Wyze Rep Dock: Efficient Battery Charging Solution
If you're searching for a reliable and convenient way to charge your Wyze camera batteries, the
Wyze Battery Charging Dock is the perfect accessory. Designed to charge two batteries simultaneously, this dock ensures your Wyze Battery Cam Pro is always ready to capture every moment without interruption.
Key Features of Wyze Battery Charging Dock
- Dual Battery Charging: Charge two Wyze Battery Cam Pro batteries at the same time, doubling your charging efficiency.
- Compact and Lightweight: Weighing only 2.75 oz and measuring 2.6in x 2in x 1in, it fits easily on any desk or shelf.
- Long Power Cable: Comes with a 6 ft USB-A to USB-C cable for flexible placement.
- Fast Charging: Fully charges batteries in approximately 8.5 hours at room temperature.
- Wide Compatibility: Specifically designed for Wyze Battery Cam Pro’s battery packs.
- Operating Conditions: Works efficiently between +10°C to +40°C with humidity under 90%.
This dock is an essential companion for Wyze camera users who want to keep their batteries charged and ready without hassle.
Wyze Plug: Smart Power Control for Your Home
Complement your Wyze camera setup with the
Wyze Plug, a smart plug that transforms ordinary devices into smart ones. Control your appliances remotely, schedule power on/off times, and integrate with voice assistants for hands-free convenience.
Wyze Plug Highlights
- Easy Smart Home Upgrade: Turn any device into a smart device with simple plug-in functionality.
- Compact Design: Small footprint (2.7" x 2.0" x 1.5") and lightweight (5.3 oz) for indoor use.
- Connectivity: Operates on 2.4GHz WiFi and supports Android 5.0+ and iOS 9.0+.
- Voice Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT.
- Power Specs: Supports up to 15A max output, perfect for lamps, fans, and small appliances.
- Warranty: Comes with a 1-year warranty for peace of mind.
Whether you want to automate your coffee maker or control your air purifier remotely, the Wyze Plug offers seamless smart home control.
Alt text: Wyze Plug controlling a coffee maker in a modern kitchen
Wyze Plug Outdoor: Smart Power for Your Outdoor Spaces
Take your smart home outdoors with the
Wyze Plug Outdoor, designed to withstand weather and provide smart control for your garden lights, holiday decorations, and more.
Why Choose Wyze Plug Outdoor?
- Weather Resistant: Rated IP64 for protection against rain and dust.
- Dual Outlets: Control two devices independently with a single plug.
- Extended WiFi Range: Up to 300 feet connectivity for outdoor use.
- Voice Control: Compatible with Alexa for easy voice commands.
- Energy Monitoring: Track power usage to optimize energy consumption.
- Durable Build: Operates in temperatures from -4°F to 120°F, perfect for year-round outdoor use.
- Compact Size: Measures 4.0” x 2.8” x 1.4” and weighs 7.2 ounces.
Ideal for backyard parties, holiday setups, or everyday outdoor lighting, the Wyze Plug Outdoor brings smart convenience to your exterior spaces.
Alt text: Outdoor smart plug controlling garden lights at dusk
Why Choose Wyze Accessories for Your Smart Home?
Wyze offers a comprehensive ecosystem of smart home products designed to work seamlessly together. The
Wyze Battery Charging Dock ensures your cameras stay powered, while the
Wyze Plug and
Wyze Plug Outdoor provide versatile smart power control for indoor and outdoor devices. Together, these products help you build a smarter, more connected home environment with ease.
"With Wyze, smart home convenience is just a plug away."
Summary of Relevant Products
Charge two Wyze Battery Cam Pro batteries simultaneously with a compact, efficient dock.
Wyze Plug
Indoor smart plug for remote control, scheduling, and voice assistant integration.
Wyze Plug Outdoor
Weather-resistant outdoor smart plug with dual outlets and energy monitoring.
What is the Wyze Battery Charging Dock and how does it work?
The Wyze Battery Charging Dock is an accessory designed to charge two Wyze Battery Cam Pro batteries simultaneously. It is compact, lightweight, and comes with a 6 ft USB-A to USB-C cable for flexible placement. The dock fully charges batteries in approximately 8.5 hours at room temperature, ensuring your Wyze cameras are always ready to use.Which Wyze camera batteries are compatible with the Wyze Battery Charging Dock?
The Wyze Battery Charging Dock is specifically designed for Wyze Battery Cam Pro battery packs, ensuring optimal charging performance and compatibility.How long does it take to fully charge batteries with the Wyze Battery Charging Dock?
The Wyze Battery Charging Dock can fully charge two Wyze Battery Cam Pro batteries in approximately 8.5 hours at room temperature.What are the size and weight specifications of the Wyze Battery Charging Dock?
The Wyze Battery Charging Dock weighs only 2.75 oz and measures 2.6 inches by 2 inches by 1 inch, making it easy to place on any desk or shelf.What are the operating conditions for the Wyze Battery Charging Dock?
The Wyze Battery Charging Dock operates efficiently in temperatures between +10°C to +40°C and in environments with humidity under 90%.What is the Wyze Plug and what devices can it control?
The Wyze Plug is a smart plug that allows you to control indoor devices such as lamps, fans, and small appliances remotely. It supports up to 15A max output and can be scheduled or controlled via voice assistants like Alexa and Google Assistant.Is the Wyze Plug compatible with voice assistants?
Yes, the Wyze Plug is compatible with Alexa, Google Assistant, and IFTTT, allowing for hands-free control of your connected devices.What are the technical requirements for using the Wyze Plug?
The Wyze Plug operates on 2.4GHz WiFi and is compatible with Android 5.0+ and iOS 9.0+ devices.Does the Wyze Plug come with a warranty?
Yes, the Wyze Plug comes with a 1-year warranty for added peace of mind.What is the Wyze Plug Outdoor and what makes it suitable for outdoor use?
The Wyze Plug Outdoor is a weather-resistant smart plug rated IP64 for protection against rain and dust. It features dual outlets that can be controlled independently, extended WiFi range up to 300 feet, and operates in temperatures from -4°F to 120°F, making it ideal for outdoor devices like garden lights and holiday decorations.Can I monitor energy usage with the Wyze Plug Outdoor?
Yes, the Wyze Plug Outdoor includes energy monitoring features, allowing you to track power usage and optimize energy consumption for your outdoor devices.How many devices can I control with the Wyze Plug Outdoor?
The Wyze Plug Outdoor has dual outlets, enabling you to control two devices independently with a single smart plug.Why should I choose Wyze accessories for my smart home?
Wyze accessories, including the Battery Charging Dock, Wyze Plug, and Wyze Plug Outdoor, are designed to work seamlessly together, providing efficient power solutions and smart control for both indoor and outdoor devices. This integrated ecosystem helps you build a smarter, more connected home with ease.
