Indoor Air Filters for Bacteria & Allergen Purification | Wyze
Air Filters Designed for Indoor Air Purification Against Bacteria and Allergens
Indoor air quality is essential for a healthy living environment, especially when it comes to protecting your home from bacteria, allergens, and harmful gases. Wyze offers a range of advanced air filtration products designed to purify your indoor air effectively, ensuring you breathe cleaner, safer air every day.
Wyze Air Filter: Customizable Filtration for Your Unique Needs
Tailored Air Purification
The Wyze Air Filter is not just any filter — it’s a customizable solution that adapts to your specific indoor air challenges. Whether you’re concerned about pet dander, allergens, viruses, bacteria, or even formaldehyde and wildfire smoke, Wyze has a filter designed for you. Filter Variants:
  • Allergen Filter (Standard): Equipped with HEPA 13, activated carbon, and a pre-filter to capture allergens and airborne particles.
  • Formaldehyde Filter (Premium): Uses HEPA 12 combined with MnO2 and activated carbon to efficiently remove formaldehyde and VOCs.
  • Wildfire Filter (Special Use): Designed to combat wildfire smoke with HEPA 12 and activated carbon.
High Efficiency and Performance
  • Virus and Bacteria Removal: 99% efficiency in filtering harmful microorganisms.
  • TVOC Removal Efficiency: Ranges from 92.7% to 98.9% depending on the filter type.
  • Particulate Matter CADR: Up to 362 m³/h (214 CFM), ensuring rapid air cleaning.
  • Service Life: Filters last between 4 to 12 months depending on usage and filter type.
Dimensions & Weight
  • Compact size at 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm).
  • Lightweight design ranging from 1.5 to 1.9 lbs (0.6 to 0.87 kg).
Customize your air like you customize your meals — breathe the air that suits your lifestyle and environment.
Man replacing air filter in purifier Lifestyle image showing easy filter replacement for clean indoor air
Wyze Air Purifier: Smart, Quiet, and Powerful Air Cleaning
Premium Air Purification with Smart Features
The Wyze Air Purifier combines powerful filtration with smart home integration, making it an ideal choice for anyone serious about indoor air quality.
  • Pre-installed Filter Options: Allergen, Formaldehyde, or Wildfire filters.
  • CADR Ratings: Up to 350 m³/h (206 CFM) for allergen filter, ensuring fast and effective air cleaning.
  • Coverage Area: Suitable for rooms between 450 to 550 square feet.
  • Noise Levels: Whisper-quiet operation starting below 21 dBA, adjustable across four fan speeds.
  • Smart Controls: Compatible with Google Home and Alexa for voice commands and automation.
  • Laser Particle Sensor: Detects particles as small as 0.3 microns with air quality updates 100 times per second.
Design and Usability
  • Dimensions: 9.5" x 9.4" x 18.5" (243 mm x 240 mm x 472 mm).
  • Weight: Approximately 8.75 to 9.32 lbs depending on filter.
  • Energy Efficient: Rated power from 3.5 to 45W.
  • Operating Conditions: Works well in temperatures from 14°F to 104°F (-10°C to 40°C) and humidity below 85%.
A luxury air purifier without the luxury price tag — protect your home and loved ones with smart, effective air cleaning.
Modern living room with air purifier Lifestyle image of air purifier blending into home environment
Wyze Air Filter Subscription: Hassle-Free Replacement Filters
Keep Your Air Purifier Performing at Its Best
To maintain optimal air quality, regular filter replacement is essential. Wyze offers a convenient subscription service for replacement filters tailored to your purifier model and filtration needs.
  • Filter Types Available: Allergen, Formaldehyde, and Wildfire.
  • Filter Composition: Includes pre-filter, True HEPA (12 or 13), activated carbon, and MnO2 for formaldehyde filters.
  • Service Life: Filters last between 4 to 12 months depending on type and usage.
  • Dimensions & Weight: Matches the original filters for easy swap-out.
Never worry about forgetting to replace your filter — keep your indoor air fresh and clean with scheduled deliveries.
Why Choose Wyze Air Filters for Indoor Air Purification?
  • Advanced HEPA Filtration: Captures 99% of bacteria, viruses, allergens, and particulate matter.
  • Activated Carbon Layers: Effectively remove odors, VOCs, and harmful gases like formaldehyde.
  • Customizable Options: Filters designed for specific air quality challenges including wildfire smoke.
  • Smart Home Integration: Control and monitor air quality from your smartphone or voice assistant.
  • Long Filter Life: Durable filters that provide months of clean air before replacement.
Breathe easier and protect your home environment with Wyze’s innovative air filtration solutions designed to combat bacteria and allergens effectively.
FeatureWyze Air FilterWyze Air PurifierWyze Air Filter Subscription
Product TypeConnected Home AccessoryConnected Home DeviceHardware Subscription
DescriptionCustom air filters for specific needsAir purifier with pre-installed filtersReplacement filters for Wyze Air Purifier
Price Range$37.99 - $63.99$169.99 - $194.99$37.99 - $63.99
VariantsAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter, Formaldehyde Filter, Wildfire Filter
Filter CompositionPre-filter + HEPA 13 + Granulated Carbon (Allergen)
Pre-filter + HEPA 12 + Activated Manganese + Granulated Carbon (Formaldehyde)
Pre-filter + HEPA 12 + Chemically Modified Granulated Carbon (Wildfire)
Same as Wyze Air Filter variants (pre-installed)Same as Wyze Air Filter variants
TVOC Removal Efficiency92.7% (Allergen), 98.9% (Formaldehyde), 97.1% (Wildfire)Not specified separately (uses premium filters)92.7% - 98.9% depending on filter type
Particulate Matter CADR362 m³/h (Allergen), 317 m³/h (Formaldehyde), 342 m³/h (Wildfire)350 CADR (approximate for purifier)Matches filter type CADR
Service Life6-12 months (Allergen), 5-12 months (Formaldehyde), 4-12 months (Wildfire)Not specified (depends on filter replacement)Same as Wyze Air Filter
Dimensions8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)Not specifiedSame as Wyze Air Filter
Weight1.5 lb - 1.9 lb depending on filterNot specifiedSame as Wyze Air Filter
Key FeaturesCustomizable filters for allergens, formaldehyde, wildfire smoke350 CADR, whisper-quiet (21 dB), smart controls, AQ alerts, laser particle detection, compatible with Alexa & Google HomeConvenient filter replacement subscription
Additional FeaturesFilters pet odors, allergens, germs, gasesAuto mode, fan speed control, child lock, app control, indoor/outdoor AQ trackingAutomatic filter replacement delivery
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What types of air filters does Wyze offer for indoor air purification?Wyze offers three main types of air filters: the Allergen Filter (Standard) with HEPA 13, activated carbon, and a pre-filter; the Formaldehyde Filter (Premium) with HEPA 12, MnO2, and activated carbon for removing formaldehyde and VOCs; and the Wildfire Filter (Special Use) with HEPA 12 and activated carbon for combating wildfire smoke.
How effective are Wyze air filters at removing bacteria, viruses, and allergens?Wyze air filters are highly effective, capturing up to 99% of bacteria, viruses, allergens, and particulate matter. Their advanced HEPA filtration and activated carbon layers ensure cleaner, safer indoor air.
What is the service life of Wyze air filters?Wyze air filters last between 4 to 12 months, depending on the filter type and usage. Regular replacement is recommended to maintain optimal air quality.
How do I know which Wyze air filter is right for my needs?Wyze offers customizable filtration solutions. Choose the Allergen Filter for general allergens and airborne particles, the Formaldehyde Filter for VOCs and formaldehyde, or the Wildfire Filter for smoke and fine particulates. Select based on your specific indoor air quality concerns.
What is the coverage area of the Wyze Air Purifier?The Wyze Air Purifier is suitable for rooms between 450 to 550 square feet, making it ideal for bedrooms, living rooms, and medium-sized spaces.
Does the Wyze Air Purifier support smart home integration?Yes, the Wyze Air Purifier is compatible with Google Home and Alexa, allowing you to control and monitor your air quality using voice commands and smart home automation.
How quiet is the Wyze Air Purifier during operation?The Wyze Air Purifier operates at whisper-quiet noise levels, starting below 21 dBA, and offers four adjustable fan speeds for customized comfort.
What is the Clean Air Delivery Rate (CADR) of Wyze air purifiers and filters?Wyze air purifiers and filters offer a CADR of up to 362 m³/h (214 CFM) for filters and up to 350 m³/h (206 CFM) for the air purifier, ensuring rapid and efficient air cleaning.
How does the Wyze Air Filter Subscription work?The Wyze Air Filter Subscription is a hassle-free service that delivers replacement filters to your door on a schedule tailored to your purifier model and filtration needs. This ensures you never forget to replace your filter and always maintain optimal air quality.
What are the dimensions and weight of Wyze air filters and purifiers?Wyze air filters measure 8.1" x 8.1" x 11.3" and weigh between 1.5 to 1.9 lbs. The Wyze Air Purifier measures 9.5" x 9.4" x 18.5" and weighs approximately 8.75 to 9.32 lbs, depending on the filter.
What makes Wyze air filters and purifiers a good choice for indoor air quality?Wyze air filters and purifiers feature advanced HEPA filtration, activated carbon layers, customizable options for specific air quality challenges, smart home integration, and long-lasting filter life, making them an excellent choice for effective indoor air purification.
What are the different filter variants available for the Wyze Air Filter?How does the Wyze Air Filter customize air purification for specific needs?Do you have any deals, ongoing sales, discounts, or promotions available?
