2K Doorbell & HD Porch Camera Combo for Smart Home Security
2K Resolution Doorbell and HD Porch Camera Combo
When it comes to securing your home’s front porch, having crystal-clear video and reliable smart features is essential. Whether you want to see every visitor in stunning detail or keep an eye on your driveway with bright floodlights, the right combination of doorbell and porch cameras can make all the difference. Below, explore top-tier 2K resolution doorbell and HD porch camera combos designed to enhance your home security with smart technology and seamless integration.
Wyze Video Doorbell v2: Crystal-Clear 2K Video Doorbell
Stunning 2K Video Quality
Wyze Video Doorbell v2 delivers head-to-toe 2K resolution video, capturing every visitor and package with remarkable clarity. This wired doorbell ensures you never miss a detail on your porch, day or night.
Local MicroSD Storage & Continuous Recording
Unlike many doorbells, it features an onboard microSD card slot for 24/7 local recording. This means you can review footage before and after doorbell presses without relying solely on cloud storage.
Essential Smart Features
  • Two-way audio: Speak directly to visitors from anywhere using the Wyze app.
  • Motion-activated voice deterrence: Automatically warn unwanted visitors with a voice prompt (requires Cam Plus subscription).
  • Pre-roll motion recording: Capture 3-6 seconds before motion events for full context.
  • Works with existing chimes: Keep your traditional doorbell sound with the included chime controller.
  • IP65 weatherproof rating: Built to withstand rain, snow, and harsh weather conditions.
  • Color Night Vision: Award-winning starlight sensor provides vivid nighttime video.
Smart Home Compatibility
Works seamlessly with Alexa and Google Home, allowing you to view live feeds and receive smart alerts on your voice assistant devices.
“Answer your door from anywhere with our clearest and most capable wired video doorbell yet.”
The Front Porch Security Bundle: Complete Porch Protection
What’s Included?
This bundle pairs the Wyze Video Doorbell (including the v2 model) with the Wyze Lock, offering a comprehensive front porch security solution.
HD Video & Two-Way Audio
View your front porch in crisp 1080p HD and communicate with visitors through two-way audio, all from the Wyze app.
Smart Lock Integration
Control your door lock remotely, check lock history, and manage access conveniently from the same app, enhancing your home’s security and convenience.
Ideal for Smart Homes
This bundle is perfect for those who want an all-in-one front porch security system combining video monitoring and keyless entry.
Wyze Cam Floodlight v2: Bright 2K Porch Camera with Floodlights
Wyze Cam Floodlight v2 illuminating driveway at night Bright, smart floodlight camera for porch security
Powerful 2800 Lumens LED Lighting
Illuminate your porch or driveway with two dimmable LED light panels delivering 2800 lumens of brightness at a crisp 5000K color temperature. Perfect for deterring intruders and enhancing night visibility.
2K Video with Color Night Vision
Capture detailed 2K (2304 x 1296) video with a wide 160° diagonal field of view. The color night vision ensures you see visitors clearly even in low light.
Smart Features for Enhanced Security
  • Two-way talk: Communicate with visitors or delivery personnel directly through the built-in speaker and microphone.
  • AI-Powered Light Control: Lights activate intelligently based on motion detection and ambient light conditions.
  • Dusk-to-dawn automation: Automatically turns lights on at sunset and off at sunrise.
  • 105dB siren: Loud alarm to scare off unwanted guests.
  • 24/7 local recording: Supports up to 256GB microSD card for continuous video storage.
  • Weatherproof IP65 rating: Durable for all outdoor conditions.
Seamless Smart Home Integration
Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Why Choose a 2K Resolution Doorbell and Porch Camera Combo?
High-resolution video doorbells and porch cameras provide sharper images, better facial recognition, and clearer package identification. Combining a 2K video doorbell like the Wyze Video Doorbell v2 with a smart floodlight camera such as the Wyze Cam Floodlight v2 ensures your front porch is monitored day and night with vivid detail and bright illumination.
This combo not only enhances security but also adds convenience with two-way audio, smart alerts, and integration with your favorite smart home assistants.
Summary of Featured Products
Product NameVideo ResolutionKey FeaturesPrice Range
Wyze Video Doorbell v22K (2304 x 1296)Local microSD storage, two-way audio, voice deterrence, IP65 weatherproof$44.98
The Front Porch Security Bundle1080p HDVideo doorbell + Wyze Lock, two-way audio, remote lock control$124.96 (varies)
Wyze Cam Floodlight v22K (2304 x 1296)2800 lumens LED floodlight, color night vision, AI light control, siren$89.98
Enhance Your Porch Security Today
Investing in a 2K resolution doorbell and HD porch camera combo like the Wyze Video Doorbell v2 paired with the Wyze Cam Floodlight v2 or the comprehensive Front Porch Security Bundle ensures your home is protected with crystal-clear video, smart features, and reliable performance. Enjoy peace of mind knowing you can monitor and control your front porch security anytime, anywhere. Wyze Cam Floodlight v2 lifestyle with phone control Control your porch security from your smartphone with Wyze app
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Cam Floodlight v2
Product TypeWired Video DoorbellBundle: Wyze Video Doorbell + Chime + Wyze LockWired Floodlight Camera
Video Resolution2K (2048 x 1536)1080p HD (Doorbell)2K (2304 x 1296)
Field of View135° horizontal, 103° vertical, 166.8° diagonalNot specified (Doorbell only)160° diagonal
Local StoragemicroSD slot (up to 256GB)Not specifiedmicroSD support (up to 256GB)
Cloud StorageOptional with Cam Plus subscriptionOptional with Cam Plus subscriptionOptional with Cam Plus subscription
Two-Way AudioYesYesYes
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)Not specifiedNot specified
Night VisionColor Night Vision with Starlight SensorNot specifiedColor Night Vision
Weather ResistanceIP65IP65IP65
PowerWired (16V-24V AC)Wired (Doorbell)Hardwired (110-120V AC)
Chime CompatibilityWorks with existing chime via included controllerIncluded Wyze Video Doorbell and ChimeN/A
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Additional FeaturesPre-roll motion recording, 30° corner kit included, quick responses, custom detection zonesRemote lock/unlock via Wyze Lock, lock history in app2800 Lumens LEDs, 105dB siren, Ambient Light Mode, AI-Powered Light Control, dusk-to-dawn automation
Price$44.98From $123.99 (varies by variant)$89.98
What is a 2K resolution doorbell and why is it important for home security?A 2K resolution doorbell, such as the Wyze Video Doorbell v2, captures video at 2304 x 1296 pixels, providing crystal-clear images of visitors and packages. This high resolution is important for home security because it allows for better facial recognition, clearer package identification, and more detailed footage, ensuring you never miss important details on your front porch.
What features does the Wyze Video Doorbell v2 offer?The Wyze Video Doorbell v2 offers stunning 2K video quality, local microSD storage for 24/7 continuous recording, two-way audio, motion-activated voice deterrence (with Cam Plus subscription), pre-roll motion recording, compatibility with existing chimes, IP65 weatherproof rating, and award-winning color night vision. It also integrates seamlessly with Alexa and Google Home for smart alerts and live viewing.
How does local microSD storage work on the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 features an onboard microSD card slot that supports continuous 24/7 local recording. This allows you to review footage before and after doorbell presses without relying solely on cloud storage, giving you more control and access to your video history.
What is included in the Front Porch Security Bundle?The Front Porch Security Bundle includes the Wyze Video Doorbell (including the v2 model) and the Wyze Lock. This combination provides comprehensive front porch security with HD video monitoring, two-way audio, and smart lock integration for remote access control and lock history management, all accessible through the Wyze app.
What are the benefits of the Wyze Cam Floodlight v2 for porch security?The Wyze Cam Floodlight v2 offers powerful 2800 lumens LED lighting, 2K video resolution with color night vision, a wide 160° field of view, two-way talk, AI-powered light control, dusk-to-dawn automation, a 105dB siren, 24/7 local recording with microSD support, and an IP65 weatherproof rating. It is ideal for illuminating and monitoring your porch or driveway, deterring intruders, and enhancing night visibility.
Can I control Wyze security devices with my smart home system?Yes, Wyze security devices such as the Video Doorbell v2 and Cam Floodlight v2 are compatible with Alexa, Google Assistant, and IFTTT. This allows you to view live feeds, receive smart alerts, and control your devices using voice commands or automation routines.
How does two-way audio work on Wyze doorbells and cameras?Two-way audio on Wyze doorbells and cameras allows you to speak directly to visitors or delivery personnel through the Wyze app, no matter where you are. The built-in speaker and microphone enable real-time communication, enhancing convenience and security.
What is color night vision and how does it improve security?Color night vision, available on Wyze Video Doorbell v2 and Cam Floodlight v2, uses advanced starlight sensors to provide vivid, full-color video even in low-light conditions. This feature improves security by allowing you to see more details at night, such as the color of clothing or vehicles.
Are Wyze security products weatherproof?Yes, both the Wyze Video Doorbell v2 and Wyze Cam Floodlight v2 have an IP65 weatherproof rating, making them durable and reliable for outdoor use in rain, snow, and harsh weather conditions.
Why should I choose a 2K resolution doorbell and porch camera combo?Choosing a 2K resolution doorbell and porch camera combo ensures your home is monitored with sharper images, better facial recognition, and clearer package identification. Combining devices like the Wyze Video Doorbell v2 and Wyze Cam Floodlight v2 provides comprehensive day and night coverage, smart features, and seamless integration with your smart home system for enhanced security and convenience.
What are the key features of the Wyze Video Doorbell v2?Can you tell me more about the Front Porch Security Bundle?Do you have any ongoing sales or discounts for the Wyze products?
