Affordable HEPA Air Filter Replacements for Allergen Control
If you're looking for effective and affordable HEPA air filter replacements to control allergens in your home, Wyze offers a range of high-quality options designed to keep your indoor air clean and healthy. Whether you want to target pet dander, pollen, dust, or other airborne irritants, these filters provide excellent filtration performance at a budget-friendly price.
Wyze Air Filter: Customizable HEPA Filtration for Allergens
Tailored Air Purification for Your Needs
The Wyze Air Filter is a connected home accessory designed to fit the Wyze Air Purifier, offering customizable filtration options to suit your specific allergen control needs. You can choose from:
- Allergen Filter (Standard): Equipped with a True HEPA 13 filter, this variant efficiently captures common allergens like dust, pollen, and pet dander.
- Formaldehyde Filter (Premium): Combines HEPA 12 filtration with activated carbon and MnO2 to remove formaldehyde and other harmful gases.
- Wildfire Filter (Special Use): Designed for smoky environments, this filter uses HEPA 12 and activated carbon to reduce wildfire smoke particles.
Key Specifications
- Dimensions: 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
- Weight: Ranges from 1.5 lb to 1.9 lb depending on filter type
- HEPA Type: True HEPA 13 (Allergen) and HEPA 12 (others)
- Activated Carbon: Included for odor and gas removal
- Particulate Matter CADR: Up to 362 m³/h (214 CFM)
- Formaldehyde CADR: 178 m³/h (premium filter)
- Virus & Bacteria Efficiency: 99%
- Service Life: 4 to 12 months depending on filter type
You don’t breathe the same air as everyone else, so why settle for generic filters? Customize your air quality with Wyze Air Filters to target allergens effectively.
Alt text: Man replacing air purifier filter for allergen control at home
Wyze Air Filter Subscription: Hassle-Free Replacement Filters
Convenient and Cost-Effective Filter Replacement
To maintain optimal allergen control, regular filter replacement is essential. Wyze offers a subscription service for their air filters, ensuring you never run out of fresh HEPA filters. The subscription includes the same filter types as the standalone Wyze Air Filter:
- Allergen Filter
- Wildfire Filter
Subscription Benefits
- Consistent Air Quality: Regularly updated filters maintain high filtration efficiency.
- Flexible Service Life: Filters last between 4 to 12 months depending on type and usage.
- Comprehensive Filtration: Pre-filter, True HEPA, and activated carbon layers for thorough allergen and gas removal.
This subscription service is perfect for those who want to keep their home environment allergen-free without the hassle of remembering filter changes.
Wyze Robot Vacuum - HEPA Filter: Additional Allergen Control
HEPA Filter for Wyze Robot Vacuum
For homes using the Wyze Robot Vacuum, maintaining a clean HEPA filter is crucial to reduce allergens stirred up during cleaning. The Wyze Robot Vacuum HEPA Filter is an affordable replacement part designed specifically for this vacuum model.
- Price: $4.99 USD
- Compatibility: Wyze Robot Vacuum
- Return Policy: 30-day hassle-free returns
Replacing the vacuum’s HEPA filter regularly helps trap fine dust and allergens, improving overall air quality as you clean.
Why Choose Wyze HEPA Filters for Allergen Control?
- Affordable Pricing: High-performance HEPA filters starting at $37.99 for standalone filters and $4.99 for vacuum replacements.
- Customizable Options: Filters tailored to your specific air quality concerns, including allergens, formaldehyde, and wildfire smoke.
- Long Service Life: Filters last up to a year, providing excellent value.
- Connected Home Integration: Compatible with Wyze Air Purifier and smart home systems for easy monitoring and control.
Investing in quality HEPA filters is a smart step toward a healthier home environment, especially for allergy sufferers.
Alt text: Hand replacing HEPA air filter in modern home air purifier
Summary of Available Wyze HEPA Air Filter Products
Product Name | Filter Types Available | Price Range (USD) | Service Life | Key Features |
Wyze Air Filter | Allergen, Formaldehyde, Wildfire | $37.99 - $63.99 | 4 to 12 months | True HEPA 12/13, Activated Carbon |
Wyze Air Filter Subscription | Allergen, Formaldehyde, Wildfire | $37.99 - $63.99 | 4 to 12 months | Convenient auto-replacement |
Wyze Robot Vacuum - HEPA Filter | Single HEPA filter for vacuum | $4.99 | N/A | Replacement for vacuum allergen control |
By choosing Wyze HEPA air filter replacements, you ensure your home stays fresh, allergen-free, and comfortable without breaking the bank.
What types of Wyze HEPA air filters are available for allergen control?
Wyze offers three main types of HEPA air filters for allergen control: the Allergen Filter (True HEPA 13 for dust, pollen, and pet dander), the Formaldehyde Filter (HEPA 12 with activated carbon and MnO2 for harmful gases), and the Wildfire Filter (HEPA 12 with activated carbon for smoke particles).How often should I replace my Wyze HEPA air filter?
Wyze HEPA air filters have a service life of 4 to 12 months, depending on the filter type and your usage. Regular replacement ensures optimal allergen control and air purification.Are Wyze HEPA air filters compatible with all air purifiers?
Wyze HEPA air filters are specifically designed to fit the Wyze Air Purifier. For vacuum cleaners, the Wyze Robot Vacuum HEPA Filter is compatible only with the Wyze Robot Vacuum.What is included in the Wyze Air Filter Subscription service?
The Wyze Air Filter Subscription provides automatic delivery of your chosen filter type (Allergen, Formaldehyde, or Wildfire) at regular intervals, ensuring you never run out of fresh filters. This service helps maintain consistent air quality and allergen control.How much do Wyze HEPA air filter replacements cost?
Wyze HEPA air filter replacements start at $37.99 for standalone air purifier filters and $4.99 for Wyze Robot Vacuum HEPA filter replacements. Prices vary depending on the filter type and subscription options.What are the benefits of using Wyze HEPA filters for allergen control?
Wyze HEPA filters offer high-performance filtration for allergens, customizable options for specific air quality concerns, affordable pricing, long service life, and seamless integration with Wyze smart home systems.Do Wyze HEPA filters remove odors and gases as well as allergens?
Yes, Wyze HEPA filters include activated carbon layers that help remove odors and harmful gases in addition to capturing allergens like dust, pollen, and pet dander.How effective are Wyze HEPA filters at removing viruses and bacteria?
Wyze HEPA filters are up to 99% efficient at capturing viruses and bacteria, helping to improve overall indoor air quality.Is there a return policy for Wyze HEPA filter replacements?
Yes, Wyze offers a 30-day hassle-free return policy for their HEPA filter replacements, including the Wyze Robot Vacuum HEPA filter.Can I customize my Wyze air filter to target specific air quality concerns?
Absolutely. Wyze offers customizable air filter options, allowing you to choose filters that specifically target allergens, formaldehyde, or wildfire smoke based on your needs.
