20ft USB Extension Cable for Wyze Cam: Extend Your Reach Without Drilling
Looking to install your Wyze Cam in the perfect spot but don’t want to drill extra holes or deal with short cables? The Wyze Cam USB Extension Cable - 20ft is the ideal solution for flexible, hassle-free camera placement. Discover how this extension cable, paired with compatible Wyze Cams, can make your home security setup easier and more effective.
Why Choose a 20ft USB Extension Cable for Wyze Cam?
A 20ft USB extension cable gives you the freedom to position your Wyze Cam exactly where you need it—indoors or outdoors—without being limited by the standard cable length. Whether you want to monitor your driveway, backyard, or a distant corner of your home, this extension cable helps you avoid unnecessary drilling and complicated installations.
Say goodbye to short cables and enjoy the freedom of a 20ft cable.
Wyze Cam USB Extension Cable - 20ft: Key Features
Universal Compatibility
Works with Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Not compatible with Wyze Cam Outdoor or Wyze Doorbell products.
Built for Durability
- IP67 Weather Rating: Designed for both indoor and outdoor use, the cable withstands rain, snow, and dust.
- Operating Temperature: -30°C to 50°C (-22°F to 122°F), making it reliable in extreme weather.
Easy Installation
- Plug-and-play: No special tools or adapters required.
- Cable Length: 20ft (6m) for maximum flexibility.
- Connector: USB Type A Male to Female.
Power and Performance
- Output Power: 5V 2A, suitable for continuous camera operation.
- Charge Only: Designed for powering your camera, not for data transmission.
Compatible Wyze Cameras: Secure Every Angle
Wyze Cam OG
- 1080p HD with Color Night Vision: See crisp details day or night.
- Built-in Spotlight & Siren: Deter intruders with a 40-lumen spotlight and 90dB siren.
- IP65 Weather Resistance: Perfect for both indoor and outdoor use.
- Fast Notifications & Upgraded Audio: Get alerts 3x faster and enjoy clear two-way communication.
- Wide 120° Field of View: Monitor large areas with a single camera.
- 3x Telephoto Lens: Focus on distant details with a 27° field of view.
- 1080p Full HD & Color Night Vision: Capture clear images even in low light.
- IP65 Weatherproof: Reliable performance in all weather conditions.
- Stackable Design: Pair with Wyze Cam OG for comprehensive coverage.
Tip: Use the 20ft extension cable to mount your Wyze Cam OG or Telephoto in hard-to-reach places, like high eaves or detached garages, without running new power lines.
Installation Ideas: Avoid Drilling, Maximize Coverage
Run the cable along baseboards, under carpets, or around window frames to keep your setup neat and drill-free.
Perfect for renters or anyone who wants a non-permanent installation.
Ideal for outdoor setups where power outlets are far from the desired camera location.
Weatherproof and Reliable for Outdoor Security
The Wyze Cam USB Extension Cable - 20ft is engineered for outdoor use, with an IP67 rating that protects against dust and water. Pair it with the weather-resistant Wyze Cam OG or Telephoto for year-round security, rain or shine.
No more worrying about cable length or exposure to the elements—just reliable, flexible security.
Summary: The Ultimate Wyze Cam USB Extension Solution
- 20ft length for maximum placement flexibility
- IP67 weatherproof for indoor and outdoor use
- Compatible with most Wyze Cams (v2/v3/v4, Pan v2/v3, OG, OG Telephoto)
- Easy, drill-free installation for renters and homeowners alike
Upgrade your Wyze Cam setup with the 20ft USB Extension Cable and enjoy seamless, flexible security coverage—without the hassle of extra drilling or limited cable reach.
What Wyze cameras are compatible with the 20ft USB Extension Cable?
The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2, Pan v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto. It is not compatible with Wyze Cam Outdoor or Wyze Doorbell products.Is the 20ft USB Extension Cable weatherproof for outdoor use?
Yes, the 20ft USB Extension Cable has an IP67 weather rating, making it suitable for both indoor and outdoor use. It is designed to withstand rain, snow, and dust, and operates reliably in temperatures from -30°C to 50°C (-22°F to 122°F).Can I use the 20ft USB Extension Cable for data transfer?
No, the 20ft USB Extension Cable is designed for power delivery only and does not support data transmission. It is intended to power your Wyze Cam for continuous operation.How do I install the Wyze Cam 20ft USB Extension Cable without drilling?
The extension cable is plug-and-play and requires no special tools or adapters. You can run the cable along baseboards, under carpets, or around window frames to keep your setup neat and avoid drilling, making it ideal for renters or non-permanent installations.What are the key features of the Wyze Cam 20ft USB Extension Cable?
Key features include a 20ft (6m) length for flexible camera placement, IP67 weatherproof rating, USB Type A Male to Female connectors, 5V 2A output power, and universal compatibility with most Wyze Cams (except Wyze Cam Outdoor and Doorbell).Why should I use a 20ft USB extension cable for my Wyze Cam?
A 20ft USB extension cable allows you to position your Wyze Cam exactly where you need it, even in hard-to-reach or distant locations, without being limited by short cables or needing to drill new holes. This maximizes your home security coverage with minimal hassle.Is the 20ft USB Extension Cable suitable for extreme weather conditions?
Yes, the cable is built to operate in extreme weather, with an operating temperature range of -30°C to 50°C (-22°F to 122°F) and an IP67 rating for dust and water resistance.Can I use the 20ft USB Extension Cable with Wyze Cam OG and OG Telephoto?
Yes, the extension cable is fully compatible with Wyze Cam OG and OG Telephoto, allowing you to mount your cameras in high or distant locations for optimal security coverage.What type of connector does the 20ft USB Extension Cable use?
The cable features a USB Type A Male to Female connector, making it easy to extend the reach of your Wyze Cam’s power supply.Is the Wyze Cam 20ft USB Extension Cable easy to install?
Yes, the cable is designed for easy, plug-and-play installation. No special tools or adapters are required, making it simple for anyone to set up.
