Best Two-Way Audio Hardwired Doorbell Cameras for Remote Answering
When it comes to securing your home entrance with clear communication and reliable video, two-way audio hardwired doorbell cameras are the perfect solution. These devices allow you to see and speak to visitors remotely, enhancing your home security and convenience. Below, we explore the top Wyze products designed specifically for wired doorbell camera setups with two-way audio capabilities.
Wyze Video Doorbell v2: The Ultimate Wired Doorbell Camera
Crisp 2K Video Quality and Wide Field of View
The Wyze Video Doorbell v2 delivers stunning 2K (2048 x 1536) resolution video, ensuring you never miss a detail at your doorstep. Its 135° horizontal and 103° vertical field of view provide broad coverage, capturing visitors clearly from multiple angles.
Reliable Two-Way Audio Communication
Equipped with an ECM (Electric Condenser Microphone) and a powerful 8Ω 1W speaker, this doorbell supports seamless two-way audio. Speak to visitors in real-time from anywhere using the Wyze app, whether you're at work or on vacation.
Wired Power and Local Storage
Powered by 16V-24V AC wiring, the Wyze Video Doorbell v2 ensures continuous operation without worrying about battery life. It also supports local microSD storage up to 256GB, allowing you to save video footage securely on-site.
Smart Features and Weather Resistance
  • Motion-activated voice deterrence to ward off unwanted guests
  • Real-time alerts sent directly to your phone
  • IP65 weather resistance for durability in all seasons
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration
Complete Installation Kit Included
The package comes with everything needed for a smooth installation: chime controller, wall plate, wedge for angled mounting, wire caps, screws, and a quick start guide.
The Front Porch Security Bundle: Comprehensive Smart Home Protection
All-in-One Security Solution
This bundle combines the Wyze Video Doorbell and Chime with the Wyze Lock, offering a complete front porch security system. View your porch in crisp 1080p HD and communicate with visitors via two-way audio.
Remote Lock Control and History Tracking
Control your door lock remotely through the Wyze app and monitor lock activity history for added security and peace of mind.
Key Features of the Doorbell in the Bundle
  • 1080p HD video with 8x digital zoom
  • Two-way audio with noise and echo cancellation
  • 120° vertical x 88° horizontal field of view
  • IP65 weather-resistant design
Smart Home Compatibility
Works seamlessly with Alexa and Google Assistant, allowing voice commands and automation.
What’s Included
  • Wyze Lock and Gateway
  • Wyze Video Doorbell and Chime
  • Mounting accessories and wiring components
Enhance Your Doorbell Setup with Wyze Video Doorbell v2 Wedge Kit
Perfect Angle Adjustment for Maximum Coverage
The Wedge Kit is designed exclusively for the Wyze Video Doorbell v2 to help you adjust the viewing angle on angled door frames or porches with stairs. This accessory eliminates blind spots and improves your home security experience.
Easy Installation and Durable Build
Made from weather-resistant plastic, the wedge kit is quick to install and built to last with a 1-year warranty.
Why Choose Wyze for Your Hardwired Doorbell Camera?
Wyze offers a range of wired doorbell cameras and bundles that combine high-resolution video, two-way audio, and smart home integration at an affordable price. Their products are designed for easy installation, reliable performance, and enhanced security features like motion detection and voice deterrence.
"Answer your door from anywhere with Wyze’s clearest and most capable wired video doorbell yet."
Lifestyle Image: Two-Way Audio in Action
Two-way audio communication with Wyze camera Speak to visitors remotely with clear two-way audio
Summary of Key Specs
FeatureWyze Video Doorbell v2Front Porch Security Bundle (Doorbell)
Video Resolution2K (2048 x 1536)1080p HD
Field of View135° horizontal, 103° vertical120° vertical x 88° horizontal
Two-Way AudioYes, with ECM mic and speakerYes, with noise/echo cancellation
Power SourceHardwired 16V-24V ACHardwired 16V-24V AC
StorageLocal microSD up to 256GBCloud and local options
Weather ResistanceIP65IP65
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Conclusion
For homeowners seeking a reliable two-way audio hardwired doorbell camera, the Wyze Video Doorbell v2 and the Front Porch Security Bundle stand out as excellent choices. They combine high-quality video, clear audio communication, and smart home compatibility to keep your front door secure and connected.
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Video Doorbell v2 Wedge Kit
TypeWired Video DoorbellSecurity Bundle (Doorbell + Lock + optional Cam V3)Accessory (Wedge Kit for Doorbell v2)
Video Resolution2K (2304 x 1296)1080p HD (Doorbell), includes Wyze Lock and optional Cam V3N/A
Local StoragemicroSD card slot for 24/7 local recordingIncludes Wyze Video Doorbell with local storageN/A
Two-Way AudioYesYes (Doorbell)N/A
Motion-Activated Voice DeterrenceYes (requires Cam Plus subscription)Yes (Doorbell)N/A
Pre-roll Motion Recording3-6 secondsNot specifiedN/A
Weather ResistanceIP65IP65 (Doorbell)Weather resistant
Works with Existing ChimeYes, includes chime controllerYes (Doorbell and Chime included)N/A
AI Detections (Person, Package)Available with Cam Plus subscriptionNot specifiedN/A
Night VisionColor Night Vision with Starlight Sensor1080p HD (Doorbell)N/A
Integration with Alexa/GoogleYesYes (Doorbell)N/A
Included AccessoriesChime Controller, 30° Corner Kit includedWyze Lock, Wyze Video Doorbell and Chime (varies by variant)1x 15° Horizontal Bracket, 2x 7.5° Vertical Brackets, Screws, Guide
InstallationWiredBundle includes devices requiring wired and app setupQuick installation
Price$44.98From $123.99 to $173.97 (depending on variant)$8.99 (Wedge Kit Only), $51.97 (Doorbell v2 + Wedge Kit)
PurposeFront porch video doorbell with smart featuresComprehensive front porch security with lock and camera optionsAdjust viewing angle for Doorbell v2
CompatibilityDoorbell v2Includes Doorbell v2 or Pro depending on variantCompatible with Doorbell v2 only
WarrantyNot specifiedNot specified1 year
What are the benefits of a two-way audio hardwired doorbell camera?A two-way audio hardwired doorbell camera allows you to see and speak to visitors at your door remotely, enhancing both security and convenience. With hardwired power, you get continuous operation without worrying about battery life, and two-way audio lets you communicate in real-time from anywhere using your smartphone.
What video quality does the Wyze Video Doorbell v2 offer?The Wyze Video Doorbell v2 provides crisp 2K (2048 x 1536) resolution video, ensuring you capture every detail at your doorstep. It also features a wide 135° horizontal and 103° vertical field of view for comprehensive coverage.
Does the Wyze Video Doorbell v2 support two-way audio?Yes, the Wyze Video Doorbell v2 is equipped with an electric condenser microphone (ECM) and a powerful speaker, enabling seamless two-way audio communication. You can speak to visitors in real-time through the Wyze app, no matter where you are.
Is the Wyze Video Doorbell v2 weather resistant?Yes, the Wyze Video Doorbell v2 is rated IP65 for weather resistance, making it durable and reliable in all seasons and weather conditions.
What smart home systems are compatible with Wyze doorbell cameras?Wyze doorbell cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for voice commands and smart home automation.
What is included in the Wyze Video Doorbell v2 installation kit?The Wyze Video Doorbell v2 comes with a complete installation kit, including a chime controller, wall plate, wedge for angled mounting, wire caps, screws, and a quick start guide for easy setup.
What is the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle combines the Wyze Video Doorbell and Chime with the Wyze Lock, providing a comprehensive front porch security solution. It offers 1080p HD video, two-way audio, remote lock control, and activity history tracking.
Can I control my Wyze Lock remotely?Yes, with the Wyze app, you can control your Wyze Lock remotely and monitor lock activity history for added security and peace of mind.
Does the Wyze Video Doorbell v2 support local storage?Yes, the Wyze Video Doorbell v2 supports local microSD storage up to 256GB, allowing you to securely save video footage on-site.
What is the purpose of the Wyze Video Doorbell v2 Wedge Kit?The Wyze Video Doorbell v2 Wedge Kit is designed to help you adjust the viewing angle of your doorbell camera, especially on angled door frames or porches with stairs. This accessory eliminates blind spots and enhances your home security coverage.
How easy is it to install the Wyze Video Doorbell v2 and Wedge Kit?Both the Wyze Video Doorbell v2 and the Wedge Kit are designed for easy installation. The Wedge Kit is made from weather-resistant plastic and comes with a 1-year warranty for durability.
What makes Wyze hardwired doorbell cameras a good choice?Wyze hardwired doorbell cameras offer high-resolution video, clear two-way audio, smart home integration, and advanced security features like motion detection and voice deterrence, all at an affordable price. Their products are easy to install and provide reliable performance for home security.
What are the key features of the Wyze Video Doorbell v2?How does the two-way audio feature work on the Wyze Video Doorbell v2?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Video Doorbell?
