Portable Removable Battery Packs for Wyze Duo Cam & Cam Pro
Upgrade Your Wyze Duo Cam Doorbell and Battery Cam Pro with Portable Removable Battery Packs
If you're looking to enhance the battery life and convenience of your Wyze Duo Cam Doorbell or Wyze Battery Cam Pro, upgrading with a portable removable battery pack is the perfect solution. These battery packs allow you to keep your devices powered longer without the hassle of frequent recharging or wiring. Discover how these accessories and camera bundles can elevate your home security setup with seamless power options and advanced features.
Wyze Removable Battery Pack: Power On the Go
Reliable and Long-Lasting Battery Power
The Wyze Removable Battery Pack is designed specifically for the Wyze Battery Cam Pro and Wyze Duo Cam Doorbell, providing a powerful 6200mAh rechargeable lithium-ion battery. This pack offers up to 6 months of battery life on a single charge, making it ideal for continuous security monitoring without interruptions.
  • Battery Capacity: 6200mAh for extended use
  • Charging: Convenient USB-C port with approximately 9 hours to full charge
  • Compact Size: 2.9 in x 1.6 in x 0.9 in, lightweight at 3.9 oz (110g)
  • Durability: Operates efficiently in temperatures from -4°F to 122°F (-20°C to 50°C)
  • Compatibility: Works seamlessly with Wyze Battery Cam Pro and Wyze Duo Cam Doorbell
Hot-swapping battery packs means no downtime for your security cameras or doorbell. Simply swap in a fully charged battery pack and keep your devices running smoothly.
Wyze Battery Cam Pro: Wireless Security with Removable Batteries
High-Definition Security Anywhere
The Wyze Battery Cam Pro is a wire-free, weatherproof security camera that delivers 2.5K HDR video resolution with color night vision. Its removable, rechargeable battery packs make it easy to maintain power without interrupting your surveillance.
  • Video Quality: 2.5K HDR for crisp, detailed footage day and night
  • Motion Detection: Radar + PIR sensors for precise and early alerts
  • Integrated Spotlight & Siren: 150 lumens LED light and siren for deterrence
  • Connectivity: Dual-band Wi-Fi (2.4 & 5 GHz) and Bluetooth setup
  • Weatherproof: IP65 rating for reliable outdoor use
  • Battery Packs: Compatible with Wyze Removable Battery Pack for easy hot-swapping
Solar Power Option for Extended Use
Pair your Wyze Battery Cam Pro with the Wyze Solar Panel to convert sunlight into continuous power, reducing the need for manual recharging. Wyze Battery Cam Pro in Outdoor Setting Enjoy wire-free security with solar-powered convenience.
Wyze Battery Cam Pro + Solar Panel Bundle: Ultimate Power Solution
Continuous Power with Solar Charging
This bundle combines the Wyze Battery Cam Pro with a dedicated solar panel, ensuring your camera stays powered longer with minimal maintenance.
  • Bundle Includes: 1 Wyze Battery Cam Pro + 1 Wyze Solar Panel
  • Power Efficiency: Solar panel converts sun rays to power your camera continuously
  • Same Features: 2.5K HDR, integrated spotlight, radar + PIR motion detection, IP65 weatherproof
  • Ideal For: Remote locations or areas where frequent battery charging is inconvenient
Wyze Duo Cam Battery Doorbell: Advanced Battery-Powered Doorbell with Removable Battery
Dual Camera Views and Smart Alerts
The Wyze Duo Cam Doorbell is the most advanced battery-powered video doorbell from Wyze, featuring dual cameras for comprehensive coverage of people and packages.
  • Video Resolution: Front camera 2K (2048 x 1536), bottom camera 1080p
  • Battery: 6200mAh removable lithium-ion battery pack with USB-C charging
  • Smart Features: Real-time AI detections, motion-activated voice deterrence, two-way audio
  • Local Storage: Supports up to 256GB microSD card for 24/7 local recording (sold separately)
  • Weather Resistance: IP65 rating for all-weather durability
  • Included: Comes with a removable battery pack for easy power management
Wyze Duo Cam Doorbell Lifestyle Secure your front porch with dual camera views and battery convenience.
Wyze Battery Charging Dock: Charge Multiple Batteries Simultaneously
Efficient Charging for Your Battery Packs
Keep your removable battery packs ready to go with the Wyze Battery Charging Dock, which charges two batteries at once.
  • Charging Time: Approximately 8.5 hours for full charge
  • Compatibility: Designed for Wyze Battery Cam Pro battery packs
  • Compact Design: Easy to place on any desk or shelf
  • Includes: Charging dock, adapter cable, and power adapter
Having multiple charged battery packs and a charging dock means you can swap batteries quickly and never lose security coverage.
Why Upgrade with Portable Removable Battery Packs?
Portable removable battery packs provide unmatched flexibility and convenience for your Wyze Duo Cam Doorbell and Battery Cam Pro. No more worrying about wiring or power outages—just swap, charge, and stay protected.
  • Extend your device uptime without interrupting security
  • Easily swap batteries indoors while cameras stay mounted outside
  • Compatible with solar panels and charging docks for versatile power options
  • Maintain continuous surveillance with local recording and smart alerts
Summary of Portable Battery Upgrade Options for Wyze Cameras
ProductKey FeaturePrice Range
Wyze Removable Battery Pack6200mAh rechargeable, USB-C$22.99
Wyze Battery Cam Pro2.5K HDR, removable batteries$89.98 (1 pack)
Wyze Battery Cam Pro + Solar PanelSolar-powered continuous charging$109.98
Wyze Duo Cam Battery DoorbellDual cameras, removable battery$89.98 - $109.99
Wyze Battery Charging DockCharges two batteries simultaneously$17.99
Upgrade your Wyze security system today with these portable removable battery packs and accessories to enjoy uninterrupted, wire-free protection.
FeatureWyze Removable Battery PackWyze Battery Cam ProWyze Duo Cam Battery DoorbellWyze Battery Charging DockWyze Battery Cam Pro + Solar Panel
TypeAccessoryCameraCameraAccessoryCamera
Compatible DevicesWyze Battery Cam Pro, Wyze Duo Cam DoorbellWyze Battery Cam ProWyze Duo Cam DoorbellWyze Battery Cam Pro battery packsWyze Battery Cam Pro
Battery Capacity6200mAh6200mAh6200mAh (22.94 Wh)N/A6200mAh
Battery LifeUp to 6 monthsUp to 6 monthsNot specifiedN/AUp to 6 months
Charging PortUSB-CUSB-CUSB-CUSB-C (charges two batteries simultaneously)USB-C
Price$22.99$89.98 (1 Pack)$89.98 (Doorbell only) / $109.99 (with extra battery)$17.99$109.98
Video ResolutionN/A2.5K HDR (2560 x 1440)Front: 2K (2048 x 1536), Bottom: 1080pN/A2.5K HDR (2560 x 1440)
WirelessN/AYes (2.4 & 5 GHz WiFi)Yes (2.4 & 5 GHz WiFi)N/AYes (2.4 & 5 GHz WiFi)
Weather ResistanceN/AIP65IP65N/AIP65
Special FeaturesReplacement rechargeable batteryIntegrated spotlight & siren, Radar + PIR motion detection, local recording, color night visionDual camera views, two-way audio, AI detections, motion-activated voice deterrenceCharges two batteries simultaneouslyIntegrated spotlight, Radar + PIR motion detection, solar powered option
Included ItemsBattery pack onlyCamera onlyDoorbell, Wi-Fi Chime, removable battery pack, USB-C cable, mounting accessoriesCharging dock, adapter cable, power adapterCamera + Solar Panel
DimensionsNot specified2.5 x 1.8 x 3.5 inches5.90 x 1.88 x 1.18 inches2.6 x 2 x 1 inches (dock)2.5 x 1.8 x 3.5 inches
WeightNot specified0.94 lbs0.92 lbs2.75 oz (78 g)0.94 lbs
Additional AccessoriesCharging cable not includedCompatible with Solar Panel, Charging Dock, MicroSD cards, Universal MountSupports local storage with microSD cardN/AIncludes solar panel to extend battery life
What is the Wyze Removable Battery Pack and which devices is it compatible with?The Wyze Removable Battery Pack is a 6200mAh rechargeable lithium-ion battery designed specifically for the Wyze Battery Cam Pro and Wyze Duo Cam Doorbell. It provides up to 6 months of battery life on a single charge and allows for easy hot-swapping to keep your devices powered without interruption.
How long does it take to fully charge the Wyze Removable Battery Pack?The Wyze Removable Battery Pack charges fully in approximately 9 hours using a convenient USB-C port.
Can I use the Wyze Removable Battery Pack in extreme temperatures?Yes, the Wyze Removable Battery Pack is designed to operate efficiently in temperatures ranging from -4°F to 122°F (-20°C to 50°C), making it suitable for various weather conditions.
What are the benefits of using portable removable battery packs with Wyze cameras?Portable removable battery packs offer unmatched flexibility and convenience by extending device uptime, allowing easy battery swaps without unmounting cameras, and eliminating the need for wiring or worrying about power outages. They are also compatible with solar panels and charging docks for versatile power options.
What features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro is a wire-free, weatherproof security camera featuring 2.5K HDR video resolution, color night vision, radar and PIR motion detection, an integrated 150-lumen spotlight and siren, dual-band Wi-Fi, and compatibility with removable battery packs for easy power management.
How does the Wyze Solar Panel work with the Wyze Battery Cam Pro?The Wyze Solar Panel pairs with the Wyze Battery Cam Pro to convert sunlight into continuous power, reducing the need for manual recharging and ensuring your camera stays powered for longer periods.
What is included in the Wyze Battery Cam Pro + Solar Panel Bundle?The Wyze Battery Cam Pro + Solar Panel Bundle includes one Wyze Battery Cam Pro and one Wyze Solar Panel, providing continuous solar-powered charging and all the advanced features of the camera, such as 2.5K HDR video, motion detection, and weatherproof design.
What makes the Wyze Duo Cam Battery Doorbell unique?The Wyze Duo Cam Battery Doorbell features dual cameras for comprehensive coverage of both people and packages, 2K and 1080p video resolution, a 6200mAh removable battery pack, real-time AI detections, motion-activated voice deterrence, two-way audio, and IP65 weather resistance.
Does the Wyze Duo Cam Battery Doorbell support local video storage?Yes, the Wyze Duo Cam Battery Doorbell supports local video storage with a microSD card of up to 256GB (sold separately), allowing for 24/7 local recording.
What is the Wyze Battery Charging Dock and how does it work?The Wyze Battery Charging Dock is designed to charge two Wyze Battery Cam Pro battery packs simultaneously. It features a compact design, charges both batteries in approximately 8.5 hours, and includes a charging dock, adapter cable, and power adapter.
How do I maintain continuous security coverage with Wyze cameras?To maintain continuous security coverage, keep multiple Wyze Removable Battery Packs charged using the Wyze Battery Charging Dock. Hot-swap batteries as needed so your cameras and doorbells remain powered without downtime. You can also use the Wyze Solar Panel for continuous solar charging.
Are Wyze battery-powered devices weatherproof?Yes, both the Wyze Battery Cam Pro and Wyze Duo Cam Battery Doorbell have an IP65 weatherproof rating, ensuring reliable performance in various outdoor conditions.
What are the benefits of using a portable removable battery pack with my Wyze devices?How long does it take to fully charge the Wyze Removable Battery Pack?Do you have any ongoing sales or discounts for the Wyze Battery Cam Pro or Duo Cam Doorbell?
