Wyze Home Monitoring: Secure Your Home with No Subscription
Wyze Home Monitoring No Subscription: Secure Your Home Effortlessly
When it comes to protecting your home without the hassle of monthly fees, Wyze offers a smart, reliable, and subscription-free home monitoring solution. The Wyze Home Monitoring Core Starter Kit and its compatible accessories provide comprehensive security coverage with easy installation and intuitive control — all without locking you into costly contracts. Explore the key products that make up this powerful system and discover how Wyze keeps your home safe, smart, and subscription-free.
Wyze Home Monitoring Core Starter Kit: The Heart of Your Security System
The Wyze Home Monitoring Core Starter Kit is designed to safeguard your home 24/7 with a simple, effective setup. This kit includes everything you need to start monitoring your space immediately, with no subscription required to use the basic features.
Key Features:
  • Comprehensive Sensor Support: Connect up to 100 sensors including entry and motion detectors.
  • Built-in Backup Battery: Stay protected even during power outages with a 10-hour backup battery.
  • Wireless Sensors: Includes 2 Wyze Entry Sensors and 1 Wyze Motion Sensor with 18-month battery life.
  • Loud Siren: An 88db siren alerts you and deters intruders.
  • Easy Control: Arm and disarm your system remotely via the Wyze app.
  • Operating Range: Sensors communicate up to 500 feet from the hub.
  • Indoor Use: Designed for indoor environments with operating temperatures from 32°F to 104°F.
Included in the Kit:
  • Wyze Sense Hub (the system’s control center)
  • 2 Wyze Entry Sensors (detect door/window open or close)
  • 1 Wyze Motion Sensor (detects movement up to 25 feet)
  • 1 Wyze Keypad (wireless, with backlit keys and emergency button)
The Wyze Home Monitoring Core Starter Kit offers peace of mind with a no-subscription model, making it an ideal choice for budget-conscious homeowners who want reliable security.
Wyze Home Monitoring Lifestyle Wyze Entry Sensors installed on doors for seamless home security
Wyze Sense Hub: The Smart Brain Behind Your Security
The Wyze Sense Hub acts as the central hub connecting all your sensors and devices. It manages communication, sends alerts, and triggers the siren when needed.
Hub Highlights:
  • Multiple Communication Methods: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF.
  • Backup Battery: Rechargeable battery with 10 hours of backup power.
  • Compact Design: Matte white and grey finish, measuring 4.5” x 4” x 1”.
  • Supports Up to 100 Sensors: Easily expand your system with additional sensors.
  • Indoor Use Only: Designed for indoor placement to maintain optimal performance.
The hub is essential for the system’s operation and is included in the Core Starter Kit, but also available separately for system expansion.
Wyze Sense Keypad: Convenient and Secure Access Control
The Wyze Sense Keypad allows you to arm and disarm your home security system remotely and on-site with ease.
Features:
  • Wireless and Easy to Install: No wiring needed, sticks securely with adhesive.
  • Backlit Keys: For easy use in low light.
  • Emergency Button: Quickly alert first responders in case of emergency.
  • Requires Wyze Sense Hub: Works seamlessly with the Wyze Home Monitoring system.
  • Indoor Use: Designed for indoor environments.
This keypad adds an extra layer of convenience and security, perfect for family members or trusted guests. Wyze Sense Keypad Lifestyle Wyze Sense Keypad for easy arming and disarming
Wyze Sense Motion Sensor & Entry Sensors: Detect Movement and Access
  • Detection Range: Up to 25 feet with a 120° field of view.
  • Adjustable Sensitivity: Customize detection to reduce false alarms.
  • Battery Life: Up to 18 months on a single battery.
  • Installation: Adhesive or screws for secure mounting.
  • Compatibility: Works with Wyze Sense Hub and Wyze Home Monitoring.
Wyze Sense Entry Sensor
  • Open/Close Detection: Alerts you when doors or windows are opened or closed.
  • Battery Life: Long-lasting 18-month battery.
  • Pack Options: Available in 3-packs for multiple entry points.
  • Requires Wyze Sense Hub: Not a standalone device.
Indoor Use Only These sensors form the backbone of your home’s perimeter security, providing instant alerts to your phone when unexpected activity is detected. Wyze Home Monitoring Motion Sensor Wyze Motion Sensor detecting activity in a living room corner
Why Choose Wyze Home Monitoring Without Subscription?
Wyze’s no-subscription home monitoring system empowers you to protect your home on your terms. You get:
  • No monthly fees for basic monitoring and alerts.
  • Easy DIY installation with wireless sensors.
  • Expandable system supporting up to 100 sensors.
  • Remote control and notifications via the Wyze app.
  • Backup battery to keep your system running during outages.
This makes Wyze an excellent choice for renters, homeowners, and anyone looking for affordable, flexible home security without ongoing costs.
Summary of Wyze Home Monitoring Products
ProductKey BenefitPrice (USD)
Wyze Home Monitoring Core Starter KitComplete starter system, no subscription needed$111.98 (with 3 months pro monitoring)
Wyze Sense HubCentral hub for sensor communication$45.98
Wyze Sense KeypadArm/disarm system remotely$27.98
Wyze Sense Motion SensorDetects motion with adjustable sensitivity$20.98
Wyze Sense Entry Sensor (3-pack)Detects door/window open/close$41.98
Secure your home today with Wyze’s subscription-free home monitoring system — smart, simple, and reliable protection you can trust.
FeatureWyze Home Monitoring Core Starter KitWyze Sense KeypadWyze Sense HubWyze Sense Motion SensorWyze Sense Entry Sensor
TypeHome MonitoringHome MonitoringHome MonitoringHome MonitoringHome Monitoring
Price$111.98 (Bundle with 3 months Professional Monitoring)$27.98$45.98$20.98 (1 Pack)$41.98 (3 Pack)
RequiresNone (includes sensors and hub)Wyze Home Monitoring, Wyze Sense HubNone (central hub)Wyze Sense HubWyze Sense Hub
FunctionalityEntry sensor, motion sensor, 24/7 monitoring optionArm/disarm system remotely, emergency buttonConnects sensors, sends alertsDetects motionDetects open/close events
Sensors SupportedIncluded sensors: Entry Sensor, Motion SensorN/ASupports up to 100 sensorsCompatible with Wyze Sense v2 & Home MonitoringCompatible with Wyze Sense v2 & Home Monitoring
Communication MethodsN/AN/AEthernet, WiFi 2.4 GHz, Bluetooth, 915MHz RF915MHz RF915MHz RF
BatteryN/AN/ABuilt-in rechargeable (10 hr backup)Battery life up to 18 monthsBattery life not specified
InstallationEasy install, sensors adhesive or screwsPlace anywhere in homeIndoor use onlyAdhesive or screwsAdhesive or screws
Indoor/Outdoor UseIndoorIndoorIndoor onlyIndoorIndoor
Additional FeaturesNotifications on phone and Sense Hub, optional subscription for monitoring and insurance discountsEmergency button on device88db siren @ 2 feetAdjustable sensitivityDetects door/window open/close
Warranty/Returns30-day hassle-free returns30-day hassle-free returnsNot specifiedNot specifiedNot specified
What is Wyze Home Monitoring without a subscription?Wyze Home Monitoring without a subscription is a smart, reliable home security solution that allows you to monitor your home without paying monthly fees. The system includes the Wyze Home Monitoring Core Starter Kit and compatible accessories, providing comprehensive security coverage with easy installation and intuitive control, all without locking you into costly contracts.
What is included in the Wyze Home Monitoring Core Starter Kit?The Wyze Home Monitoring Core Starter Kit includes the Wyze Sense Hub (the system’s control center), 2 Wyze Entry Sensors (for doors or windows), 1 Wyze Motion Sensor (detects movement up to 25 feet), and 1 Wyze Keypad (wireless, with backlit keys and emergency button).
Do I need a subscription to use Wyze Home Monitoring?No, you do not need a subscription to use the basic features of Wyze Home Monitoring. The system provides essential home security functions, such as sensor alerts and remote control via the Wyze app, without any monthly fees.
How many sensors can I connect to the Wyze Home Monitoring system?You can connect up to 100 sensors, including entry and motion detectors, to the Wyze Home Monitoring system, allowing you to expand coverage throughout your home.
Does Wyze Home Monitoring work during power outages?Yes, the Wyze Sense Hub features a built-in rechargeable backup battery that provides up to 10 hours of power during outages, ensuring your home remains protected.
How do I control and monitor my Wyze Home Monitoring system?You can easily arm and disarm your Wyze Home Monitoring system remotely using the Wyze app. The app also sends instant notifications to your phone when sensors detect unexpected activity.
Are Wyze Home Monitoring sensors wireless?Yes, Wyze Home Monitoring sensors are wireless, making installation quick and easy without the need for complicated wiring.
What is the range of Wyze Home Monitoring sensors?Wyze Home Monitoring sensors can communicate with the hub from up to 500 feet away, providing flexible placement options throughout your home.
Can I use Wyze Home Monitoring in outdoor environments?No, Wyze Home Monitoring products, including the hub, sensors, and keypad, are designed for indoor use only and operate best within temperatures from 32°F to 104°F.
How long do the batteries last in Wyze sensors?Both the Wyze Entry Sensors and Wyze Motion Sensor offer up to 18 months of battery life on a single battery, ensuring long-lasting performance.
What is the Wyze Sense Hub and why is it important?The Wyze Sense Hub is the central control unit for the Wyze Home Monitoring system. It connects all your sensors and devices, manages communication, sends alerts, and triggers the siren when needed. The hub is essential for the system’s operation.
How does the Wyze Sense Keypad enhance home security?The Wyze Sense Keypad allows you to arm and disarm your security system easily, both remotely and on-site. It features backlit keys for low-light use and an emergency button to quickly alert first responders.
What are the features of the Wyze Motion Sensor?The Wyze Motion Sensor detects movement up to 25 feet with a 120° field of view, offers adjustable sensitivity to reduce false alarms, and has an 18-month battery life. It can be installed with adhesive or screws and works with the Wyze Sense Hub.
What does the Wyze Entry Sensor do?The Wyze Entry Sensor detects when doors or windows are opened or closed, sending instant alerts to your phone. It features an 18-month battery life and is available in 3-packs for monitoring multiple entry points.
Is Wyze Home Monitoring a good choice for renters and homeowners?Yes, Wyze Home Monitoring is ideal for both renters and homeowners due to its easy DIY installation, wireless sensors, no monthly fees, and flexible, expandable system.
How loud is the Wyze Home Monitoring siren?The Wyze Home Monitoring system includes an 88db siren, which is loud enough to alert you and deter intruders.
What are the key features of the Wyze Home Monitoring Core Starter Kit?How does the Wyze Sense Hub work with the home monitoring system?Do you have any deals, ongoing sales, discounts, or promotions?
