20ft USB Extension Cable for Wyze Cam – Perfect Solution for Homes with Limited Outlets
20ft USB Extension Cable for Wyze Cam: The Ultimate Solution for Homes with Limited Outlets
If you’re searching for a reliable 20 ft cable for your Wyze Cam in a house with limited outlets, you’re in the right place. Discover how the Wyze Cam USB Extension Cable - 20ft can transform your camera setup, and explore the compatible Wyze Cams that work seamlessly with this extension for maximum flexibility and coverage.
Extend Your Reach: Wyze Cam USB Extension Cable - 20ft
Say goodbye to short cables and restricted camera placement! The Wyze Cam USB Extension Cable - 20ft is designed for homeowners who need extra length to reach distant outlets, making it perfect for houses with limited power sources.
Key Features
  • Length: 20 feet (6 meters) for maximum flexibility in camera placement.
  • Compatibility: Works with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Weatherproof: IP67 rating ensures reliable performance indoors and outdoors.
  • Durability: Built with AWG 18# wire for safe, efficient power delivery.
  • Easy Installation: Plug-and-play design with USB Type A Male to Female connectors.
  • Operating Temperature: -30°C to 50°C (-22°F to 122°F), suitable for most environments.
Enjoy the freedom to place your Wyze Cam exactly where you need it—no more worrying about outlet locations!
Compatible Wyze Cams: Secure Every Corner of Your Home
The 20ft USB extension cable is compatible with a range of Wyze Cams, each offering unique features to enhance your home security.
Wyze Cam OG
  • Versatile Placement: Use the 20ft cable to install your Wyze Cam OG in hard-to-reach spots, both indoors and outdoors.
  • HD Video: 1080p resolution with color night vision for clear footage day and night.
  • Weather Resistance: IP65 rating for reliable outdoor use.
  • Built-in Spotlight & Siren: Deter intruders with a 40-lumen spotlight and 90-decibel siren.
  • Fast Notifications: 3x faster motion alerts and improved two-way audio.
The Wyze Cam OG, paired with the 20ft extension cable, lets you monitor large rooms, garages, or outdoor spaces without worrying about outlet proximity.
Wyze Cam v4
  • Crystal-Clear Security: 2.5K QHD resolution and enhanced color night vision.
  • Motion-Activated Spotlight: Keep your home safe day or night.
  • Wi-Fi 6 Support: Faster, more reliable connectivity.
  • Flexible Mounting: Stand, wall, or ceiling mount options.
  • Weatherproof: IP65 rating for indoor and outdoor use.
With the Wyze Cam v4 and a 20ft extension cable, you can cover entryways, driveways, or backyards—even when outlets are far away.
  • 3x Telephoto Lens: Focus on distant points of interest with clarity.
  • HD Video: 1080p resolution and color night vision.
  • Weather Resistance: IP65 rating for all-weather performance.
  • Fast Streaming & Alerts: Quicker live-streaming and notifications.
The Wyze Cam OG Telephoto, combined with the 20ft cable, is ideal for monitoring driveways, gates, or any area that needs a closer look from afar.
Why Choose a 20ft USB Extension Cable for Your Wyze Cam?
  • Perfect for Large Homes: Reach outlets across rooms, hallways, or even outside.
  • Ideal for Limited Outlets: No need to rearrange furniture or use unsightly extension cords.
  • Weatherproof & Durable: Built to last, indoors or out.
  • Easy to Install: No technical expertise required—just plug in and go.
Whether you’re setting up a Wyze Cam in your living room, garage, backyard, or any hard-to-reach area, the 20ft USB extension cable gives you the freedom to secure your home your way.
Frequently Asked Questions
Q: Does the 20ft extension cable come with a power adapter? A: No, the cable does not include a power adapter. It is compatible with any 5V/2A Wyze-branded power adapter. Q: Is this cable compatible with Wyze Cam Outdoor or Wyze Doorbell? A: No, this extension cable is not compatible with Wyze Cam Outdoor or Wyze Doorbell products. Q: Can I use this cable for data transfer? A: No, this cable is designed for charging only and does not support data transmission.
Conclusion
Upgrade your Wyze Cam setup with the Wyze Cam USB Extension Cable - 20ft and enjoy the flexibility to place your cameras wherever you need them most—even in homes with limited outlets. Pair it with compatible Wyze Cams like the Wyze Cam OG, Wyze Cam v4, and Wyze Cam OG Telephoto for comprehensive, reliable home security.
Secure every corner of your home—no outlet left behind!
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam OGWyze Cam v4Wyze Cam OG Telephoto
Product TypeAccessory (USB Extension Cable)Indoor/Outdoor CameraIndoor/Outdoor CameraIndoor/Outdoor Camera
Price$7.99From $21.58From $35.98From $29.98
Cable Length / Power20ft (6m), USB Type A Male-Female6ft USB cable, 5V/1A adapter6ft USB cable, 5V/1A adapter6ft USB cable, 5V/1A adapter
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG, OG Telephoto---
Video ResolutionN/A1080p Full HD2.5K QHD (2560x1440)1080p Full HD
Field of ViewN/A121.4° (DFOV)115.8° (DFOV)27° (DFOV) (3x Telephoto)
Night VisionN/AColor Night VisionEnhanced Color Night VisionColor Night Vision
SpotlightN/AYes (40 lumens)Yes (72 lumens, motion-activated)No
Weather ResistanceIP67IP65IP65IP65
AudioN/A2-way, improved clarity2-way, improved clarity2-way, improved clarity
Local StorageN/AUp to 256GB microSD (exFAT)Up to 512GB microSDUp to 256GB microSD (exFAT)
Cloud StorageN/AWith subscriptionWith subscriptionWith subscription
Wi-FiN/A2.4 GHz2.4 GHz, Wi-Fi 62.4 GHz
IntegrationsN/AAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Operating Temperature-30°C to 50°C (-22°F to 122°F)-20°C to 55°C (-4°F to 131°F)-20°C to 50°C (-4°F to 122°F)-20°C to 55°C (-4°F to 131°F)
Special FeaturesCharge only, weatherproofBuilt-in spotlight & siren, fast notifications, stackable2.5K QHD, Wi-Fi 6, motion spotlight, wide dynamic range3x Telephoto lens, stackable, fast notifications
WarrantyNot specified1-Year1-Year1-Year
What Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto. It is not compatible with Wyze Cam Outdoor or Wyze Doorbell products.
Is the 20ft Wyze Cam USB Extension Cable weatherproof for outdoor use?Yes, the 20ft Wyze Cam USB Extension Cable is IP67 weatherproof rated, making it suitable for both indoor and outdoor installations.
Does the 20ft USB Extension Cable come with a power adapter?No, the 20ft USB Extension Cable does not include a power adapter. It is compatible with any 5V/2A Wyze-branded power adapter.
Can I use the 20ft USB Extension Cable for data transfer with my Wyze Cam?No, the 20ft USB Extension Cable is designed for charging and power delivery only. It does not support data transmission.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?The Wyze Cam USB Extension Cable - 20ft features a 20-foot (6 meter) length, IP67 weatherproof rating, AWG 18# wire for safe power delivery, easy plug-and-play installation with USB Type A Male to Female connectors, and an operating temperature range of -30°C to 50°C (-22°F to 122°F).
Why should I use a 20ft USB extension cable for my Wyze Cam?A 20ft USB extension cable allows you to place your Wyze Cam in hard-to-reach areas, ideal for large homes or spaces with limited outlets. It provides flexibility in camera placement without the need for unsightly extension cords and is built to withstand indoor and outdoor conditions.
Is the 20ft USB Extension Cable easy to install?Yes, the 20ft USB Extension Cable features a plug-and-play design, making installation simple and requiring no technical expertise. Just connect the cable between your Wyze Cam and power adapter.
What environments is the 20ft USB Extension Cable suitable for?The 20ft USB Extension Cable is suitable for most environments, with an operating temperature range of -30°C to 50°C (-22°F to 122°F), making it ideal for both indoor and outdoor use.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Can you tell me more about the compatibility of the 20ft cable with different Wyze Cam models?Do you have any ongoing sales or discounts for the Wyze Cam USB Extension Cable?
