IP67 Rated 20ft USB Extension Cables for Wyze Cameras
Where to Find IP67 Rated 20ft USB Extension for Wyze Cameras
If you're looking to extend the reach of your Wyze cameras with a durable, weatherproof USB extension cable, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. Designed specifically for Wyze cameras, this cable offers both length and ruggedness, making it ideal for outdoor and indoor setups where power outlets are far from your camera location.
Wyze Cam USB Extension Cable - 20ft: The Ultimate IP67 Rated Extension
Key Features and Compatibility
  • Length: 20 feet (6 meters) of flexible extension to place your Wyze cameras exactly where you need them.
  • IP67 Weather Rating: Fully waterproof and dustproof, this cable withstands harsh outdoor conditions, ensuring reliable performance rain or shine.
  • Compatible Devices: Works seamlessly with a wide range of Wyze cameras including:
  • Wyze Cam v2, v3, v3 Pro, v4
  • Wyze Cam Pan v2, v3
  • Wyze Cam OG Standard and Telephoto
  • Connector Type: USB Type A Male to Female for easy plug-and-play connection.
  • Durability: AWG 18# cable wire with an outer diameter of 3.8mm, built to last.
  • Operating Temperature: Performs well in extreme temperatures from -30°C to 50°C (-22°F to 122°F).
  • Power Output: Supports 5V 2A power delivery to keep your cameras running smoothly.
This extension cable is a must-have accessory for anyone wanting to expand their Wyze camera setup outdoors or in hard-to-reach indoor locations without worrying about cable damage or weather exposure.
Say goodbye to short cables and enjoy the freedom of a 20ft cable that’s built to last outdoors.
Wyze Cam Outdoor Installation
Additional Wyze Accessories to Complement Your Setup
While the 20ft USB extension cable is essential for extending your camera’s reach, consider these accessories to enhance your Wyze camera experience:
Wyze Surge Protector
  • Power for Multiple Devices: Features 3 USB ports and 3 grounded outlets.
  • Safety: 268 joules surge suppression, flame resistant, and overload protection.
  • Compact Design: Slim profile with right-angle flat plug and non-slip rubber pads.
  • Perfect for Home Use: Keep your Wyze cameras and other smart devices powered safely.
Wyze Cam Floodlight Plug-In Mount
  • Easy Outdoor Lighting: Plug-n-play mount for Wyze Cam Floodlight models.
  • 20ft Power Cord: Matches the length of the USB extension cable for flexible placement.
  • Outdoor Safe: Certified for outdoor use with robust cable wire and temperature tolerance.
  • Simple Installation: No need for complex junction boxes.
Wyze Cam Floodlight Lifestyle
Why Choose Wyze for Your Camera Accessories?
Wyze accessories are designed with the user in mind, offering:
  • Seamless Compatibility: Accessories like the 20ft USB extension cable are tailor-made for Wyze cameras, ensuring hassle-free setup.
  • Durability: IP67 rating and robust materials mean your equipment withstands outdoor elements.
  • Affordability: High-quality accessories at budget-friendly prices.
  • Smart Home Integration: Compatible with Alexa and Google Assistant for voice control and automation.
Summary
For those searching for an IP67 rated 20ft USB extension cable for Wyze cameras, the Wyze Cam USB Extension Cable - 20ft stands out as the best choice. It offers weatherproof durability, extensive compatibility, and reliable power delivery to keep your cameras running smoothly in any environment. Enhance your home security setup with this cable and consider pairing it with other Wyze accessories like the surge protector and floodlight mount for a comprehensive, smart home solution.
FeatureWyze Cam USB Extension Cable - 20ftWyze Surge ProtectorWyze Cam Floodlight Plug-In Mount
TypeAccessoriesAccessoriesCameras
Price$7.99 USD$4.99 USD (was $9.99 USD)$19.98 USD
Description20ft USB extension cable for Wyze Cam modelsSurge-protected power strip with 3 USB ports and 3 outletsPlug-n-play floodlight mount, no junction box needed
Compatible DevicesWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard/TelephotoAny device needing power via USB or grounded outletWyze Cam Floodlight v1, v2, Floodlight Pro
Cable Length20 ftNot applicable20 ft (6m) power cord
Power Input/OutputUSB3 USB ports + 3 grounded outlets110 - 120V AC
Outdoor SafeNoNoYes
Operating TemperatureNot specifiedNot specified-22°F to 122°F
CertificationsNot specifiedNot specifiedUL153, RoHS, REACH SVHC 240, CP65, UL94, UL746A,B, ASTM D495, UL62, UL817, UL2556, UL1581
Included Items1x 20ft USB extension cable1x Surge Protector1x Plug-in Mount, 1x Floodlight Pro mounting kit, 1x Mounting screw kit, 1x Foam tape, 1x Quick Start Guide
Color OptionsDefaultDefaultBlack, White
What is the Wyze Cam USB Extension Cable - 20ft and what makes it ideal for Wyze cameras?The Wyze Cam USB Extension Cable - 20ft is a durable, weatherproof USB extension cable designed specifically for Wyze cameras. With its 20-foot length, IP67 waterproof and dustproof rating, and robust construction, it is perfect for both indoor and outdoor setups where power outlets are far from your camera location.
Which Wyze camera models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with a wide range of Wyze cameras, including Wyze Cam v2, v3, v3 Pro, v4, Wyze Cam Pan v2, v3, and Wyze Cam OG Standard and Telephoto models.
Is the Wyze Cam USB Extension Cable - 20ft weatherproof?Yes, the Wyze Cam USB Extension Cable - 20ft is IP67 rated, making it fully waterproof and dustproof. It is designed to withstand harsh outdoor conditions, ensuring reliable performance in rain, snow, or dust.
What are the technical specifications of the Wyze Cam USB Extension Cable - 20ft?The cable is 20 feet (6 meters) long, uses AWG 18# wire with a 3.8mm outer diameter, supports 5V 2A power delivery, and operates in temperatures ranging from -30°C to 50°C (-22°F to 122°F). It features a USB Type A Male to Female connector for easy plug-and-play use.
Can I use the Wyze Cam USB Extension Cable - 20ft for outdoor camera installations?Absolutely. The cable's IP67 rating and durable construction make it ideal for outdoor camera installations, allowing you to place your Wyze cameras in hard-to-reach or exposed locations without worrying about weather damage.
What other Wyze accessories can enhance my camera setup?In addition to the 20ft USB extension cable, Wyze offers accessories like the Wyze Surge Protector, which provides multiple USB ports and outlets with surge protection, and the Wyze Cam Floodlight Plug-In Mount, which offers easy outdoor lighting and a 20ft power cord for flexible placement.
Why should I choose Wyze accessories for my smart home security setup?Wyze accessories are designed for seamless compatibility with Wyze cameras, feature durable and weather-resistant materials, are affordably priced, and support smart home integration with Alexa and Google Assistant for voice control and automation.
Where can I buy the IP67 rated 20ft USB extension cable for Wyze cameras?You can purchase the Wyze Cam USB Extension Cable - 20ft directly from the Wyze website or authorized retailers. It is the recommended choice for those seeking a reliable, weatherproof extension cable for Wyze cameras.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Is the Wyze Cam USB Extension Cable compatible with all Wyze camera models?Do you have any deals, ongoing sales, discounts, or promotions available?
