Wyze Security Bundle with Easy DIY Installation and Smart Features
Protecting your home has never been easier or smarter. Wyze offers a range of thoughtfully curated security bundles designed for easy DIY installation and packed with intelligent features to keep your home safe and connected. Whether you want comprehensive coverage inside and out or focused front porch security, Wyze has the perfect solution tailored to your needs.
Essential Security Bundle: All-in-One Home Protection
The
Essential Security Bundle is your complete package for safeguarding every corner of your home. This bundle combines multiple smart devices that work seamlessly together, providing you with peace of mind and effortless control.
Key Features:
Wyze Video Doorbell v2
Monitor your front door with crisp 1080p HD video. Enjoy two-way audio to greet visitors or deter unwanted guests remotely. The doorbell also supports motion-activated voice deterrence and local microSD storage for capturing every moment in detail.
Wyze Lock Bolt
Say goodbye to fumbling with keys. This smart lock features a fast fingerprint sensor and a backlit keypad for quick, secure access. It auto-locks for added security if you forget to lock the door manually.
Wyze Cam Pan v3
Cover large areas with 360° horizontal and 180° vertical pan-and-tilt capabilities. The camera automatically tracks motion using AI, offers color night vision, and two-way audio, so you never miss a detail.
Two Wyze Cam OG Cameras
Versatile plug-in cameras with motion-activated spotlights and color night vision. Perfect for indoor or outdoor use with IP65 weather resistance.
This bundle is designed for easy DIY installation, allowing you to set up your home security system quickly without professional help.
Stay connected and secure with Wyze smart cameras indoors and outdoors.
Wyze Cam v4 Home Security Bundle: Crystal Clear Surveillance
For those who want unmatched video clarity and smart home integration, the
Wyze Cam v4 Home Security Bundle is an excellent choice.
Highlights:
2.5K QHD Resolution
Capture stunningly detailed video with Quad High Definition clarity, providing sharper images than ever before.
Enhanced Color Night Vision
See vibrant colors even in low-light conditions, thanks to advanced hardware that outperforms traditional night vision.
Motion-Activated Spotlight
Automatically lights up when motion is detected, deterring intruders and improving video quality at night.
Wi-Fi 6 Support
Enjoy a stronger, more reliable connection at greater distances, ensuring your cameras stay online and responsive.
Smart Alerts & Detection
Receive notifications for motion, sound, and even smoke or CO alarms. Customize detection zones to focus on what matters most.
Voice Assistant Compatibility
Works seamlessly with Alexa and Google Assistant for hands-free control.
This wired camera bundle supports 24/7 local recording and comes with 4 microSD cards (128GB each) for ample storage.
Wyze Cam v4 keeps your home safe day and night with enhanced color night vision.
The Front Porch Security Bundle: Smart Entryway Protection
Focus your security efforts on the most important access point — your front porch. The
Front Porch Security Bundle combines smart locking and video doorbell technology for ultimate convenience and safety.
Bundle Components:
Wyze Video Doorbell (1080p HD)
View your front porch in clear HD video and communicate with visitors using two-way audio. Never miss a delivery or visitor again.
Wyze Lock or Wyze Lock Bolt
Lock and unlock your door remotely via the Wyze app. Monitor lock history and receive notifications about door activity.
Wyze Chime
Hear alerts inside your home when someone presses the doorbell.
Smart Features:
- Remote access and control from anywhere
- Integration with Alexa and Google Assistant
- Motion event notifications to keep you informed in real-time
This bundle is perfect for those who want a simple, effective way to secure their main entry point with easy installation and smart home compatibility.
Why Choose Wyze Security Bundles?
Wyze security bundles are designed with the modern homeowner in mind — offering easy DIY installation, smart features, and reliable performance at an affordable price. With Wyze, you get:
- Comprehensive coverage from doorbell to backyard
- Smart automation with fingerprint locks and AI-powered cameras
- Clear, vibrant video day and night
- Seamless app control and voice assistant compatibility
- Expandable systems to grow with your security needs
Invest in your home’s safety with Wyze’s smart security bundles and enjoy peace of mind knowing your property is protected 24/7.
Summary of Wyze Security Bundles for Easy DIY Installation
Bundle Name | Key Devices Included | Price (USD) | Ideal For |
Essential Security Bundle | Video Doorbell v2, Lock Bolt, Cam Pan v3, 2x Cam OG | $199.99 | Full home coverage |
Wyze Cam v4 Home Bundle | 4x Wyze Cam v4 + 4x 128GB microSD cards | $169.99 | High-res indoor/outdoor cameras |
Front Porch Security Bundle | Video Doorbell, Wyze Lock/Lock Bolt, Wyze Chime | From $123.99 | Front door and entryway security |
What is included in the Wyze Essential Security Bundle?
The Wyze Essential Security Bundle includes the Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and two Wyze Cam OG cameras. This all-in-one package provides comprehensive home protection with smart features and easy DIY installation.How easy is it to install Wyze security bundles?
Wyze security bundles are designed for easy DIY installation. All devices come with straightforward instructions, allowing you to set up your home security system quickly without the need for professional help.What are the main features of the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle features 2.5K QHD resolution for crystal clear video, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 support, smart alerts for motion, sound, and smoke/CO alarms, and compatibility with Alexa and Google Assistant. It also includes four 128GB microSD cards for 24/7 local recording.Can Wyze security cameras be used both indoors and outdoors?
Yes, Wyze security cameras such as the Wyze Cam OG and Wyze Cam v4 are designed for both indoor and outdoor use. They feature weather resistance (IP65 rating) and advanced night vision to keep your property secure in any environment.Does Wyze support smart home integration?
Absolutely. Wyze security devices are compatible with popular voice assistants like Alexa and Google Assistant, allowing for hands-free control and seamless integration into your smart home ecosystem.What is the Front Porch Security Bundle and what does it include?
The Front Porch Security Bundle is designed to secure your main entryway. It includes a Wyze Video Doorbell (1080p HD), a Wyze Lock or Wyze Lock Bolt, and a Wyze Chime. This bundle offers remote access, real-time notifications, and smart home compatibility for ultimate convenience and safety.How does the Wyze Lock Bolt enhance home security?
The Wyze Lock Bolt features a fast fingerprint sensor and a backlit keypad for secure, keyless entry. It also auto-locks for added security and allows you to monitor lock history and receive notifications through the Wyze app.What storage options are available for Wyze security cameras?
Wyze security cameras support local microSD card storage, allowing for continuous 24/7 recording. The Wyze Cam v4 Home Security Bundle, for example, comes with four 128GB microSD cards for ample video storage.What are the benefits of choosing a Wyze security bundle?
Wyze security bundles offer comprehensive coverage, smart automation with AI-powered cameras and fingerprint locks, clear video day and night, seamless app and voice assistant control, and expandable systems—all at an affordable price.How do Wyze cameras provide night vision?
Wyze cameras, such as the Cam Pan v3 and Cam v4, feature advanced color night vision and motion-activated spotlights, allowing you to see clear, vibrant images even in low-light conditions.
