Advanced Home Security Kits with Two-Way Audio & Motion Alerts
Advanced Home Security Kit with Two-Way Audio and Motion Alerts
Protecting your home has never been easier or smarter. Whether you want to monitor your front porch, backyard, or driveway, the latest Wyze security solutions combine crystal-clear video, intelligent motion detection, and two-way audio communication to keep you connected and in control — anytime, anywhere. Explore the top Wyze products designed to deliver advanced home security with seamless installation and smart features.
Wyze Bulb Cam: The 2-in-1 Outdoor Security Camera and Smart Light
Transform any outdoor light fixture into a powerful security system with the Wyze Bulb Cam. This innovative device combines an 800-lumen dimmable LED bulb with a 2K HD security camera, offering both illumination and surveillance in one sleek package.
Key Features:
  • 2K HD Video with Color Night Vision: Capture sharp, detailed video day and night with vibrant color even in low light.
  • Wide 160° Field of View: See more of your surroundings with a super-wide angle lens that covers large outdoor areas.
  • Instant Motion Alerts: Receive real-time notifications on your smartphone whenever motion is detected.
  • Two-Way Audio: Speak directly to visitors, delivery personnel, or pets through your phone using the built-in microphone and speaker.
  • Local Video Storage: Supports microSD cards up to 256GB for continuous 24/7 local recording without monthly fees.
  • Easy Installation: Simply screw into most standard light fixtures—no complicated wiring or tools needed.
  • Smart Lighting Control: Customize brightness, set schedules, and connect up to 5 accessory bulbs for full outdoor lighting coverage.
  • Built-in Siren and Lighting Effects: Deter unwanted guests with flashing lights and a loud siren activated remotely.
The Wyze Bulb Cam is perfect for those who want a discreet, multi-functional security solution that blends seamlessly with existing outdoor lighting.
Wyze Bulb Cam installed outdoors illuminating a porch at night Wyze Bulb Cam: Security meets smart lighting
Wyze Cam Floodlight v2: Bright, Smart, and Weatherproof Security
For those who need powerful illumination combined with advanced security, the Wyze Cam Floodlight v2 is a top choice. This floodlight camera delivers 2800 lumens of bright LED light alongside 2K video resolution and intelligent motion detection.
Highlights:
  • 2800 Lumens Motion-Activated LEDs: Flood your driveway or yard with bright light that activates instantly when motion is detected.
  • 2K Video with Color Night Vision: See clear, colorful footage even in complete darkness.
  • Wide 160° Viewing Angle: Covers a broad area to eliminate blind spots.
  • Two-Way Talk & Loud 105dB Siren: Communicate with visitors or scare off intruders with a powerful siren.
  • Ambient Light Mode: Provides a low-level light that brightens automatically upon motion detection.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) with no subscription required.
  • Dusk-to-Dawn Automation: Automatically turns on at sunset and off at sunrise.
  • IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions.
  • Smart Assistant Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
The Wyze Cam Floodlight v2 is ideal for illuminating large outdoor spaces while providing robust security features and two-way communication.
Wyze Cam Floodlight v2 illuminating a driveway with a person detected Bright and smart floodlight security with two-way audio
Wyze Cam v4 Outdoor Bundle: Ultimate Clarity and Connectivity
For comprehensive outdoor surveillance, the Wyze Cam v4 Outdoor Bundle offers unmatched video quality and smart features. This bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card for local storage.
Why Choose Wyze Cam v4?
  • 2.5K QHD Resolution: Ultra-clear video with enhanced color night vision for detailed monitoring.
  • Motion-Activated Spotlight: Automatically lights up areas when motion is detected to deter intruders.
  • Two-Way Audio: Talk and listen through the camera using your smartphone.
  • Wi-Fi 6 Support: Faster, more reliable wireless connection for smooth streaming.
  • 24/7 Local Recording: Continuous recording to microSD card included in the bundle.
  • Smart Home Compatibility: Works with Alexa and Google Assistant for voice commands and integration.
  • Advanced Motion Detection Zones: Customize detection areas to reduce false alerts.
  • Weatherproof Design: Rated for outdoor use with IP65 protection.
This bundle is perfect for homeowners seeking high-resolution video, reliable power, and smart home integration in one package.
Why Choose an Advanced Home Security Kit with Two-Way Audio and Motion Alerts?
Two-way audio allows you to interact with visitors, delivery personnel, or even pets remotely, providing peace of mind and convenience. Motion alerts keep you instantly informed of any activity around your home, enabling quick responses to potential threats. Combining these features with high-quality video and smart lighting creates a comprehensive security solution that protects your property day and night.
Summary of Featured Products
ProductVideo ResolutionNight VisionTwo-Way AudioMotion AlertsLighting FeaturesLocal StoragePrice
Wyze Bulb Cam2K HDColor Night VisionYesYes800 lumen dimmable LEDmicroSD up to 256GB$49.98
Wyze Cam Floodlight v22K HDColor Night VisionYesYes2800 lumen floodlightmicroSD up to 256GB$89.98
Wyze Cam v4 Outdoor Bundle2.5K QHDEnhanced Color Night VisionYesYesMotion-activated spotlightmicroSD 128GB included$69.99
Enhance your home security today with these advanced Wyze products that combine two-way audio, motion alerts, and smart lighting to keep your property safe and connected.
FeatureWyze Bulb CamWyze Cam Floodlight v2Wyze Cam v4 Outdoor BundleWyze Cam v4
Price$49.98$89.98$69.99$35.98 (1 Pack) / $107.94 (3 Pack)
Video Resolution2K HD2K2.5K QHD2.5K QHD
Night VisionColor Night VisionColor Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
Field of View160° Wide160° WideNot specifiedDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Lighting800 Lumen Dimmable LED Bulb2800 Lumens (2 floodlight heads)Motion-activated spotlight2 white spotlight LEDs (72 lumens)
Local RecordingYes, microSD up to 256 GBYes, microSD up to 256 GBYes, microSD 128 GB includedYes, microSD up to 512 GB
Cloud Storage SubscriptionOptional Cam PlusOptional Cam PlusOptional Cam PlusOptional Cam Plus
Two-Way AudioYesYesYesYes
Built-in SirenYesYes (105 dB)YesYes
Motion Detection ZonesYesYes (270° PIR detection area)YesYes
Dusk-to-Dawn AutomationYesYesNot specifiedNot specified
Weather ResistanceOutdoor rated (IP65 not specified)IP65Yes (Outdoor compatible)IP65
Power SourceFits most light fixtures (screw-in bulb)Hardwired or plug-in mount optionWiredWired
Wi-Fi Support2.4 GHz2.4 GHzWi-Fi 62.4 GHz & Wi-Fi 6
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Additional FeaturesMotion-activated lights, siren, local storage no subscription neededAmbient Light Mode, AI-Powered Light Control, 24/7 local recordingIncludes Outdoor Power Adapter, 24/7 local recordingWide Dynamic Range, 8x digital zoom, waterproof speaker
Included AccessoriesNoneNoneOutdoor Power Adapter, 128GB microSDMounting hardware, power adapter, USB cable
What is included in the Advanced Home Security Kit with Two-Way Audio and Motion Alerts?The Advanced Home Security Kit features Wyze's latest security solutions, including the Wyze Bulb Cam, Wyze Cam Floodlight v2, and Wyze Cam v4 Outdoor Bundle. Each product offers two-way audio, motion alerts, high-definition video, and smart lighting features for comprehensive home protection.
How does the Wyze Bulb Cam work as both a security camera and a smart light?The Wyze Bulb Cam combines an 800-lumen dimmable LED bulb with a 2K HD security camera. It screws into most standard outdoor light fixtures, providing both bright illumination and high-quality video surveillance in one device. It also features color night vision, motion alerts, two-way audio, and local video storage.
What are the key features of the Wyze Cam Floodlight v2?Wyze Cam Floodlight v2 offers 2800 lumens of motion-activated LED lighting, 2K HD video with color night vision, a wide 160° viewing angle, two-way talk, a 105dB siren, ambient light mode, 24/7 local recording, dusk-to-dawn automation, IP65 weather resistance, and smart assistant integration with Alexa, Google Assistant, and IFTTT.
Does the Wyze Cam v4 Outdoor Bundle support local video storage?Yes, the Wyze Cam v4 Outdoor Bundle includes a 128GB microSD card for continuous 24/7 local video recording, allowing you to store footage without monthly subscription fees.
Can I communicate with visitors using Wyze security cameras?Yes, all featured Wyze security cameras, including the Bulb Cam, Cam Floodlight v2, and Cam v4, offer two-way audio. This allows you to speak and listen to visitors, delivery personnel, or even pets directly through your smartphone.
How do motion alerts work on Wyze security cameras?Wyze security cameras use intelligent motion detection to monitor activity around your home. When motion is detected, you receive instant notifications on your smartphone, enabling you to respond quickly to any potential threats or visitors.
Are Wyze security cameras easy to install?Yes, Wyze security cameras are designed for easy installation. The Wyze Bulb Cam simply screws into most standard light fixtures, while the Cam Floodlight v2 and Cam v4 Outdoor Bundle come with straightforward setup instructions and weatherproof designs for outdoor use.
Do Wyze security cameras require a subscription for video storage?No, all featured Wyze security cameras support local video storage via microSD cards (up to 256GB for Bulb Cam and Floodlight v2, 128GB included with Cam v4 Outdoor Bundle), allowing continuous recording without monthly subscription fees.
Are Wyze security cameras compatible with smart home systems?Yes, Wyze security cameras work with popular smart home platforms such as Amazon Alexa and Google Assistant. The Wyze Cam Floodlight v2 also supports IFTTT for advanced automation and voice control.
What weather conditions can Wyze outdoor security cameras withstand?Wyze outdoor security cameras, including the Bulb Cam, Cam Floodlight v2, and Cam v4, are rated IP65 weather resistant. They are built to withstand rain, snow, and harsh outdoor conditions, ensuring reliable performance year-round.
Can you tell me more about the features of the Wyze Bulb Cam?How does the two-way audio feature work in the advanced home security kit?Do you have any ongoing sales or discounts for the Wyze products?
