Expandable Home Security Monitoring System with Peel Stick Sensors
Protect your home effortlessly with a customizable and expandable home security system designed to keep every corner safe. Featuring advanced peel stick sensors and smart cameras, these solutions offer seamless installation, robust monitoring, and smart alerts to give you peace of mind.
Whole Home Security Starter Kit: Comprehensive Protection Made Simple
The
Whole Home Security Starter Kit is the perfect entry point for anyone looking to secure their home with an expandable system. This all-in-one bundle includes:
- Wyze Cam v4: A high-definition smart camera with 2.5K QHD resolution and enhanced color night vision.
- Wyze Video Doorbell v2: Monitor your front door with real-time alerts and HD video.
- Wyze Home Monitoring Starter Kit: Includes peel stick sensors that easily attach to doors and windows without tools.
Key Features:
- Expandable Sensor Support: Add up to 100 sensors to cover every entry point.
- Easy Peel Stick Installation: No drilling or complicated setup; sensors stick firmly and discreetly.
- Smart Alerts: Receive instant notifications on your phone when sensors detect activity.
- Integrated App Control: Manage cameras, sensors, and alerts from a single intuitive app.
This starter kit is designed to grow with your needs, allowing you to add more sensors and cameras as your security demands increase.
Wyze Cam v4: Crystal Clear Security, Day and Night
The
Wyze Cam v4 is a standout smart camera that delivers unmatched clarity and smart features for your home security system.
Why Choose Wyze Cam v4?
- 2.5K Quad HD Resolution: Capture every detail with crystal-clear video quality.
- Enhanced Color Night Vision: See vibrant colors even in low-light conditions, unlike traditional black-and-white night vision.
- Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
- 24/7 Local Recording: Supports continuous recording to a microSD card (up to 256GB) without subscription fees.
- Weather Resistant (IP65): Suitable for both indoor and outdoor use.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Easy Setup: Bluetooth-enabled for hassle-free installation with a magnetic mount—no screws or tools needed.
With its wide 115.9° field of view and AI-powered auto-zoom tracking, the Wyze Cam v4 keeps a vigilant eye on your property, focusing on what matters most.
Wyze Sense Hub: The Central Brain for Your Security Network
At the heart of your expandable security system is the
Wyze Sense Hub, which connects all your sensors and devices to keep your home monitored efficiently.
Hub Highlights:
- Supports Up to 100 Sensors: Easily expand your system with additional peel stick sensors for doors, windows, and more.
- Multiple Communication Methods: Connects via Ethernet, Wi-Fi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF for reliable performance.
- Built-in Rechargeable Battery: Provides up to 10 hours of backup power during outages.
- Loud 88 dB Siren: Alerts you and deters intruders with a powerful alarm.
- Compact and Stylish Design: Matte white base with a grey speaker top fits discreetly in any room.
The Sense Hub acts as the command center, ensuring all sensors communicate seamlessly and alerts reach you instantly.
Wyze Bulb Cam: Dual-Purpose Security and Lighting Solution
Enhance your home security with the
Wyze Bulb Cam, a unique 2-in-1 device that combines a smart LED light bulb with a 2K HD security camera.
Features That Shine:
- 2K HD Video with Color Night Vision: Clear video day and night with vibrant colors.
- Motion-Activated Light: Automatically lights up your space when motion is detected, improving safety and visibility.
- 95 dB Siren: Loud enough to scare off unwanted visitors.
- Easy Installation: Fits standard E26 light sockets—no extra wiring needed.
- IP65 Weather Resistant: Perfect for outdoor fixtures like porches and garages.
- Smart Controls: Schedule lighting, set motion-activated triggers, and control remotely via the Wyze app.
- Local and Cloud Storage: Supports microSD cards up to 256GB and cloud storage options.
This device is ideal for securing outdoor areas while providing functional lighting, making it a smart addition to any expandable home security setup.
Why Choose an Expandable System with Peel Stick Sensors?
Peel stick sensors offer a hassle-free way to secure your home without damaging walls or doors. Their easy installation and wireless connectivity make expanding your security system simple and flexible.
- No Tools Required: Stick sensors on doors, windows, or other entry points.
- Wireless and Reliable: Communicate with the Sense Hub up to 500 feet away.
- Customizable Alerts: Tailor notifications to your lifestyle and security needs.
- Seamless Integration: Works perfectly with Wyze cameras and other smart devices.
Conclusion
Building a secure home has never been easier with Wyze’s expandable home security monitoring system featuring peel stick sensors. From the comprehensive
Whole Home Security Starter Kit to the advanced
Wyze Cam v4 and versatile
Wyze Bulb Cam, you get a powerful, easy-to-install, and smartly integrated solution. The
Wyze Sense Hub ties it all together, enabling you to expand your system effortlessly as your security needs grow.
Protect your home with confidence and convenience—start with a solid foundation and add sensors and cameras wherever you need them.
What is an expandable home security monitoring system with peel stick sensors?
An expandable home security monitoring system with peel stick sensors is a customizable solution that allows you to protect your entire home. The system uses wireless sensors that easily stick to doors and windows without tools, and can be expanded to include up to 100 sensors. It integrates with smart cameras and a central hub for seamless monitoring and instant alerts.What is included in the Whole Home Security Starter Kit?
The Whole Home Security Starter Kit includes a Wyze Cam v4 (2.5K QHD smart camera with color night vision), a Wyze Video Doorbell v2 (HD video doorbell with real-time alerts), and a Wyze Home Monitoring Starter Kit with peel stick sensors for doors and windows. This bundle provides comprehensive protection and is designed to be easily expandable.How do peel stick sensors work and how are they installed?
Peel stick sensors are wireless devices that attach to doors, windows, or other entry points using a strong adhesive backing. Installation is simple—just peel off the protective layer and stick the sensor in place. No drilling, screws, or tools are required, making setup quick and damage-free.How many sensors can I add to the Wyze security system?
You can add up to 100 peel stick sensors to the Wyze security system, allowing you to cover every entry point and expand your home security as needed.What are the key features of the Wyze Cam v4?
The Wyze Cam v4 offers 2.5K Quad HD resolution, enhanced color night vision, a motion-activated spotlight and 99 dB siren, 24/7 local recording to a microSD card (up to 256GB), weather resistance (IP65), smart home integration with Alexa, Google Assistant, and IFTTT, and easy Bluetooth-enabled setup with a magnetic mount.What is the Wyze Sense Hub and what does it do?
The Wyze Sense Hub is the central brain of the security system, connecting all sensors and devices. It supports up to 100 sensors, offers multiple communication methods (Ethernet, Wi-Fi, Bluetooth, RF), has a built-in rechargeable battery for up to 10 hours of backup power, and features a loud 88 dB siren for alerts.Can the Wyze security system be controlled from a mobile app?
Yes, the Wyze security system can be managed through an integrated app. The app allows you to control cameras, sensors, and alerts from a single, intuitive interface, providing real-time notifications and remote access to your security devices.What is the Wyze Bulb Cam and how does it enhance home security?
The Wyze Bulb Cam is a 2-in-1 device that combines a smart LED light bulb with a 2K HD security camera. It features color night vision, a motion-activated light, a 95 dB siren, easy installation in standard E26 sockets, IP65 weather resistance, and supports both local and cloud storage. It is ideal for securing outdoor areas while providing functional lighting.Is the Wyze security system suitable for both indoor and outdoor use?
Yes, components like the Wyze Cam v4 and Wyze Bulb Cam are IP65 weather resistant, making them suitable for both indoor and outdoor installation. This allows you to monitor and protect all areas of your property.Do I need a subscription for 24/7 recording with Wyze cameras?
No, Wyze cameras such as the Wyze Cam v4 support continuous 24/7 local recording to a microSD card (up to 256GB) without requiring a subscription. Cloud storage options are also available if desired.How does the Wyze security system send alerts?
The Wyze security system sends instant smart alerts to your phone via the Wyze app whenever sensors detect activity or cameras identify motion. You can customize notifications to fit your security preferences.What are the benefits of using peel stick sensors for home security?
Peel stick sensors offer hassle-free installation without damaging walls or doors, wireless connectivity with up to 500 feet range, customizable alerts, and seamless integration with Wyze cameras and other smart devices. They make expanding and personalizing your home security system simple and flexible.
