Extend Your Wyze Security Camera Battery Life with Extra Battery Packs
When it comes to home security, uninterrupted monitoring is essential. Wyze offers innovative security cameras with rechargeable battery options, and to keep your cameras running longer without frequent recharging, the
Wyze Removable Battery Pack is the perfect accessory. This page highlights the best Wyze security cameras with battery options and how the extra battery pack can extend your camera’s uptime for peace of mind.
Wyze Battery Cam Pro: Long-Lasting Wireless Security
Key Features
- 2.5K HDR Video Resolution: Crystal-clear video quality at 2560 x 1440 resolution ensures you never miss a detail.
- Wire-Free Design: Completely wireless with no hub required, making installation quick and flexible.
- Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security by deterring intruders.
- Radar + PIR Motion Detection: Advanced motion sensors for accurate alerts.
- Removable, Rechargeable Battery Packs: Comes with a powerful 6200mAh battery that lasts up to 6 months on a single charge.
- Weatherproof (IP65): Durable for outdoor use in various weather conditions.
- Dual-Band WiFi Support: Compatible with both 2.4 GHz and 5 GHz networks.
- Two-Way Audio: Communicate through the camera with built-in speaker and microphone.
- Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
Specifications
- Dimensions: 2.5 x 1.8 x 3.5 inches
- Weight: 0.94 lbs
- Battery Capacity: 6200mAh
- Operating Temperature: -20°C to 50°C (-4°F to 122°F)
- Night Vision: 2 IR LEDs + 2 White LEDs (187 lumens)
- Field of View: 134° diagonal, 108° horizontal, 56° vertical
The Wyze Battery Cam Pro is ideal for users who want a high-resolution, wire-free security camera with extended battery life and smart features.
Stay secure outdoors with Wyze Battery Cam Pro
Wyze Removable Battery Pack: Power Up Your Battery Cam Pro
Why Choose the Wyze Removable Battery Pack?
- 6200mAh Capacity: Matches the original battery capacity of the Battery Cam Pro, providing up to 6 months of battery life per charge.
- Rechargeable Lithium-Ion Battery: Efficient and long-lasting power source.
- USB-C Charging Port: Convenient and fast charging with modern USB-C connectivity.
- Compact and Lightweight: Weighs only 3.9 oz (110g) and measures 2.9 x 1.6 x 0.9 inches, easy to swap in and out.
- Wide Operating Temperature Range: Works reliably from -20°C to 50°C (-4°F to 122°F).
- Compatible with Battery Cam Pro and Duo Cam Doorbell: Versatile accessory for multiple Wyze battery-powered devices.
Benefits
Keep your Wyze Battery Cam Pro running longer without downtime by having extra charged battery packs ready to swap. Perfect for extended trips, vacation homes, or areas where frequent charging is inconvenient.
Security Starter Pack: Wired and Wireless Hybrid Solution
What’s Included?
- Wyze Cam Pan v3 (360° coverage, 1080p HD)
- Wyze Cam v4 (2.5K QHD resolution, color night vision)
Features
- Wyze Cam Pan v3: Offers 360° horizontal and 180° vertical view with smooth pan and tilt functionality.
- Wyze Cam v4: Features a CMOS Starlight sensor for enhanced low-light performance and 2 white spotlight LEDs for color night vision.
- Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible installation.
- Wired Power: Both cameras use indoor power adapters, so no battery pack is needed here, but they complement battery cams for a comprehensive security setup.
This starter pack is perfect for users who want a mix of wired and wireless cameras for different areas of their home.
Versatile indoor monitoring with Wyze Cam v4
Enhance Your Wyze Security Setup with Extra Battery Packs
For users relying on Wyze Battery Cam Pro or Duo Cam Doorbell, the
Wyze Removable Battery Pack is an essential accessory to extend battery life and maintain continuous security coverage. With up to 6 months of battery life per charge and quick USB-C charging, you can keep your cameras powered without interruption.
Investing in extra battery packs means less downtime, more flexibility, and peace of mind knowing your home is always protected.
Summary of Relevant Products
Rechargeable, wire-free camera with up to 6 months battery life and 2.5K HDR video.
Extra 6200mAh rechargeable battery for Battery Cam Pro and Duo Cam Doorbell.
Includes Wyze Cam Pan v3 and Wyze Cam v4 for wired indoor/outdoor security.
Maximize your Wyze security camera uptime and enjoy uninterrupted home monitoring with the right battery solutions tailored to your needs. Whether you choose the wireless freedom of the Battery Cam Pro or the comprehensive coverage of the Security Starter Pack, adding extra battery packs ensures your cameras stay powered longer and your home stays safer.
How can I extend the battery life of my Wyze security camera?
You can extend the battery life of your Wyze security camera by using the Wyze Removable Battery Pack. This extra rechargeable battery allows you to quickly swap out depleted batteries, ensuring your Wyze Battery Cam Pro or Duo Cam Doorbell stays powered for up to 6 months per charge.What is the Wyze Removable Battery Pack and which devices is it compatible with?
The Wyze Removable Battery Pack is a 6200mAh rechargeable lithium-ion battery designed to provide extended power for Wyze Battery Cam Pro and Duo Cam Doorbell. It is compact, lightweight, and features a USB-C charging port for fast and convenient charging.How long does the Wyze Battery Cam Pro battery last on a single charge?
The Wyze Battery Cam Pro can last up to 6 months on a single charge, thanks to its powerful 6200mAh removable battery pack. Actual battery life may vary depending on usage and environmental conditions.What are the key features of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro offers 2.5K HDR video resolution, a wire-free design, integrated spotlight and 100 dB siren, radar and PIR motion detection, weatherproof IP65 rating, dual-band WiFi support, two-way audio, and smart home integration with Alexa, Google Assistant, and IFTTT.Can I use the Wyze Removable Battery Pack with other Wyze cameras?
The Wyze Removable Battery Pack is specifically compatible with the Wyze Battery Cam Pro and Duo Cam Doorbell. It is not designed for use with other Wyze camera models.How do I charge the Wyze Removable Battery Pack?
The Wyze Removable Battery Pack features a USB-C charging port, allowing for fast and convenient charging with any compatible USB-C cable and power adapter.Is the Wyze Battery Cam Pro suitable for outdoor use?
Yes, the Wyze Battery Cam Pro is weatherproof with an IP65 rating, making it durable and reliable for outdoor use in various weather conditions.What is included in the Wyze Security Starter Pack?
The Wyze Security Starter Pack includes the Wyze Cam Pan v3, which offers 360° coverage and 1080p HD video, and the Wyze Cam v4, which features 2.5K QHD resolution and color night vision. Both cameras are wired and ideal for comprehensive indoor and outdoor security.Do the Wyze Cam Pan v3 and Wyze Cam v4 require battery packs?
No, both the Wyze Cam Pan v3 and Wyze Cam v4 are powered by indoor power adapters and do not require battery packs. They are designed for continuous wired operation.Why should I invest in extra battery packs for my Wyze security cameras?
Investing in extra Wyze Removable Battery Packs ensures your Wyze Battery Cam Pro or Duo Cam Doorbell remains powered without interruption. This is especially useful for extended trips, vacation homes, or locations where frequent charging is inconvenient, providing continuous security and peace of mind.
