All-in-One Smart Home Security Bundle for Front Porch Entry
Comprehensive Smart Home Security Bundle for Front Porch Entry
Securing your front porch is essential for protecting your home and loved ones. The Front Porch Security Bundle by Wyze offers an all-in-one solution combining smart video doorbells, locks, and sensors to keep your entryway safe and monitored 24/7. This comprehensive bundle integrates advanced technology with user-friendly controls, making it the perfect choice for modern homeowners seeking peace of mind.
The Front Porch Security Bundle: Ultimate Protection at Your Doorstep
High-Definition Video Doorbell with Two-Way Audio
The bundle features the Wyze Video Doorbell and Chime, delivering crisp 1080p HD video so you can clearly see who’s at your front door. Whether you’re home or away, the two-way audio lets you greet visitors or deter unwanted guests instantly through your smartphone.
  • 1080p HD video quality for clear, detailed monitoring
  • Two-way audio to communicate directly with visitors
  • Remote viewing and control via the Wyze app
  • Compatible variants include Wyze Lock Bolt Matte Black paired with Video Doorbell Pro or Video Doorbell v2 for enhanced security options
Smart Lock Integration for Keyless Entry
Included in the bundle is the Wyze Lock, which allows you to lock or unlock your door remotely. You can also view your lock history anytime, ensuring you know who accessed your home and when.
  • Remote locking/unlocking from anywhere
  • Real-time lock activity logs in the Wyze app
  • Easy installation and seamless integration with the video doorbell
  • Matte black finish option for a sleek, modern look
Did you know? You can lock or unlock your door directly from the Wyze Video Doorbell viewer, streamlining your front porch security management.
Outdoor smart home security lifestyle Stay connected and secure with smart cameras monitoring your front porch.
Enhance Your Security with Wyze Sense Entry Sensor
To complement the video and lock system, the Wyze Sense Entry Sensor detects when doors or windows open or close, providing an additional layer of security.
  • Works with Wyze Sense v2 or Wyze Home Monitoring systems
  • Instant alerts when entry points are accessed
  • Sold in convenient 3-packs for multiple doors or windows
  • Easy to install and discreetly monitors your home’s vulnerable points
Wyze Sense Hub: The Central Command for Your Security Devices
The Wyze Sense Hub acts as the brain of your home monitoring system, connecting all sensors and sending instant alerts to your phone.
  • Supports up to 100 sensors for scalable security
  • Multiple communication methods: Ethernet, WiFi (2.4 GHz), Bluetooth, and RF
  • Built-in rechargeable battery with 10-hour backup for uninterrupted protection
  • Compact design fits seamlessly into your home environment
Smart lock keypad lifestyle Control your smart lock and keypad effortlessly for enhanced front porch security.
Why Choose This Smart Home Security Bundle?
  • Comprehensive coverage: Video, audio, lock control, and entry detection all in one package
  • Remote access: Manage your front porch security from anywhere using the Wyze app
  • Easy installation: Designed for DIY setup with user-friendly instructions
  • Affordable pricing: Multiple bundle variants to fit your budget and security needs
  • Expandable system: Add more Wyze Sense sensors or accessories as needed
Protect your home’s first line of defense with a smart security system that works together seamlessly.
Summary of Included Products
The Front Porch Security Bundle Ultimate smart home front porch security with video doorbell, chime, and smart lock. Wyze Sense Entry Sensor Detects door/window open and close events for added security. Wyze Sense Hub Central hub connecting sensors and sending alerts.
Secure your front porch with this all-in-one smart home security bundle and enjoy peace of mind knowing your home is protected with the latest technology.
FeatureThe Front Porch Security BundleWyze Sense Entry SensorWyze Sense Hub
TypeCamerasHome MonitoringHome Monitoring
DescriptionSmart home front porch security with video doorbell, chime, and lockDetects when things open/close; requires Wyze Sense HubConnects monitoring components and sends alerts
Video Resolution1080p HD (Video Doorbell)N/AN/A
Two-way AudioYes (Video Doorbell and Chime)NoNo
Remote Lock/UnlockYes (Wyze Lock)NoNo
Lock HistoryYes (via Wyze app)NoNo
Requires HubNoYes (Wyze Sense Hub)N/A (Hub itself)
ConnectivityWi-FiRF (915 MHz)Ethernet, WiFi 2.4 GHz, Bluetooth 4.1+ BLE, 915 MHz RF
Sensor SupportN/AEntry sensors (open/close detection)Supports up to 100 sensors
BatteryWyze Lock: Batteries (4x AA)N/A (sensor battery not specified here)Built-in rechargeable battery (10 hours backup)
Indoor/Outdoor UseIndoor/Outdoor (Video Doorbell and Lock)IndoorIndoor only
Price$123.99 - $173.97 (varies by variant)$41.98 (3 Pack)$45.98
Included ItemsWyze Video Doorbell, Chime, Wyze Lock variants3 Entry SensorsHub, Power Adapter, Ethernet Cable, Window Decals, Quick Start Guide
Special FeaturesView and communicate via video doorbell; remote lock controlDetects open/close eventsCentral hub for sensor connectivity and alerts
Weather ResistanceNot specifiedNot specifiedIndoor use only
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a high-definition video doorbell with chime, a smart lock, Wyze Sense Entry Sensors, and the Wyze Sense Hub. This all-in-one package provides comprehensive front porch security with video monitoring, keyless entry, and real-time alerts.
How does the Wyze Video Doorbell enhance front porch security?The Wyze Video Doorbell offers 1080p HD video quality and two-way audio, allowing you to see and communicate with visitors at your front door from anywhere using the Wyze app. It helps deter unwanted guests and keeps you connected to your home at all times.
Can I control the Wyze Smart Lock remotely?Yes, the Wyze Smart Lock allows you to lock or unlock your door remotely through the Wyze app. You can also view real-time lock activity logs, ensuring you always know who accessed your home and when.
What is the Wyze Sense Entry Sensor and how does it work?The Wyze Sense Entry Sensor detects when doors or windows are opened or closed. It sends instant alerts to your phone, providing an extra layer of security for your home. The sensors are easy to install and can be used on multiple entry points.
What role does the Wyze Sense Hub play in the security system?The Wyze Sense Hub acts as the central command center for your security devices. It connects up to 100 sensors and sends instant alerts to your phone. The hub supports Ethernet, WiFi, Bluetooth, and RF connections, and features a built-in rechargeable battery for backup power.
Is the Wyze Front Porch Security Bundle easy to install?Yes, the Wyze Front Porch Security Bundle is designed for easy DIY installation. The components come with user-friendly instructions, making it simple for homeowners to set up and start protecting their front porch quickly.
Can I expand my Wyze security system with additional sensors?Absolutely. The Wyze security system is expandable, allowing you to add more Wyze Sense Entry Sensors or other compatible accessories as your security needs grow.
Does the Wyze app allow remote management of my front porch security?Yes, the Wyze app enables you to manage your front porch security from anywhere. You can view live video, communicate with visitors, lock or unlock your door, and receive instant alerts all through the app.
Are there different bundle variants available for the Wyze Front Porch Security Bundle?Yes, the Wyze Front Porch Security Bundle offers multiple variants, such as pairing the Wyze Lock Bolt Matte Black with either the Video Doorbell Pro or Video Doorbell v2, allowing you to choose the best option for your home and budget.
What are the main benefits of choosing the Wyze Front Porch Security Bundle?The main benefits include comprehensive coverage with video, audio, lock control, and entry detection; remote access and management via the Wyze app; easy DIY installation; affordable pricing; and the ability to expand your system as needed.
What features does the Wyze Sense Entry Sensor offer for added security?How does the Wyze Sense Hub connect all the security devices in the bundle?Are there any ongoing promotions or discounts available for the security bundle?
