DIY Indoor Smart 8 Zone Sprinkler Controller Upgrade with Easy Setup
Upgrade your lawn irrigation system effortlessly with a smart, connected sprinkler controller designed for indoor DIY installation. Whether you want to control your sprinklers remotely, customize watering schedules, or optimize water usage with weather-based intelligence, the Wyze Sprinkler Controller lineup offers an ideal solution for an 8-zone system upgrade.
Wyze Sprinkler Controller: Smarter, Greener Lawn Care
The Wyze Sprinkler Controller is a cutting-edge connected home device that brings smarter, simpler, and greener control to your irrigation system. Perfect for DIY enthusiasts, it supports up to 8 customizable irrigation zones, allowing you to tailor watering schedules to your lawn’s unique needs.
Key Features:
- 8 Customizable Zones: Manage up to 8 different sprinkler zones independently for precise watering.
- Remote Control via App: Easily control your sprinkler system from anywhere using the Wyze app.
- Personalized Weekly Schedules: Set watering routines that fit your lifestyle and plant needs.
- WeatherSense Certified: EPA WaterSense certification ensures efficient water use.
- Weather-Based Watering: Unlock Sprinkler Plus for intelligent weather skips and hyper-local weather insights.
- Quick Installation: Most users can complete setup in about 20 minutes.
- Peace of Mind Integration: Works seamlessly with Wyze Cam for yard monitoring.
This controller is available in two styles: the standalone Sprinkler Controller or the Sprinkler Controller + Sprinkler Controller Box bundle for enhanced outdoor durability.
Affordable Refurbished Option: (Refurbished) Wyze Sprinkler Controller
For budget-conscious users, the refurbished Wyze Sprinkler Controller offers the same smart zoned control and app-based management at a lower price point. It supports up to 8 zones and includes a free 1-year subscription to Sprinkler Plus weather service, enabling weather-based watering adjustments.
Highlights:
- Up to 8 Zones: Customize watering for multiple areas.
- Easy App Control: Manage your irrigation system remotely.
- Weather-Based Watering: Sprinkler Plus subscription included.
- Quick DIY Setup: Installation typically takes 20 minutes.
- Compatibility: Works with most residential irrigation systems in North America, including those with master valves or pump relays.
This refurbished option is ideal for those who want smart irrigation without the full retail price, maintaining the core features needed for an efficient lawn watering upgrade.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
To complement your indoor smart sprinkler controller, the Wyze Weatherproof Sprinkler Controller Box offers a rugged, IP65-rated enclosure designed for outdoor mounting. This accessory ensures your controller stays protected from the elements, extending its lifespan and reliability.
Features:
- IP65 Weatherproof Rating: Fully sealed against dust and water jets.
- Durable Design: Equipped with 4 clasps and a gridded cover for extra protection.
- Flexible Power Options: Supports hardwiring or outdoor outlet power.
- Compatibility: Designed exclusively for the Wyze Sprinkler Controller.
Mounting your controller outdoors with this box means you can place it wherever it’s most convenient without worrying about weather damage.
Why Choose Wyze for Your DIY Smart Sprinkler Upgrade?
"Smarter irrigation means a greener lawn and a healthier planet."
Wyze’s smart sprinkler solutions combine ease of installation, advanced weather intelligence, and flexible zone control to help you save water and maintain a lush yard effortlessly. The included Sprinkler Plus subscription unlocks weather-based watering that automatically skips unnecessary cycles, reducing water waste and lowering your utility bills.
With the Wyze app, you get full control and insights right at your fingertips, making it simple to adjust watering schedules based on your weekly routine or changing weather conditions.
Enhance Your Smart Home Ecosystem
Pair your Wyze Sprinkler Controller with other Wyze smart home devices like the Wyze Cam v4 Outdoor Bundle for added security and peace of mind. Monitor your yard while managing your irrigation system, all from one convenient app.
Upgrade your lawn care with the Wyze DIY Indoor Smart 8 Zone Sprinkler Controller and enjoy easy setup, smart watering, and efficient irrigation management today.
Product Summary
What is the Wyze Sprinkler Controller and how does it work?
The Wyze Sprinkler Controller is a smart, connected device designed for indoor DIY installation that allows you to manage up to 8 irrigation zones. It enables remote control, personalized watering schedules, and weather-based watering through the Wyze app, making lawn care smarter and more efficient.How many zones can the Wyze Sprinkler Controller manage?
The Wyze Sprinkler Controller supports up to 8 customizable irrigation zones, allowing you to tailor watering schedules for different areas of your lawn or garden.Can I control the Wyze Sprinkler Controller remotely?
Yes, you can control the Wyze Sprinkler Controller from anywhere using the Wyze app. This allows you to adjust watering schedules, start or stop watering, and monitor your system remotely.What is Sprinkler Plus and what are its benefits?
Sprinkler Plus is a subscription service that unlocks advanced weather-based watering features for the Wyze Sprinkler Controller. It provides intelligent weather skips and hyper-local weather insights, helping you save water and optimize your irrigation schedule.Is the Wyze Sprinkler Controller easy to install?
Yes, the Wyze Sprinkler Controller is designed for easy DIY installation. Most users can complete the setup in about 20 minutes using the included instructions and the Wyze app.Does the Wyze Sprinkler Controller work with existing irrigation systems?
The Wyze Sprinkler Controller is compatible with most residential irrigation systems in North America, including those with master valves or pump relays.What is the difference between the standard and refurbished Wyze Sprinkler Controller?
The refurbished Wyze Sprinkler Controller offers the same smart zoned control and app-based management as the standard version but at a lower price point. It also includes a free 1-year Sprinkler Plus subscription and is ideal for budget-conscious users.What is the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box is an IP65-rated enclosure designed to protect your Wyze Sprinkler Controller when mounted outdoors. It shields the controller from dust and water, ensuring durability and reliability in any weather.Can I mount the Wyze Sprinkler Controller outdoors?
Yes, by using the Wyze Weatherproof Sprinkler Controller Box, you can safely mount your controller outdoors. The box provides full protection against the elements and supports both hardwiring and outdoor outlet power.How does the Wyze Sprinkler Controller help save water?
The Wyze Sprinkler Controller uses EPA WaterSense-certified technology and weather-based intelligence to optimize watering schedules. With Sprinkler Plus, it can automatically skip unnecessary watering cycles based on real-time weather data, reducing water waste and lowering utility bills.Can I integrate the Wyze Sprinkler Controller with other Wyze smart home devices?
Yes, the Wyze Sprinkler Controller can be paired with other Wyze smart home devices, such as the Wyze Cam v4 Outdoor Bundle, allowing you to monitor your yard and manage irrigation from the same app for added convenience and security.
