Wyze Lock Integration: Lock or unlock your door from anywhere using the Wyze app. You can also view your lock history to monitor access.
  • Multiple Variants: Choose from options including Wyze Lock Bolt Matte Black paired with Wyze Video Doorbell Pro or Video Doorbell v2, and bundles that include the Wyze Cam V3 for enhanced coverage.
  • Affordable Pricing: Starting at just $124.96, this bundle offers premium features at a budget-friendly price.
  • Remote Access & Control: Manage your front porch security seamlessly from your smartphone, whether you're at home or away.
"You can lock/unlock the door right from the Wyze Video Doorbell viewer, making home access management effortless."
Smart Home Front Porch Security Monitor your front porch with Wyze’s smart video doorbell and camera system.
Wyze Sense Hub: The Central Brain for Your Home Monitoring
To enhance your front porch security system, the Wyze Sense Hub acts as the central controller connecting all your monitoring devices. It ensures that alerts and notifications are sent promptly to your phone, keeping you informed of any activity.
Why You Need the Wyze Sense Hub:
  • Core Connectivity: Links all Wyze Sense sensors and devices for a unified security system.
  • Real-Time Alerts: Receive instant notifications for motion, door activity, or other sensor triggers.
  • Easy Integration: Works seamlessly with Wyze Home Monitoring and other Wyze smart devices.
  • Compact & Reliable: Small footprint designed to fit discreetly in your home.
Wyze Sense Keypad: Remote Arm & Disarm for Added Security
The Wyze Sense Keypad offers convenient control over your home security system, allowing you to arm or disarm it remotely.
Features:
  • Remote Disarming: Control your security system from anywhere, perfect for when you arrive home or leave.
  • Emergency Button: Quickly send alerts to first responders in case of an emergency.
  • Indoor Use: Designed for easy installation inside your home.
  • Requires Wyze Sense Hub: Works in conjunction with the Wyze Sense Hub for full functionality.
Wyze Lock Keypad Secure your home with the Wyze Sense Keypad for easy arming and disarming.
Wyze Sense Motion Sensor: Detect Movement with Precision
Enhance your front porch security with the Wyze Sense Motion Sensor, which detects motion up to 25 feet away with a 120° field of view.
Highlights:
  • Adjustable Sensitivity: Customize detection settings to reduce false alarms.
  • Long Battery Life: Up to 18 months on a single battery.
  • Flexible Installation: Use adhesive backing or screws for secure mounting.
  • Compatible with Wyze Sense Hub: Integrates smoothly into your existing Wyze security system.
Additional Sensors for a Smarter Home
Wyze Sense Climate Sensor
Monitor temperature and humidity in your home to ensure a comfortable environment. Ideal for basements, attics, or any room where climate control matters.
  • 500 ft Range: Place sensors in distant rooms.
  • Sleek Design: White matte finish blends into any decor.
  • Easy Mounting: Adhesive or screws for flexible placement.
Protect your home from water damage by detecting leaks early.
  • Leak Alerts: Get notified immediately if water is detected.
  • Indoor Use Only: Perfect for basements, kitchens, or bathrooms.
  • Compatible with Wyze Sense Hub: Integrates with your home monitoring system.
Why Choose This Affordable Smart Home Front Porch Security System?
Investing in a smart home front porch security system with video monitoring is a smart way to protect your home and loved ones. The Wyze Front Porch Security Bundle and complementary Wyze Sense devices offer a comprehensive, affordable, and easy-to-use solution that fits any budget.
  • Complete Security: Video, motion detection, door access, and environmental monitoring.
  • Remote Control: Manage your home security from anywhere.
  • Expandable System: Add sensors and devices as needed.
  • User-Friendly App: Intuitive Wyze app for seamless control and notifications.
Secure your front porch today with this affordable smart home system and enjoy peace of mind knowing your home is protected 24/7.
ProductTypePrice (USD)Key FeaturesRequiresIndoor/Outdoor UseConnectivity/CompatibilityNotes
The Front Porch Security BundleCameras Bundle123.99 - 173.97Wyze Video Doorbell (1080p HD), Two-way audio, Wyze Lock (remote lock/unlock, lock history)Wyze appIndoor/OutdoorWyze appMultiple variants; some sold out
Wyze Sense HubHome Monitoring45.98Connects monitoring components, sends alertsCore for Wyze Home MonitoringIndoorWyze Home Monitoring SystemRequired for Wyze Sense sensors and keypad
Wyze Sense KeypadHome Monitoring27.98Arm/disarm system remotely, emergency buttonWyze Sense HubIndoorWyze Home MonitoringPermanent adhesive mounting, max 100 accessories
Wyze Sense Motion SensorHome Monitoring20.98Detects motion, adjustable sensitivity, 25 ft range, 120° FOVWyze Sense HubIndoorWyze Sense v2, Wyze Home MonitoringAdhesive or screw installation, battery life up to 18 months
Wyze Sense Climate SensorHome Monitoring41.98 (3 Pack)Tracks temperature and humidity, 500 ft range, sleek designWyze Sense HubIndoorWyze Sense v2, Wyze Home MonitoringPeel-and-stick or screw mounting, battery life 1.5 years
Wyze Sense Leak Sensor & ProbeHome Monitoring13.98 - 55.98Leak detection, sensor range up to 500 ft, indoor use onlyWyze Sense HubIndoorWyze Sense v2, Wyze Home MonitoringMultiple styles: 2 Probes or 3 Sensors + 1 Probe
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a 1080p HD video doorbell with chime, Wyze Lock integration for remote door access, and options to add devices like the Wyze Lock Bolt Matte Black, Wyze Video Doorbell Pro or v2, and Wyze Cam V3 for enhanced coverage. This bundle provides comprehensive video monitoring and smart lock control for your front porch.
How does the Wyze video doorbell enhance front porch security?The Wyze video doorbell offers 1080p HD video monitoring, two-way audio for communicating with visitors, and real-time notifications to your smartphone. It allows you to see, hear, and speak to anyone at your front door, providing an extra layer of security and convenience.
Can I control my front door lock remotely with this system?Yes, with Wyze Lock integration, you can lock or unlock your front door from anywhere using the Wyze app. You can also view your lock history and manage access remotely, making home access management effortless.
What is the Wyze Sense Hub and why do I need it?The Wyze Sense Hub is the central controller for your Wyze security devices. It connects all Wyze Sense sensors and devices, ensuring you receive real-time alerts and notifications for motion, door activity, and other sensor triggers. It is essential for integrating and managing your smart home security system.
How does the Wyze Sense Keypad improve home security?The Wyze Sense Keypad allows you to arm or disarm your security system remotely and features an emergency button to quickly alert first responders. It is designed for easy indoor installation and works in conjunction with the Wyze Sense Hub for full functionality.
What are the benefits of the Wyze Sense Motion Sensor?The Wyze Sense Motion Sensor detects movement up to 25 feet away with a 120° field of view. It features adjustable sensitivity to reduce false alarms, long battery life of up to 18 months, and flexible installation options. It integrates seamlessly with the Wyze Sense Hub for comprehensive home monitoring.
Can I monitor temperature and humidity with this system?Yes, the Wyze Sense Climate Sensor allows you to monitor temperature and humidity in your home. It has a 500 ft range, a sleek white matte design, and can be easily mounted with adhesive or screws, making it ideal for basements, attics, or any room where climate control is important.
How does the Wyze Sense Leak Sensor protect my home?The Wyze Sense Leak Sensor and Probe detect water leaks early and send instant alerts to your phone, helping you prevent water damage. These sensors are designed for indoor use and integrate with the Wyze Sense Hub for a smarter, safer home.
Is the Wyze smart home front porch security system affordable?Yes, the Wyze Front Porch Security Bundle starts at just $124.96, offering premium features like HD video monitoring, smart lock control, and sensor integration at a budget-friendly price.
Can I expand my Wyze smart home security system?Absolutely. The Wyze smart home security system is expandable, allowing you to add additional sensors and devices as needed to customize and enhance your home’s security.
How do I control and monitor my Wyze security system?You can control and monitor your Wyze security system using the intuitive Wyze app on your smartphone. The app allows you to manage devices, receive real-time notifications, view video feeds, and control access remotely from anywhere.
What are the key features of the Front Porch Security Bundle?How does the Wyze Sense Hub enhance my front porch security system?Are there any ongoing sales or discounts available for the Front Porch Security Bundle?
