Wyze Battery Pack with USB-C Charging for Outdoor Cameras
Wyze Battery Pack with USB-C Charging for Outdoor Camera Usage
When it comes to securing your outdoor spaces with reliable, wire-free cameras, Wyze offers some of the best battery-powered options designed for long-lasting performance and easy charging. If you're searching for a Wyze battery pack with USB-C charging capabilities tailored for outdoor camera use, the Wyze Battery Cam Pro and its solar-powered variant stand out as top choices. These cameras combine high-resolution video, weather resistance, and flexible power solutions to keep your property safe without the hassle of constant wiring.
Wyze Battery Cam Pro: Powerful Battery with USB-C Charging
Long-Lasting Battery Life & Rechargeable Packs
The Wyze Battery Cam Pro features removable, rechargeable battery packs with a robust 6200mAh capacity, providing up to 6 months of battery life on a single charge. This makes it ideal for outdoor use where power outlets may not be readily available. The battery packs recharge in approximately 9 hours via USB-C, ensuring quick and convenient power-ups.
High-Quality Video & Smart Features
  • 2.5K HDR video resolution (2560 x 1440) for crystal-clear footage
  • Integrated spotlight and siren for enhanced security
  • Advanced Radar + PIR motion detection for accurate alerts
  • Color night vision with 2 IR LEDs and 2 white LEDs (187 lumens)
  • Supports 2.4 GHz and 5 GHz WiFi for stable connectivity
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration
Weatherproof & Durable Design
Built to withstand the elements, the Wyze Battery Cam Pro is rated IP65 weatherproof, operating reliably in temperatures from -20°C to 50°C (-4°F to 122°F) and humidity below 90%. Its compact size (2.5 x 1.8 x 3.5 inches) and matte finish make it discreet yet rugged for outdoor environments.
Flexible Mounting & Storage
The camera includes a 1/4” - 20 standard mount and a wall mount for easy installation anywhere outside. It supports local storage with microSD cards up to 256 GB, allowing you to save footage without relying solely on cloud services. Outdoor security camera mounted on a porch with greenery Wyze Battery Cam Pro in an outdoor setting, perfect for home security.
Wyze Battery Cam Pro + Solar Panel: Continuous Power from the Sun
Solar Charging for Extended Outdoor Use
For those wanting to eliminate the need for manual recharging, the Wyze Battery Cam Pro + Solar Panel bundle offers a seamless solar charging solution. The solar panel continuously powers the camera during daylight, keeping the 6200mAh rechargeable battery topped up and ready for action.
Same Great Features with Added Convenience
This model shares all the advanced features of the Battery Cam Pro, including:
  • 2.5K HDR video quality
  • Radar + PIR motion detection
  • IP65 weatherproof rating
The solar panel is designed to withstand outdoor conditions and provides a sustainable power source, making it perfect for remote locations or areas with limited access to electrical outlets. Solar panel powering an outdoor security camera Wyze Battery Cam Pro with solar panel for continuous outdoor charging.
Why Choose Wyze Battery-Powered Outdoor Cameras?
"Wyze’s battery-powered cameras with USB-C charging combine convenience, durability, and smart technology to provide reliable outdoor security without the need for complex wiring."
  • Wire-free installation means you can place cameras anywhere outdoors without worrying about power cables.
  • Rechargeable battery packs with USB-C charging offer fast, universal compatibility with modern chargers.
  • Weatherproof IP65 rating ensures cameras perform well in rain, snow, and heat.
  • Smart home integration allows voice control and automation with Alexa, Google Assistant, and IFTTT.
  • High-resolution video and night vision keep your property monitored day and night with clear footage.
Additional Wyze Outdoor Camera Options
While the Wyze Battery Cam Pro models are the best fit for battery packs with USB-C charging, Wyze also offers other outdoor cameras that might interest you:
Wyze Cam Pan v3
  • 1080p resolution with 360° pan and 180° tilt
  • IP65 weather resistance (requires separate outdoor power adapter)
  • Two-way audio and motion tracking
  • Ideal for areas where wired power is available
Wyze Cam Pan v3 in snowy outdoor environment Wyze Cam Pan v3 providing versatile outdoor coverage.
Wyze Cam Outdoor v2
  • Wire-free with 3 to 6 months battery life (two 2600mAh batteries)
  • 1080p resolution with color night vision
  • Magnetic and screw mounting options
  • Travel Mode for monitoring on the go
Conclusion
For outdoor camera usage with a focus on battery packs featuring USB-C charging, the Wyze Battery Cam Pro and Wyze Battery Cam Pro + Solar Panel are the premier choices. They offer long battery life, quick USB-C recharging, and robust weatherproofing, making them perfect for securing your outdoor spaces with minimal hassle. The solar panel option further enhances convenience by providing continuous power from sunlight, ideal for remote or hard-to-reach locations. Choose Wyze for smart, reliable, and flexible outdoor security solutions that keep you connected and protected.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Cam Pan v3Wyze Cam Outdoor v2
Video Resolution2.5K HDR2.5K HDR1080p (1920 x 1080)1080p (1920 x 1080)
Video FPSNot specifiedNot specifiedDay: 20 fps / Night: 15 fpsDay: 20 fps / Night: 10 fps
Field of ViewNot specifiedNot specified120° FOV130°
Pan & TiltNoNo360° horizontal, 180° verticalNo
Night VisionColor Night VisionColor Night VisionColor Night VisionColor Night Vision
Motion DetectionRadar + PIRRadar + PIRMotion trackingPIR Motion Detection
Spotlight & SirenIntegrated Spotlight & SirenIntegrated Spotlight & SirenNoNo
BatteryRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery PacksRequires power adapter (sold separately)2x 2600 mAh rechargeable batteries
Power OptionsBattery, Solar Panel (optional)Battery + Solar Panel includedWired (requires power adapter)Battery
Weatherproof RatingIP65IP65IP65IP65
Wi-Fi Support2.4 & 5 GHz2.4 & 5 GHz2.4 GHz onlyNot specified (likely 2.4 GHz)
Local StorageMicroSD card supportMicroSD card supportMicroSD card support (up to 256GB)MicroSD card slot (up to 256GB)
Two-Way AudioYesYesYesYes
DimensionsNot specifiedNot specified124mm x 60mm x 63mm2.3" x 2.3" x 2.8"
WeightNot specifiedNot specified11.29 oz (320 g)9.8 oz
SetupBluetoothⓇ Setup, No Hub RequiredBluetoothⓇ Setup, No Hub RequiredBluetoothⓇ Setup, Requires power adapterNo hub, wire-free
Price (Single Unit)$89.98$109.98$39.98$63.99 (Add-On Camera)
Additional FeaturesHot-swap battery packs, Integrated spotlight, Siren, Bird Detection (with Cam Plus)Same as Battery Cam Pro + Solar continuous power8x digital zoom, Alexa/Google/IFTTT integrationTravel Mode, Magnetic & screw mounts
What is the Wyze Battery Cam Pro and how does it work for outdoor security?The Wyze Battery Cam Pro is a wire-free, battery-powered outdoor security camera designed for long-lasting performance. It features a 6200mAh rechargeable battery pack with USB-C charging, providing up to 6 months of battery life on a single charge. The camera offers 2.5K HDR video resolution, color night vision, integrated spotlight and siren, and advanced motion detection, making it ideal for reliable outdoor security.
Does the Wyze Battery Cam Pro support USB-C charging?Yes, the Wyze Battery Cam Pro comes with removable, rechargeable battery packs that can be recharged via USB-C. This allows for fast and convenient charging using modern USB-C chargers.
How long does the Wyze Battery Cam Pro battery last and how quickly does it recharge?The Wyze Battery Cam Pro’s 6200mAh battery pack can last up to 6 months on a single charge, depending on usage. Recharging the battery via USB-C takes approximately 9 hours.
Is the Wyze Battery Cam Pro weatherproof for outdoor use?Yes, the Wyze Battery Cam Pro is rated IP65 weatherproof, making it suitable for outdoor use in rain, snow, and heat. It operates reliably in temperatures from -20°C to 50°C (-4°F to 122°F) and humidity below 90%.
Can I use a solar panel with the Wyze Battery Cam Pro for continuous charging?Yes, the Wyze Battery Cam Pro + Solar Panel bundle allows you to continuously power your camera using solar energy. The solar panel keeps the 6200mAh battery charged during daylight, reducing the need for manual recharging and making it ideal for remote or hard-to-reach locations.
What smart features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro includes 2.5K HDR video, color night vision, integrated spotlight and siren, advanced Radar + PIR motion detection, and supports both 2.4 GHz and 5 GHz WiFi. It is also compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
How can I mount the Wyze Battery Cam Pro outdoors?The Wyze Battery Cam Pro comes with a 1/4” - 20 standard mount and a wall mount, allowing for flexible installation anywhere outside your home.
Does the Wyze Battery Cam Pro support local video storage?Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB, enabling you to save footage without relying solely on cloud services.
Are there other Wyze outdoor cameras with battery power and USB-C charging?The Wyze Battery Cam Pro and its solar panel bundle are the primary Wyze outdoor cameras featuring battery packs with USB-C charging. Other Wyze outdoor cameras, like the Wyze Cam Outdoor v2, offer battery power but do not feature USB-C charging.
What are the benefits of choosing a Wyze battery-powered outdoor camera?Wyze battery-powered outdoor cameras offer wire-free installation, long-lasting rechargeable battery packs with USB-C charging, weatherproof IP65 rating, smart home integration, and high-resolution video with night vision. These features provide reliable and flexible outdoor security without the need for complex wiring.
What are the key features of the Wyze Battery Cam Pro?How does the solar panel work with the Wyze Battery Cam Pro?Are there any ongoing promotions or discounts for Wyze products?
