Large Capacity Wyze MicroSD Cards for Continuous Video Loop
Large Capacity MicroSD Cards for Continuous Wyze Cam Video Loop
When it comes to continuous video recording with your Wyze Cam, having the right microSD card is essential. Whether you want to capture every moment with uninterrupted footage or create time-lapse videos, a large capacity microSD card designed for Wyze devices ensures smooth, reliable local storage without monthly fees.
Wyze MicroSD Card: Perfect for Continuous Recording
Unlock the full potential of your Wyze Cam with the official Wyze MicroSD Card. Available in 32GB, 128GB, and 256GB sizes, these cards are optimized for continuous local recording and time-lapse capture on Wyze cameras.
  • Continuous Local Recording: Record 24/7 directly to the microSD card without relying on cloud subscriptions.
  • No Monthly Fees: Enjoy free local storage with easy playback through the Wyze app.
  • Easy Setup: Insert the card into your Wyze Cam, enable local recording in the app, and start capturing.
  • Automatic Overwrite: When full, the card overwrites the oldest footage, ensuring you never miss a moment.
  • Compatible Sizes: Supports microSDHC and microSDXC formats, Class 10 speed for smooth video capture.
This card is ideal for users who want to maximize storage capacity for continuous video loops on Wyze Cams, including the Battery Cam Pro, Cam v4, and Video Doorbells.
"The Wyze MicroSD Card is your best companion for uninterrupted home security footage, offering large storage and seamless integration with Wyze devices."
Wyze Video Doorbell v2 Lifestyle Capture every moment with Wyze Video Doorbell v2 and local microSD storage.
Wyze Video Doorbell v2: 2K Video with Local MicroSD Storage
The Wyze Video Doorbell v2 is not only a smart doorbell with crystal-clear 2K video but also supports continuous local recording via a built-in microSD card slot.
  • 2K HD Video Resolution: See visitors and packages in stunning detail.
  • Local microSD Storage: Supports continuous 24/7 recording with a microSD card (sold separately), so you never miss what happens before or after the doorbell rings.
  • Two-Way Audio & Voice Deterrence: Communicate with visitors and deter unwanted guests with motion-activated voice alerts.
  • Works with Existing Chime: Includes a chime controller to keep your traditional doorbell sound.
  • Weatherproof IP65 Rating: Durable for all weather conditions.
  • Smart Features: Motion detection, real-time alerts, and compatibility with Alexa and Google Home.
This doorbell is perfect for homeowners who want detailed video surveillance with local storage options, ensuring continuous recording without cloud dependency.
Wyze Cam v4 + FREE 32GB MicroSD Card: Advanced Security with Large Storage
For those seeking enhanced home security, the Wyze Cam v4 offers 2.5K QHD resolution and comes bundled with a free 32GB Wyze MicroSD Card, ideal for continuous video loop recording.
  • 2.5K QHD Resolution: Ultra-clear video quality for detailed monitoring.
  • Enhanced Color Night Vision: See vibrant colors even in low light.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected.
  • 24/7 Local Recording: Supports continuous recording to the included microSD card.
  • Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
  • Smart Alerts: Person detection, motion zones, and sound detection.
  • Weather Resistant (IP65): Suitable for indoor and outdoor use.
  • Voice Assistant Compatible: Works with Alexa and Google Assistant.
This camera and microSD card combo is a great choice for users who want high-resolution continuous recording with reliable local storage included.
Wyze Duo Cam Battery Doorbell: Dual Views with Large MicroSD Support
The Wyze Duo Cam Battery Doorbell is Wyze’s most advanced battery-powered doorbell, supporting local microSD storage up to 256GB for continuous recording when hardwired.
  • Dual Camera Views: Front 2K and bottom 1080p cameras cover people and packages.
  • Supports up to 256GB microSD Card: Store days of continuous footage locally.
  • Two-Way Audio & Motion-Activated Voice Deterrence: Communicate and deter intruders.
  • Battery Powered with Optional Hardwired Power: Enables 24/7 local recording when connected.
  • Weatherproof IP65: Built to withstand harsh outdoor conditions.
  • Smart AI Detections: Real-time alerts for people, packages, and vehicles.
Includes Wyze Wi-Fi Chime and Removable Battery Pack. Ideal for users wanting flexible installation options with large local storage capacity for continuous video loops. Wyze Duo Cam Doorbell Lifestyle Advanced dual-camera views with large capacity microSD support.
Why Choose Large Capacity MicroSD Cards for Wyze Cams?
Using a large capacity microSD card like the Wyze MicroSD Card 128GB or 256GB allows your Wyze Cam to:
  • Record Longer Continuous Video Loops: More storage means more days of footage before overwriting.
  • Avoid Cloud Subscription Fees: Local storage is free and private.
  • Access Footage Anytime: Playback directly from the Wyze app or by removing the card.
  • Support Advanced Features: Time-lapse videos, continuous recording, and event-based recording.
Pro Tip: For continuous recording on battery-powered Wyze cameras like the Battery Cam Pro, it’s recommended to use a wired power source to avoid rapid battery drain.
Summary
For continuous video loop recording on Wyze Cams, the Wyze MicroSD Card is the best choice, available in large capacities up to 256GB. Pair it with compatible Wyze devices such as the Wyze Video Doorbell v2, Wyze Cam v4, or Wyze Duo Cam Battery Doorbell to enjoy uninterrupted local recording, no monthly fees, and easy access to your footage. Invest in the right microSD card and Wyze camera combo to keep your home secure with reliable, high-capacity local storage.
FeatureWyze MicroSD CardWyze Video Doorbell v2Wyze Cam v4 + FREE 32GB MicroSD CardWyze Duo Cam Battery Doorbell
TypeAccessory (Memory Card)Wired Video DoorbellSecurity Camera with included MicroSD CardBattery-Powered Video Doorbell
Video ResolutionN/A2K (2048 x 1536)2.5K QHDFront: 2K (2048 x 1536), Bottom: 1080p
Storage32GB, 128GB, 256GB microSD variantsLocal microSD storage (up to 256GB)32GB MicroSD included, supports local storageSupports up to 256GB microSD (exFAT format)
Continuous Local RecordingYesYesYesOptional with microSD card
Night VisionN/AColor Night Vision (Starlight Sensor)Enhanced Color Night VisionIR Night Light (6x 850 nm)
AudioN/ATwo-way audioTwo-way audioTwo-way audio, Siren (90 dB)
Motion DetectionN/AYesYesYes
Voice DeterrenceN/AMotion-activated voice deterrence (subscription required)N/AMotion-activated voice deterrence
Weather ResistanceN/AIP65IP65IP65
ConnectivityN/AWi-Fi 2.4 GHzWi-Fi 6Wi-Fi 2.4 & 5 GHz
PowerN/AWired (16V-24V AC)Wired (requires outdoor power adapter)Battery or Hardwired (10-24V AC)
Field of ViewN/A135° horizontal, 103° verticalNot specifiedFront: 132° horizontal, 100° vertical; Bottom: 121° horizontal, 60° vertical
Additional FeaturesEnables continuous recording and timelapsePre-roll motion recording (3-6 seconds), works with existing chimeMotion-activated spotlight, Wi-Fi 6 support, smoke/co alertsDual camera views, removable battery pack, Alexa/Google Assistant integration
Price Range$8.99 - $29.99$44.98$35.98$89.98 - $109.99
What size microSD card is best for continuous recording on Wyze Cams?For continuous video recording on Wyze Cams, it is recommended to use a large capacity microSD card such as 128GB or 256GB. These sizes allow for longer video loops and more days of footage before older recordings are overwritten.
Are Wyze MicroSD Cards compatible with all Wyze cameras?Yes, Wyze MicroSD Cards are designed to be compatible with a wide range of Wyze devices, including Wyze Cam v4, Wyze Video Doorbell v2, Wyze Duo Cam Battery Doorbell, and Battery Cam Pro. They support both microSDHC and microSDXC formats.
How does continuous local recording work with Wyze MicroSD Cards?Continuous local recording allows your Wyze Cam to record 24/7 directly to the microSD card. When the card is full, it automatically overwrites the oldest footage, ensuring you always have the most recent recordings available.
Do I need a cloud subscription to use local microSD storage with Wyze Cams?No, you do not need a cloud subscription to use local microSD storage. All footage is stored directly on the microSD card, allowing you to access and playback recordings for free through the Wyze app.
How do I set up a Wyze MicroSD Card for continuous recording?To set up a Wyze MicroSD Card, simply insert the card into your Wyze Cam, enable local recording in the Wyze app, and your camera will begin capturing continuous footage automatically.
Which Wyze devices support large capacity microSD cards for continuous recording?Wyze devices that support large capacity microSD cards for continuous recording include the Wyze Cam v4, Wyze Video Doorbell v2, Wyze Duo Cam Battery Doorbell, and Battery Cam Pro. Some models support up to 256GB microSD cards.
What are the benefits of using a large capacity microSD card with Wyze Cams?Using a large capacity microSD card with Wyze Cams allows for longer continuous video loops, eliminates monthly cloud storage fees, provides private and secure local storage, and supports advanced features like time-lapse and event-based recording.
Can I access my Wyze Cam footage without removing the microSD card?Yes, you can access and playback your Wyze Cam footage directly from the Wyze app without removing the microSD card. Alternatively, you can remove the card and view recordings on a computer if needed.
Does continuous recording on battery-powered Wyze cameras affect battery life?Yes, continuous recording on battery-powered Wyze cameras can drain the battery quickly. For best results and longer recording times, it is recommended to use a wired power source with battery-powered models.
What video resolution do Wyze Cams offer with local microSD recording?Wyze Cams offer high-definition video resolutions with local microSD recording, including 2K HD on the Wyze Video Doorbell v2 and 2.5K QHD on the Wyze Cam v4, ensuring clear and detailed footage.
What are the different sizes available for the Wyze MicroSD Card?How do I set up the Wyze MicroSD Card in my Wyze Cam?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze MicroSD Card?
