8 Zone Sprinkler Controller with Customizable Watering Schedule
For homeowners and gardening enthusiasts looking to optimize their lawn irrigation, an 8 zone sprinkler controller with customizable watering schedules offers the perfect blend of convenience, efficiency, and smart technology. Wyze provides a comprehensive solution with its Wyze Sprinkler Controller lineup, designed to give you full control over your lawn watering needs while saving water and money.
Wyze Sprinkler Controller: Smarter, Simpler, Greener
Advanced 8-Zone Control for Your Lawn
The Wyze Sprinkler Controller supports up to 8 customizable irrigation zones, allowing you to tailor watering schedules for different areas of your yard. Whether you have flower beds, vegetable gardens, or large lawn sections, you can set unique names and even add photos for each zone in the Wyze app, making management intuitive and personalized.
Customizable Watering Schedules
Create personalized weekly watering routines that fit your lifestyle. The Wyze app lets you easily start, pause, or stop watering with a simple tap. This flexibility ensures your plants get the right amount of water exactly when they need it.
Weather-Based Watering with Sprinkler Plus
Included with the controller is a 1-year free subscription to Sprinkler Plus, Wyze’s weather service that uses hyper-local weather data to adjust watering schedules intelligently. It skips watering on rainy days and adapts to moisture levels, helping you conserve water and protect your plants.
"If every landscape in the U.S. used a WaterSense labeled weather-based irrigation controller, we could save 220 billion gallons of water annually." – EPA
Easy DIY Installation
Replacing your existing controller is a breeze with a typical setup time of just 20 minutes. The Wyze Sprinkler Controller is compatible with most residential irrigation systems in North America, including those with master valves or pump relays.
Peace of Mind with Wyze Cam Integration
Monitor your watering zones remotely with live video feeds from Wyze Cam. Check if your dog is enjoying the sprinkler or if any zone is running unexpectedly. Notifications keep you informed in real-time.
Control your lawn watering from anywhere with the Wyze app
Refurbished Wyze Sprinkler Controller: Affordable and Reliable
For budget-conscious users, the refurbished Wyze Sprinkler Controller offers the same smart zoned control and customizable schedules at a lower price point. It supports up to 8 zones and includes the Sprinkler Plus weather-based watering subscription for one year.
- Compatible with most residential irrigation systems
- Easy app control and personalized watering routines
- Weather-based watering to save water and money
- Quick 20-minute installation
This option is perfect if you want to enjoy smart irrigation without paying full price.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
To ensure your sprinkler controller stays safe and functional outdoors, the Wyze Weatherproof Sprinkler Controller Box offers a rugged, IP65-rated enclosure. It features:
- Full weatherproof protection for outdoor use
- Four secure clasps and a gridded cover for extra durability
- Power options for hardwiring or outdoor outlets
- Designed exclusively for Wyze Sprinkler Controller compatibility
This box lets you mount your controller anywhere outside without worry, extending the life and reliability of your smart irrigation system.
Weatherproof enclosure for secure outdoor installation
Why Choose Wyze for Your Sprinkler Control?
- WaterSense Certified: The Wyze Sprinkler Controller is EPA WaterSense certified, ensuring efficient water use.
- Smartphone Convenience: Manage your irrigation from anywhere with the Wyze app.
- Custom Zones: Up to 8 zones with unique names and photos for easy identification.
- Weather Intelligence: Sprinkler Plus subscription included for weather-based watering.
- Easy Installation: DIY setup in under 20 minutes.
- Durability: Optional weatherproof box for outdoor protection.
Summary of Key Features
Feature | Wyze Sprinkler Controller | Refurbished Controller | Weatherproof Box |
Zones Supported | Up to 8 | Up to 8 | N/A |
Customizable Watering Schedules | Yes | Yes | N/A |
Weather-Based Watering | Yes (Sprinkler Plus) | Yes (Sprinkler Plus) | N/A |
Installation Time | ~20 minutes | ~20 minutes | N/A |
Weatherproof Rating | Indoor use | Indoor use | IP65 Outdoor Rated |
Power Options | Hardwire or outlet | Hardwire or outlet | Supports both |
Price | $59.99 (sold out) | $24.99 (sold out) | $39.99 |
Optimize your lawn watering with Wyze’s smart 8 zone sprinkler controller solutions. Whether you want a brand-new controller, a budget-friendly refurbished option, or a durable weatherproof enclosure, Wyze has you covered for smarter, greener irrigation.
What is the Wyze 8 Zone Sprinkler Controller?
The Wyze 8 Zone Sprinkler Controller is a smart irrigation device that allows you to control up to 8 separate watering zones in your yard. It features customizable watering schedules, weather-based adjustments, and easy app-based management for efficient and convenient lawn care.How does the customizable watering schedule work on the Wyze Sprinkler Controller?
With the Wyze Sprinkler Controller, you can create personalized weekly watering routines for each of your 8 zones. The Wyze app lets you easily start, pause, or stop watering with a tap, ensuring your plants receive the right amount of water at the right time.What is Sprinkler Plus and how does it help save water?
Sprinkler Plus is Wyze’s weather service included free for one year with the controller. It uses hyper-local weather data to automatically adjust your watering schedule, skipping irrigation on rainy days and adapting to moisture levels. This helps conserve water and protect your plants.Is the Wyze Sprinkler Controller easy to install?
Yes, the Wyze Sprinkler Controller is designed for easy DIY installation, typically taking about 20 minutes. It is compatible with most residential irrigation systems in North America, including those with master valves or pump relays.Can I control the Wyze Sprinkler Controller remotely?
Absolutely. The Wyze Sprinkler Controller can be managed from anywhere using the Wyze app on your smartphone. You can monitor, start, stop, or adjust watering schedules remotely for maximum convenience.What is the benefit of the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box provides IP65-rated protection for your controller, making it safe for outdoor installation. It features secure clasps, a durable cover, and supports both hardwired and outlet power options, ensuring your controller stays protected in any weather.Is there a refurbished Wyze Sprinkler Controller available?
Yes, Wyze offers a refurbished Sprinkler Controller that provides the same smart zoned control and customizable schedules as the new model, but at a lower price. It also includes a one-year Sprinkler Plus subscription and supports up to 8 zones.Is the Wyze Sprinkler Controller WaterSense certified?
Yes, the Wyze Sprinkler Controller is EPA WaterSense certified, ensuring efficient water use and helping you save water and money while maintaining a healthy lawn.Can I integrate Wyze Cam with the Sprinkler Controller?
Yes, you can integrate Wyze Cam with your Sprinkler Controller to monitor your watering zones remotely. Live video feeds and real-time notifications help you keep an eye on your lawn and irrigation system.What are the main features of the Wyze Sprinkler Controller?
Key features include support for up to 8 zones, customizable watering schedules, weather-based watering with Sprinkler Plus, easy 20-minute installation, smartphone app control, WaterSense certification, and optional weatherproof outdoor protection.
