Wyze Removable Battery Pack Compatibility with Doorbells
If you're looking to enhance your Wyze doorbell experience with extended battery life, understanding the compatibility of the Wyze Removable Battery Pack with Wyze doorbell models is essential. This guide highlights the key features and compatibility details of the Wyze Removable Battery Pack and how it works with Wyze doorbell products.
Wyze Removable Battery Pack: Power on the Go
Designed for Wyze Battery Cam Pro and Duo Cam Doorbell
The Wyze Removable Battery Pack is a powerful 6200mAh rechargeable battery designed specifically for Wyze's Battery Cam Pro and Duo Cam Doorbell models. This battery pack offers:
  • Long-lasting power: Up to 6 months of battery life on a single charge, allowing you to place your camera or doorbell outdoors without worrying about frequent recharging or nearby power outlets.
  • Convenient USB-C charging: Equipped with a built-in USB-C port, the battery pack can be easily recharged with any standard USB-C cable (charging cable not included).
  • Easy replacement: Removable design makes swapping batteries quick and hassle-free, ensuring your Wyze devices stay powered continuously.
The Wyze Removable Battery Pack is the perfect accessory to keep your Wyze Duo Cam Doorbell running longer and more reliably.
Wyze Video Doorbell v2: Wired Power with Advanced Features
Compatibility Note
The Wyze Removable Battery Pack is not compatible with the Wyze Video Doorbell v2, as this model is designed to be powered via wired connection. The Video Doorbell v2 requires a 16V-24V AC power source and includes a chime controller to work seamlessly with your existing home chime system.
Key Features of Wyze Video Doorbell v2
  • 2K HD video resolution: Crystal-clear video quality to capture every detail on your porch.
  • Local microSD storage: Continuous 24/7 recording with onboard storage, so you never miss a moment.
  • Two-way audio: Talk to visitors directly through the Wyze app.
  • Motion-activated voice deterrence: Automatically warns visitors they are being recorded.
  • Weatherproof design: IP65 rating ensures reliable operation in all weather conditions.
  • Smart home integration: Works with Alexa and Google Home for voice control and live feed viewing.
Front Porch Security Bundle: Comprehensive Smart Home Protection
For those seeking an all-in-one solution, the Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock and Chime, offering:
  • 1080p HD porch monitoring with two-way audio.
  • Remote door locking/unlocking via the Wyze app.
  • Motion event and lock history tracking for enhanced security.
  • Compatibility with Alexa and Google Assistant for smart home convenience.
This bundle is ideal for wired doorbell setups and does not utilize the Wyze Removable Battery Pack.
Summary: Which Doorbells Work with the Wyze Removable Battery Pack?
ProductBattery Pack Compatible?Power Source
Wyze Duo Cam DoorbellYesBattery (Removable)
Wyze Battery Cam ProYesBattery (Removable)
Wyze Video Doorbell v2NoWired (16V-24V AC)
Front Porch Security BundleNoWired + Smart Lock
If you own a Wyze Duo Cam Doorbell or Battery Cam Pro, the Wyze Removable Battery Pack is an excellent accessory to extend your device's runtime and maintain uninterrupted security coverage.
Why Choose Wyze Removable Battery Pack?
  • Extended outdoor use: Perfect for locations without easy access to power outlets.
  • Quick and simple charging: USB-C port for fast recharging.
  • Reliable power: 6200mAh capacity ensures months of operation.
  • Compatible with select Wyze devices: Specifically designed for Battery Cam Pro and Duo Cam Doorbell.
Enhance Your Wyze Doorbell Experience
While the Wyze Video Doorbell v2 and Front Porch Security Bundle rely on wired power, the Wyze Removable Battery Pack offers unmatched convenience for battery-powered Wyze doorbells. Choose the right power solution based on your doorbell model to ensure optimal performance and security.
Wyze Doorbell in Use Experience seamless home security with Wyze doorbells powered by reliable battery solutions.
For more information on Wyze accessories and compatible devices, consider the Wyze Removable Battery Pack as a must-have for your battery-powered Wyze doorbell setup.
FeatureWyze Removable Battery PackWyze Video Doorbell v2The Front Porch Security Bundle
TypeAccessoryWired Video DoorbellSecurity Bundle
Compatible DevicesWyze Battery Cam Pro, Wyze Duo Cam DoorbellWired Video Doorbell v2Wyze Video Doorbell, Wyze Lock
Battery Capacity6200mAh rechargeableN/A (Wired)N/A
Battery LifeUp to 6 months per chargeN/AN/A
Charging PortUSB-CN/AN/A
Video ResolutionN/A2K (2048 x 1536)1080p HD (Video Doorbell), includes Wyze Lock
Local StorageN/AmicroSD card slot for local recordingN/A
Two-Way AudioN/AYesYes
Motion-Activated Voice DeterrenceN/AYes (requires subscription)N/A
Weather ResistanceN/AIP65IP65 (Video Doorbell)
Field of ViewN/A120° Vertical x 88° HorizontalN/A
ConnectivityN/AWiFi 2.4 GHz (802.11 b/g/n)WiFi 2.4 GHz (Video Doorbell), Bluetooth & Zigbee (Lock)
Power SourceRechargeable battery16V-24V AC, ≥10VAVideo Doorbell: 16V-24V AC; Lock: 4x AA Batteries
Included ItemsBattery pack onlyDoorbell + Chime Controller, Wall Plate, Wedge, etc.Wyze Lock, Gateway, Batteries, Video Doorbell, Chime, Mounting accessories
Price$22.99$44.98From $123.99
Special FeaturesLong battery life, USB-C charging2K video, pre-roll recording, works with existing chimeRemote lock/unlock, lock history, Alexa & Google Assistant compatible
WarrantyNot specifiedNot specifiedNot specified
Which Wyze doorbells are compatible with the Wyze Removable Battery Pack?The Wyze Removable Battery Pack is compatible with the Wyze Duo Cam Doorbell and Wyze Battery Cam Pro. It is not compatible with the Wyze Video Doorbell v2 or the Front Porch Security Bundle.
Is the Wyze Removable Battery Pack compatible with the Wyze Video Doorbell v2?No, the Wyze Removable Battery Pack is not compatible with the Wyze Video Doorbell v2. The Video Doorbell v2 requires a wired 16V-24V AC power source and cannot be powered by a battery pack.
How long does the Wyze Removable Battery Pack last on a single charge?The Wyze Removable Battery Pack offers up to 6 months of battery life on a single charge, depending on usage and environmental conditions.
How do I recharge the Wyze Removable Battery Pack?The Wyze Removable Battery Pack features a built-in USB-C port for convenient recharging. You can use any standard USB-C cable to recharge the battery pack (charging cable not included).
Can I use the Wyze Removable Battery Pack with the Front Porch Security Bundle?No, the Wyze Removable Battery Pack is not compatible with the Front Porch Security Bundle. This bundle is designed for wired doorbell setups and does not support battery power.
What are the benefits of using the Wyze Removable Battery Pack with my Wyze doorbell?The Wyze Removable Battery Pack provides extended outdoor use, quick and simple USB-C charging, reliable 6200mAh power capacity, and easy battery replacement for uninterrupted security coverage with compatible Wyze devices.
What power source does the Wyze Video Doorbell v2 require?The Wyze Video Doorbell v2 requires a wired 16V-24V AC power source and includes a chime controller for integration with your existing home chime system.
What features does the Wyze Video Doorbell v2 offer?The Wyze Video Doorbell v2 offers 2K HD video resolution, local microSD storage for continuous 24/7 recording, two-way audio, motion-activated voice deterrence, weatherproof IP65 design, and smart home integration with Alexa and Google Home.
Why should I choose the Wyze Removable Battery Pack for my Wyze doorbell?The Wyze Removable Battery Pack is ideal for locations without easy access to power outlets, offering months of reliable operation, fast USB-C charging, and compatibility with select Wyze devices like the Duo Cam Doorbell and Battery Cam Pro.
What are the key features of the Wyze Removable Battery Pack?How long does the Wyze Removable Battery Pack last on a single charge?Do you have any deals, ongoing sales, discounts, or promotions?
