Wyze Doorbell Pro Kit & Lock Bolt: Smart Home Security Bundle
Wyze Doorbell Pro Kit with Lock Bolt Option: Ultimate Smart Home Security
Upgrade your home security with the Wyze Doorbell Pro Kit combined with the Wyze Lock Bolt, a perfect duo for seamless access control and vigilant monitoring. This combination offers you cutting-edge technology to protect your home while providing convenience and peace of mind.
Wyze Lock Bolt: Smart, Secure, and Effortless Entry
Key Features of Wyze Lock Bolt
Fingerprint Unlock & Backlit Keypad Say goodbye to fumbling for keys. The Wyze Lock Bolt features an ultra-fast fingerprint reader and a luxurious backlit keypad, allowing you to unlock your door in less than a second with just a tap or a fingerprint. Auto-Lock for Peace of Mind Never worry about leaving your door unlocked again. The Lock Bolt auto-locks after a customizable delay, ensuring your home stays secure even if you forget to lock up. Robust Security & Weatherproof Design Crafted from solid metal, this smart lock is fully pick-proof and weatherproof with an IPX5 rating, built to withstand the elements and deter intruders. Long Battery Life & Emergency Access Powered by 4 AA batteries lasting up to 12 months, with a USB-C port for emergency charging. The Wyze app allows you to generate one-time emergency codes for guests, expiring automatically for added security. Anti-Peep Technology Protect your passcode from prying eyes by entering extra digits before or after your code without affecting the unlocking process. Easy Installation & Stylish Design Replaces your existing deadbolt in about 20 minutes and comes in Matte Black or Satin Nickel finishes to complement your door’s exterior.
Control at Your Fingertips
The Wyze app acts as your command center, enabling you to:
  • View lock/unlock history with timestamps and access methods
  • Create and manage up to 20 access codes and 50 fingerprints
  • Set auto-expiring codes and access schedules
  • Lock or unlock remotely within Bluetooth range
“Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans.”
Wyze Lock Bolt lifestyle image showing smart lock on front door Wyze Lock Bolt installed on a stylish front door, blending security with design.
Wyze Video Doorbell v2: Crystal Clear 2K Video & Smart Alerts
Why Choose Wyze Video Doorbell v2?
2K HD Video with Wide Field of View Capture every visitor in stunning 2048 x 1536 resolution with a 166.8° diagonal field of view, ensuring no detail goes unnoticed. Two-Way Audio & Motion-Activated Voice Deterrence Communicate with guests or delivery personnel from anywhere and deter unwanted visitors with built-in voice alerts triggered by motion. Local and Cloud Storage Options Save video footage locally on a microSD card (up to 256GB) or opt for cloud storage with the Wyze Security Plan for added convenience. Weather Resistant & Durable Rated IP65 for weather resistance, the doorbell withstands harsh outdoor conditions, operating reliably from -4°F to 122°F. Easy Installation Kit Included Comes with a chime controller, wall plate, wedge for angled mounting, wire caps, and screws for a hassle-free setup.
Smart Home Integration
Compatible with Alexa, Google Assistant, and IFTTT, the Wyze Video Doorbell v2 fits seamlessly into your smart home ecosystem. Lifestyle image of a family interacting with a smart doorbell Stay connected to your home and loved ones with Wyze Video Doorbell v2.
Why Combine Wyze Lock Bolt with Wyze Doorbell Pro Kit?
Pairing the Wyze Lock Bolt with the Wyze Video Doorbell v2 creates a comprehensive front door security system that offers:
  • Complete Access Control: Monitor visitors and grant secure entry remotely or via fingerprint.
  • Enhanced Convenience: No more keys or missed visitors; manage everything from your smartphone.
  • Increased Safety: Real-time alerts and auto-lock features keep your home protected 24/7.
This combination is ideal for homeowners seeking a modern, reliable, and easy-to-use smart home security solution.
Additional Accessories for Wyze Lock Bolt
To maintain and customize your Wyze Lock Bolt, consider these replacement parts:
  • Wyze Lock Bolt Screws – Replacement screws for secure installation.
  • Wyze Lock Bolt Interior Assembly Metal Plate – Anchors the interior assembly firmly to your door.
  • Wyze Lock Bolt Interior Assembly Battery Cover – Replacement cover to protect the battery compartment.
These parts ensure your smart lock remains in optimal condition for years to come.
Summary
The Wyze Doorbell Pro Kit combined with the Wyze Lock Bolt offers a powerful, user-friendly smart home security solution. With advanced fingerprint access, 2K video monitoring, and seamless app control, you can protect your home effortlessly while enjoying modern convenience. Upgrade your front door security today with Wyze’s trusted technology. Wyze Lock Bolt lifestyle image showing app control on smartphone Control your Wyze Lock Bolt easily from your smartphone app.
FeatureWyze Lock BoltWyze Video Doorbell v2
Product TypeConnected Home - Smart LockCameras - Wired Video Doorbell
Price$79.98$44.98
Unlock/Access MethodFingerprint sensor, backlit keypad, app tap2-way audio via app, motion alerts
Video ResolutionN/A2K (2048 x 1536)
KeypadYes, backlit keypad with anti-peep technologyNo
Fingerprint ReaderYes, ultra-fast fingerprint sensorNo
Auto-lock FeatureYes, configurable auto-lock timerNo
Weatherproof RatingIPX5IP65
Battery LifeUp to 12 months (4x AA batteries)Wired power
Battery ReplacementYes, 4 AA batteries replaceableN/A
Emergency AccessOne-time emergency codes via appN/A
App ConnectivityBluetooth local connection onlyWiFi 2.4 GHz direct connection
Remote AccessVia Bluetooth within rangeFrom anywhere via WiFi
Cloud StorageNoOptional with Cam Plus subscription
Voice Assistant IntegrationNoYes (Alexa, Google Home)
Installation Time~20 minutes, replaces existing deadboltWired installation, includes chime controller
Security FeaturesHardware encryption, two-factor authenticationEnd-to-end encryption, HTTPS, AES 128-bit
Locking MethodOne-touch lock button on keypad or appN/A
Number of Fingerprints StoredUp to 50N/A
Number of Access CodesUp to 20 codes, with auto-expiring optionsN/A
Anti-peep TechnologyYesN/A
Weather ResistanceYes, pick-proof and weatherproofYes, IP65 weather resistant
Additional FeaturesUSB-C port for emergency chargingMotion-activated voice deterrence (with subscription)
Compatible PlatformsiOS 9.0+, Android 5.0+iOS 9.0+, Android 5.0+
What is included in the Wyze Doorbell Pro Kit with Lock Bolt Option?The Wyze Doorbell Pro Kit with Lock Bolt Option includes the Wyze Video Doorbell v2 and the Wyze Lock Bolt. This combination provides advanced home security with features like 2K HD video monitoring, fingerprint unlocking, and seamless app control for complete access management.
How does the Wyze Lock Bolt enhance home security?The Wyze Lock Bolt enhances home security with features such as ultra-fast fingerprint unlocking, a backlit keypad, auto-lock functionality, anti-peep technology, and a robust, weatherproof design. It also offers long battery life and emergency access options for added peace of mind.
What are the key features of the Wyze Lock Bolt?Key features of the Wyze Lock Bolt include fingerprint unlock, a backlit keypad, auto-lock with customizable delay, pick-proof and weatherproof construction (IPX5 rated), long battery life (up to 12 months), emergency USB-C charging, anti-peep technology, easy installation, and stylish design options in Matte Black or Satin Nickel.
How do I control and manage the Wyze Lock Bolt?You can control and manage the Wyze Lock Bolt using the Wyze app. The app allows you to view lock/unlock history, create and manage up to 20 access codes and 50 fingerprints, set auto-expiring codes and access schedules, and lock or unlock the door remotely within Bluetooth range.
What makes the Wyze Video Doorbell v2 stand out?The Wyze Video Doorbell v2 stands out with its 2K HD video resolution, 166.8° wide field of view, two-way audio, motion-activated voice deterrence, local and cloud storage options, weather resistance (IP65 rated), and easy installation kit. It also integrates with Alexa, Google Assistant, and IFTTT for smart home compatibility.
Can I store video footage from the Wyze Video Doorbell v2 locally?Yes, you can store video footage locally on a microSD card (up to 256GB) with the Wyze Video Doorbell v2. Additionally, you have the option to use cloud storage with the Wyze Security Plan for added convenience.
Is the Wyze Lock Bolt weatherproof and suitable for outdoor use?Yes, the Wyze Lock Bolt is weatherproof with an IPX5 rating, making it suitable for outdoor use and capable of withstanding various weather conditions.
How easy is it to install the Wyze Lock Bolt and Video Doorbell v2?Both the Wyze Lock Bolt and Video Doorbell v2 are designed for easy installation. The Lock Bolt can replace your existing deadbolt in about 20 minutes, and the Video Doorbell v2 comes with a complete installation kit, including a chime controller, wall plate, wedge, wire caps, and screws.
What smart home systems are compatible with the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 is compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration into your existing smart home ecosystem.
What replacement parts are available for the Wyze Lock Bolt?Replacement parts for the Wyze Lock Bolt include Wyze Lock Bolt Screws, the Interior Assembly Metal Plate, and the Interior Assembly Battery Cover. These accessories help maintain and customize your smart lock for long-term use.
Why should I combine the Wyze Lock Bolt with the Wyze Doorbell Pro Kit?Combining the Wyze Lock Bolt with the Wyze Doorbell Pro Kit provides comprehensive front door security, offering complete access control, enhanced convenience, and increased safety. You can monitor visitors, grant secure entry, and receive real-time alerts—all managed from your smartphone.
How does the auto-lock feature work on the Wyze Lock Bolt?The auto-lock feature on the Wyze Lock Bolt automatically locks your door after a customizable delay, ensuring your home remains secure even if you forget to lock it manually.
What is anti-peep technology on the Wyze Lock Bolt?Anti-peep technology allows you to enter extra digits before or after your actual passcode on the Wyze Lock Bolt keypad, preventing others from guessing your code by watching your entry sequence.
Can you tell me more about the features of the Wyze Lock Bolt?How does the Wyze app help in managing the Wyze Lock Bolt?Do you have any ongoing sales or discounts for the Wyze Doorbell Pro Kit or Wyze Lock Bolt?
