Wyze Smart Security Plus Bundle: Affordable Home Surveillance
Affordable and Reliable Wyze Smart Security Plus Bundle for Homes and Apartments
When it comes to securing your home or apartment without breaking the bank, the Wyze Smart Security Plus Bundle offers an unbeatable combination of affordability, reliability, and smart technology. Designed to provide comprehensive surveillance and monitoring, this bundle integrates multiple sensors and devices that work seamlessly together to keep your living space safe and comfortable.
The Core of Your Smart Security: Wyze Sense Hub
At the heart of the Wyze Smart Security Plus Bundle is the Wyze Sense Hub — the essential brain that connects all your monitoring components. This hub ensures that every sensor and device communicates effectively, sending instant alerts to your smartphone whenever something unusual is detected.
  • Price: $45.98
  • Function: Central control unit for all Wyze Sense sensors
  • Key Feature: Reliable alert system for real-time notifications
  • Compatibility: Works with all Wyze Sense v2 sensors and Wyze Home Monitoring
The Wyze Sense Hub is designed to be the backbone of your home security system, making it easy to manage multiple sensors from one place.
Wyze Smart Home Lifestyle Smart home security in action with Wyze devices
Comprehensive Sensor Suite for Full Home Coverage
Wyze Sense Motion Sensor
Detect movement with precision using the Wyze Sense Motion Sensor. Perfect for monitoring entryways, hallways, or any room where motion detection is critical.
  • Detection Range: Up to 25 feet
  • Field of View: 120° wide angle
  • Battery Life: Up to 18 months
  • Installation: Adhesive back or screws for secure mounting
  • Price: $20.98
This sensor is ideal for alerting you to unexpected activity, helping you respond quickly to potential intruders or emergencies.
Wyze Sense Entry Sensor
Keep track of doors, windows, cabinets, or any entry point with the Wyze Sense Entry Sensor. It notifies you instantly when something opens or closes.
  • Pack Size: 3 Pack
  • Price: $41.98
  • Use Case: Perfect for apartments and homes to monitor access points
  • Installation: Easy peel-and-stick adhesive backing
  • Compatibility: Requires Wyze Sense Hub
Protect your home from water damage with the Wyze Sense Leak Sensor & Probe. It detects leaks early, giving you peace of mind especially in basements, kitchens, or bathrooms.
  • Operating Temperature: 32-104°F (0-40°C)
  • Sensor Range: Up to 500 feet
Indoor Use Only
  • Price: Starting at $13.98 for probes, $55.98 for sensor packs
  • Compatibility: Works with Wyze Sense v2 and Wyze Home Monitoring
Enhance Your Security with Additional Smart Features
Wyze Sense Climate Sensor
Monitor temperature and humidity levels throughout your home to maintain comfort and prevent issues like mold or frozen pipes.
  • Range: 500 feet for remote placement
  • Design: Sleek, unobtrusive white sensor
  • Price: $41.98 for a 3-pack
  • Installation: Place on surfaces or stick to walls
  • Requires: Wyze Sense Hub
Wyze Sense Keypad
Arm or disarm your security system remotely with the Wyze Sense Keypad, adding convenience and control at your fingertips.
  • Price: $27.98
  • Features: Emergency button, remote disarm, first responder alerts
  • Installation: Indoor use with permanent adhesive
  • Compatibility: Requires Wyze Sense Hub and Wyze Home Monitoring
Wyze Keypad Lifestyle Secure your home with easy keypad control
Why Choose Wyze Smart Security Plus Bundle?
The Wyze Smart Security Plus Bundle is designed for homeowners and apartment dwellers who want a reliable, easy-to-install, and affordable surveillance system. With a variety of sensors covering motion, entry, leaks, and climate, plus a central hub and keypad for control, this bundle offers peace of mind and smart home convenience.
  • Affordable pricing without sacrificing quality
  • Scalable system supporting up to 100 sensors per hub
  • Long battery life and wireless installation for flexibility
  • Real-time alerts directly to your smartphone
  • Sleek, unobtrusive designs that blend into any home environment
Wyze Smartwatch Lifestyle Integrate your smart home with wearable technology
Conclusion
For anyone seeking an affordable yet reliable smart security solution for homes or apartments, the Wyze Smart Security Plus Bundle is a top choice. Its comprehensive sensor lineup, centralized hub, and user-friendly controls make it easy to protect your property and loved ones with confidence. Start building your smart home security system today with Wyze — where innovation meets affordability.
FeatureWyze Sense HubWyze Sense Climate SensorWyze Sense Motion SensorWyze Sense KeypadWyze Sense Leak Sensor & ProbeWyze Sense Entry Sensor
DescriptionConnects monitoring components and sends alertsTracks temperature and humidityDetects motionDisarm home security remotelyNotifies of leaksDetects when things open/close
Requires-Wyze Sense HubWyze Sense HubWyze Sense HubWyze Sense HubWyze Sense Hub
CompatibilityCore of Wyze Home Monitoring SystemWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home Monitoring
Standalone FunctionalityYesNoNoNoNoNo
Detection RangeN/A500 ft25 ftN/AUp to 500 ftN/A
Field of ViewN/AN/A120°N/AN/AN/A
Sensors per Hub MaxN/AN/A100100N/AN/A
Sensitivity SettingsN/AN/AAdjustableN/AN/AN/A
InstallationN/ASurface or peel-and-stick adhesiveAdhesive back or screwsPermanent adhesiveN/AN/A
Battery LifeN/AN/AUp to 18 monthsN/AN/AN/A
Indoor UseYesYesYesYesIndoor use onlyYes
Emergency ButtonNoNoNoYesNoNo
Arm/Disarm SystemNoNoNoYesNoNo
AlertsYesYesYesYesYesYes
Price (USD)$45.98$41.98 (3 Pack)$20.98 (1 Pack)$27.98$13.98 (2 Probes) / $55.98 (3 Sensors + 1 Probe)$41.98 (3 Pack)
What is included in the Wyze Smart Security Plus Bundle?The Wyze Smart Security Plus Bundle includes the Wyze Sense Hub, motion sensors, entry sensors, leak sensors and probes, climate sensors, and a keypad. These devices work together to provide comprehensive home or apartment security.
How does the Wyze Sense Hub work?The Wyze Sense Hub acts as the central control unit for all Wyze Sense sensors. It connects all your monitoring components, ensuring seamless communication and sending real-time alerts to your smartphone whenever unusual activity is detected.
Is the Wyze Smart Security Plus Bundle suitable for apartments?Yes, the Wyze Smart Security Plus Bundle is ideal for both homes and apartments. Its wireless installation, easy setup, and scalable system make it perfect for renters and homeowners alike.
How many sensors can the Wyze Sense Hub support?The Wyze Sense Hub can support up to 100 sensors, allowing you to scale your security system to cover every area of your home or apartment.
What types of sensors are included in the Wyze Smart Security Plus Bundle?The bundle includes motion sensors, entry sensors, leak sensors and probes, and climate sensors. Each sensor is designed to monitor specific aspects of your home, such as movement, entry points, water leaks, and temperature or humidity.
How are Wyze sensors installed?Wyze sensors are designed for easy installation. Most sensors use peel-and-stick adhesive backing, while some can also be mounted with screws. This makes setup quick and convenient without the need for professional installation.
Do I need a subscription for real-time alerts with Wyze Smart Security Plus?No subscription is required to receive real-time alerts from the Wyze Sense Hub and sensors. Alerts are sent directly to your smartphone whenever activity is detected.
Are Wyze sensors compatible with other Wyze devices?Yes, Wyze Sense v2 sensors are compatible with the Wyze Sense Hub and Wyze Home Monitoring system, allowing for seamless integration with other Wyze smart home devices.
How long do the batteries last in Wyze sensors?Wyze sensors are designed for long battery life, with motion sensors lasting up to 18 months. This ensures minimal maintenance and reliable performance.
Can I monitor temperature and humidity with the Wyze Smart Security Plus Bundle?Yes, the Wyze Sense Climate Sensor included in the bundle allows you to monitor temperature and humidity levels throughout your home, helping to prevent issues like mold or frozen pipes.
What is the price of the Wyze Smart Security Plus Bundle components?Component prices include $45.98 for the Wyze Sense Hub, $20.98 for the motion sensor, $41.98 for a 3-pack of entry sensors, $55.98 for leak sensor packs, $13.98 for leak probes, $41.98 for a 3-pack of climate sensors, and $27.98 for the keypad.
Is the Wyze Smart Security Plus Bundle easy to use?Yes, the bundle is designed for user-friendly installation and operation. The central hub, wireless sensors, and intuitive keypad make it easy to set up and control your home security system.
Does the Wyze Smart Security Plus Bundle offer real-time smartphone alerts?Yes, the system provides real-time alerts directly to your smartphone whenever motion, entry, leaks, or unusual climate conditions are detected.
Can I arm or disarm the Wyze security system remotely?Yes, the Wyze Sense Keypad allows you to arm or disarm your security system remotely, and it features an emergency button and first responder alerts for added safety.
Is the Wyze Smart Security Plus Bundle affordable?Yes, the Wyze Smart Security Plus Bundle is designed to be an affordable home security solution without sacrificing quality or reliability.
Can you tell me more about the Wyze Sense Hub and its features?How does the Wyze Sense Motion Sensor work for monitoring my home?Do you have any ongoing sales or discounts for the Wyze Smart Security Plus Bundle?
