Affordable Luxury Air Purifier with New Filters for Indoors
When it comes to maintaining a healthy indoor environment, having a reliable air purifier with advanced filtration and smart features is essential. The Wyze Air Purifier lineup offers affordable luxury with cutting-edge technology, whisper-quiet operation, and customizable filters designed to meet your specific air quality needs. Whether you want to combat allergens, formaldehyde, wildfire smoke, or pet odors, Wyze has you covered with premium filters and smart controls.
Wyze Air Purifier: Premium Performance Without the Premium Price
Powerful Air Cleaning Capacity
The Wyze Air Purifier delivers an impressive Clean Air Delivery Rate (CADR) of 350 m³/h, cycling through 12,000 cubic feet of air every hour. This means it can effectively purify the air in rooms up to 550 sq. ft (42 m²), making it ideal for bedrooms, living rooms, and home offices.
Whisper-Quiet Operation
Operating at just 21 decibels on its lowest setting, the Wyze Air Purifier is quieter than a purring kitten, ensuring it won’t disturb your sleep or daily activities while keeping your air fresh and clean.
Smart Controls & Real-Time Air Quality Monitoring
Equipped with laser particle detection, the purifier tracks ultra-fine particles down to 0.3 microns with 100 checks per second. The Wyze app provides instant air quality alerts, detailed pollutant tracking, and remote control via smartphone. It’s also compatible with Alexa and Google Home for voice commands and automation.
Customizable Filter Options
Choose from three premium pre-installed filters tailored to your environment:
- Allergen Filter (Standard): Combats common allergens with HEPA 13 and granulated carbon.
- Formaldehyde Filter (Premium): Destroys harmful VOCs like formaldehyde found in new furniture and construction materials, featuring True HEPA 12 and activated manganese carbon.
- Wildfire Filter (Special Use): Optimized for wildfire smoke with chemically modified granulated carbon and True HEPA 12.
Easy Maintenance & Portability
The purifier features a convenient handle for easy room-to-room movement and a simple filter replacement process that takes just a few steps.
"A luxury air purifier without the luxury price tag."
Enjoy clean air effortlessly with easy filter changes.
Wyze Air Filter: Tailored Filtration for Your Unique Needs
Customize Your Air Quality
Just like you wouldn’t eat the same meal every day, your air purifier shouldn’t use a one-size-fits-all filter. Wyze Air Filters allow you to customize your air purification based on your lifestyle and environment.
Filter Types Available
- Allergen Filter (Standard): Ideal for everyday use to capture dust, pollen, pet dander, and other allergens.
- Formaldehyde Filter (Premium): Targets and neutralizes formaldehyde and other harmful VOCs, perfect for new homes or spaces with chemical odors.
- Wildfire Filter (Special Use): Designed to absorb wildfire smoke and related pollutants effectively.
Easy Filter Replacement
Replacing your filter is quick and hassle-free with a simple three-step process: remove the old filter, insert the new one, and resume breathing clean air.
"Customize your air like you customize your burger."
(Refurbished) Wyze Air Purifier: Affordable Smart Air Quality Solution
Same Features, Lower Price
For those seeking an even more budget-friendly option, the refurbished Wyze Air Purifier offers the same powerful 350 CADR, whisper-quiet 21 dB operation, and smart features including AQ alerts and laser particle detection.
Certified Quality & Safety
CARB certified and recommended for rooms up to 550 sq. ft, this refurbished model is a smart choice for eco-conscious buyers who want luxury air purification without compromise.
Recommended Filter Replacement
To maintain optimal performance, filters should be replaced every 6 months, ensuring your indoor air stays fresh and healthy.
Why Choose Wyze Air Purifiers?
- Affordable luxury: High-end features at a price that fits your budget.
- Smart home integration: Compatible with Alexa, Google Home, and the Wyze app for seamless control.
- Custom filters: Adapt your purifier to seasonal allergies, wildfire smoke, or chemical sensitivities.
- Quiet operation: Runs silently in the background, perfect for bedrooms and nurseries.
- Easy maintenance: Simple filter swaps and portable design.
Conclusion
Investing in a Wyze Air Purifier means bringing home a smart, efficient, and customizable air cleaning solution that fits your lifestyle and budget. With new filters designed for specific indoor air challenges and smart features that keep you informed and in control, Wyze makes luxury air purification accessible to everyone.
Control your Wyze Air Purifier remotely with smart plugs and voice assistants.
Product Summary
Wyze Air Purifier
Premium filters, 350 CADR, whisper-quiet, smart controls, AQ alerts, laser particle detection.
Price: $169.99 - $194.99 depending on filter variant.
Wyze Air Filter
Custom filters for allergens, formaldehyde, wildfire smoke. Easy replacement.
Price: $37.99 - $63.99.
Same features as new, lower price, CARB certified, recommended filter replacement every 6 months.
Price: $139.99.
What makes the Wyze Air Purifier an affordable luxury air purifier?
The Wyze Air Purifier combines premium features like advanced filtration, smart controls, and whisper-quiet operation at a price significantly lower than most luxury air purifiers. It offers high-end performance, customizable filters, and smart home integration without the premium price tag.How large of a room can the Wyze Air Purifier clean effectively?
The Wyze Air Purifier is designed to purify rooms up to 550 square feet (42 m²), making it ideal for bedrooms, living rooms, and home offices. It delivers a Clean Air Delivery Rate (CADR) of 350 m³/h, cycling through 12,000 cubic feet of air every hour.What types of filters are available for the Wyze Air Purifier?
Wyze offers three premium filter options: the Allergen Filter (Standard) for dust, pollen, and pet dander; the Formaldehyde Filter (Premium) for neutralizing formaldehyde and VOCs; and the Wildfire Filter (Special Use) for absorbing wildfire smoke and related pollutants.How do I choose the right Wyze Air Filter for my needs?
Select the Allergen Filter for everyday use against common allergens, the Formaldehyde Filter if you have new furniture or chemical odors, and the Wildfire Filter if you need protection from wildfire smoke. Each filter is tailored to specific air quality challenges.How quiet is the Wyze Air Purifier during operation?
The Wyze Air Purifier operates at just 21 decibels on its lowest setting, which is quieter than a purring kitten. This makes it perfect for bedrooms, nurseries, and other quiet spaces.Does the Wyze Air Purifier have smart features?
Yes, the Wyze Air Purifier features smart controls, real-time air quality monitoring with laser particle detection, instant air quality alerts, and remote control via the Wyze app. It is also compatible with Alexa and Google Home for voice commands and automation.How often should I replace the Wyze Air Purifier filter?
For optimal performance and air quality, it is recommended to replace your Wyze Air Purifier filter every 6 months.Is the Wyze Air Purifier easy to maintain?
Yes, the Wyze Air Purifier is designed for easy maintenance. It features a convenient handle for portability and a simple three-step filter replacement process: remove the old filter, insert the new one, and resume use.What is the difference between the new and refurbished Wyze Air Purifier?
The refurbished Wyze Air Purifier offers the same powerful 350 CADR, whisper-quiet operation, and smart features as the new model, but at a lower price. It is CARB certified and recommended for rooms up to 550 sq. ft, making it a budget-friendly and eco-conscious choice.Are Wyze Air Purifiers compatible with smart home systems?
Yes, Wyze Air Purifiers are compatible with Alexa, Google Home, and the Wyze app, allowing for seamless smart home integration, voice control, and automation.How much do Wyze Air Purifiers and filters cost?
Wyze Air Purifiers range from $169.99 to $194.99 depending on the filter variant. Wyze Air Filters are priced between $37.99 and $63.99. The refurbished Wyze Air Purifier is available for $139.99.
