Best USB-C Portable Battery Packs for Wyze Cameras
Best Charging Portable Battery Pack for Wyze Camera with USB-C Connectivity
When it comes to powering your Wyze cameras, especially the Wyze Battery Cam Pro, having a reliable and efficient portable battery pack with USB-C connectivity is essential. Whether you want to keep your camera running longer without frequent recharges or need a convenient way to swap batteries, Wyze offers the perfect solutions tailored for your needs.
Wyze Battery Cam Pro: The Ultimate Wire-Free Security Camera
The Wyze Battery Cam Pro is a cutting-edge wireless security camera designed for flexible, wire-free installation anywhere around your home or property. It features:
  • 2.5K HDR Video Resolution for crystal-clear, detailed footage day and night.
  • Integrated Spotlight & Siren to deter intruders with 150 lumens of motion-activated LED light and a loud siren.
  • Radar + PIR Motion Detection for precise and early alerts.
  • Removable, Rechargeable Battery Packs with USB-C charging support.
  • IP65 Weatherproof Rating to withstand rain, dust, and harsh outdoor conditions.
  • Dual-Band WiFi Support (2.4 & 5 GHz) for fast and stable connectivity.
  • Local Recording capability with microSD card support (up to 256GB).
  • No Hub Required for easy setup and operation.
This camera is perfect for those who want a high-quality, wire-free security solution with the convenience of removable batteries that can be charged separately.
"No wires. No hubs. Ultimate wireless security."
Wyze Removable Battery Pack: USB-C Rechargeable Power on the Go
To keep your Wyze Battery Cam Pro running without interruption, the Wyze Removable Battery Pack is a must-have accessory. Key features include:
  • 6200mAh Capacity providing up to 6 months of battery life on a single charge.
  • Built-in USB-C Charging Port for fast and convenient recharging with any standard USB-C charger.
  • Compatible with both Wyze Battery Cam Pro and Wyze Duo Cam Doorbell.
  • Lightweight and portable, making it easy to swap batteries without taking down your camera.
This battery pack ensures your camera stays powered longer and lets you hot-swap batteries to avoid downtime.
Wyze Battery Charging Dock: Charge Two Batteries Simultaneously
For efficient charging of your Wyze camera batteries, the Wyze Battery Charging Dock is an excellent companion accessory:
  • Dual Battery Charging lets you charge two removable battery packs at the same time.
  • Comes with a USB-A to USB-C power cable and power adapter.
  • Compact and lightweight design (2.6in x 2in x 1in).
  • Fully charges batteries in approximately 8.5 hours at room temperature.
  • Compatible specifically with Wyze Battery Cam Pro’s battery packs.
This dock is perfect for users who want to keep multiple batteries ready for extended camera use without hassle.
Why Choose Wyze for Your Portable Battery Needs?
Wyze’s ecosystem is designed to provide seamless power solutions for your wireless cameras with USB-C connectivity, ensuring:
  • Convenience: Easily charge batteries with USB-C, a widely adopted standard.
  • Flexibility: Removable batteries allow for quick swaps and continuous monitoring.
  • Durability: Weatherproof cameras and accessories built to last outdoors.
  • Smart Features: Advanced motion detection, spotlight, and local/cloud recording options.
With Wyze, you get a complete, integrated system that keeps your security cameras powered and ready wherever you need them.
Summary of Recommended Products for USB-C Charging Portable Battery Packs for Wyze Cameras
Product NameKey FeaturesPrice Range
Wyze Battery Cam Pro2.5K HDR, removable battery, IP65 weatherproof$89.98 - $219.98
Wyze Removable Battery Pack6200mAh, USB-C charging port, 6 months life$22.99
Wyze Battery Charging DockCharges two batteries simultaneously, USB-C$17.99
Enhance Your Wyze Camera Experience
Pair your Wyze Battery Cam Pro with the removable battery pack and charging dock to enjoy uninterrupted security coverage with the convenience of USB-C charging. Whether you’re monitoring your home, RV, or outdoor spaces, these accessories ensure your camera stays powered and ready.
"Power your Wyze camera anywhere with USB-C ease."
Outdoor Security Camera in Use Experience wireless security freedom with Wyze Battery Cam Pro outdoors.
FeatureWyze Battery Cam ProWyze Removable Battery PackWyze Battery Charging Dock
TypeCameraAccessory (Battery)Accessory (Charging Dock)
Price$89.98 (1 Pack)$22.99$17.99
Video Resolution2.5K HDR (2560 x 1440)N/AN/A
Power SourceRemovable, Rechargeable Battery Packs6200mAh Rechargeable BatteryCharges up to two battery packs simultaneously
Battery LifeUp to 6 monthsUp to 6 months per chargeN/A
Charging MethodBattery packs removable and rechargeableBuilt-in USB-C charging portUSB-A to USB-C cable included
Weatherproof RatingIP65N/AN/A
Wireless Connectivity2.4 & 5 GHz WiFiN/AN/A
Motion DetectionRadar + PIR Motion DetectionN/AN/A
Additional FeaturesIntegrated Spotlight & Siren, Color Night Vision, Local recording (microSD), Two-way audioCompatible with Wyze Battery Cam Pro and Duo Cam DoorbellCharges two batteries simultaneously
Dimensions2.5 x 1.8 x 3.5 inchesNot specifiedDock: 2.6 x 2 x 1 in (58 x 52 x 26 mm)
Weight0.94 lbsNot specified2.75 oz (78 g)
Included ItemsCamera, Wall MountBattery Pack onlyCharging Dock, Adapter Cable, Power Adapter
CompatibilityN/AWyze Battery Cam Pro, Wyze Duo Cam DoorbellWyze Battery Cam Pro's battery packs
SetupWireless, no hub requiredN/AN/A
What is the best portable battery pack for Wyze cameras with USB-C connectivity?The Wyze Removable Battery Pack is the best portable battery pack for Wyze cameras with USB-C connectivity. It features a 6200mAh capacity, provides up to 6 months of battery life on a single charge, and is compatible with both the Wyze Battery Cam Pro and Wyze Duo Cam Doorbell. Its built-in USB-C charging port allows for fast and convenient recharging.
Which Wyze cameras are compatible with the Wyze Removable Battery Pack?The Wyze Removable Battery Pack is compatible with the Wyze Battery Cam Pro and the Wyze Duo Cam Doorbell, making it a versatile power solution for your Wyze security devices.
How long does the Wyze Removable Battery Pack last on a single charge?The Wyze Removable Battery Pack can last up to 6 months on a single charge, depending on camera usage and environmental conditions.
How do I charge the Wyze Removable Battery Pack?You can charge the Wyze Removable Battery Pack using its built-in USB-C charging port. Simply connect it to any standard USB-C charger for fast and convenient recharging.
What is the Wyze Battery Charging Dock and how does it work?The Wyze Battery Charging Dock is an accessory designed to charge two Wyze removable battery packs simultaneously. It comes with a USB-A to USB-C power cable and a power adapter, and can fully charge two batteries in approximately 8.5 hours at room temperature.
Can I charge two Wyze camera batteries at the same time?Yes, the Wyze Battery Charging Dock allows you to charge two Wyze removable battery packs at the same time, ensuring you always have a spare battery ready for your camera.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, making it suitable for outdoor use in rain, dust, and harsh weather conditions.
Does the Wyze Battery Cam Pro require a hub for operation?No, the Wyze Battery Cam Pro does not require a hub. It is designed for easy, wire-free setup and operation.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro features 2.5K HDR video resolution, integrated spotlight and siren, radar and PIR motion detection, removable rechargeable battery packs with USB-C charging, IP65 weatherproof rating, dual-band WiFi support, local recording with microSD card support, and does not require a hub.
Why should I choose Wyze for portable battery solutions for my security cameras?Wyze offers a seamless ecosystem for powering wireless cameras with USB-C connectivity, providing convenience, flexibility with removable batteries, durable weatherproof designs, and smart features like advanced motion detection and local/cloud recording. This ensures your cameras stay powered and ready for use anywhere.
What are the key features of the Wyze Battery Cam Pro?How long does the Wyze Removable Battery Pack last on a single charge?What is the warranty policy for the Wyze Battery Cam Pro?
